試試吧\r
DEMO:
http://emn178.idv.st
在會員列表的個人資料和瀏覽主題時左邊的資料會顯示
2004/04/06更新:
已經寫出了能夠在舊有的資料庫更新的版本了
下面是直接安裝資料庫的檔案
複製起來存成reply_install.php放在跟目錄下執行
<?php
* reply_install.php
* begin : 2004/4/6
* copyright : emn178 http://emn178.idv.st/
* email : emn17@pchome.com.tw
* $Id reply_install.php,v 1.1 20040406 084000 emn178 $ *
define('IN_PHPBB', true);
$phpbb_root_path = './';
// Start session management
init_userprefs($userdata);
// End session management
if( !$userdata['session_logged_in'] )
header('Location: ' . append_sid("login.$phpEx?redirect=reply_install.$phpEx", true));
if( $userdata['user_level'] != ADMIN )
message_die(GENERAL_MESSAGE, $lang['Not_Authorised']);
$sql = "ALTER TABLE ".USERS_TABLE." ADD `user_reply` mediumint(8) UNSIGNED DEFAULT '0' NOT NULL AFTER `user_posts`";
if ( !$db->sql_query($sql) )
message_die(GENERAL_MESSAGE, 'Error adding field to the tablefont');
$text = 'Field has installed successfully' . '<br>';
$error = 0;
$sql = "SELECT u.user_id
FROM " . USERS_TABLE . " u";
while($row = $db->sql_fetchrow($result))
$user_id[] = $row['user_id'];
for($i = 0;$i < count($user_id);$i++)
$sql = "UPDATE " . USERS_TABLE . " SET user_reply = user_posts WHERE user_id = $user_id[$i] ";
if(!$db->sql_query($sql))
$error++;
$sql = "SELECT t.topic_id
FROM " . TOPICS_TABLE . " t";
$t_topic_id[] = $row['topic_id'];
for($i = 0;$i < count($t_topic_id);$i++)
decision($t_topic_id[$i]);
function decision($topic_id)
global $db;
$sql = "SELECT p.post_id, p.topic_id, p.poster_id
FROM " . POSTS_TABLE . " p";
$de = '- 1';
message_die(GENERAL_ERROR, 'Could not obtain newer/older topic information', '', __LINE__, __FILE__, $sql);
if($topic_id == $row['topic_id'])
$post_id[] = $row['post_id'];
$poster_id[] = $row['poster_id'];
for($i = 0;$i < count($post_id);$i++)
for($j = 0;$j <count($post_id) - 1;$j++)
if($post_id[$j] > $post_id[$j+1] )
$temp = $post_id[$j];
$post_id[$j] = $post_id[$j+1];
$post_id[$j+1] = $temp;
$temp = $poster_id[$j];
$poster_id[$j] = $poster_id[$j+1];
$poster_id[$j+1] = $temp;
$sql = "UPDATE " . USERS_TABLE . " SET user_reply = user_reply $de WHERE user_id = $poster_id[0] ";
$error++;
if($error == 0)
$text = $text . "All infomation of replies is update successfully.";
$text = $text . '<font color="#ff0000">' . "There are some unexpected errors." . '</font>';
message_die(GENERAL_MESSAGE, $text);
增加顯示在會員列表中
2004/04/07修正內容:
viewtopic.php部分少了一段程式碼,已加上去\r
## Mod Title: 區分發表主題與回覆(Separate Topics and Replies MOD)
## Mod Version: v1.2 for phpBB
## Author: emn178 - http://emn178.idv.st
## Description: 此Mod能夠將使用者的文章數區分為主題數和回覆數\r
## Installation Level: Easy
## Files To Edit: 7
## memberlist.php
## viewtopic.php
## includes/functions_post.php
## includes/usercp_viewprofile.php
## templates/subSilver/memberlist_body.tpl
## templates/subSilver/profile_view_body.tpl
## templates/subSilver/viewtopic_body.tpl
## Included Files: N/A
在SQL資料庫的phpbb_users資料表格中,增加一個user_reply欄位在user_posts後面
欄位 類型 長度 屬性 Null 內定值 額外
user_reply MEDIUMNIT 8 UNSIGNED not null 0
#-----[ 開啟 ]------------------------------------------
$sign = ($mode == 'delete') ? '- 1' : '+ 1';
#-----[ 前面加上 ]------------------------------------------
//reply and posts mod
$reply = false;
$sqlp = "SELECT p.post_id, p.topic_id
WHERE forum_id = $forum_id";
$resultat = $db->sql_query($sqlp);
while($row = $db->sql_fetchrow($resultat))
$postid[] = $row['post_id'];
if(count($postid) > 1)
for($i = 0;$i < count($postid);$i++)
if($post_id > $postid[$i])
$reply = true;
if($mode == 'reply')
$replysign = '+ 1';
if($mode == 'delete' && $reply == true)
$replysign = "- 1";
if ($mode != 'poll_delete')
SET user_posts = user_posts $sign
WHERE user_id = $user_id";
#-----[ 改成 ]------------------------------------------
SET user_posts = user_posts $sign,
user_reply = user_reply $replysign
viewtopic.php
// Go ahead and pull all data for this topic
$sql = "SELECT u.username, u.user_id, u.user_posts,
#-----[ 之中找到 ]------------------------------------------
u.user_posts,
#-----[ 後面加上 ]------------------------------------------
u.user_reply,
$poster_posts = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Posts'] . ': ' . $postrow[$i]['user_posts'] : '';
$poster_topic = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Topics'] . ': ' . ($postrow[$i]['user_posts'] - $postrow[$i]['user_reply']) : '';
$poster_reply = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Replies'] . ': ' . $postrow[$i]['user_reply'] : '';
'POSTER_POSTS' => $poster_posts,
'POSTER_TOPICS' => $poster_topic,
'POSTER_REPLIES' => $poster_reply,
{postrow.POSTER_POSTS}<br />
{postrow.POSTER_TOPICS}<br />
{postrow.POSTER_REPLIES}<br />
$posts_per_day = $profiledata['user_posts'] / $memberdays;
$topic = $profiledata['user_posts'] - $profiledata['user_reply'];
$reply = $profiledata['user_reply'];
'POSTS' => $profiledata['user_posts'],
'TOPICS' => $topic,
'REPLIES' => $reply,
'L_TOTAL_POSTS' => $lang['Total_posts'],
'L_TOTAL_TOPICS' => $lang['Topics'],
'L_TOTAL_REPLIES' => $lang['Replies'],
<td valign="top" align="right" nowrap="nowrap"><span class="gen">{L_TOTAL_POSTS}: </span></td>
<td valign="top"><b><span class="gen">{POSTS}</span></b><br /><span class="genmed">[{POST_PERCENT_STATS} / {POST_DAY_STATS}]</span> <br /><span class="genmed"><a href="{U_SEARCH_USER}" class="genmed">{L_SEARCH_USER_POSTS}</a></span></td>
<td valign="top"><b><span class="gen">{POSTS}</span></b></td>
<td valign="top" align="right" nowrap="nowrap"><span class="gen">{L_TOTAL_TOPICS}: </span></td>
<td valign="top"><b><span class="gen">{TOPICS}</span></b></td>
<td valign="top" align="right" nowrap="nowrap"><span class="gen">{L_TOTAL_REPLIES}: </span></td>
<td valign="top"><b><span class="gen">{REPLIES}</span></b><br />
<span class="genmed">[{POST_PERCENT_STATS} / {POST_DAY_STATS}]</span><br /><span class="genmed"><a href="{U_SEARCH_USER}" class="genmed">{L_SEARCH_USER_POSTS}</a></span></td>
memberlist.php
'L_POSTS' => $lang['Posts'],
'L_TOPICS' => $lang['Topics'],
'L_REPLIES' => $lang['Replies'],
$sql = "SELECT username, user_id, user_viewemail, user_posts, user_regdate, user_from, user_website, user_email, user_icq, user_aim, user_yim, user_msnm, user_avatar, user_avatar_type, user_allowavatar
, user_reply
#-----[ 變成 ]------------------------------------------
$sql = "SELECT username, user_id, user_viewemail, user_posts, user_regdate, user_from, user_website, user_email, user_icq, user_aim, user_yim, user_msnm, user_avatar, user_avatar_type, user_allowavatar, user_reply
$posts = ( $row['user_posts'] ) ? $row['user_posts'] : 0;
$topic = ( $row['user_posts'] ) ? ($row['user_posts'] - $row['user_reply']) : 0;
$reply = ( $row['user_reply'] ) ? $row['user_reply'] : 0;
'POSTS' => $posts,
'TOPICS' => $topic,
<th class="thTop" nowrap="nowrap">{L_POSTS}</th>
<th class="thTop" nowrap="nowrap" width = "150">{L_POSTS}/{L_TOPICS}/{L_REPLIES}</th>
<td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gen">{memberrow.POSTS}</span></td>
<td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gen">{memberrow.POSTS} / {memberrow.TOPICS} / {memberrow.REPLIES}</span></td>
#-----[ 儲存並關閉所有檔案 ]------------------------------------------
# EoM
## Mod Version: v1.0 for phpBB plus
## Files To Edit: 5
## include/functions_post.php
## profilcp/profilcp_public_base.php
## viewtopic.php
## templates/fisubsilversh/viewtopic_body.tpl
## templates/fisubsilversh/profilcp/public_base_body.tpl
在SQL資料庫的phpbb_users資料表格中,增加一個user_reply欄位在user_posts後面\r
if ($mode == 'delete')
if ($count_posts)
$sign = "- 1";
$sign = "";
if ($count_posts)
$sign = "+ 1";
$sign = "";
//reply and posts mod by emn178
$reply = false;
$reply = true;
if ($count_posts)
$sign = "- 1";
if($reply == true)
$replysign = "- 1";
$sign = "";
if ($count_posts)
$sign = "+ 1";
$replysign = "+ 1";
$sign = "";
$posts_per_day = $view_userdata['user_posts'] / $memberdays;
$topic = $view_userdata['user_posts'] - $view_userdata['user_reply'];
$reply = $view_userdata['user_reply'];
'POSTS' => $nb_posts,
'TOPICS' => $topic,
viewtopic.php
templates/fisubsilversh/public_base_body.tpl
<td valign="top">
<span class="gen"><b>{POSTS}</b></span><br />
<!-- BEGIN switch_post_stat -->
<!-- END switch_post_stat -->
<td valign="top">
<td valign="top">
<span class="gen"><b>{TOPICS}</b></span>
<td valign="top">
<span class="gen"><b>{REPLIES}</b></span><br />
# EoM
http://phpbb-tw.net/phpbb/viewtopic.php?t=23813
或我的論壇提出討論
