[外掛]後台關閉註冊 v 0.02
御津闇慈
文章: 645
註冊時間: 2001-11-17 10:59
[外掛]後台關閉註冊 v 0.02
文章 由 御津闇慈 »
## Mod Title: 後台關閉註冊 v 0.02
## Author: 御津闇慈 = 炎之虛空 (zxery3@hotmail.com)
## Description:
##   管理員可以從控制台關閉註冊
##   不需要把檔案下載回來再修改
##   0.02升級:後台可以寫上關閉註冊的原因
## Files To Edit:
##   profile.php
##   admin/admin_board.php
##   /templates/subSilver/admin/board_config_body.tpl
##   lang_admin.php
## ADD SQL
#-----[ ACTION: 開啟檔案 ]------------------------------------------
profile.php
#-----[ ACTION: 尋找 ]------------------------------------------
else if ( $mode == 'editprofile' || $mode == 'register' )
		if ( !$userdata['session_logged_in'] && $mode == 'editprofile' )
			redirect(append_sid("login.$phpEx?redirect=profile.$phpEx&mode=editprofile", true));
		include($phpbb_root_path . 'includes/usercp_register.'.$phpEx);
		exit;
#-----[ ACTION: 替換為 ]------------------------------------------
	else if ( $mode == 'editprofile' )
		exit;
	else if ( $mode == 'register' )
			if( !$board_config['register_enable'] && $userdata['user_level'] != ADMIN )
      			message_die(GENERAL_MESSAGE, $board_config['register_content'] , 'Information');
		exit;
#-----[ save: 存檔 ]------------------------------------------
$smtp_yes = ( $new['smtp_delivery'] ) ? "checked=\"checked\"" : "";
$smtp_no = ( !$new['smtp_delivery'] ) ? "checked=\"checked\"" : "";
#-----[ ADD: 加入 ]------------------------------------------
// Register_MOD
$register_enable_yes = ( $new['register_enable'] ) ? "checked=\"checked\"" : "";
$register_enable_no = ( !$new['register_enable'] ) ? "checked=\"checked\"" : "";
"L_SUBMIT" => $lang['Submit'],
"L_RESET" => $lang['Reset'],
"L_REGISTER_SETTING" => $lang['Register_Setting'], // Register_MOD
"L_REGISTER_STATUS" => $lang['Register_Status'], // Register_MOD
"L_REGISTER_CONTENT" => $lang['Register_Content'], // Register_MOD
"L_REGISTER_WARNING" => $lang['Register_Warning'], // Register_MOD
"S_REGISTER_YES" => $register_enable_yes, // Register_MOD
"S_REGISTER_NO" => $register_enable_no, // Register_MOD
"REGISTER_CONTENT" => $new['register_content'], // register_MOD
		<td class="row1">{L_ENABLE_PRUNE}</td>
		<td class="row2"><input type="radio" name="prune_enable" value="1" {PRUNE_YES} /> {L_YES}&&<input type="radio" name="prune_enable" value="0" {PRUNE_NO} /> {L_NO}</td>
<tr><!-- REGISTER_MOD -->
      <th class="thHead" colspan="2">{L_REGISTER_SETTING}</th>
      <td class="row1">{L_REGISTER_STATUS}</td>
      <td class="row2">
      <input type="radio" name="register_enable" value="1" {S_REGISTER_YES}> {L_ENABLED}
      <input type="radio" name="register_enable" value="0" {S_REGISTER_NO}>
      {L_DISABLED}</td>
      <td class="row1" valign="top">{L_REGISTER_CONTENT}<br /><span class="gensmall">{L_REGISTER_WARNING}</span></td>
      <td class="row2"><textarea name="register_content" rows="5" cols="30" maxlength="255">{REGISTER_CONTENT}</textarea></td>
lang_admin.php
$lang['Register_Setting'] = '會員註冊功能';
$lang['Register_Status'] = '註冊狀態';
$lang['Register_Content'] = '註冊關閉原因';
$lang['Register_Warning'] = "請勿使用單引號 ('), 字數限制 255 字元";
#-----[SOL語法]-----------------------------------------------
INSERT INTO phpbb_config (config_name , config_value) VALUES ('register_enable', '1');
INSERT INTO phpbb_config (config_name , config_value) VALUES ('register_content', '');
#-----[ OK!!: 完成!! ]------------------------------------------
回到「非官方認證外掛」
