安裝方法很簡單,僅需將下列的檔案照目錄覆蓋掉原檔即可\r
- 覆蓋這三個檔案 (phpbb根目錄) :
posting.php
viewtopic.php
search.php
- 覆蓋這兩個檔案" (在 includes\ 底下) :
topic_review.php
bbcode.php
- 覆蓋掉這兩個檔案 : (ex: /templates/subSilver/ )
bbcode.tpl
posting_body.tpl
~~~~完成.....簡單吧!!
需注意的是,若你有安裝快速回覆,或者任何曾經動到以上檔案的MOD
則需要再重新安裝一次原MOD......否則可能會出問題
Hide Mode for 2.0.4
[外掛]Hide Mode for 2.0.18
呵呵~~ 怎麼沒有安裝過程呢?
我來補上吧!
前言:這外掛很難裝,也很容易出錯,沒有一點修改基礎的人請勿嘗試
程式部分修改:河風
Lockdown by ThE DrAgOn'S
in posting.php
-----(find)-------
if( $attach_sig && $user_sig != '' && $userdata['user_sig_bbcode_uid'] )
$user_sig = bbencode_second_pass($user_sig, $userdata['user_sig_bbcode_uid']);
if( $bbcode_on )
$preview_message = bbencode_second_pass($preview_message, $bbcode_uid);
-----{Replace by}-------
$valid = FALSE;
if( $userdata['session_logged_in'] ) {
$sql = "SELECT p.poster_id, p.topic_id
FROM " . POSTS_TABLE . " p
WHERE p.topic_id = $topic_id
AND p.poster_id = " . $userdata['user_id'];
$resultat = $db->sql_query($sql);
$valid = $db->sql_numrows($resultat) ? TRUE : FALSE;}
$user_sig = bbencode_third_pass($user_sig, $userdata['user_sig_bbcode_uid'], $valid);
if( $bbcode_on )
$preview_message = bbencode_third_pass($preview_message, $bbcode_uid, $valid);
-----{ FIND}-------
if ( !preg_match('/^Re:/', $subject) && strlen($subject) > 0 )
$subject = 'Re: ' . $subject;
-----{Add Below}-------
if( !$userdata['session_logged_in'] ) {$message = hide_in_quote($message);}
$sql = "SELECT p.poster_id, p.topic_id FROM " . POSTS_TABLE . " p WHERE p.topic_id = $topic_id AND p.poster_id = " . $userdata['user_id'];
if(!$db->sql_numrows($resultat)) {$message = hide_in_quote($message);}
----------{Save close all}-----------
in viewtopic.php
-----{ FIND}-------
// Generate a 'Show posts in previous x days' select box. If the postdays var is POSTed
// then get it's value, find the number of topics with dates newer than it (to properly
// handle pagination) and alter the main query
$valid = FALSE;
-----{ FIND}-------
if ( $user_sig != '' && $user_sig_bbcode_uid != '' )
$user_sig = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($user_sig, $user_sig_bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $user_sig);
if ( $bbcode_uid != '' )
$message = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($message, $bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $message);
$user_sig = bbencode_third_pass($user_sig, $user_sig_bbcode_uid, $valid);
$message = bbencode_third_pass($message, $bbcode_uid, $valid);
In search.php
-----{ FIND}-------
// If the board has HTML off but the post has HTML
// on then we process it, else leave it alone
if ( $return_chars != -1 )
if( $return_chars == -1 )
-----{ FIND}-------
$message = bbencode_third_pass($message, $bbcode_uid, FALSE);
In topic_review.php // in the "/includes" directory
-----{ FIND}-------
// Okay, let's do the loop, yeah come on baby let's do the loop
// and it goes like this ...
$valid = FALSE;
-----{ FIND}-------
if ( $bbcode_uid != "" )
in bbcode.php // in the "/includes" directory
-----{ FIND}-------
$bbcode_tpl['email'] = str_replace('{EMAIL}', '\\\1', $bbcode_tpl['email']);
$bbcode_tpl['show'] = str_replace('{HTEXTE}', '\\\1', $bbcode_tpl['show']);
-----{ FIND}-------
* Does second-pass bbencoding. This should be used before displaying the message in
* a thread. Assumes the message is already first-pass encoded, and we are given the
* correct UID as used in first-pass encoding.
-----{Add Before}------
function hide_in_quote($text)
$text = preg_replace("#\[hide\](.*?)\[\/hide\]#si","--- phpBB : The Protected Message is not copied in this quote ---", $text);
return $text;
function bbencode_third_pass($text, $uid, $deprotect)
global $bbcode_tpl;
// pad it with a space so we can distinguish between FALSE and matching the 1st char (index 0).
// This is important; bbencode_quote(), bbencode_list(), and bbencode_code() all depend on it.
$text = " " . $text;
// First: If there isn't a "[" and a "]" in the message, don't bother.
if (! (strpos($text, "[") && strpos($text, "]")) )
// Remove padding, return.
$text = substr($text, 1);
return $text;
// Patterns and replacements for URL and email tags..
$patterns = array();
$replacements = array();
if ( $deprotect ) {
$patterns[0] = "#\[hide:$uid\](.*?)\[/hide:$uid\]#si";
$replacements[0] = $bbcode_tpl['show'];
$replacements[0] = $bbcode_tpl['hide'];
$text = preg_replace($patterns, $replacements, $text);
// Remove our padding from the string..
return $text;
-----{ FIND}-------
// [img]image_url_here[/img] code..
$text = preg_replace("#\[img\](([a-z]+?)://([^ \"
]+?))\[/img\]#si", "[img:$uid]\\\1[/img:$uid]", $text);
//[hide]message[/hide]
$text = preg_replace("#\[hide\](.*?)\[\/hide\]#si","[hide:$uid]\\\1[/hide:$uid]", $text);
in bbcode.tpl // in the Templates/{Used template}/ directory
-----{Add At top}----
<!-- BEGIN show -->
</span>
<table border="0" align="center" width="90%" cellpadding="3" cellspacing="1">
<td><span class="genmed"><b>看完後請務必修改剛剛的留言,說一下心得感想喔....(不然會被我趕出去 ^^")</b></span></td>
<td class="quote">
{HTEXTE}
</td>
</table>
<span class="postbody">
<!-- END show -->
<!-- BEGIN hide -->
</span>
<td><span class="genmed"><b>神秘內容:</b></span></td>
<td class="quote">
<center>--- 假如已是*註冊會員*:那麼您必須回覆留言才能看到完整的文章! ---<p>上傳很辛苦,請給發表者一點鼓勵吧!</center>
</td>
</table>
<!-- END hide -->
in posting_body.tpl // in the Templates/{Used template}/ directory
-----{FIND (In the list of "// Helpline )-------
f_help = "{L_BBCODE_F_HELP}";
-----{Add After}-----
h_help = "{L_BBCODE_H_HELP}";
-----{ FIND}-------
bbtags = new Array('[b]','[/b]','[i]','[/i]','[u]','[/u]','[quote]','[/quote]','[code]','[/code]','[list]','[/list]','[list=]','[/list]','[img]','[/img]','[url]','[/url]
bbtags = new Array('[b]','[/b]','[i]','[/i]','[u]','[/u]','[quote]','[/quote]','[code]','[/code]','[list]','[/list]','[list=]','[/list]','[img]','[/img]','[url]','[/url]','[hide]','[/hide]');
-----{ FIND}-------
<input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="text-decoration: underline; width: 40px" onClick="bbstyle(16)" onMouseOver="helpline('w')" />
</span></td>
-----{Add Below}----- \r
<input type="button" class="button" accesskey="h" name="addbbcode18" value="隱藏" style="width: 40px" onClick="bbstyle(18)" onMouseOver="helpline('h')" />
</span></td>
開啟 language\lang_chinese_traditional_taiwan\lang_main.php
尋找
$lang['bbcode_a_help'] = '關閉所有開啟的 BBCode 標籤';
後面加入
$lang['bbcode_h_help'] = "隱藏內容:[hide]隱藏文字內容[/hide] (alt+h)";
開啟 posting.php
尋找
'L_BBCODE_B_HELP' => $lang['bbcode_b_help'],
後面加入
'L_BBCODE_H_HELP' => $lang['bbcode_h_help'],
All Right's Reserved To ThE DrAgOn'S
文章來源: http://www.phpbbhacks.com/viewhack.php?id=870
^_^
我來補上吧!
程式部分修改:河風
in posting.php
-----(find)-------
if( $bbcode_on )
$valid = FALSE;
if( $bbcode_on )
-----{ FIND}-------
in viewtopic.php
-----{ FIND}-------
$valid = FALSE;
-----{ FIND}-------
In search.php
-----{ FIND}-------
-----{ FIND}-------
-----{ FIND}-------
$valid = FALSE;
-----{ FIND}-------
-----{ FIND}-------
-----{ FIND}-------
return $text;
global $bbcode_tpl;
return $text;
if ( $deprotect ) {
return $text;
-----{ FIND}-------
<!-- BEGIN show -->
</span>
<td class="quote">
{HTEXTE}
</td>
</table>
<!-- END show -->
<!-- BEGIN hide -->
</span>
<td class="quote">
</td>
</table>
<!-- END hide -->
-----{ FIND}-------
-----{ FIND}-------
</span></td>
</span></td>
尋找
後面加入
開啟 posting.php
尋找
後面加入
^_^
七點要求:
1. 發問前先搜尋,確定沒有重複後再發表
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
七點要求:
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
此外掛支援到 2.0.18
詳見作者網頁:
http://www.philiweb.com/download/hide/h ... =1&lang=en
另外還有進階功能可以設定 (例如版主可以不受限制、限制文章數達到一定才可觀看等等...)
http://www.philiweb.com/download/hide/4hide.php?lang=en
詳見作者網頁:
Version 1 : *ONLY* admins & moderators can see ALL the hidden messages without posting. BUT they are the *only ones* who can see hidden messages.
Version 2 : *ONLY Members* who have posted at less xx messages into the forum can see ALL the hidden messages.
(Important : The number of messages to put in the files to modify must be the same.)
Version 3 : "Improvement" for version 1 OR version 2 => Obligation to post a message in a thread to see hidden message(s) inside.
Version 4 : Mod Hide "standard" EXCEPT for Admins & moderators who can see hidden messages everywhere and immediatly.
Version 5 : Mod Hide "standard" + VERSION 2. Members who have posted at less xx messages into the forum can see ALL the hidden messages. The others ones can see a "hidden message" if they have posted into the good thread. (Important : The number of messages to put in the files to modify must be the same.)
