[求檔]請問誰有下載中心 (pafiledb)
w2812451
文章: 255
註冊時間: 2005-07-16 21:38
文章 w2812451 »
我的不見了!誰可以提供!原檔案在幾個月前已經不能用了!請問哪個好心的大大有保留的是否可以提供!感謝~蠻需要的
kljian
文章: 71
註冊時間: 2003-12-02 08:10
來自: takumi
[轉貼] pafiledb0.0.9d_tw.rar
文章 kljian »
這裡有你想要的! pafiledb0.0.9d_tw.rar
w2812451
文章: 255
文章 w2812451 »
要如何安裝~我沒看見說明檔阿= =
kljian
文章: 71
來自: takumi
文章 kljian »
w2812451 寫:要如何安裝~我沒看見說明檔阿= =
在目錄 pafiledb\docs 底下有 install.txt 文字檔找一下!
## MOD Title: pafiledb integration
## MOD Version: 0.0.9c
## MOD Author: squall < mohdalbasri@yahoo.com > (Mohammed Al-Basri) www.mohd.tk
##	       MJ < mj@phpbbfm.net > www.phpbbfm.com
## MOD Description: Integration of pafiledb (Database download manager) with phpbb.
##                  pafiledb use header, footer, session, template, and database system
##		    of phpbb.
##			Only for phpBB 2.0.4!
## Installation Level: (easy)
## Installation Time: 10-15 Minutes
## Files To Edit (10) : admin/index.php
##			includes/constant.php
##		       admin/admin_db_utilities.php
##		       includes/page_header.php,
##                     language/lang_english/lang_main.php,
##                     templates/subSilver/admin/page_header.tpl,
##                     templates/subSilver/overall_header.tpl,
##		       templates/subSilver/subSilver.cfg
## Included Files:     dload.php,
##		       admin/admin_pa_catauth.php
##		       admin/admin_pa_category.php,
##		       admin/admin_pa_custom.php,
##		       admin/admin_pa_file.php,
##		       admin/admin_pa_license.php,
##		       admin/admin_pa_settings.php,
##		       language/*/lang_admin_pafiledb.php
##		       language/*/lang_pafiledb.php
##		       pafiledb/*.*,
##		       templates/subSilver/pa_*.tpl ( 18 )
##		       templates/subSilver/admin/pa_*.tpl ( 19 )
##		       templates/subSilver/images/icon_mini_download.gif
##		       templates/subSilver/images/lang_english/icon_pa_*.gif ( 9 )
## For Security Purposes, Please Check: http://www.phpbb.com/mods/downloads/ for the
## in our MOD-Database, located at: http://www.phpbb.com/mods/downloads/
## Author Note:
## follow all the instruction below first then upload and run from your browser,
## pafiledb/docs/pafiledb_installer.php (choose new installation) and if you have the table already installed,
## you won't need to change anything in them except that you won't need the admin table
## since you are going to use ACP.
## Create and CHMOD (0777) THE FOLLOWING DIRECTORIES:
## - pafiledb/uploads/
## - pafiledb/cache/
## - pafiledb/cache/templates/subSilver/
## - pafiledb/cache/templates/subSilver/admin
## - pafiledb/images/screenshots/
## Change History:
##	0.0.9 : ADD/Fixed:
##		- THE WHOLE MOD IS RE WRITIEN
##		- ADDED ALOT OF FEATURE
##		- FIXING ALOT OF SECURITY BUGS
##	0.0.8 : Added/Fixed:
##		- Fixed the global varaible problem. (you don't have to set global var to on)
##		- Changed the whole coding structure in all file.
##		- Comment viewing like the viewtopic.
##		- Added the file checker feature (beware if this one or you will end up erasing all file.)
##		- Changed some images and included them into templates/*/images/ folder.
##		- Main Templates cleaned up, added clickable folder icons.
##		- Fixed bug with category sort feature.
##		- Added edit download count when editing file.
##		- Added Dutch, German and Italian language support .
##	0.0.7 : Added/Fixed:
##		- Fixed bug with screen shot upload.
##		- Fixed bug with templates in ACP.
##		- Removed Variable $str found in search.php.
##		- Changed directory for images and icons.
##		- Changed all url and action to append_sid.
##	0.0.6 : Added/Fixed:
##		- Backupdb & restore to phpBB forum backup style
##		- Changed tables to phpbb style
##		- Show screenshots as image instead of link. (you may choose now either links or image).
##		- Long Description - Multiple line text area.
##		- Replaced pafiledb language with phpbb.
##		- Unlimited subCategories.
##		- Added Upload Screenshot feature (there is a small bugs on it)
##		- Added Disable "View All" link
##		- Added Disable Database feature
##		- comment feature (only registered users can post)
##		- Email is using phpBB class emailer.
##		- New File indicator you can now set the number of day to show that the file is new
##		- Added toplist file (you can now specify number of file that in toplist.
##		- Removed the following bugs:
##			* Replaced pafiledb Time Zone with phpbb.
##			* Replaced pafiledb Language with phpbb.
##			* Email fields can be left blank, but confirmation of email sent is returned.
##			* Custom Field data not reading from db
##			* Time on posted comment
##			* Edit file (ACP), sub-cats & files not showing
##			* Backup Database screwed
##			* removing some un needed row from setting table like language and style.
##			* fixing the problem of jumpmenu fix in pafiledb.php file because file send the $str instead of $lang
##			* 'Comment Explain' text missing
##			* Title on posted comment
##			* max_comment_chars field in _settings table missing
##			* Javascript error when posting or previewing comment
##			* Email not actually sending to address ??? (Not for me anyway!)
##			* Time on file page
##	0.0.5 : - Re-packing of all working files
##     	 	- Changed paFileDB_installer.php
## 	0.0.4 : Fixed:
## 		- {dbname} showing in the email instead of the variable that should replace it.
## 		- Uploaded file not returning full URL.
## 		- Replaced pafiledb Time Zone with phpbb.
## 		- Email fields can be left blank, but confirmation of email sent is returned
## 		- Fixed sort for viewall.. (sort according to rating not yet due to php version)
## 		- Custom Field data not reading from db
## 		- Added support for view online when some one in download page.
##	0.0.3 : - Fixed the editing file bug in ACP
##		- Fixed the the file in sub category bug.
##		- Fixed the uploading file url bug when uploading
##		- Changed message after rating or e-mail sending
##		- Made copywrite with phpbb copywrite only if you are in download database
##	0.0.2 : All templates made to fit phpBB default, clean up of code.
## 	0.0.1 : First release, I need just to modify the *.tpl file in admin
## 		section.
copy dload.php to root
copy admin/*.php to admin/
copy templates/subSilver/*.tpl to templates/subSilver/
copy templates/subSilver/images/*.gif to templates/subSilver/images
copy templates/subSilver/images/lang_english*.gif to templates/subSilver/images/lang_english
copy templates/subSilver/admin/*.tpl to templates/subSilver/admin/
copy pafiledb/*.* to pafiledb/
copy language/lang_english/* to language/lang_english/*
run pafiledb/docs/pafiledb_installer.php or pafiledb_mysql.sql
includes/constants.php
define('PAGE_GROUPCP', -11);
define('PAGE_DOWNLOAD', -12);
admin/index.php
// End functions
include($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_admin_pafiledb.' . $phpEx);
						case PAGE_FAQ:
							$location = $lang['Viewing_FAQ'];
							$location_url = "index.$phpEx?pane=right";
							break;
						case PAGE_DOWNLOAD:
							$location = $lang['Viewing_Download'];
							$location_url = "../dload.$phpEx";
							break;
					case PAGE_FAQ:
						break;
					case PAGE_DOWNLOAD:
						break;
	include('./page_footer_admin.'.$phpEx);
$tables = array('auth_access', 'banlist', 'categories'....
#-----[ FIND IN LINE ]------------------------------------------
'forums', 'forum_prune',
#-----[ ADD INTO LINE ]------------------------------------------
'pa_cat', 'pa_comments', 'pa_custom', 'pa_customdata', 'pa_files', 'pa_license', 'pa_config', 'pa_votes', 'pa_download_info', 'pa_mirros',
						<td height="25" align="center" valign="top" nowrap="nowrap"><span class="mainmenu">&nbsp;<a href="{U_PROFILE}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_profile.gif" width="12" height="13" border="0" alt="{L_PROFILE}" hspace="3" />{L_PROFILE}</a>&nbsp; &nbsp;<a href="{U_PRIVATEMSGS}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_message.gif" width="12" height="13" border="0" alt="{PRIVATE_MESSAGE_INFO}" hspace="3" />{PRIVATE_MESSAGE_INFO}</a>&nbsp; &nbsp;<a href="{U_LOGIN_LOGOUT}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_login.gif" width="12" height="13" border="0" alt="{L_LOGIN_LOGOUT}" hspace="3" />{L_LOGIN_LOGOUT}</a>&nbsp;</span></td>
						<td height="25" align="center" nowrap class="mainmenu" valign="top">
						&nbsp;<a href="{U_DOWNLOAD}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_download.gif" width="13" height="13" border="0" alt="{PRIVATE_MESSAGE_INFO}" title="{PRIVATE_MESSAGE_INFO}" hspace="3" align="top" />{L_DOWNLOAD}</a>&nbsp;
						</td>
$lang['FAQ'] = 'FAQ';
$lang['Download'] = 'Download';
$lang['Viewing_FAQ'] = 'Viewing FAQ';
$lang['Viewing_Download'] = 'Viewing Download';
	'L_FAQ' => $lang['FAQ'],
	'L_DOWNLOAD' => $lang['Download'],
	'U_FAQ' => append_sid('faq.'.$phpEx),
	'U_DOWNLOAD' => append_sid('dload.'.$phpEx),
viewonline.php
				case PAGE_FAQ:
					$location_url = "faq.$phpEx";
					break;
				case PAGE_DOWNLOAD:
					$location_url = "dload.$phpEx";
					break;
// Vote graphic length defines the maximum length of a vote result
$images['pa_search'] = "$current_template_images/{LANG}/icon_pa_search.gif";
$images['pa_stats'] = "$current_template_images/{LANG}/icon_pa_stats.gif";
$images['pa_toplist'] = "$current_template_images/{LANG}/icon_pa_toplist.gif";
$images['pa_upload'] = "$current_template_images/{LANG}/icon_pa_upload.gif";
$images['pa_viewall'] = "$current_template_images/{LANG}/icon_pa_viewall.gif";
$images['pa_download'] = "$current_template_images/{LANG}/icon_pa_download.gif";
$images['pa_rate'] = "$current_template_images/{LANG}/icon_pa_rate.gif";
$images['pa_email'] = "$current_template_images/{LANG}/icon_pa_email.gif";
$images['pa_comment_post'] = "$current_template_images/{LANG}/icon_pa_post_comment.gif";
$images['pa_file_new'] = "$current_template_images/icon_pa_new.gif";
# EoM
