[問題]關於CashMod
yuankuei
文章: 23
註冊時間: 2003-07-24 04:21
來自: CA 91801
文章 yuankuei »
抱歉!! 剛剛看錯,以為你是在看文章的地方沒辦法顯示出金錢.. :P
以下是我的 viewtopic_body.tpl 片段.. (這是在看文章的時候顯示出作者的金錢數目)
[php]<!-- BEGIN postrow -->
<td valign="top" class="{postrow.ROW_CLASS}" rowspan="2"><a name="{postrow.U_POST_ID}" id="{postrow.U_POST_ID}"></a><strong>{postrow.POSTER_NAME}</strong><br /><span class="name"><a name="{postrow.U_POST_ID}"></a></span>
<span class="name"><b>{postrow.NICKNAME}</b></span><br />
<span class="postdetails">{postrow.POSTER_RANK}<br />
{postrow.RANK_IMAGE}{postrow.POSTER_AVATAR}<br /><br />
{postrow.POSTER_AGE}<br/ >
{postrow.POSTER_JOINED}<br />
{postrow.POSTER_POSTS}<br />
{postrow.POSTER_FROM}<br />
<!-- BEGIN cashrow -->
{postrow.cashrow.CASH_NAME}: {postrow.cashrow.CASH_AMOUNT}<br />
<!-- END cashrow -->[/php]
主要就是在 {postrow.POSTER_FROM} 的後面加進\r
[php]<!-- BEGIN cashrow -->
另外關於 porfile_view_body.tpl 的部分
我檔案片段如下
[php]<tr>
<td align="right" nowrap="nowrap" class="explaintitle">{L_OCCUPATION}:</td>
<td>{OCCUPATION}</td>
<td align="right" valign="top" nowrap="nowrap" class="explaintitle">{L_INTERESTS}:</td>
<td>{INTERESTS}</td>
<td valign="top" align="right" nowrap="nowrap"><span class="explaintitle">{L_BIRTHDAY}:</span></td>
<td><b><span class="gen">{BIRTHDAY}</span></b></td>
<td valign="middle" align="right" nowrap="nowrap"><span class="explaintitle">{cashrow.CASH_NAME}:</span></td>
<td><table border=0><tr><td width="50"><span class="gen"><b>{cashrow.CASH_AMOUNT}</b></span></td>
<!-- BEGIN switch_donatedisplay -->
<form style="{display: inline;}" action="{cashrow.S_DONATE_ACTION}" method="post"><td><span class="gen"><input type="submit" value="{cashrow.L_DONATE}" class="liteoption" /> <input type="hidden" name="member_donate" value="1" /><input type="hidden" name="cash_type" value="{cashrow.CASH_TYPE}" /><input name="donate_amount" value="0" size="5" class="post" /> / </span></td><td width="50"><span class="gen"><b>{cashrow.DONATER_CASH}</b></span></td></form>
<!-- END switch_donatedisplay -->
<!-- BEGIN switch_admindisplay -->
<form style="{display: inline;}" action="{cashrow.S_ADMIN_ACTION}" method="post"><td><span class="gen"><input type="submit" value="{cashrow.L_ADD_CASH}" class="liteoption" /> <input type="hidden" name="admin_donate" value="1" /><input type="hidden" name="cash_type" value="{cashrow.CASH_TYPE}" /><input name="admin_amount" value="0" size="5" class="post" /></span></td></form>
<!-- END switch_admindisplay -->
</tr></table></td>
<!-- BEGIN switch_exchangeon -->
<td valign="top" align="right" nowrap="nowrap"><span class="gen"></span></td>
<form style="{display: inline;}" action="{U_EXCHANGE}" method="post"><td><input type="submit" value="{L_EXCHANGE}" class="liteoption" /></td></form>
<!-- END switch_exchangeon -->[/php]
因為我有裝 BIRTHDAY MOD 所以加在 {L_BIRTHDAY} 的下面\r
不過照道理講,只要有這一段程式碼應該就會顯示出金錢才是..??
可以用 interest 當關鍵字下去找,不要用 {interests}
個人資料裡面應該是會有興趣這個欄位才對,除非你自行更動過了..
也有可能是某個 MOD 有改過也說不定..
參考一下.. :roll:
by the way..如果在 viewtopic_body.tpl 檔案裡面確定有這一段\r
但是還是沒有金錢顯示的話..那要到 viewtopic.php 裡面找找問題所在\r
cash mod 安裝到現在完全沒有問題
還可以有好幾種不同的幣值,我覺得這是一個功能強大的 MOD
最後由 yuankuei 於 2003-09-04 16:28 編輯,總共編輯了 1 次。
Martinet
文章: 850
註冊時間: 2003-06-09 21:58
文章 Martinet »
謝謝你熱心的回答....我去試試...有問題再請教你...^^
Martinet
文章: 850
文章 Martinet »
成功囉....謝謝你~^^
Martinet
文章: 850
文章 Martinet »
現在碰到了一個新的小問題.....
當我有兩種幣值時..看文章時他的排版是
文章: 62
Oaf普通幣: 1531 Oaf分享 <--被擠到
幣: 0
人氣指數 : 6.70
來自: 風之城 : 新竹
註冊時間: 2003-06-21
能不能改成
文章: 62
Oaf普通幣 : 1531 <--與下面有分隔....
Oaf分享幣 : 0
人氣指數 : 6.70
來自: 風之城 : 新竹
註冊時間: 2003-06-21
先謝謝囉....^^
atthis
文章: 216
註冊時間: 2003-07-29 19:16
文章 atthis »
我的viewtopic_body.tpl在cash mod附近的樣子
<br />{postrow.cashrow.CASH_NAME}:postrow.cashrow.CASH_AMOUNT}
</span><br /></td>
<td class="{postrow.ROW_CLASS}" width="100%" height="28" valign=
"top"><table width="100%" border="0" cellspacing="0" cellpadding="0">
在文章中看起來像這樣\r
性別:
註冊時間: 2003-08-08
文章: 5
人氣指數: 11.98
Level/Skill Ratio: 1/0
Class: Apprentice
金幣: 108
銀幣: 5095
兩個幣值間會換行,不會擠在一起
Martinet
文章: 850
文章 Martinet »
喔喔....謝謝你....可以了....
再問一個問題.......怎麼兌換幣值阿?.....XD~
感謝解答啦....^^"(我的問題怎麼那麼多....XD~)
atthis
文章: 216
文章 atthis »
有兩種以上的幣值時在"貨幣匯率"開啟貨幣間的兌換
先設定兩貨幣間的匯率(如 1:10),
之後在下面的"disable"或"關閉"上按一下就會出現 1:10 或 10:1
實際要兌換時,在"會員列表"中檢視會員資料時會看到"兌換"鈕,按了就會進入兌換畫面
發展中 Mod
禁止發言 (水桶名單)
有興趣的人一起來討論喔~~
天霜
文章: 882
註冊時間: 2003-04-15 19:40
來自: 星之鄉學園
文章 天霜 »
Martinet 寫:喔喔....謝謝你....可以了....
進入系統管理控制台>虛擬貨幣>貨幣匯率
除非是個人疏失所造成的問題
這世界還有拼命守護的價值嗎...
Martinet
文章: 850
文章 Martinet »
XD~忘了說 , 那設過了.... 匯率是 10 : 1
動感超人
文章: 485
註冊時間: 2003-02-09 14:06
文章 動感超人 »
個人資料裡有個"兌幣"的功能
無限期蒸發中
Martinet
文章: 850
文章 Martinet »
XD~有看到就是不會用阿.....~
ponbaber
文章: 94
註冊時間: 2002-11-16 17:27
來自: 新竹空軍基地
文章 ponbaber »
動感超人 寫:個人資料裡有個"兌幣"的功能
可否張貼一下是哪一段程式碼可以讓個人資料呈現"兌幣"功能,
我實在找不到好灰心唷...
別人不給你的,學著自己先給別人
分享會加速學習也是快樂的動力~
Martinet
文章: 850
文章 Martinet »
        </tr></table></td>
動感超人
文章: 485
文章 動感超人 »
在個人資料裡看看有沒有一個圖檔的按鈕。
要用兌幣的功能,cash mod裡一定要建立2種以上的貨幣。
如果還是沒出現,可能是您程式碼改錯了。
這是兌幣的畫面:
另外,我的cash有修正過,所以畫面看起來可能跟你們自己的不一樣。
我想你們大概是被原來那怪怪的詞改混了吧^^|||
我也忘記那篇修正在哪裡了,總之,應該在竹貓主站&分站上有關cash的文章裡吧。
無限期蒸發中
ponbaber
文章: 94
來自: 新竹空軍基地
文章 ponbaber »
抱歉我剛剛發現都沒有那些訊息的關係,好像是我沒有打開現金模組開關,
可是我打開之後發表文章卻都顯示\r
Fatal error: Call to undefined function: cashupdate() in c:\appserv\www\phpbb3\includes\functions_post.php on line 231
我實在很頭痛..我把我的檔案放上來好了。
functions_post.rar
viewtopic_body.rar
超人你圖的顏色好漂亮丫^^a
最後由 ponbaber 於 2003-09-09 00:53 編輯,總共編輯了 1 次。
別人不給你的,學著自己先給別人
分享會加速學習也是快樂的動力~
