[問題] 請教有無--活動報名模組
池上文源
註冊時間: 2004-11-01 16:41
來自: Taipei
文章 池上文源 »
找到原因了,原來我沒有先作sql表的更新。
池上文源 寫:依說明安裝後,一登入就出現以下錯誤的訊息...
一般錯誤
Could not get meeting usergroups
SQL Error : 1146 Table 'savrinorg_phpbb.phpbb_meeting_data' doesn't exist
SELECT m.meeting_id, mg.meeting_group FROM phpbb_meeting_data m, phpbb_meeting_usergroup mg WHERE mg.meeting_id = m.meeting_id
Line : 520
File : /home/httpd/vhosts/savrin.net/httpdocs/forum/includes/page_header.php
不知有那位大大知道是什麼問題,要如何解決?
mcdondon
文章: 20
註冊時間: 2004-12-04 17:27
來自: HK
文章 mcdondon »
這是小弟直譯的中文檔
<?php
/* lang_meeting.php [Chinese]
// Administration
$lang['Meeting_admin'] = '活動';
$lang['Meeting_add_new'] = '新增活動';
$lang['Meeting_manage'] = '修改活動';
$lang['Meeting_manage_explain'] = '在這裡,你有權修改及刪除活動。';
$lang['Meeting_delete'] = '刪除活動?';
$lang['Meeting_delete_explain'] = '你肯定要刪除活動嗎?';
$lang['Meeting_add'] = '新增活動';
$lang['Meeting_edit'] = '修改活動';
// Forum part
$lang['Meeting'] = '活動管理';
$lang['Meeting_until'] = '截止報名日期';
$lang['Meeting_location'] = '地點';
$lang['Meeting_subject'] = '活動名稱';
$lang['Meeting_closed'] = '截止';
$lang['No_meeting'] = '沒有活動';
$lang['Meeting_no_period'] = '報名期限以過';
$lang['Meeting_desc'] = '活動詳情';
$lang['Meeting_link'] = '連結';
$lang['Meeting_places'] = '名額';
$lang['Meeting_usergroup'] = '群組';
$lang['Meeting_filter'] = '搜尋選項';
$lang['Meeting_all'] = '所有數據';
$lang['Meeting_open'] = '活動中';
$lang['Meeting_sign_on'] = '出席率承諾';
$lang['Meeting_sign_edit'] = '改變出席率';
$lang['Meeting_sign_off'] = '取消報名';
$lang['Meeting_sign_off_explain'] = '你是否肯定要取消報名?';
$lang['Meeting_detail'] = '活動詳情';
$lang['Meeting_viewlist'] = '活動名單';
$lang['Meeting_userlist'] = '報名會員';
$lang['Meeting_no_user'] = '沒有報名會員';
$lang['Meeting_free_places'] = '尚餘名額';
$lang['Meeting_sure_total'] = '現有網上會員出席率';
$lang['Meeting_sure_total_user'] = '現有肯定出席會員率';
$lang['Meeting_statistic'] = '數據';
$lang['Meeting_comments'] = '出席人數';
$lang['Meeting_comment'] = '會員意見';
$lang['Meeting_enter_comment'] = '新增意見';
$lang['No_active_meetings'] = '暫時沒有活動';
$lang['One_active_meeting'] = '本會正在籌備1個正式活動';
$lang['Active_meetings'] = '本會正在籌備%s個正式活動';
文章 阿維 »
Meeting 1.2.1 新增的部份
第15至25行:
// Configuration
$lang['Meeting_config'] = 'Meeting Configuration';
$lang['Meeting_config_explain'] = 'From here you can manage all basic settings for meetings on your board.';
$lang['Meeting_config_updated'] = 'Meeting Configuration successfull updated';
$lang['Click_return_meeting_config'] = 'Click %shere%s to return to the Meeting Configuration.';
$lang['User_allow_enter_meeting'] = 'Allow users to enter meetings';
$lang['User_allow_enter_meeting_explain'] = 'If you will set here YES, each user can enter meetings. Say NO here to enable this only on ACP by an Admin.';
$lang['User_allow_edit_meeting'] = 'Allow users to edit meetings';
$lang['User_allow_edit_meeting_explain'] = 'If you will set here YES, each user can edit meetings. Say NO here to enable this only on ACP by an Admin.';
第59至62行:
$lang['Meeting_create_by'] = 'Created by <a href="%s" class="genmed">%s</a>';
$lang['Meeting_edit_by'] = 'Last edited by <a href="%s" class="genmed">%s</a>';
$lang['Meeting_start_value'] = 'Start value for assign drop down';
$lang['Meeting_recure_value'] = 'Intervall for this drop down';
後台語系:
Meeting admin
Meeting add new
Meeting config
Meeting manage
請各位前輩幫忙補足謝謝!
文章 阿維 »
最後由 阿維 於 2006-03-11 15:25 編輯,總共編輯了 1 次。
kkt
文章: 625
註冊時間: 2005-06-15 01:37
來自: H.K.
文章 kkt »
mcdondon 大, 請修正一個筆誤別字.. ;-)
$lang['Meeting_no_period'] = '報名期限過';
在此學到很多架站知識, 永遠多謝:
yuei
文章: 93
註冊時間: 2005-12-20 22:14
文章 yuei »
JORDAN 寫:版本更新到: Meeting 1.3.6
http://www.oxpus.de/dl_details.php?view ... =274&cat=1
喔...@_@
升級檔居然沒提到怎麼將1.3.0升級到1.3.1跟1.3.2... :-o
我的剛好是1.3.0...Orz
有人願意解說一下1.3.0之後加了什麼東西嗎 :oops:
英文對我來說太火星了(哭)
---進期完成的外掛修改---
auction_mod加入拍賣問與答
行事曆,活動報名,相簿藝廊,3隻mod做整合如下
照片能發表至行事歷上,行事歷能看見該天照片
活動報名日期可從行事曆裡的活動做選擇
聊天室顯示會員照片
jwxie
文章: 604
註冊時間: 2005-11-26 12:02
文章 jwxie »
我想應該是跟132升級到133一樣吧.
最後由 jwxie 於 2006-03-13 07:18 編輯,總共編輯了 1 次。
目前本人帳號嚴重地被盜用!MSN已經被盜!
請尊守竹貓各區裡的發文格式, 謝謝合作!
所有新手必看的
[教學]認識、安裝和參考PHPBB的新手基本教學通
PS:感謝各位大大的幫助和教導^^
Q168.net空間技術交流
yuei
文章: 93
Re: ....
文章 yuei »
jwxie 寫:我想應該是跟132升級到133一樣吧
失敗@@...
我照著升級檔去做
在132 to 133就進不去後台的meeting config了 :oops:
喔...自爆
我只升級132 to 133 用136的檔
剛剛將所有SQL執行了
目前是沒啥問題
差語係檔的翻譯了
---進期完成的外掛修改---
auction_mod加入拍賣問與答
活動報名日期可從行事曆裡的活動做選擇
聊天室顯示會員照片
文章 阿維 »
Meeting 1.3.6 新增的部份
第15至31行:
$lang['Meeting_choose'] = 'Choosing';
// Configuration
$lang['User_allow_enter_meeting'] = 'Allow users to create meetings';
$lang['User_allow_enter_meeting_explain'] = 'If you will set here YES, each user can create meetings. Say NO here to enable this only on ACP by an Admin. GROUPS will enable this to users who are a member of minimum one of the following groups.';
$lang['User_allow_delete_meeting'] = 'Allow Users to delete their Meetings';
$lang['User_allow_delete_meeting_explain'] = 'If you say YES here, each user can delete his own meeting. Say NO here to disable this option.';
$lang['User_allow_delete_meeting_comments'] = 'Allow Users to delete their Meeting Comments';
$lang['User_allow_delete_meeting_comments_explain'] = 'If you say YES here, each user can delete his own meeting comments. Say NO here fo disable this option.';
$lang['Meeting_notify'] = 'Enable email notification for user sign on/off';
$lang['Meeting_notify_explain'] = 'Enable the notifications to the board email adress, if a user will sign of/off a meeting or changing the promise';
第66至75行:
$lang['Meeting_unjoin_message'] = 'A user have unjoined a meeting';
$lang['Meeting_unjoin_user'] = 'User %s have unjoined from meeting %s.';
$lang['Meeting_join_message'] = 'A user have joined a meeting';
$lang['Meeting_join_user'] = 'User %s have joined to meeting %s.';
$lang['Meeting_change_message'] = 'A user have changed the sign on to a meeting';
$lang['Meeting_change_user'] = 'User %s have changed the sign on to meeting %s.';
假如有人要翻譯的話,就從這些開始翻譯起吧 :mrgreen:
jwxie
文章: 604
文章 jwxie »
Meeting 1.3.6 新增的部份
第15至31行:
$lang['Meeting_choose'] = '活動選擇';
// Configuration
$lang['Meeting_config'] = '活動管理設定';
$lang['Meeting_config_explain'] = '此功能允許你設定,管理與修改相關的活動設定';
$lang['Meeting_config_updated'] = '資料更新成功!';
$lang['Click_return_meeting_config'] = '點選 %s這裡%s 返回活動管理設定.';
$lang['User_allow_enter_meeting'] = '會員自由發佈新的活動';
$lang['User_allow_enter_meeting_explain'] = '如果選擇『允許』, 每一個註冊會員將有權限自由發佈活動; 否則, 發佈權限仍然只有『系統管理員』, 或者權限將跟以下最少一個群組共享。';
$lang['User_allow_edit_meeting'] = '給予會員權限修改自己發佈的活動資訊。';
$lang['User_allow_edit_meeting_explain'] = '給予會員權限修改自己發佈的活動資訊; 否則, 否則, 請關閉此功能。';
$lang['User_allow_delete_meeting'] = '給予會員權限刪除自己發佈的活動資訊。';
$lang['User_allow_delete_meeting_explain'] = '給予會員權限刪除自己發佈的活動資訊, 否則, 請關閉此功能。';
$lang['User_allow_delete_meeting_comments'] = '給予會員權限刪除自己發佈的活動訊息與留言。';
$lang['User_allow_delete_meeting_comments_explain'] = '給予會員權限刪除自己發佈的活動訊息與留言; 否則, 請關閉此功能';
$lang['Meeting_notify'] = '開啟電子郵件訊息';
$lang['Meeting_notify_explain'] = '開啟此功能後, 將會接收所有活動成員的最新動態, 包括出席與退出活動。';
第66至75行:
$lang['Meeting_create_by'] = '活動發佈: <a href="%s" class="genmed">%s</a>';
$lang['Meeting_edit_by'] = '最後更新: <a href="%s" class="genmed">%s</a>';
$lang['Meeting_unjoin_message'] = '一位成員已經退出活動。';
$lang['Meeting_unjoin_user'] = '會員 %s 已經從退出活動 %s.';
$lang['Meeting_join_message'] = '有新成員註冊參加活動';
$lang['Meeting_join_user'] = '會員 %s 已經註冊參加活動 %s.';
$lang['Meeting_change_message'] = '成員已經改變及更新出席資訊';
$lang['Meeting_change_user'] = '成員 %s 已經改變及更新出席資訊 %s.';
(翻譯並不完善, 其中兩句我並不太了解他的意思。
因此我是香港人, 所以翻譯書面語也許會不太好, 另外, 也因為在外國住久, 文法也是比較差,,, 有意見請提供)
所有新手必看的
PS:感謝各位大大的幫助和教導^^
Q168.net空間技術交流
文章 阿維 »
你說的對,最好還是讓其他前輩來校對比較好 (因為有點怪怪的) :-P
yuei
文章: 93
文章 yuei »
JORDAN 寫:你說的對,最好還是讓其他前輩來校對比較好 (因為有點怪怪的) :-P
其實ok啦 :oops:
翻譯這種東西看的懂是在幹嘛就好~_~
我是用成
$lang['Meeting_start_value'] = '最低參與可能性(%)';
$lang['Meeting_recure_value'] = '最低參與可能性每次增加多少直到99';
上面第2個很難去詮釋他...
比如說我打5
就會從5 10 15 20 25 30~~直到100%
如果我打10
就會從10 20 30 40~~直到100
如果打50
參與可能性就只有50 跟100 能選了
15~31行幾乎是後台的
我是看的懂知道在幹嘛就不去管他了~_~
66~75行似乎是mail中會收到的訊息?@@
---進期完成的外掛修改---
auction_mod加入拍賣問與答
活動報名日期可從行事曆裡的活動做選擇
聊天室顯示會員照片
文章 阿維 »
Meeting 1.3.14 新增的部份 (2007-01-13)
將第15行刪除:
第47至48行原文語意變動:
$lang['Meeting_sign_on'] = 'Sign on the meeting with a promise of';
$lang['Meeting_sign_edit'] = 'Promise change in';
更動為:
$lang['Meeting_sign_on'] = 'Sign on the meeting with';
$lang['Meeting_sign_edit'] = 'Change promise to';
第69至70行:
$lang['Meeting_unwill_message'] = 'A user will not visit a meeting';
$lang['Meeting_unwill_user'] = 'User %s will not visit the meeting %s.';
第77至102行:
$lang['Meeting_signons'] = 'Your signons';
$lang['Meeting_guest_overall'] = 'Overall number of guests all user can max. invite';
$lang['Meeting_guest_single'] = 'Number of guests a user can max. invite';
$lang['Meeting_remain_guest_text'] = 'You have invited %s guests, but currently there are only %s places free.<br />Please go back and invite less people.';
$lang['Meeting_user_guest'] = ' + one guest';
$lang['Meeting_user_guests'] = ' + %s guests';
$lang['Meeting_user_guest_popup'] = ' + <a href="javascript:void(0)" onclick="openguestpopup(%s, %s);">one guest</a>';
$lang['Meeting_user_guests_popup'] = ' + <a href="javascript:void(0)" onclick="openguestpopup(%s, %s);">%s guests</a>';
$lang['Meeting_guests'] = 'Guests';
$lang['Meeting_owm_guests'] = 'Your guests';
$lang['Meeting_prenames'] = 'Prenames';
$lang['Meeting_names'] = 'Names';
$lang['Meeting_invite_guests'] = ' with ';
$lang['Meeting_overall_guest_places'] = ' + overall %s guests';
$lang['Meeting_single_guest_places'] = ' (%s guests each user)';
$lang['Meeting_remain_guest_places'] = '. Currently %s guests invitable.';
$lang['Meeting_no_guest_limit'] = 'Enter 0 to disable this limit';
$lang['Meeting_all'] = 'All User';
$lang['Meeting_group'] = 'Usergroup';
$lang['Meeting_no_signon'] = 'Refusal';
$lang['Meeting_yes_signon'] = 'Promise';
$lang['Meeting_intervall_explain'] = 'Use 0/100 to let the users just refuse or promise a meeting';
$lang['Meeting_only_registered'] = 'Only for registered users!';
$lang['Meeting_guest_names'] = 'User must enter the names of invited guests';
$lang['Meeting_guest_names_explain'] = 'This option will replace the drop down for the number of invited guests into a form to enter the guest names.<br />The user will invite the number of guests he enters in the new form; based on the maximum allowed number of guests.';
$lang['Meeting_guestname_entering_explain'] = 'Enter here the name of your guests. Be sure you enter the prename <b>and</b> the name of your guests. To sign off a guest, delete the row and submit the form.';
後台語系:
language/lang_english/lang_admin.php
// Meeting MOD
$lang['Meeting_add_new'] = 'Add new meeting';
$lang['Meeting_manage'] = 'Manage meetings';
官方下載點:
http://www.oxpus.de/downloads.php?view=detail&id=274
文章: 8535
將此外掛 (目前最新版 1.3.15) 發表至 '非官方認證外掛' 版面.
http://phpbb-tw.net/phpbb/viewtopic.php?t=48708
文章 阿維 »
Meeting Mod 1.3.16 新增的部份 (2007-06-03)
第54行:
$lang['Meeting_user_joins'] = 'registered people';
第86行:
$lang['Meeting_guests'] = '訪客';
第99行:
$lang['Meeting_yes_signons'] = '承諾 ';
第106至113行:
// Email functions
$lang['Meeting_mail'] = 'Send email to all registered people';
$lang['Meeting_mail_subject'] = 'Email subject';
$lang['Meeting_mail_text'] = 'Email message';
$lang['Meeting_mail_to'] = 'Send email to';
$lang['Meeting_mail_all'] = 'all registered people';
$lang['Meeting_mail_sign_yes'] = 'only promised people';
$lang['Meeting_mail_sign_no'] = 'only not promised people';
