[問題]Multiple BBCode MOD 摸不著頭腦
貓星少年
文章: 27
註冊時間: 2002-09-02 21:16
文章 貓星少年 »
## easymod compliant
## MOD Title:    Multiple BBCode MOD
## MOD Author:   Nuttzy99 < nospam@blizzhackers.com > (n/a) http://www.blizzhackers.com
## MOD Description:  Allows you to install BBCode MODs that
##    add quick BBCode buttons in post edits.  Without this
##    MOD, there is no standard way of installing BBCode MODs.
## MOD Version:  1.2.1
## Installation Level:  EASY
## Installation Time:   2 minutes
## Files To Edit:       posting.php
##                      templates/subSilver/posting_body.tpl
## Included Files:      n/a
## Author Notes:
##     + if Multi BBCode MOD v1.0.1 is already installed, use the update to 1.2.0 MOD
##          and do NOT install this MOD script
##     + Works with phpBB 2.0.2 thru 2.0.6
##     + installable with EasyMOD
## MOD History:
##    2003-09-25 - Version 1.2.1
##         + improved MOD Template compliance
##    2003-08-15 - Version 1.2.0
##         + updated for 2.0.6
##         + allows additional hotkeys - Xore did most of the work ;-)
##         + made EasyMOD compatiable
##    2003-02-03 - Version 1.0.1
##         + updated for 2.0.4
##         + no code changes required, just updated the header info
\n##
##    2002-08-31 - Version 1.0.0
##         + initial release
#-----[ OPEN ]---------------------------------
posting.php
#-----[ FIND ]---------------------------------
#  NOTE - the full line to look for is:
# make_jumpbox('viewforum.'.$phpEx);
make_jumpbox(
#-----[ AFTER, ADD ]---------------------------------
// MULTI BBCODE-begin
//NOTE: the first element of each array must be ''   Add new elements AFTER the ''
$EMBB_keys = array('') ;
$EMBB_widths = array('') ;
$EMBB_values = array('') ;
for ($i=1; $i<count($EMBB_values); $i++)
	// load BBcode MODs info
	$val = ($i*2)+16 ;
	$template->assign_block_vars('MultiBB', array(
\n		'KEY' => $EMBB_keys[$i],
		'NAME' => "addbbcode$val",
		'WIDTH' => $EMBB_widths[$i],
		'VALUE' => $EMBB_values[$i],
		'STYLE' => "bbstyle($val)")
// MULTI BBCODE-end
#   NOTE - the complete line to find is:
# function helpline(help) {
function helpline(
// MULTI BBCODE-start
	// put an "n" in front of the value to make it an acceptable variable name
	if ((help == '1') || (help == '2') || (help == '3') || (help == '4') || (help == '5') || (help == '6') || (help == '7') || (help == '8') || (help == '9') || (help == '0'))
		help = 'n' + help ;
// MULTI BBCODE-end
#			  <input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="text-decoration: underline; width: 40px" onClick="bbstyle(16)" onMouseOver="helpline('w')" />
#			  </span></td>
	name="addbbcode16"
	</td>
			<!-- BEGIN MultiBB -->
			<td><span class="genmed">
			  <input type="button" class="button" accesskey="{MultiBB.KEY}" name="{MultiBB.NAME}" value="{MultiBB.VALUE}" style="width: {MultiBB.WIDTH}px" onClick="{MultiBB.STYLE}" onMouseOver="helpline('{MultiBB.KEY}')" />
			  </span></td>
			<!-- END MultiBB -->
#					<select name="addbbcodefontcolor" onChange="bbfontstyle('[color=' + this.form.addbbcodefontcolor.options[this.form.addbbcodefontcolor.selectedIndex].value + ']', '[/color]')" onMouseOver="helpline('s')">
	name="addbbcode18"
#-----[ IN-LINE FIND ]---------------------------------
name="addbbcode18"
#-----[ IN-LINE REPLACE ]---------------------------------
this.form.addbbcode18.options
this.form.addbbcode18.selectedIndex
#					</select>  {L_FONT_SIZE}:<select name="addbbcodefontsize" onChange="bbfontstyle('[size=' + this.form.addbbcodefontsize.options[this.form.addbbcodefontsize.selectedIndex].value + ']', '[/size]')" onMouseOver="helpline('f')">
	name="addbbcode20"
name="addbbcode20"
this.form.addbbcode20.options
this.form.addbbcode20.selectedIndex
#-----[ SAVE/CLOSE ALL FILES ]---------------------------------
# EoM
make_jumpbox(
不明白要怎樣改??多處也是這樣\r
可否幫我整理一下
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
make_jumpbox(
#-----[ 尋找 ]---------------------------------
#  注意 - 這行完整的樣子是:
\n# make_jumpbox('viewforum.'.$phpEx);
make_jumpbox(
~Mac
貓星少年
文章: 27
文章 貓星少年 »
make_jumpbox(
   $val = ($i*2)+16 ;
// MULTI BBCODE-end
是否這樣??
