[外掛] eDoNKeY BBcode (EasyMod)
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 由 Mac »
## EasyMod 0.0.7 Compliant
## MOD Title:   eDoNKeY BBcode
## MOD Version:   1.0.0
## MOD Author:   [H-c] Riva, sica, ch3och3
## Link:   http://www.phpbb.com/phpBB/viewtopic.php?t=12060
## Edited:   Mac < ycl_6@sinamail.com >
## Date:    March 31, 2003
## MOD Description:   Creates eDoNKeY hyperlink
##                         Usage is [ed2k=ed2k://url]text[/ed2k] or ed2k://
## Installation Level:  (easy)
## Installation Time:  5-10 Minutes
## Files To Edit:   5
##                   - includes/bbcode.php
##                   - posting.php
##                   - templates/subSilver/bbcode.tpl
##                   - language/lang_english/lang_main.php
##                   - templates/subSilver/posting_body.tpl
## Included Files:   None
# IMPORTANT: if you are installing manually (without EasyMod) you MUST first
#       install the Multi Quick BBCode Mod (included).
#-----[ OPEN ]--------------------------------
includes/bbcode.php
#-----[ FIND ]---------------------------------
	$bbcode_tpl['url4'] = str_replace('{DESCRIPTION}', '\\\5', $bbcode_tpl['url4']);
#-----[ AFTER, ADD ]-------------------------------
	// The URL replacements codes for the eDonkey Links - eDonkey MOD
	$bbcode_tpl['ed2k'] = str_replace('{URL}', '\\\1', $bbcode_tpl['ed2k']);
	$bbcode_tpl['ed2k'] = str_replace('{DESCRIPTION}', '\\\2', $bbcode_tpl['ed2k']);
	$replacements[] = $bbcode_tpl['url4'];
	// [ed2k=ed2k://url]text[/ed2k] code.
	$patterns[12] = "#\[ed2k=(ed2k://.*?)\](.*?)\[/ed2k\]#si";
	$replacements[12] = $bbcode_tpl['ed2k'];
\n#
	$ret = preg_replace("#([
 ])([a-z0-9\-_.]+?)@([\w\-]+\.([\w\-\.]+\.)*[\w]+)#i", "\\\1<a href=\"mailto:\\\2@\\\3\">\\\2@\\\3</a>", $ret);
	// make the file links clickable - eDonkey MOD
 ])(ed2k://\|file\|(.*)\|\d+\|\w+\|/?)#", "\\\1ed2k (file): <a href=\"\\\2\">\\\3</a>", $ret);
	// make the server links clickable - eDonkey MOD
 ])(ed2k:(//)?\|server\|([\d\.]+)\|(\d+)\|/?)#", "\\\1ed2k (server): <a href=\"\\\2\">\\\4 at \\\5 </a>", $ret);
#-----[ OPEN ]---------------------------------
posting.php
$EMBB_keys = array(''
$EMBB_widths = array(''
$EMBB_values = array(''
#-----[ IN-LINE FIND ]---------------------------------
#-----[ IN-LINE AFTER, ADD ]---------------------------------
,'ed'
,'40'
,'ed2k'
   'L_BBCODE_F_HELP' =>
#-----[ AFTER, ADD ]--------------------------------
	'L_BBCODE_ED_HELP' => $lang['bbcode_ed_help'], // eDoNKeY
## --- NOTE: You will have to make this change to ALL languages that you     ---
## ---       plan to support on your board.  I use "English" as an example   ---
$lang['bbcode_f_help']
#-----[ AFTER, ADD ]---------------------------------
$lang['bbcode_ed_help'] = "ed2k text: [ed2k=ed2k://url]text[/ed2k] (alt+ed)"; // eDonkey
<!-- BEGIN right --><img src="{URL}" border="0" align="right" /><!-- END right -->
<!-- BEGIN ed2k --><a href="{URL}" target="_blank" class="postlink">{DESCRIPTION}</a><!-- END ed2k -->
f_help = "{L_BBCODE_F_HELP}";
ed_help = "{L_BBCODE_ED_HELP}";
# NOTE: the actual line to find is MUCH longer, containing all the bbcode tags
bbtags = new Array(
'[url]','[/url]'
,'[ed2k]','[/ed2k]'
#-----[ SAVE/CLOSE FILES ]---------------------------------
# EoM
只在 2.0.4 上面測試過
使用方法:
[ed2k=ed2k://|file|X-FILES_-_S01-EP01_-_GORGE_PROFONDE_-_VF-FR_by_lara.avi|244610560|871bc271e397d2c85f81e48cc11ef7e4|/]eDoNKeY Test[/ed2k]
[ed2k=ed2k://|file|X-FILES_-_S01-EP01_-_GORGE_PROFONDE_-_VF-FR_by_lara.avi|244610560|871bc271e397d2c85f81e48cc11ef7e4|/]ed2k://|file|X-FILES_-_S01-EP01_-_GORGE_PROFONDE_-_VF-FR_by_lara.avi|244610560|871bc271e397d2c85f81e48cc11ef7e4|/[/ed2k]
~Mac
回到「非官方認證外掛」
