## Hack Title: Always show 'edited by'
## Hack Version: 0.0.3
## Author: Freakin' Booty ;-P
## Description: When a user edits a post, 'edited by' is always shown. Without this MOD, 'edited by' is
## only shown after a reply has been posted.
## Also shows what user exactly has edited the post.
## Compatibility: 2.0.4
## Installation Level: Easy
## Installation Time: 5-10 minutes
## Files To Edit: 3
## includes/constants.php
## includes/functions_post.php
## viewtopic.php
## Included Files: 1
## db_update.php
## History:
## 0.0.3: Fixed a bug where the data is input for the first time.
## 0.0.2: Now shows who exactly has edited the post, and how many times. On top also shows what the last
## post time was.
## 0.0.1: Initial release
## Author Notes:
## 0.0.2 is unreleased, so that is why there are no upgrade instructions or anything.
## Support: http://www.phpbbhacks.com/forums
## Copyright: ?003 Always show 'edited by' 0.0.3 - Freakin' Booty ;-P
## You downloaded this hack from phpBBHacks.com, the #1 source for phpBB related downloads.
## Please visit http://www.phpbbhacks.com/forums for support.
## This hack is released under the GPL License.
## This hack can be freely used, but not distributed, without permission.
## Intellectual Property is retained by the hack author(s) listed above.
###############################################一般情況,會員自己更改過文章,而下面沒有其他回覆的話,是不會顯示回覆次數的,這個外掛就可以就算沒人回覆也可以顯示修改次數
