平台: MS Windows XP Pro SP2 Eng (on FAT32) + IIS 5.1 + PHP 4.4.1 + MySQL 4.1.15 (Essential Package) + phpBB 2.0.18
裝好了各樣的軟件後(大概依上面的次序), 執行 {my domain}/phpBB2/install/install.php 安裝時遇上以下問題
Warning: mysql_connect(): Client does not support authentication protocol requested by server;
consider upgrading MySQL client in ...\phpbb2\db\mysql4.php on line 48
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in
...\phpbb2\db\mysql4.php on line 330
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in
...\phpbb2\db\mysql4.php on line 331
\n
再爬爬文, 發現很多大大都在用 phpMyAdmin 來管理, 也下載了 2.6.4 pl4 及 2.7.0 pl1, 跟著大大們的建議修改了 config.inc.php 後, 也出現同樣的問題, 再以"phpMyAdmin"搜索, 發現了這篇文章, 在 MySQL Command Line Client 登入後, 執行 SET PASSWORD FOR {username}@{hostname} = OLD_PASSWORD('{password}'); (注意大小寫) 就能順利安裝 phpBB
http://phpbb-tw.net/phpbb/viewtopic.php?t=40453
至於phpMyAdmin, 所了以上修正後, 修改了 config.inc.php 成下面的樣子 (只顯示修改的部份), 亦能登入及建立新的戶口, 由於本人把 $cfg['Servers'][$i]['auth_type'] 設成 "http" 時會出現"Not Authorized" 之類的錯誤, 所以改用了 "cookie", 同時亦由於使用cookie, 必須要設定 $cfg['blowfish_secret']
$cfg['PmaAbsoluteUri'] = 'http://{my domain}/phpMyAdmin';
$cfg['blowfish_secret'] = 'XXXXXX'; //任意字串\r
$cfg['Servers'][$i]['host'] = 'localhost'; // MySQL hostname or IP address
$cfg['Servers'][$i]['port'] = ''; // MySQL port - leave blank for default port
$cfg['Servers'][$i]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfg['Servers'][$i]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')
$cfg['Servers'][$i]['extension'] = 'mysql'; // The php MySQL extension to use ('mysql' or 'mysqli')
$cfg['Servers'][$i]['compress'] = FALSE; // Use compressed protocol for the MySQL connection
// (requires PHP >= 4.3.0)
$cfg['Servers'][$i]['controluser'] = 'root'; // MySQL control user settings
// (this user must have read-only
$cfg['Servers'][$i]['controlpass'] = 'xxxxxx'; // access to the "mysql/user"
// and "mysql/db" tables).
// The controluser is also
// used for all relational
// features (pmadb)
$cfg['Servers'][$i]['auth_type'] = 'cookie'; // Authentication method (config, http or cookie based)?
$cfg['Servers'][$i]['user'] = ''; // MySQL user
$cfg['Servers'][$i]['password'] = ''; // MySQL password (only needed
// with 'config' auth_type)
希望小弟的少少分享能夠給其他新手們一點點指引
