[修正]functions.php - 2006/06/09
phpBB Plus Support
godbless
文章: 647
註冊時間: 2002-05-17 06:02
來自: 台北市南京東路4段
文章 由 godbless »
這個升級檔是在升級為2.0.21後,會需要做的多國語言設定修正
原文:http://www.phpbb2.de/ftopic39239.html
It has come to my attention that there may be a bug in this release which will affect those who run a forum with multiple languages installed and in use and lead to the default language being changed under some circumstances.
If this issue is affecting you, the following change should resolve it.
可以到這邊來下載(easymod 0.3.0 測試OK)
http://www.gffclan.com/dload.php?action=file&file_id=9
includes/functions.php
# Line 510
		$board_config['default_lang'] = $default_lang;
		$userdata['user_lang'] = $default_lang;
#-----[ REPLACE WITH ]---------------------------------------------
# Line 513
	elseif ( $board_config['default_lang'] !== $default_lang )
   elseif ( $userdata['user_id'] === ANONYMOUS && $board_config['default_lang'] !== $default_lang )
# Line 524
外掛問題區發問格式就在這裡,請務必一定照著格式來~!
你不照著規則來,就算是神也搞不清楚你的問題在哪裡!
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
回到「phpBB 2 plus 綜合討論」
