圖片:
軟體名稱:QuickTime
版本:6.5
語系:多國語言
系統需求:Mac OS 10.2.5 或更高,Windows 98/2000/Me/XP
公司名稱:Apple Computer, Inc.
下載頁面:http://www.apple.com/quicktime/download
直接下載(Windows XP,Chinese):http://qtinstall.info.apple.com/mickey/ ... taller.exe
軟體說明:對Windows終於有中文版了,下載來玩玩吧!
[推薦]QuickTime 6.5(支援中文也支援窗戶)
Re: [推薦]QuickTime 6.5(支援中文也支援窗
我...我只有在小時候看過QT.........mit 寫:一下子看見中文版的QT還有點不習慣呢Yanzi 寫:
現在用這幾個了...
QuickTime Alternative
http://download.betanews.com/download/1049831315/quicktimealt116.exe (5.14 Mb)
Release Notes:
QuickTime Alternative will allow you to play QuickTime files (.mov, .qt and other extensions) without having to install the official QuickTime Player. As a bonus, Internet Explorer will play all QuickTime movies that are embedded in a webpage. You do need a media player that is capable of playing QuickTime files. The included Media Player Classic supports it and works very well. The QuickTime Browser plugin supports Internet Explorer, Opera, Netscape and Mozilla.
Real Alternative
http://download.betanews.com/download/1054136293/realalt109.exe (4.77 Mb)
Release Notes:
Real Alternative will allow you to play RealMedia files. This way you can play RealMedia files without having to install RealPlayer/RealOne Player. You do need a player that is capable of playing RealMedia. The included Media Player Classic supports it and works very well. Supported: RealAudio (.ra .rpm), RealMedia (.rm .ram .rmvb .rpx .smi .smil), RealText (.rt), ReadPix (.rp), RealMedia embedded in webpages. .smi and .smil files sometimes only play the first part of a clip. This is a limitation of the current Media Player Classic. The Browser plugin supports Internet Explorer, Opera, Netscape and Mozilla.
簡單的說明一下,如果你安裝了上面2套軟體(安裝過程中可以勾選只安裝codec),以後就可以用Windows內附的撥放程式來開啟RM檔或是Qtime的影像檔了,不用再花多餘的時間跟空間去裝REALplayer或Qtime,適合跟我一樣喜歡一套軟體多用途的人(老實說其實是懶惰 ^^")
Nimo Codec Pack 5.0 Build 9 Beta 1
http://hw-driver.nctu.edu.tw/pub/slime/media/Nimo50Build9Beta1.exe
Codec包 , 也是一樣裝了以後就不用再去裝啥Xivd、Divx一大堆亂七八糟的 , 懶惰蟲專用 ( 萬歲~ )
Ps.安裝過程中記得選FULL
- 文章: 1086
- 註冊時間: 2003-10-28 14:50
