請問一下,為什麼我傳到lycos.co.uk的空間,在登入及登出時候都會跑到\r
http://www.tripod.lycos.co.uk/
另外,為什麼我的語法都不能用?像URL、IMG...等都不能
[問題]為什麼我用lycos.co.uk有點問題
[問題]Re: 為什麼我用lycos.co.uk有點問題
Taco0234 寫:請問一下,為什麼我傳到lycos.co.uk的空間,在登入及登出時候都會跑到\r
請問用的是這一段嗎?
http://phpbb-tw.net/phpbb/viewtopic.php?t=14908
把 function redirect 這那一段改成:
~Mac
function redirect($url)
global $db, $board_config;
if (!empty($db))
$db->sql_close();
$server_protocol = ($board_config['cookie_secure']) ? 'https://' : 'http://';
$server_name = preg_replace('#^\/?(.*?)\/?$#', '\1', trim($board_config['server_name']));
$server_port = ($board_config['server_port'] <> 80) ? ':' . trim($board_config['server_port']) : '';
$script_name = preg_replace('#^\/?(.*?)\/?$#', '\1', trim($board_config['script_path']));
$script_name = ($script_name == '') ? $script_name : '/' . $script_name;
//$url = preg_replace('#^\/?(.*?)\/?$#', '/\1', trim($url));
// Redirect via an HTML form for PITA webservers
if (@preg_match('/Microsoft|WebSTAR|Xitami/', getenv('SERVER_SOFTWARE')))
header('Refresh: 0; URL=' . $server_protocol . $server_name . $server_port . $script_name . $url);
echo '<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"><html><head><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"><meta http-equiv="refresh" content="0; url=' . $server_protocol . $server_name . $server_port . $script_name . $url . '"><title>Redirect</title></head><body><div align="center">If your browser does not support meta redirection please click <a href="' . $server_protocol . $server_name . $server_port . $script_name . $url . '">HERE</a> to be redirected</div></body></html>';
exit;
// Behave as per HTTP/1.1 spec for others
//header('Location: ' . $server_protocol . $server_name . $server_port . $script_name . $url);
header('Location: ' . $url);
exit;
