[問題]phpbb could not find image
JamesChiu
註冊時間: 2002-05-29 16:06
來自: Hong Kong
文章 JamesChiu »
Hello all,
Im frist time post on there. Anyone can help me? :oops:
phpbb could not find acators imagic .... I saw the path is wrong.
./html/modules/Forums/images/avatars/[b][color=#1900ff]gallery[/color]/[color=#00ff00]gallery[/color][/b]/xxx.gif
or
./html/[b][color=#1900ff]modules/Forums/images/ranks[/color][/b][b]/[color=#00ff00]modules/Forums/images/ranks[/color][/b]/6stars.gif
Where can i by manual edit the path? I checked Administration Panel>Configuration haven't the path about. :-o
Thank You of Help!!
James Chiu
silverwing
文章: 111
註冊時間: 2002-01-15 15:40
來自: 天涯盡頭
文章 silverwing »
基本組態有檢查過了?
個人頭像儲存路徑
在您 phpBB 2 根目錄底下的路徑, 例如: images/avatars
系統相簿儲存路徑
在您 phpBB 2 根目錄底下的路徑, 例如: images/avatars/gallery
竹貓星球的處女作—phpBB論壇架設寶典。
我手寫我口,讓起落鍵盤的十指,
為我訴盡澎湃心情的點點滴滴……\r
http://www.kidking.idv.tw
http://www.story.club.tw
http://brothers.cnbbs.org
JamesChiu
來自: Hong Kong
文章 JamesChiu »
Yes I checked ..
個人頭像儲存路徑
系統相簿儲存路徑
But I aslo can't disply 個人頭/系統相簿 ...
The link on here : http://www.thejamesvision.com/html/modu ... wtopic&t=1
Thank You
James Chiu
文章 小竹子 »
JamesChiu 寫:Yes I checked ..
個人頭像儲存路徑
系統相簿儲存路徑
Thank You
James Chiu
舉例如下
個人頭像儲存路徑
在您 phpBB 2 根目錄底下的路徑, 例如: images/avatars/japan/1.gif
系統相簿儲存路徑
在您 phpBB 2 根目錄底下的路徑, 例如: images/avatars/gallery1.gif
JamesChiu
來自: Hong Kong
文章 JamesChiu »
Thanks reply ..!!! :)
舉例如下
個人頭像儲存路徑
系統相簿儲存路徑
I think mean that ... But I not mean ... why the problem on the path is "./gallery/gallery All image Pathx2. And I checked not wrong on 根目錄底下的路徑.
Sorry !! I can't try chinese on office and I frist time set the phpnuke with phpBB. Hope you can mean the problem.
You can overview on : http://www.thejamesvision.com/html/modu ... wtopic&t=1
We are learning me by hand edit the problem?
Thank You
James Chiu.
文章 小竹子 »
PHPNUKE的安裝可以參考
http://phpbb-tw.net/phpbb/viewtopic.php?t=5327
剛剛連線到你的NUKE站台發現你的檔案路徑有問題
1.RANKS 無法顯示應該是連結路徑過深\r
http://www.thejamesvision.com/html/modules/Forums/images/ranks/modules/Forums/images/ranks/6stars.gif
2.頭像連結路徑設定錯誤
http://gallery/blank.gif
JamesChiu
來自: Hong Kong
文章 JamesChiu »
也不行. :-?
I've got a double ranks/ranks in the path and don't know where to correct this. As for the double gallery in the path, it should be corrected in the Admin page!?
I had resetup again .... Because Im is useing Hosting service with a mysql plan.
Anymore can fix my problem?
Thank You :)
James Chiu
文章 小竹子 »
你的連結路徑有問題
建議改成
http://www.thejamesvision.com/html/modules/Forums/images/ranks/6stars.gif
2.頭像連結路徑設定錯誤
建議改成
http://www.thejamesvision.com/html/modules/Forums/images/avatars/gallery1.gif
