已經安裝好了!
http://61.62.49.52
問題出再登入之後右邊會出現一堆英文
If this is your first visit, please be sure to check out the FAQ. You will need to register before you can post and use all the features of the Sfzch個人電腦工作室.終極槍神 forums. To view messages, select the forum that you would like to visit from the selection below.
我找不到在哪裡可以把這些英文改掉>"<
麻煩知道的大大教我,感激不盡!
[問題]關於subblack右邊的公告文字
