測試狀況: 裝有文章氣泡的, 會在 pm 使用引言時, 會顯示了html 的
## MOD Title: Allow multiple spaces in posts
## MOD Author: chris_blessing < webguy@330i.net > (Chris Blessing) http://forums.330i.net
## MOD Description: As the title states, it simply allows users to use multiple spaces
## in their posts by inserting the entity as necessary.
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: 1 Minute
## Files To Edit: includes/functions_post.php
## Included Files: n/a
## Author Notes:
## This is a global add-on, no ACP control provided (yet).
## MOD History:
## 2004-04-17 - Version 1.0.0
## - first edition, no ACP yet
$message = bbencode_first_pass($message, $bbcode_uid);
// MOD allow multiple spaces BEGIN
$message = replace_double_spaces($message);
// MOD allow multiple spaces END
function replace_double_spaces($message)
// setup find/replace vars
$nbsp_match = '/ /';
$nbsp_replace = ' ';
// replace all instances of double-spaces with a single space +
$message = preg_replace($nbsp_match, $nbsp_replace, $message);
return $message;
# EoM
