[外掛]主題合併功能(管理選項)
動機不明
喝咖啡的綠皮猴
喝咖啡的綠皮猴
文章: 1179
註冊時間: 2002-03-06 20:37
來自: GOP (重啟)
[外掛]主題合併功能(管理選項)
文章 動機不明 »
前言:phpbb 提供了好用的分割功能,卻缺少了 合併 的功能,這個MOD可以補強不足,讓 管理團隊 多了一個可用的選項。 ;-)
Mod Title: Merge Topic MOD
Mod Version: 1.0.2
Author: Shannado - <sven@shannado.nl> - Sven - http://www.shannado.nl/forumorg
來源:http://www.shannado.nl/forumorg/viewtopic.php?t=20 ←請由此處下載 Merge Topics MOD
開啟 language/lang_english/lang_main.php
搜尋
[php]<?php
// That's all Folks!
?>[/php]
前面加入\r
[php]<?php
// Merge Topic MOD
$lang['Merge'] = 'Merge';
$lang['Topics_Merged'] = 'The selected topics have been merged';
$lang['No_Topics_Merged'] = 'No topics were merged';
$lang['Confirm_merge_topic'] = 'Are you sure you want to merge the selected topic/s?<br><span class=genmed>(Next you will select a target post to merge these into next)</span>';
$lang['Merge_to_forum'] = 'Merge to forum';
$lang['Merge_topic'] = 'Merge this topic';
$lang['Merge_post'] = 'Merge posts in this topic';
$lang['Merge_after'] = 'Merge from selected post';
$lang['Merge_posts'] = 'Merge selected posts';
$lang['Mod_CP_explain'] = 'Using the form below you can perform mass moderation operations on this forum. You can lock, unlock, move, merge or delete any number of topics.';
$lang['Mod_CP_merge_explain'] = 'Select the topic with which the topic/post has to merge';
$lang['Merge_Topic_explain'] = 'Using the form below you can merge posts to a topic, either by selecting the posts individually or by merging at a selected post';
$lang['Merge_post_topic'] = 'Merge posts into a topic';
$lang['Posts_Merged'] = 'The selected posts have been merged';
?>[/php]
開啟 viewtopic.php
搜尋
[php]<?php
$topic_mod .= '<a href="' . append_sid("modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=move"). '"><img src="' . $images['topic_mod_move'] . '" alt="' . $lang['Move_topic'] . '" title="' . $lang['Move_topic'] . '" border="0" /></a> ';
?>[/php]
後面加入\r
[php]<?php
$topic_mod .= '<a href="' . append_sid("modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=mergepost"). '"><img src="' . $images['topic_mod_merge'] . '" alt="' . $lang['Merge_post'] . '" title="' . $lang['Merge_post'] . '" border="0" /></a> ';
?>[/php]
開啟 modcp.php
搜尋
[php]<?php
$unlock = ( isset($HTTP_POST_VARS['unlock']) ) ? TRUE : FALSE;
?>[/php]
後面加入\r
[php]<?php
// Merge topic MOD
$mergetopic = ( isset($HTTP_POST_VARS['mergetopic']) ) ? TRUE : FALSE;
$mergepost = ( isset($HTTP_POST_VARS['mergepost']) ) ? TRUE : FALSE;
// Merge topic MOD
?>[/php]
搜尋
[php]<?php
$mode = 'move';
?>[/php]
後面加入\r
[php]<?php
else if ( $mergetopic )
$mode = 'mergetopic';
else if ( $mergepost )
$mode = 'mergepost';
?>[/php]
搜尋
[php]<?php
case 'lock':
?>[/php]
前面加入\r
[php]<?php
// Merge Topic MOD - Begin
case 'mergetopic':
$page_title = $lang['Mod_CP'];
// this starts after you selected the forum to which the topic will be moved/merged
if ( $merge2 )
$new_forum_id = $HTTP_POST_VARS['new_forum'];
if ( isset($HTTP_POST_VARS['topic_id_list']) )
$topics = $HTTP_POST_VARS['topic_id_list'];
$topic_list = '';
for($i = 0; $i < count($topics); $i++)
$topic_list .= ( ( $topic_list != '' ) ? ', ' : '' ) . $topics[$i];
$hidden_fields .= '<input type="hidden" name="topic_id_list[]" value="' . intval($topics[$i]) . '" />';
$topic_list = $topic_id;
$hidden_fields .= '<input type="hidden" name="' . POST_TOPIC_URL . '" value="' . $topic_id . '" />';
$hidden_fields .= '<input type="hidden" name="' . POST_FORUM_URL . '" value="' . $forum_id . '" />';
$hidden_fields .= '<input type="hidden" name="mode" value="' . $mode . '" />';
$hidden_fields .= '<input type="hidden" name="new_forum" value="' . $new_forum_id . '" />';
$template->assign_block_vars('switch_shadow_topic', array());
$template->assign_vars(array(
'FORUM_NAME' => $forum_name,
'L_MOD_CP' => $lang['Mod_CP'],
'L_MOD_CP_EXPLAIN' => $lang['Mod_CP_merge_explain'],
'L_SELECT' => $lang['Select'],
'L_MERGE' => $lang['Merge'],
'L_TOPICS' => $lang['Topics'],
'L_REPLIES' => $lang['Replies'],
'L_LASTPOST' => $lang['Last_Post'],
'L_LEAVESHADOW' => $lang['Leave_shadow_topic'],
'U_VIEW_FORUM' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"),
'S_HIDDEN_FIELDS' => $hidden_fields,
'S_MODCP_ACTION' => append_sid("modcp.$phpEx"))
'body' => 'modcp_merge_topicpost.tpl')
// Define censored word matches
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
$sql = "SELECT t.*, u.username, u.user_id, p.post_time
FROM " . TOPICS_TABLE . " t, " . USERS_TABLE . " u, " . POSTS_TABLE . " p
WHERE t.forum_id = $new_forum_id
AND t.topic_poster = u.user_id
AND p.post_id = t.topic_last_post_id
AND t.topic_moved_id = 0
AND t.topic_id NOT IN ($topic_list)
ORDER BY t.topic_type DESC, p.post_time DESC
LIMIT $start, " . $board_config['topics_per_page'];
message_die(GENERAL_ERROR, 'Could not obtain topic information', '', __LINE__, __FILE__, $sql);\r
$topic_title = '';
if ( $row['topic_status'] == TOPIC_LOCKED )
$folder_img = $images['folder_locked'];
$folder_alt = $lang['Topic_locked'];
if ( $row['topic_type'] == POST_ANNOUNCE )
$folder_img = $images['folder_announce'];
$folder_alt = $lang['Announcement'];
else if ( $row['topic_type'] == POST_STICKY )
$folder_img = $images['folder_sticky'];
$folder_alt = $lang['Sticky'];
$folder_img = $images['folder'];
$folder_alt = $lang['No_new_posts'];
$topic_id = $row['topic_id'];
$topic_type = $row['topic_type'];
$topic_status = $row['topic_status'];
if ( $topic_type == POST_ANNOUNCE )
$topic_type = $lang['Topic_Announcement'] . ' ';
else if ( $topic_type == POST_STICKY )
$topic_type = $lang['Topic_Sticky'] . ' ';
else if ( $topic_status == TOPIC_MOVED )
$topic_type = $lang['Topic_Moved'] . ' ';
$topic_type = '';
if ( $row['topic_vote'] )
$topic_type .= $lang['Topic_Poll'] . ' ';
$topic_title = $row['topic_title'];
if ( count($orig_word) )
$topic_title = preg_replace($orig_word, $replacement_word, $topic_title);
$u_view_topic = '';
$topic_replies = $row['topic_replies'];
$last_post_time = create_date($board_config['default_dateformat'], $row['post_time'], $board_config['board_timezone']);
$template->assign_block_vars('topicrow', array(
'U_VIEW_TOPIC' => $u_view_topic,
'TOPIC_FOLDER_IMG' => $folder_img,
'TOPIC_TYPE' => $topic_type,
'TOPIC_TITLE' => $topic_title,
'REPLIES' => $topic_replies,
'LAST_POST_TIME' => $last_post_time,
'TOPIC_ID' => $topic_id,
'L_TOPIC_FOLDER_ALT' => $folder_alt)
'PAGINATION' => generate_pagination("modcp.$phpEx?" . POST_FORUM_URL . "=$forum_id", $forum_topics, $board_config['topics_per_page'], $start),
'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / $board_config['topics_per_page'] ) + 1 ), ceil( $forum_topics / $board_config['topics_per_page'] )),
'L_GOTO_PAGE' => $lang['Goto_page'])
$template->pparse('body');
// After you selected the topic to merge with
else if ( $confirm )
// $leave_shadow = ( $HTTP_POST_VARS['merge_leave_shadow'] ) ? TRUE : 0;
if ( empty($HTTP_POST_VARS['topic_id_to']) )
message_die(GENERAL_MESSAGE, $lang['None_selected']);
$topic_id_to = $HTTP_POST_VARS['topic_id_to'];
$old_forum_id = $forum_id;
if ( $topic_id != $topic_id_to )
$topics = ( isset($HTTP_POST_VARS['topic_id_list']) ) ? $HTTP_POST_VARS['topic_id_list'] : array($topic_id);
$topic_list = '';
$sql = "SELECT *
WHERE topic_id IN ($topic_list)
AND topic_status <> " . TOPIC_MOVED;
if ( !($result = $db->sql_query($sql, BEGIN_TRANSACTION)) )
message_die(GENERAL_ERROR, 'Could not select from topic table', '', __LINE__, __FILE__, $sql);
$row = $db->sql_fetchrowset($result);
$db->sql_freeresult($result);
for($i = 0; $i < count($row); $i++)
$topic_id = $row[$i]['topic_id'];
if ( isset($HTTP_POST_VARS['merge_leave_shadow']) )
// Insert topic in the old forum that indicates that the forum has moved.
$sql = "INSERT INTO " . TOPICS_TABLE . " (forum_id, topic_title, topic_poster, topic_time, topic_status, topic_type, topic_vote, topic_views, topic_replies, topic_first_post_id, topic_last_post_id, topic_moved_id)
VALUES ($old_forum_id, '" . addslashes(str_replace("\'", "''", $row[$i]['topic_title'])) . "', '" . str_replace("\'", "''", $row[$i]['topic_poster']) . "', " . $row[$i]['topic_time'] . ", " . TOPIC_MOVED . ", " . POST_NORMAL . ", " . $row[$i]['topic_vote'] . ", " . $row[$i]['topic_views'] . ", " . $row[$i]['topic_replies'] . ", " . $row[$i]['topic_first_post_id'] . ", " . $row[$i]['topic_last_post_id'] . ", $topic_id_to)";
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, 'Could not insert shadow topic', '', __LINE__, __FILE__, $sql);
$sql = "DELETE
WHERE topic_id = $topic_id";
message_die(GENERAL_ERROR, 'Could not delete old topic', '', __LINE__, __FILE__, $sql);
$sql = "UPDATE " . POSTS_TABLE . "
SET forum_id = $new_forum_id, topic_id = $topic_id_to
message_die(GENERAL_ERROR, 'Could not update post topic ids', '', __LINE__, __FILE__, $sql);
// Sync the forum indexes
sync('forum', $new_forum_id);
sync('forum', $old_forum_id);
sync('topic', $topic_id_to);
$message = $lang['Topics_Merged'] . '<br /><br />';
$message = $lang['No_Topics_Merged'] . '<br /><br />';
if ( !empty($topic_id) )
$redirect_page = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id_to");
$message .= sprintf($lang['Click_return_topic'], '<a href="' . $redirect_page . '">', '</a>');
$redirect_page = append_sid("modcp.$phpEx?" . POST_FORUM_URL . "=$forum_id");
$message .= sprintf($lang['Click_return_modcp'], '<a href="' . $redirect_page . '">', '</a>');
$message = $message . '<br \><br \>' . sprintf($lang['Click_return_forum'], '<a href="' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$old_forum_id") . '">', '</a>');
'META' => '<meta http-equiv="refresh" content="3;url=' . $redirect_page . '">')
// Here you select the forum is has to merge to
if ( empty($HTTP_POST_VARS['topic_id_list']) && empty($topic_id) )
$hidden_fields = '<input type="hidden" name="mode" value="' . $mode . '" /><input type="hidden" name="' . POST_FORUM_URL . '" value="' . $forum_id . '" />';
// Set template files
'movetopic' => 'modcp_merge_topic.tpl')
'MESSAGE_TITLE' => $lang['Confirm'],
'MESSAGE_TEXT' => $lang['Confirm_merge_topic'],
'L_MERGE_TO_FORUM' => $lang['Merge_to_forum'],
'L_YES' => $lang['Yes'],
'L_NO' => $lang['No'],
'S_FORUM_SELECT' => make_forum_select('new_forum'),
'S_MODCP_ACTION' => append_sid("modcp.$phpEx"),
'S_HIDDEN_FIELDS' => $hidden_fields)
$template->pparse('movetopic');
break;
case 'mergepost':
if ( $confirm )
$new_forum_id = $HTTP_POST_VARS['new_forum_id'];
$posts = $HTTP_POST_VARS['post_id_list'];
$sql = "SELECT poster_id, topic_id, post_time
FROM " . POSTS_TABLE . "
WHERE post_id = " . $posts[0];
message_die(GENERAL_ERROR, 'Could not get post information', '', __LINE__, __FILE__, $sql);
$post_rowset = $db->sql_fetchrow($result);
$post_time = $post_rowset['post_time'];
if( !empty($HTTP_POST_VARS['merge_type_all']) )
$post_id_sql = '';
for($i = 0; $i < count($posts); $i++)
$post_id_sql .= ( ( $post_id_sql != '' ) ? ', ' : '' ) . $posts[$i];
SET topic_id = $topic_id_to, forum_id = $new_forum_id
WHERE post_id IN ($post_id_sql)";
else if( !empty($HTTP_POST_VARS['merge_type_beyond']) )
WHERE post_time >= $post_time\r
AND topic_id = $topic_id";
if( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, 'Could not update posts table', '', __LINE__, __FILE__, $sql);
sync('topic', $topic_id);
'META' => '<meta http-equiv="refresh" content="3;url=' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id") . '">')
$message = $lang['Posts_Merged'] . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id") . '">', '</a>');
// Step 1 - Pic topic to merge to
else if ( isset($HTTP_POST_VARS['merge_type_all']) || isset($HTTP_POST_VARS['merge_type_beyond']) )
if ( isset($HTTP_POST_VARS['post_id_list']) )
$posts_list = '';
$posts_list .= ( ( $posts_list != '' ) ? ', ' : '' ) . $posts[$i];
$hidden_fields .= '<input type="hidden" name="post_id_list[]" value="' . intval($posts[$i]) . '" />';
$posts_list = $post_id;
$hidden_fields .= '<input type="hidden" name="' . POST_POST_URL . '" value="' . $post_id . '" />';
$hidden_fields .= '<input type="hidden" name="new_forum_id" value="' . $new_forum_id . '" />';
$hidden_fields .= '<input type="hidden" name="merge_type_all" value="' . $HTTP_POST_VARS['merge_type_all'] . '" />';
$hidden_fields .= '<input type="hidden" name="merge_type_beyond" value="' . $HTTP_POST_VARS['merge_type_beyond'] . '" />';
'L_MOD_CP_EXPLAIN' => $lang['Mod_CP_explain'],
//AND t.topic_id NOT IN ($topic_list)
AND t.topic_id != $topic_id
$topic_title = '';
$topic_type = '';
$u_view_topic = '';
{ // Step 0 - select the post you want to merge
'merge_post_body' => 'modcp_merge_post.tpl')
$sql = "SELECT u.username, p.*, pt.post_text, pt.bbcode_uid, pt.post_subject, p.post_username
FROM " . POSTS_TABLE . " p, " . USERS_TABLE . " u, " . POSTS_TEXT_TABLE . " pt
WHERE p.topic_id = $topic_id
AND p.poster_id = u.user_id
AND p.post_id = pt.post_id
ORDER BY p.post_time ASC";
message_die(GENERAL_ERROR, 'Could not get topic/post information', '', __LINE__, __FILE__, $sql);
$s_hidden_fields = '<input type="hidden" name="' . POST_FORUM_URL . '" value="' . $forum_id . '" /><input type="hidden" name="mode" value="mergepost" />';
$s_hidden_fields .= '<input type="hidden" name="' . POST_TOPIC_URL . '" value="' . $topic_id . '" />';
if( ( $total_posts = $db->sql_numrows($result) ) > 0 )
$postrow = $db->sql_fetchrowset($result);
'L_MERGE_TOPIC' => $lang['Merge_Topic'],
'L_MERGE_TOPIC_EXPLAIN' => $lang['Merge_Topic_explain'],
'L_AUTHOR' => $lang['Author'],
'L_MESSAGE' => $lang['Message'],
'L_MERGE_POST_TOPIC' => $lang['Merge_post_topic'],
'L_POSTED' => $lang['Posted'],
'L_MERGE_POSTS' => $lang['Merge_posts'],
'L_SUBMIT' => $lang['Submit'],
'L_MERGE_AFTER' => $lang['Merge_after'],
'L_MARK_ALL' => $lang['Mark_all'],
'L_UNMARK_ALL' => $lang['Unmark_all'],
'L_POST' => $lang['Post'],
'S_MERGE_ACTION' => append_sid("modcp.$phpEx"),
'S_HIDDEN_FIELDS' => $s_hidden_fields,
'S_FORUM_SELECT' => make_forum_select("new_forum_id"))
for($i = 0; $i < $total_posts; $i++)
$post_id = $postrow[$i]['post_id'];
$poster_id = $postrow[$i]['user_id'];
$poster = $postrow[$i]['username'];
$post_date = create_date($board_config['default_dateformat'], $postrow[$i]['post_time'], $board_config['board_timezone']);
$bbcode_uid = $postrow[$i]['bbcode_uid'];
$message = $postrow[$i]['post_text'];
$post_subject = ( $postrow[$i]['post_subject'] != '' ) ? $postrow[$i]['post_subject'] : $topic_title;
// If the board has HTML off but the post has HTML
// on then we process it, else leave it alone
if ( !$board_config['allow_html'] )
if ( $postrow[$i]['enable_html'] )
$message = preg_replace('#(<)([\/]?.*?)(>)#is', '<\\\2>', $message);
if ( $bbcode_uid != '' )
$message = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($message, $bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $message);
$post_subject = preg_replace($orig_word, $replacement_word, $post_subject);
$message = preg_replace($orig_word, $replacement_word, $message);
$message = make_clickable($message);
if ( $board_config['allow_smilies'] && $postrow[$i]['enable_smilies'] )
$message = smilies_pass($message);
$message = str_replace("
", '<br />', $message);
$checkbox = ( $i > 0 ) ? '<input type="checkbox" name="post_id_list[]" value="' . $post_id . '" />' : ' ';
$template->assign_block_vars('postrow', array(
'ROW_CLASS' => $row_class,
'POSTER_NAME' => $poster,
'POST_DATE' => $post_date,
'POST_SUBJECT' => $post_subject,
'MESSAGE' => $message,
'POST_ID' => $post_id,
'S_MERGE_CHECKBOX' => $checkbox)
$template->pparse('merge_post_body');
break;
// Merge Topic MOD - End
?>[/php]
搜尋
[php]<?php
?>[/php]
後面加入\r
[php]<?php
?>[/php]
開啟 templates/subSilver/subSilver.cfg
搜尋
[php]<?php
$images['topic_mod_move'] = "$current_template_images/topic_move.gif";
?>[/php]
後面加入\r
[php]<?php
$images['topic_mod_merge'] = "$current_template_images/topic_merge.gif";
?>[/php]
開啟 templates/subSilver/modcp_body.tpl
搜尋
		<input type="submit" name="move" class="liteoption" value="{L_MOVE}" />
後面加入\r
		<input type="submit" name="mergetopic" class="liteoption" value="{L_MERGE}" />
上傳附加檔案:modcp_merge_post.tpl, modcp_merge_topic.tpl & modcp_merge_topicpost.tpl 到 /template/subSilver/
下面是我翻譯的中文語系,自覺翻的頗差,若有辭不達意的情形煩請幫忙重翻,我也好修正,謝謝!
[php]<?php
// Merge Topic MOD
$lang['Merge'] = '合併';
$lang['Topics_Merged'] = '選擇的主題已被合併';
$lang['No_Topics_Merged'] = '沒有主題被合併';
$lang['Confirm_merge_topic'] = '確定你要合併選擇的主題嗎?<br><span class=genmed>(確定之後請選擇被指定的合併文章)</span>';
$lang['Merge_to_forum'] = '合併至討論區';
$lang['Merge_topic'] = '合併這主題';
$lang['Merge_post'] = '合併這主題的文章';
$lang['Merge_after'] = '從指定的文章合併';
$lang['Merge_posts'] = '合併選擇的文章';
$lang['Mod_CP_explain'] = '使用合併的功能之前,你必須對這討論區擁有板主的權限. 你可以鎖定, 解鎖, 移動, 合併或刪除任何文章.';
$lang['Mod_CP_merge_explain'] = '選擇這個主題內的 文章 合併';
$lang['Merge_Topic_explain'] = '你可以對這主題內的文章使用合併的功能, 選擇好後再選擇另一主題即可進行合併';
$lang['Merge_post_topic'] = '主題合併控制台';
$lang['Posts_Merged'] = '選擇的文章已被合併';
?>[/php]
儲存所有檔案
完工!
(安裝成功之後,會出現在[移動]、[分割]、[刪除]等選項之中,時間晚了,我來不及放DEMO圖,請見諒 :-? )
七點要求:
1. 發問前先搜尋,確定沒有重複後再發表
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
cater
文章: 52
註冊時間: 2002-07-02 17:10
來自: 電腦前的cater
文章 cater »
感謝河風 呵........這個外掛不錯\r
一次成功.....o(^_^)o
谷雨
文章: 45
註冊時間: 2002-01-13 05:55
來自: 失落的天堂
文章 谷雨 »
呵,不錯的東東,明天來試試!
當你走到左邊,發現右邊才是你要的天堂時
  一切是痛苦的.........
http://books.4partners.com/
jackyilk
文章: 538
註冊時間: 2002-07-21 18:55
來自: 台灣
文章 jackyilk »
一次完成 謝謝分享
chadav
竹貓好朋友
竹貓好朋友
文章: 65
註冊時間: 2002-07-04 21:04
文章 chadav »
感謝分享!! 一次成功!!
克服自我是最大的挑戰
動機不明
喝咖啡的綠皮猴
喝咖啡的綠皮猴
文章: 1179
來自: GOP (重啟)
文章 動機不明 »
呵~
大家都一次成功啊?
好高興 ;) (我也是一次成功喔~)
七點要求:
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
MelonKing
文章: 47
註冊時間: 2002-07-02 20:47
文章 MelonKing »
很棒滴功能,安裝也很簡單!!
偶也是一次成功唷^^
涼風有訊,秋月無邊,虧我思嬌的情緒好比度日如年!
雖然我不是玉樹臨風、瀟灑倜儻,但我有廣闊的胸襟加強健的臂彎!
回到「非官方認證外掛」
