[問題]非常感谢依夢前辈!!!
jikey
文章: 90
註冊時間: 2003-09-18 00:49
文章 由 jikey »
大竹新手 寫:
jikey 寫:我理得他!
大馬很少人用phpbb的所以要交流一下.
http://www.freetalkarea.com/phpBB2/downloads.php?cat=4 <-- joe version 有shop, bank and cash mod.
谢谢你提供的西 :mrgreen: ,我去看了,不过我只想安依前辈整理的水怪RPG,如他所说,分散安我真的不了 :-| ,毕竟我是新手~
还以为这里只有台湾人民和香港的 ;-)
大人的确很少用phpbb架式论。
方便给我你的网址吗?
大&#39532;竹&#2
文章: 32
註冊時間: 2004-01-11 04:46
來自: malaysia
文章 由 大&#39532;竹&#2 »
进入搶匪有限公司出现:
無法取得保鑣列表!!
SQL Error : 1146 Table 'blueskyphp.phpbb_rpg_bodyguard' doesn't exist
SELECT u.username, u.user_posts, b.bodyguard_salary, b.invite_time, b.yes_or_no FROM phpbb_users u, phpbb_rpg_bodyguard b WHERE u.user_id = b.to_id and b.from_id = 3 ORDER BY b.invite_time DESC
Line : 855
进入水怪大陸銀行:
無法取得匯款記錄!!
SQL Error : 1146 Table 'blueskyphp.phpbb_rpg_event' doesn't exist
SELECT * FROM phpbb_rpg_event WHERE event_class = 3 AND user_id = 3 ORDER BY event_time DESC LIMIT 0, 50
Line : 164
大&#39532;竹&#2
文章: 32
來自: malaysia
进入排工列表:
无法取得排班列表!!
SQL Error : 1146 Table 'blueskyphp.phpbb_rpg_joinjobs' doesn't exist
SELECT w.job_name, u.username, j.join_time FROM phpbb_rpg_joinjobs j, phpbb_users u, phpbb_rpg_jobs w WHERE j.in_which_store = 0 AND w.in_which_store = 0 AND j.user_id = u.user_id AND j.job_id = w.job_id ORDER BY j.job_id, j.join_time LIMIT 0, 30
水怪道具店:
無法取得商品列表!!
SQL Error : 1146 Table 'blueskyphp.phpbb_rpg_items' doesn't exist
SELECT * FROM phpbb_rpg_items WHERE in_which_store = 0 ORDER BY item_id
Line : 527
Line : 60
職業考照檢定:
無法取得基礎職照資料!!
SQL Error : 1146 Table 'blueskyphp.phpbb_rpg_position' doesn't exist
SELECT MAX(position_order) as base_top FROM phpbb_rpg_position WHERE position_class = 0
Line : 114
大&#39532;竹&#2
文章: 32
來自: malaysia
Could not obtain post/user information.
SQL Error : 1054 Unknown column 'u.user_robfail' in 'field list'
SELECT u.username, u.user_money, u.user_id, u.user_posts, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile,u.user_robfail, u.rpg_level, u.rpg_cur_hp, u.rpg_max_hp, u.rpg_cur_mp, u.rpg_max_mp, u.rpg_cur_exp, u.rpg_max_exp, u.rpg_attack, u.rpg_defense, u.rpg_magic, u.rpg_speed, u.rpg_medals, p.*, pt.post_text, pt.post_subject, pt.bbcode_uid FROM phpbb_posts p, phpbb_users u, phpbb_posts_text pt WHERE p.topic_id = 125 AND pt.post_id = p.post_id AND u.user_id = p.poster_id ORDER BY p.post_time ASC LIMIT 0, 15
Line : 397
File : C:\Domains\blueskyphp.uni.cc\wwwroot\viewtopic.php
其他主题给不能进去了!
吉川拓也
文章: 1215
註冊時間: 2003-02-09 18:24
來自: [ G.I.T ]
文章 由 吉川拓也 »
你水怪的SQL有執行了嗎 ?
如果沒有執行出現以上錯誤是正確的 ..
你可以嘗試一個一個SQL新增加看看 !!
善用 搜尋 可以解決您 90% 的問題
頭腦清晰,選擇正確。 (╯▔︹▔)╯~╘═╛
大&#39532;竹&#2
文章: 32
來自: malaysia
吉川拓也 寫:你水怪的SQL有執行了嗎 ?
如果沒有執行出現以上錯誤是正確的 ..
执行时出现了怪怪的华文字体,可是不是乱码。
那边只提供一个完全版本SQL而已~
GeniusKiKi
文章: 1086
註冊時間: 2003-10-28 14:50
文章 由 GeniusKiKi »
怪怪的華文字體?
也許您可以使用複製貼上
將他張貼到此給其他朋友參考
再也不當爛好人...
好人是小白轉型成大白的墊腳石...
文章 由 依夢兒 »
StickyKid 寫:另外回答一下...依夢兒是男兒身~XD
沒關係啦,我已經習慣了....XD
而且網路上本來就是不分國籍和性別的....XD
大马竹猫新手 寫:SQL Error : 1146 Table 'blueskyphp.phpbb_rpg_joinjobs' doesn't exist
blueskyphp. ....?
請問您的 phpBB 版本是藍色的天空嗎?
我在釋出水怪 RPG 完整版之前,只有在安裝過 Cash Mod 外掛的 phpBB 2.0.6 上安裝測試無誤。
所以我只能夠保證水怪 RPG 完整版與 phpBB 2.0.6 的相容性沒有問題。
至於像是「藍色的天空」這一類屬於自行整合的 Hacks phpBB 的相容性,我就不敢保證了,這一點請您瞭解。
又,壓縮檔內的 SQL.sql 是以資料庫開頭為 phpbb_xxxx 所撰寫的,例如 phpbb_config ,這是大多數 phpBB 玩家的預設值。
看來您的 phpBB 的資料庫開頭是 blueskyphp.phpbb_xxxx ,例如 blueskyphp.phpbb_config ,是嗎?
這樣您是無法將 SQL.sql 的內容新增至您的資料庫中喲!
我從您張貼的錯誤訊息研判,您應該還沒有順利的將遊戲需要的資料庫數據新增至您的資料庫中,所以才會錯誤連連。
請自行將 SQL.sql 內的 phpbb_ 改成 blueskyphp.phpbb_ 後,再新增至資料庫中。
以第一句為範例:
# 頭彩
INSERT INTO phpbb_config VALUES("rpg_jackpot", "100000");
請改成:
# 頭彩
INSERT INTO blueskyphp.phpbb_config VALUES("rpg_jackpot", "100000");
大&#39532;竹&#2
文章: 32
來自: malaysia
哦,不是蓝天空,那个是我自己付费的空间,然后自己安装下去phpbb的~给你看看
$table_prefix = 'phpbb_';
define('PHPBB_INSTALLED', false);
那可以重复执行吗?你提供的sql,还是必须斩掉资料库~不要 T.T
我试修改成blueskyphp.phpbb看先,不过为何没有修改前安装,赛马和赌博既然可以玩?奇怪
文章 由 依夢兒 »
大马竹猫新手 寫:$table_prefix = 'phpbb_';
怪了,你現在又說你資料庫 $table_prefix 是 phpbb_ ,
怎麼之前錯誤訊息內會出現 blueskyphp.phpbb_ 呢?
你先看一下你的資料庫內的 table 是什麼開頭。
如果是 blueskyphp.phpbb_ ,例如 blueskyphp.phpbb_config , blueskyphp.phpbb_ ,
你就照我前面所說的,先修改 SQL.sql 的內容,再重新執行一次。
如果已經有新增至資料庫內的部份,就跳過不要執行。
s80022
文章: 19
註冊時間: 2003-02-14 07:31
文章 由 s80022 »
搜尋:
SQL.txt
刪除:
ADD `user_bank` int(11) unsigned NOT NULL default '0',
就可以了
jikey
文章: 90
文章 由 jikey »
請問我可以安裝只是赛和赌博而已嗎?
GeniusKiKi
文章: 1086
文章 由 GeniusKiKi »
水怪什麼時候有  了~一.一||
再也不當爛好人...
好人是小白轉型成大白的墊腳石...
jikey
文章: 90
文章 由 jikey »
GeniusKiKi 寫:水怪什麼時候有  了~一.一||
:-o 可是我玩過理~
水怪賽馬遊戲\r
是不是跑馬是另一個mod?
文章 由 依夢兒 »
水怪有賽馬,沒錯啊....
安裝後,把不要開放的單元連結拿掉就行了。
