只是又變成231行的問題了
// Make admin a user (if already admin) ... ignore if you're trying
// to change yourself from an admin to user!
if ( $userdata['user_id'] != $user_id )
$sql = "UPDATE " . AUTH_ACCESS_TABLE . "
SET auth_view = 0, auth_read = 0, auth_post = 0, auth_reply = 0, auth_edit = 0, auth_delete = 0, auth_sticky = 0, auth_announce = 0
, auth_globalannounce = 0WHERE group_id = $group_id";
message_die(GENERAL_ERROR, 'Could not update auth access', '', __LINE__, __FILE__, $sql);
// Update users level, reset to USER
SET user_level = " . USER . "
WHERE user_id = $user_id";
