[教學] attach_mod_v237 成功安裝法分享
[問題]為什麼我安裝後會出現這麼多error!
Running :: CREATE TABLE phpbb_attachments_config ( config_name varchar(255) NOT NULL, config_value varchar(255) NOT NULL, PRIMARY KEY (config_name) ) -> FAILED ---> Table 'phpbb_attachments_config' already exists
Running :: CREATE TABLE phpbb_forbidden_extensions ( ext_id mediumint(8) UNSIGNED NOT NULL auto_increment, extension varchar(100) NOT NULL, PRIMARY KEY (ext_id) ) -> FAILED ---> Table 'phpbb_forbidden_extensions' already exists
Running :: CREATE TABLE phpbb_extension_groups ( group_id mediumint(8) NOT NULL auto_increment, group_name char(20) NOT NULL, cat_id tinyint(2) DEFAULT '0' NOT NULL, allow_group tinyint(1) DEFAULT '0' NOT NULL, download_mode tinyint(1) UNSIGNED DEFAULT '1' NOT NULL, upload_icon varchar(100) DEFAULT '', max_filesize int(20) DEFAULT '0' NOT NULL, forum_permissions varchar(255) default '' NOT NULL, PRIMARY KEY group_id (group_id) ) -> FAILED ---> Table 'phpbb_extension_groups' already exists
Running :: CREATE TABLE phpbb_extensions ( ext_id mediumint(8) UNSIGNED NOT NULL auto_increment, group_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, extension varchar(100) NOT NULL, comment varchar(100), PRIMARY KEY ext_id (ext_id) ) -> FAILED ---> Table 'phpbb_extensions' already exists
Running :: CREATE TABLE phpbb_attachments_desc ( attach_id mediumint(8) UNSIGNED NOT NULL auto_increment, physical_filename varchar(255) NOT NULL, real_filename varchar(255) NOT NULL, download_count mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, comment varchar(255), extension varchar(100), mimetype varchar(100), filesize int(20) NOT NULL, filetime int(11) DEFAULT '0' NOT NULL, thumbnail tinyint(1) DEFAULT '0' NOT NULL, PRIMARY KEY (attach_id), KEY filetime (filetime), KEY physical_filename (physical_filename(10)), KEY filesize (filesize) ) -> FAILED ---> Table 'phpbb_attachments_desc' already exists
Running :: CREATE TABLE phpbb_attachments ( attach_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, post_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, privmsgs_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, user_id_1 mediumint(8) NOT NULL, user_id_2 mediumint(8) NOT NULL, KEY attach_id_post_id (attach_id, post_id), KEY attach_id_privmsgs_id (attach_id, privmsgs_id) ) -> FAILED ---> Table 'phpbb_attachments' already exists
Running :: CREATE TABLE phpbb_quota_limits ( quota_limit_id mediumint(8) unsigned NOT NULL auto_increment, quota_desc varchar(20) NOT NULL default '', quota_limit bigint(20) unsigned NOT NULL default '0', PRIMARY KEY (quota_limit_id) ) -> FAILED ---> Table 'phpbb_quota_limits' already exists
Running :: CREATE TABLE phpbb_attach_quota ( user_id mediumint(8) unsigned NOT NULL default '0', group_id mediumint(8) unsigned NOT NULL default '0', quota_type smallint(2) NOT NULL default '0', quota_limit_id mediumint(8) unsigned NOT NULL default '0', KEY quota_type (quota_type) ) -> FAILED ---> Table 'phpbb_attach_quota' already exists
Running :: ALTER TABLE phpbb_forums ADD auth_download TINYINT(2) DEFAULT '0' NOT NULL -> FAILED ---> Duplicate column name 'auth_download'
Running :: ALTER TABLE phpbb_auth_access ADD auth_download TINYINT(1) DEFAULT '0' NOT NULL -> FAILED ---> Duplicate column name 'auth_download'
Running :: ALTER TABLE phpbb_posts ADD post_attachment TINYINT(1) DEFAULT '0' NOT NULL -> FAILED ---> Duplicate column name 'post_attachment'
Running :: ALTER TABLE phpbb_topics ADD topic_attachment TINYINT(1) DEFAULT '0' NOT NULL -> FAILED ---> Duplicate column name 'topic_attachment'
Running :: ALTER TABLE phpbb_privmsgs ADD privmsgs_attachment TINYINT(1) DEFAULT '0' NOT NULL -> FAILED ---> Duplicate column name 'privmsgs_attachment'
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('upload_dir','files') -> FAILED ---> Duplicate entry 'upload_dir' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('upload_img','images/icon_clip.gif') -> FAILED ---> Duplicate entry 'upload_img' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('topic_icon','images/icon_clip.gif') -> FAILED ---> Duplicate entry 'topic_icon' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('display_order','0') -> FAILED ---> Duplicate entry 'display_order' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_filesize','262144') -> FAILED ---> Duplicate entry 'max_filesize' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('attachment_quota','52428800') -> FAILED ---> Duplicate entry 'attachment_quota' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_filesize_pm','262144') -> FAILED ---> Duplicate entry 'max_filesize_pm' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_attachments','3') -> FAILED ---> Duplicate entry 'max_attachments' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_attachments_pm','1') -> FAILED ---> Duplicate entry 'max_attachments_pm' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('disable_mod','0') -> FAILED ---> Duplicate entry 'disable_mod' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('allow_pm_attach','1') -> FAILED ---> Duplicate entry 'allow_pm_attach' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('attachment_topic_review','0') -> FAILED ---> Duplicate entry 'attachment_topic_review' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('allow_ftp_upload','0') -> FAILED ---> Duplicate entry 'allow_ftp_upload' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('show_apcp','0') -> FAILED ---> Duplicate entry 'show_apcp' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('attach_version','2.3.10') -> FAILED ---> Duplicate entry 'attach_version' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('default_upload_quota', '0') -> FAILED ---> Duplicate entry 'default_upload_quota' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('default_pm_quota', '0') -> FAILED ---> Duplicate entry 'default_pm_quota' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_server','') -> FAILED ---> Duplicate entry 'ftp_server' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_path','') -> FAILED ---> Duplicate entry 'ftp_path' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('download_path','') -> FAILED ---> Duplicate entry 'download_path' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_user','') -> FAILED ---> Duplicate entry 'ftp_user' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_pass','') -> FAILED ---> Duplicate entry 'ftp_pass' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_pasv_mode','1') -> FAILED ---> Duplicate entry 'ftp_pasv_mode' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_display_inlined','1') -> FAILED ---> Duplicate entry 'img_display_inlined' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_max_width','0') -> FAILED ---> Duplicate entry 'img_max_width' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_max_height','0') -> FAILED ---> Duplicate entry 'img_max_height' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_link_width','0') -> FAILED ---> Duplicate entry 'img_link_width' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_link_height','0') -> FAILED ---> Duplicate entry 'img_link_height' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_create_thumbnail','0') -> FAILED ---> Duplicate entry 'img_create_thumbnail' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_min_thumb_filesize','12000') -> FAILED ---> Duplicate entry 'img_min_thumb_filesize' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_imagick', '') -> FAILED ---> Duplicate entry 'img_imagick' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('use_gd2','0') -> FAILED ---> Duplicate entry 'use_gd2' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('wma_autoplay','0') -> FAILED ---> Duplicate entry 'wma_autoplay' for key 1
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('flash_autoplay','0') -> FAILED ---> Duplicate entry 'flash_autoplay' for key 1
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (1,'php') -> FAILED ---> Duplicate entry '1' for key 1
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (2,'php3') -> FAILED ---> Duplicate entry '2' for key 1
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (3,'php4') -> FAILED ---> Duplicate entry '3' for key 1
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (4,'phtml') -> FAILED ---> Duplicate entry '4' for key 1
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (5,'pl') -> FAILED ---> Duplicate entry '5' for key 1
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (6,'asp') -> FAILED ---> Duplicate entry '6' for key 1
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (7,'cgi') -> FAILED ---> Duplicate entry '7' for key 1
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (1,'Images',1,1,1,'',0,'') -> FAILED ---> Duplicate entry '1' for key 1
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (2,'Archives',0,1,1,'',0,'') -> FAILED ---> Duplicate entry '2' for key 1
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (3,'Plain Text',0,0,1,'',0,'') -> FAILED ---> Duplicate entry '3' for key 1
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (4,'Documents',0,0,1,'',0,'') -> FAILED ---> Duplicate entry '4' for key 1
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (5,'Real Media',0,0,2,'',0,'') -> FAILED ---> Duplicate entry '5' for key 1
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (6,'Streams',2,0,1,'',0,'') -> FAILED ---> Duplicate entry '6' for key 1
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (7,'Flash Files',3,0,1,'',0,'') -> FAILED ---> Duplicate entry '7' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (1, 1,'gif', '') -> FAILED ---> Duplicate entry '1' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (2, 1,'png', '') -> FAILED ---> Duplicate entry '2' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (3, 1,'jpeg', '') -> FAILED ---> Duplicate entry '3' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (4, 1,'jpg', '') -> FAILED ---> Duplicate entry '4' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (5, 1,'tif', '') -> FAILED ---> Duplicate entry '5' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (6, 1,'tga', '') -> FAILED ---> Duplicate entry '6' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (7, 2,'gtar', '') -> FAILED ---> Duplicate entry '7' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (8, 2,'gz', '') -> FAILED ---> Duplicate entry '8' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (9, 2,'tar', '') -> FAILED ---> Duplicate entry '9' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (10, 2,'zip', '') -> FAILED ---> Duplicate entry '10' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (11, 2,'rar', '') -> FAILED ---> Duplicate entry '11' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (12, 2,'ace', '') -> FAILED ---> Duplicate entry '12' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (13, 3,'txt', '') -> FAILED ---> Duplicate entry '13' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (14, 3,'c', '') -> FAILED ---> Duplicate entry '14' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (15, 3,'h', '') -> FAILED ---> Duplicate entry '15' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (16, 3,'cpp', '') -> FAILED ---> Duplicate entry '16' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (17, 3,'hpp', '') -> FAILED ---> Duplicate entry '17' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (18, 3,'diz', '') -> FAILED ---> Duplicate entry '18' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (19, 4,'xls', '') -> FAILED ---> Duplicate entry '19' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (20, 4,'doc', '') -> FAILED ---> Duplicate entry '20' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (21, 4,'dot', '') -> FAILED ---> Duplicate entry '21' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (22, 4,'pdf', '') -> FAILED ---> Duplicate entry '22' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (23, 4,'ai', '') -> FAILED ---> Duplicate entry '23' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (24, 4,'ps', '') -> FAILED ---> Duplicate entry '24' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (25, 4,'ppt', '') -> FAILED ---> Duplicate entry '25' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (26, 5,'rm', '') -> FAILED ---> Duplicate entry '26' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (27, 6,'wma', '') -> FAILED ---> Duplicate entry '27' for key 1
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (28, 7,'swf', '') -> FAILED ---> Duplicate entry '28' for key 1
Running :: INSERT INTO phpbb_quota_limits (quota_limit_id, quota_desc, quota_limit) VALUES (1, 'Low', 262144) -> FAILED ---> Duplicate entry '1' for key 1
Running :: INSERT INTO phpbb_quota_limits (quota_limit_id, quota_desc, quota_limit) VALUES (2, 'Medium', 2097152) -> FAILED ---> Duplicate entry '2' for key 1
Running :: INSERT INTO phpbb_quota_limits (quota_limit_id, quota_desc, quota_limit) VALUES (3, 'High', 5242880) -> FAILED ---> Duplicate entry '3' for key 1
第一次安MOD裝成功了attach_mod_v2.3.10
重灌了不知多少次\r
原本一直找不到原因為何失敗,結來這看看有沒有什麼關於這方面的,我檢查了2次,以為都沒錯,結果~~看到樓主這句話,注意這邊容易出錯 是加在大括號後,後我在去看一次,啊勒,我還真的放錯地方,~~~~謝樓主名言~~~~不然準備重灌2.0.11在試一次~~
好高興第一次裝mod成功~~~~~ya~~~
#-----[開啟]---------------------------------------------
common.php
#-----[ 尋找 ]---------------------------------------------
# 大約在第 181 行
$board_config[$row['config_name']] = $row['config_value'];
#-----[ 在上面那行的大括號 } 之後增加這些碼...注意這邊容易出錯 是加在大括號後 ]--------------------------------------
include($phpbb_root_path . 'attach_mod/attachment_mod.'.$phpEx);
重灌了不知多少次\r
common.php
# 大約在第 181 行
[問題]attach_mod_v2.3.10 安裝問題請教
attach_mod_v2.3.10 安裝問題請教各位高手
os:window2000
db:SQLserver
phpbb:phpBB-2.0.10
mod:attach_mod_v2.3.10 跟 lang_chinese_traditional_taiwan_amod_v239
要安裝前已經在竹貓爬了很多篇文章了,
大該會出錯的地方也有注意,
沒想到安裝了兩次還是一樣的問題,
連錯誤都不知在哪,
煩請各方高手指教,
我出現的狀況是在FTP 上傳伺服器功能測試回覆是成功的,
但是在測試要發表文章,
新增附加檔案後送出,
url會指向http://localhost/phpbb2/posting.php?mode=newtopic&f=1
再來過好一會...就是一片空白的頁面,
url還是停留在http://localhost/phpbb2/posting.php(完成)
不知如何是好.....?
在竹貓找了好久似乎沒看到類似的問題,
所以希望高手們指教.....謝謝!
os:window2000
db:SQLserver
phpbb:phpBB-2.0.10
要安裝前已經在竹貓爬了很多篇文章了,
大該會出錯的地方也有注意,
沒想到安裝了兩次還是一樣的問題,
連錯誤都不知在哪,
煩請各方高手指教,
但是在測試要發表文章,
新增附加檔案後送出,
再來過好一會...就是一片空白的頁面,
不知如何是好.....?
在竹貓找了好久似乎沒看到類似的問題,
所以希望高手們指教.....謝謝!
好像推出新版...但中文化好像沒跟上
●架設主機作業系統:Windows Server 2003
●快速架站程式:EasyPHP 1.7
●您的上網方式:Giga ADSL 2M/512 PPPoE 固定 IP * 1
●您安裝的程式:IIS 6.0 + Apache + php + MySql
●您的 phpBB2 版本:phpBB 2.0.17
●您的 phpBB2 連結網址: http://www.ashpro.idv.tw:8080/
●快速架站程式:EasyPHP 1.7
