小弟在某個論壇看到(PHPBB2.0.3)
該論壇有一種功能,按下IMG貼圖鈕之後
會跳出一個視窗如下圖:
然後上傳完畢之後會顯示LINK+語法,貼圖的人只要把整行複製下來貼到文章內就可以...
這樣好像滿方便的,比起上傳以附件方式呈現或是上傳附件之後又自己抓連結來貼圖好用(以對會員來說)
請問各位有經驗的大大們,這是外掛吧??
還是...............
應該要怎麼弄呢???
謝謝大大為我解答
嗯...是站長自己改的河風 寫:那個應該是該站長自己改出來的.
這一招在某些論壇上是蠻流行的
不過目前還沒有人放CODE出來 ^^"
剛才試著連該網站....它真的掛了咧!依夢兒 寫:那個網站....是不是消失了??
<FORM ENCTYPE="multipart/form-data" ACTION="imageupload.php" METHOD="POST">
The file: <INPUT TYPE="file" NAME="userfile">
<INPUT TYPE="submit" VALUE="Upload">
</FORM>
<?php
// Image file upload by Bloody
// http://www.bloodys.com/
// email: info@bloodys.com
// If you use this script, please put a link back to http://www.bloodys.com/
$path = "";
$max_size = 200000;
if (!isset($HTTP_POST_FILES['userfile'])) exit;
if (is_uploaded_file($HTTP_POST_FILES['userfile']['tmp_name'])) {
if ($HTTP_POST_FILES['userfile']['size']>$max_size) { echo "The file is too big<br>
"; exit; }
if (($HTTP_POST_FILES['userfile']['type']=="image/gif") || ($HTTP_POST_FILES['userfile']['type']=="image/pjpeg") || ($HTTP_POST_FILES['userfile']['type']=="image/jpeg")) {
if (file_exists($path . $HTTP_POST_FILES['userfile']['name'])) { echo "The file already exists<br>
"; exit; }
$res = copy($HTTP_POST_FILES['userfile']['tmp_name'], $path .
$HTTP_POST_FILES['userfile']['name']);
if (!$res) { echo "upload failed!<br>
"; exit; } else { echo "upload sucessful<br>
echo "File Name: ".$HTTP_POST_FILES['userfile']['name']."<br>
echo "File Size: ".$HTTP_POST_FILES['userfile']['size']." bytes<br>
echo "File Type: ".$HTTP_POST_FILES['userfile']['type']."<br>
} else { echo "Wrong file type<br>
"; exit; }
