在下頭一次安裝此MOD也是遇到這個問題.
問題出在於..
[php]#原MOD說明檔
function user_avatar_url($mode, &$error, &$error_msg, $avatar_filename)
if ( !preg_match('#^(http)|(ftp):\/\/#i', $avatar_filename) )
$avatar_filename = 'http://' . $avatar_filename;
if ( !preg_match('#^((http)|(ftp):\/\/[\w\-]+?\.([\w\-]+\.)+[\w]+(:[0-9]+)*\/.*?\.(gif|jpg|jpeg|png)$)#is', $avatar_filename) )
$error = true;
$error_msg = ( !empty($error_msg) ) ? $error_msg . '<br />' . $lang['Wrong_remote_avatar_format'] : $lang['Wrong_remote_avatar_format'];
return;
global $board_config, $lang;
#--內文略--
$l_avatar_size : $l_avatar_size;
return;
注意!這裡!
# EoM[/php]標示處多了一個 "}", 造成下方[php]return ( $mode == 'editprofile' ) ? ", user_avatar = '" . str_replace("\'", "''", $avatar_filename) . "', user_avatar_type = " . USER_AVATAR_REMOTE : '';
}[/php]無法正確將連結圖片引入系統之中..
剛重新下載來看, 原檔連結那邊尚未修正..
