<?php
* usercp_viewprofile.php
* email : support@phpbb.com
* $Id: usercp_viewprofile.php,v 1.5.2.1 2003/02/25 23:28:30 acydburn Exp $
if ( !defined('IN_PHPBB') )
die("Hacking attempt");
exit;
if ( empty($HTTP_GET_VARS[POST_USERS_URL]) || $HTTP_GET_VARS[POST_USERS_URL] == ANONYMOUS )
message_die(GENERAL_MESSAGE, $lang['No_user_id_specified']);
$profiledata = get_userdata($HTTP_GET_VARS[POST_USERS_URL]);
$sql = "SELECT *
FROM " . RANKS_TABLE . "
ORDER BY rank_special, rank_min";
message_die(GENERAL_ERROR, 'Could not obtain ranks information', '', __LINE__, __FILE__, $sql);
$ranksrow[] = $row;
$db->sql_freeresult($result);
// Output page header and profile_view template
$template->set_filenames(array(\r
'body' => 'profile_view_body.tpl')
make_jumpbox('viewforum.'.$phpEx);
// Calculate the number of days this user has been a member ($memberdays)
// Then calculate their posts per day
$regdate = $profiledata['user_regdate'];
$memberdays = max(1, round( ( time() - $regdate ) / 86400 ));
$posts_per_day = $profiledata['user_posts'] / $memberdays;
// Get the users percentage of total posts
if ( $profiledata['user_posts'] != 0 )
$total_posts = get_db_stat('postcount');
$percentage = ( $total_posts ) ? min(100, ($profiledata['user_posts'] / $total_posts) * 100) : 0;
$percentage = 0;
$avatar_img = '';
if ( $profiledata['user_avatar_type'] && $profiledata['user_allowavatar'] )
switch( $profiledata['user_avatar_type'] )
case USER_AVATAR_UPLOAD:
$avatar_img = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $profiledata['user_avatar'] . '" alt="" border="0" />' : '';
break;
case USER_AVATAR_REMOTE:
$avatar_img = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $profiledata['user_avatar'] . '" alt="" border="0" />' : '';
break;
case USER_AVATAR_GALLERY:
$avatar_img = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $profiledata['user_avatar'] . '" alt="" border="0" />' : '';
break;
$poster_rank = '';
$rank_image = '';
if ( $profiledata['user_rank'] )
for($i = 0; $i < count($ranksrow); $i++)
if ( $profiledata['user_rank'] == $ranksrow[$i]['rank_id'] && $ranksrow[$i]['rank_special'] )
$poster_rank = $ranksrow[$i]['rank_title'];
$rank_image = ( $ranksrow[$i]['rank_image'] ) ? '<img src="' . $ranksrow[$i]['rank_image'] . '" alt="' . $poster_rank . '" title="' . $poster_rank . '" border="0" /><br />' : '';
if ( $profiledata['user_posts'] >= $ranksrow[$i]['rank_min'] && !$ranksrow[$i]['rank_special'] )
$temp_url = append_sid("privmsg.$phpEx?mode=post&" . POST_USERS_URL . "=" . $profiledata['user_id']);
$pm_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_pm'] . '" alt="' . $lang['Send_private_message'] . '" title="' . $lang['Send_private_message'] . '" border="0" /></a>';
$pm = '<a href="' . $temp_url . '">' . $lang['Send_private_message'] . '</a>';
if ( !empty($profiledata['user_viewemail']) || $userdata['user_level'] == ADMIN )
$email_uri = ( $board_config['board_email_form'] ) ? append_sid("profile.$phpEx?mode=email&" . POST_USERS_URL .'=' . $profiledata['user_id']) : 'mailto:' . $profiledata['user_email'];
$email_img = '<a href="' . $email_uri . '"><img src="' . $images['icon_email'] . '" alt="' . $lang['Send_email'] . '" title="' . $lang['Send_email'] . '" border="0" /></a>';
$email = '<a href="' . $email_uri . '">' . $lang['Send_email'] . '</a>';
$email_img = ' ';
$email = ' ';
$www_img = ( $profiledata['user_website'] ) ? '<a href="' . $profiledata['user_website'] . '" target="_userwww"><img src="' . $images['icon_www'] . '" alt="' . $lang['Visit_website'] . '" title="' . $lang['Visit_website'] . '" border="0" /></a>' : ' ';
$www = ( $profiledata['user_website'] ) ? '<a href="' . $profiledata['user_website'] . '" target="_userwww">' . $profiledata['user_website'] . '</a>' : ' ';
if ( !empty($profiledata['user_icq']) )
$icq_status_img = '<a href="http://wwp.icq.com/' . $profiledata['user_icq'] . '#pager"><img src="http://web.icq.com/whitepages/online?icq=' . $profiledata['user_icq'] . '&img=5" width="18" height="18" border="0" /></a>';
$icq_img = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $profiledata['user_icq'] . '"><img src="' . $images['icon_icq'] . '" alt="' . $lang['ICQ'] . '" title="' . $lang['ICQ'] . '" border="0" /></a>';
$icq = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $profiledata['user_icq'] . '">' . $lang['ICQ'] . '</a>';
$icq_status_img = ' ';
$icq_img = ' ';
$icq = ' ';
$aim_img = ( $profiledata['user_aim'] ) ? '<a href="aim:goim?screenname=' . $profiledata['user_aim'] . '&message=Hello+Are+you+there?"><img src="' . $images['icon_aim'] . '" alt="' . $lang['AIM'] . '" title="' . $lang['AIM'] . '" border="0" /></a>' : ' ';
$aim = ( $profiledata['user_aim'] ) ? '<a href="aim:goim?screenname=' . $profiledata['user_aim'] . '&message=Hello+Are+you+there?">' . $lang['AIM'] . '</a>' : ' ';
$msn_img = ( $profiledata['user_msnm'] ) ? $profiledata['user_msnm'] : ' ';
$msn = $msn_img;
$yim_img = ( $profiledata['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $profiledata['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
$yim = ( $profiledata['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $profiledata['user_yim'] . '&.src=pg">' . $lang['YIM'] . '</a>' : '';
$temp_url = append_sid("search.$phpEx?search_author=" . urlencode($profiledata['username']) . "&showresults=posts");
$search_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_search'] . '" alt="' . $lang['Search_user_posts'] . '" title="' . $lang['Search_user_posts'] . '" border="0" /></a>';
$search = '<a href="' . $temp_url . '">' . $lang['Search_user_posts'] . '</a>';
include($phpbb_root_path . 'includes/level_mod.'.$phpEx); //added for Level Mod (Mac)
if ( $profiledata['username'] == *~死靈~* ) {
$level_level = "LeVeLMaX";
$level_hp = "MaX / MaX";
$level_hp_percent = 100;
$level_mp = "MaX / MaX";
$level_mp_percent = 100;
$level_exp = "MaX / MaX";
$level_exp_percent = 100;
$level_skillratio = "sKiLlMaX";
$level_classname = "<font color=red><b>DF-死靈</b></font>";
// Generate page
$page_title = $lang['Viewing_profile'];
$template->assign_vars(array(
'USERNAME' => $profiledata['username'],
'JOINED' => create_date($lang['DATE_FORMAT'], $profiledata['user_regdate'], $board_config['board_timezone']),
'POSTER_RANK' => $poster_rank,
'RANK_IMAGE' => $rank_image,
'POSTS_PER_DAY' => $posts_per_day,
'POSTS' => $profiledata['user_posts'],
'PERCENTAGE' => $percentage . '%',
'POST_DAY_STATS' => sprintf($lang['User_post_day_stats'], $posts_per_day),
'POST_PERCENT_STATS' => sprintf($lang['User_post_pct_stats'], $percentage),
'SEARCH_IMG' => $search_img,
'SEARCH' => $search,
'PM_IMG' => $pm_img,
'PM' => $pm,
'EMAIL_IMG' => $email_img,
'EMAIL' => $email,
'WWW_IMG' => $www_img,
'WWW' => $www,
'ICQ_STATUS_IMG' => $icq_status_img,
'ICQ_IMG' => $icq_img,
'ICQ' => $icq,
'AIM_IMG' => $aim_img,
'AIM' => $aim,
'MSN_IMG' => $msn_img,
'MSN' => $msn,
'YIM_IMG' => $yim_img,
'YIM' => $yim,
'LOCATION' => ( $profiledata['user_from'] ) ? $profiledata['user_from'] : ' ',
'OCCUPATION' => ( $profiledata['user_occ'] ) ? $profiledata['user_occ'] : ' ',
'INTERESTS' => ( $profiledata['user_interests'] ) ? $profiledata['user_interests'] : ' ',
'AVATAR_IMG' => $avatar_img,
'L_VIEWING_PROFILE' => sprintf($lang['Viewing_user_profile'], $profiledata['username']),
'L_ABOUT_USER' => sprintf($lang['About_user'], $profiledata['username']),
'L_AVATAR' => $lang['Avatar'],
'L_POSTER_RANK' => $lang['Poster_rank'],
'L_JOINED' => $lang['Joined'],
'L_TOTAL_POSTS' => $lang['Total_posts'],
'L_SEARCH_USER_POSTS' => sprintf($lang['Search_user_posts'], $profiledata['username']),
'L_CONTACT' => $lang['Contact'],
'L_EMAIL_ADDRESS' => $lang['Email_address'],
'L_EMAIL' => $lang['Email'],
'L_PM' => $lang['Private_Message'],
'L_ICQ_NUMBER' => $lang['ICQ'],
'L_YAHOO' => $lang['YIM'],
'L_AIM' => $lang['AIM'],
'L_MESSENGER' => $lang['MSNM'],
'L_WEBSITE' => $lang['Website'],
'L_LOCATION' => $lang['Location'],
'L_OCCUPATION' => $lang['Occupation'],
'L_INTERESTS' => $lang['Interests'],
'U_SEARCH_USER' => append_sid("search.$phpEx?search_author=" . urlencode($profiledata['username'])),
/* BEGIN LEVEL MOD */
'HP' => $level_hp,
'HP_WIDTH' => $level_hp_percent,
'HP_EMPTY' => ( 100 - $level_hp_percent ),
'MP' => $level_mp,
'MP_WIDTH' => $level_mp_percent,
'MP_EMPTY' => ( 100 - $level_mp_percent ),
'EXP' => $level_exp,
'EXP_WIDTH' => $level_exp_percent,
'EXP_EMPTY' => ( 100 - $level_exp_percent ),
'LEVEL' => $level_level,
'LEVEL_CLASSNAME' => $level_classname,
'LEVEL_SKILLRATIO' => $level_skillratio,
/* END LEVEL MOD */
'S_PROFILE_ACTION' => append_sid("profile.$phpEx"))
$template->pparse('body');
