http://phpbb-tw.net/phpbb/viewtopic.php?t=18473
http://mods.db9.dk/viewtopic.php?t=11
使用版本:(phpBB 2.0.3)
網站位置:http://appleboy46.no-ip.com
我裝了now confirmed on ver 2.0.6 (*EM)這個外掛
會在人名下面顯示自己所加入的會員群組
可是那個會員群組的連結有問題...如下
http://appleboy46.no-ip.com/phpBB2/groupcp.?g=2772
在groupcp的後面多了一個點...不知我哪裡改錯了
還有他的會員群組會有圖案.....
我裝了之後並沒有....請大家幫我看看...哪段程式碼有問題
## MOD Title: Show Usergroups
## MOD Author: Niels Chr. R鷣 Denmark < ncr@db9.dk > http://mods.db9.dk
## Description: This mod will add information about the posters current membership
## of any usergroups, they belong to - the list is shown beside
## the users posts/users profile, hidden groups are shown in itallic (only if
## the viewing user also are a member) - now also support show images for usergroups
## Mod Version: 1.3.2.
## Compability 2.0.6
## Installation Level: easy
## Files To Edit: 5
## viewtopic.php
## includes/template.php
## includes/usercp_viewprofile.php
## templates/subSilver/profile_view_body.tpl
## templates/subSilver/viewtopic_body.tpl
## Included Files: 6
## includes/functions_usergroup.php
## templates/subSilver/show_usergroup.tpl
## templates/subSilver/show_usergroup_as_dropdown.tpl
## templates/subSilver/images/groups_snow.gif";
## templates/subSilver/images/groups_star2.gif";
## templates/subSilver/images/groups_diamond3.gif";
## Author Notes:
## This MOD is compatible and can be installed by EasyMOD
## of Nuttzy (but is not officially EasyMOD Compliant)!
## http://www.phpbb.com/phpBB/viewtopic.php?t=124436
## In any case, if you install this MOD manually or using an
## alpha release of EM, please run this file NOW, before
## editing phpBB files by EM or manually!!!
## Otherwise, you may have an error message during your next
## connection.
## MOD History:
## 2003-09-04 - version 1.3.2.
## - fixed a problem with viewtopic.php (change the included file)
## - added new features to template.php
## 2003-08-29 - version 1.3.1.
## - updated the included file functions_usergroup.php
## 2003-08-27 - version 1.3.0.
## - Complete re-write, now uses own template file to define the show layout
## - Name changed from "member of" to "Show usergroup" as it is more correct
## 2003-08-27 - version 1.2.7.
## - fixing a bug, witch couse by version 1.2.4, made hidden group visible
## 2003-08-23 - version 1.2.6.
## - now rewritten how-to, to be EM ready
## ????-??-?? - version 1.2.5.
## - improved code, now uses 1 SQL, and improved the options in template code
## ????-??-?? - version 1.2.4.
## - code changed to allow more flex style control
## ????-??-?? - version 1.2.3.
## - confirmed for 2.0.5 by "kooky"
## ????-??-?? - version 1.2.2.
## - support images as well, code the group id into the template image file (e.g. subSilver.cfg)
## ????-??-?? - version 1.2.1.
## - added commas between usergroups
## ????-??-?? - version 1.2.0.
## - fixed a bug, causing user group to be none, also confirmed for phpBB2 version 2.0.2
## ????-??-?? - version 0.9.2.
## - History started, security update, now hidden groups are hidden if users are not allowed to view
## ????-??-?? - version 0.9.1.
## - updated by to version 2.0.1. by J廨獽e Gamez < Jerome@campinvaders.net> http://www.campinvaders.net
## ????-??-?? - Version 0.9.0
## - Initial release phpBB2 RC-1
viewtopic.php
// Okay
include($phpbb_root_path . 'includes/functions_usergroup.'.$phpEx);
$template->pparse('body');
if (display_usergroups($userdata['user_id'],$poster_id,'postrow'))
$template->append_block_vars('postrow',array(
'L_USER_GROUP' =>$lang['Usergroups'],
'L_GO' => $lang['Go']));
} else
'L_NO_USER_GROUP' =>$lang['Usergroups'],
'L_NO_USERGROUPS'=> $lang['None']));
// Functions added for USERGROUP MOD
function append_var_from_handle_to_block($blockname,$varname, $handle)
if (!$this->loadfile($handle))
die("Template->assign_var_from_handle(): Couldn't load template file for handle $handle");
// Compile it, with the "no echo statements" option on.
$_str = "";
$code = $this->compile($this->uncompiled_code[$handle], true, '_str');
// evaluate the variable assignment.
eval($code);
// assign the value of the generated variable to the given varname.
$this->append_block_vars($blockname, array($varname => $_str));
return true;
function append_block_vars($blockname, $vararray)
if (strstr($blockname, '.'))
// Nested block.
$blocks = explode('.', $blockname);
$blockcount = sizeof($blocks) - 1;
$str = '$this->_tpldata';
for ($i = 0; $i <= $blockcount; $i++)
$str .= '[\'' . $blocks[$i] . '.\']';
eval('$lastiteration = sizeof(' . $str . ') - 1;');
$str .= '[' . $lastiteration . ']';
// Now we add the block that we're actually assigning to.
// We're adding a new iteration to this block with the given
// variable assignments.
$str .= '= array_merge('.$str.',$vararray);';
// Now we evaluate this assignment we've built up.
eval($str);
// Top-level block.
// Add a to existing block with the variable assignments
// we were given.
$current_iteration = sizeof($this->_tpldata[$blockname . '.'])-1;
$this->_tpldata[$blockname . '.'][$current_iteration] = array_merge($this->_tpldata[$blockname . '.'][$current_iteration],$vararray);
return true;
* Flush a root level block, so it becomes empty.
function flush_block_vars($blockname)
// Top-level block.
// flush a existing block we were given.
unset($this->_tpldata[$blockname . '.']);
return true;
if (display_usergroups($userdata['user_id'],$profiledata[user_id],'show_usergroup_as_dropdown'))
$template->assign_vars(array(
'L_USER_GROUP' =>$lang['Usergroups']));
} else
templates/Subsilver/viewtopic_body.tpl
{postrow.POSTER_FROM}
<br/>{postrow.L_USER_GROUP}{postrow.L_NO_USER_GROUP}: {postrow.SHOW_USERGROUPS}{postrow.L_NO_USERGROUPS}
# (make sure to edit this file for every theme your admin uses).
{JOINED}</span></b></td>
<td valign="middle" align="right"><span class="gen">{L_USER_GROUP}{L_NO_USER_GROUP}:</span></td>
<td class="row1" valign="middle" width="100%"><b><span class="gen">{SHOW_USERGROUPS}{L_NO_USERGROUPS}</span></b></td>
templates/subSilver/subSilver.cfg
// add as meny as these, as you have usergroups, the ID is the same as the usergroup ID, these examples covers grop id 1->6
$images['groups'][1] = "$current_template_images/groups_snow.gif";
$images['groups'][2] = "$current_template_images/groups_star2.gif";
$images['groups'][3] = "$current_template_images/groups_diamond3.gif";
$images['groups'][4] = "$current_template_images/groups_snow.gif";
$images['groups'][5] = "$current_template_images/groups_star2.gif";
$images['groups'][6] = "$current_template_images/groups_diamond3.gif";
copy root/includes/functions_usergroup.php to includes/functions_usergroup.php
copy root/templates/subSilver/show_usergroup.tpl to templates/subSilver/show_usergroup.tpl
copy root/templates/subSilver/show_usergroup_as_dropdown.tpl to templates/subSilver/show_usergroup_as_dropdown.tpl
copy root/templates/subSilver/images/groups_snow.gif to templates/subSilver/images/groups_snow.gif
copy root/templates/subSilver/images/groups_star2.gif to templates/subSilver/images/groups_star2.gif
copy root/templates/subSilver/images/groups_diamond3.gif to templates/subSilver/images/groups_diamond3.gif
# EoM
