[討論][修改]虛擬形象(加強後台管理)
翔翎
文章: 56
註冊時間: 2002-08-18 21:32
文章 由 翔翎 »
在北飄有人發表了加強後台管理
可直接跟改數量
我把他轉成繁體了
faceset.php
但直接覆蓋後並不能使用\r
哪部分該改一改\r
麻煩大大\r
[php]
<?php
error_reporting(7);
require("./global.php");
cpheader();
adminlog(iif($faceid!=0,"face id = $faceid",""));
if (isset($action)==0) {
$action="modify";
// ###################### Start Upload #######################
if ($action=="upload") {
$leibie1 = $DB_site->query("SELECT * FROM week9_class where have = '1'");
while ($facesort = $DB_site->fetch_array($leibie1))
$faceleibie .= " <option value=\"$facesort[id]\">$facesort[name1]</option>";
echo "<p><b>使用這項功能要求你的服務器有PHP寫入文件的權限。如果權限不夠,操作將無法完成。</b></p>";
doformheader("faceset","doupload",1);
maketableheader("從電腦中上傳新的形像圖片");
echo "
<tr class=secondalt valign=top>
<td><p>上傳形像分類</p></td>
<td><p>
<select name=\"sp_sort\">
$faceleibie
</select>
</p></td>
makeuploadcode("圖標文件(大圖標)","sp_graphic");
makeuploadcode("圖標文件(小圖標)","sp_sxgraphic");
makeinputcode("形像名稱","sp_name");
makeinputcode("形像介紹","sp_description");
makeinputcode("所售價錢","sp_money");
makeinputcode("商品耐用度<br>(以10為基本單位每10可以使用1天)","sp_wear");
makeinputcode("商品數量<br>(默認5個)","sp_number","5");
echo "
<tr class=firstalt valign=top>
<td><p>適合人群</p></td>
<td><p>
<select name=\"sp_fitherd\">
<option value=\"t\" selected>所有人</option>
<option value=\"m\">帥哥</option>
<option value=\"f\">美女</option>
</select>
doformfooter("上傳");
// ###################### Start DoUpload #######################
if ($HTTP_POST_VARS['action']=="doupload") {
$vararray = array("sp_sort" => "$_REQUEST[sp_sort]",
"sp_name" => "$_REQUEST[sp_name]",
"sp_description" => "$_REQUEST[sp_description]",
"sp_money" => "$_REQUEST[sp_money]",
"sp_wear" => "$_REQUEST[sp_wear]",
"sp_fitherd" => "$_REQUEST[sp_fitherd]",
"sp_graphic" => "$_REQUEST[sp_graphic][name]",
"sp_sxgraphic" => "$_REQUEST[sp_sxgraphic][name]"
if("" == trim($vararray["sp_graphic"]))
echo "上傳文件名不能為空!<br> <a href=javascript:window.history.back()>點這裡返回修改</a>";
exit;
if("" == trim($vararray["sp_sxgraphic"]))
exit;
if("" == trim($vararray["sp_name"]))
echo "<p align=center>名稱不能為空。<a href=javascript:history.back()>點這裡返回修改</a></p>";
exit;
if("" == trim($vararray["sp_description"]))
echo "<p align=center>介紹不能為空。<a href=javascript:history.back()>點這裡返回修改</a></p>";
exit;
if("" == trim($vararray["sp_money"]))
echo "<p align=center>售價不能為空。<a href=javascript:history.back()>點這裡返回修改</a></p>";
exit;
if("" == trim($vararray["sp_wear"]))
echo "<p align=center>使用時間不能為空。<a href=javascript:history.back()>點這裡返回修改</a></p>";
exit;
$sp_sortpath = trim($vararray["sp_sort"]);
$image_basepath = "../images/face/$sp_sortpath/";
if("" != $_FILES['sp_sxgraphic']['name'])
if(!preg_match("/.gif$/i", $_FILES['sp_sxgraphic']['name']))
echo "<p align=center>隻允許上傳gif格式的文件。<a href=javascript:window.history.back()>點這裡返回修改</a></p>";
exit;
$namex = $_FILES["sp_sxgraphic"]["name"];
$sp_sxgraphic = preg_replace("'[
\s]'", "", $namex);
if("" == trim($sp_sxgraphic))
$faceidrows = $DB_site->query_first("SELECT COUNT(*) AS nr FROM week9_data WHERE sp_sxgraphic = '$sp_sxgraphic' and sort='$sp_sort'");
$nr = $faceidrows[nr];
if ($nr != '0')
echo "這個文件已經存在在數據庫裡!<br> <a href=javascript:window.history.back()>點這裡返回修改</a>";\r
exit;
$targetFileName = $image_basepath.$sp_sxgraphic;
if (is_uploaded_file($_FILES["sp_sxgraphic"]["tmp_name"]))
move_uploaded_file($_FILES["sp_sxgraphic"]["tmp_name"], "$targetFileName");
echo "上傳" . $_FILES["sp_sxgraphic"]["name"] . "失敗!!<br>";
echo "<a href=javascript:window.history.back()>點這裡返回修改</a>";
exit;
if("" != $_FILES['sp_graphic']['name'])
if(!preg_match("/.gif$/i", $_FILES['sp_graphic']['name']))
exit;
$name = $_FILES["sp_graphic"]["name"];
$sp_graphic = preg_replace("'[
\s]'", "", $name);
if("" == trim($sp_graphic))
$faceidrows = $DB_site->query_first("SELECT COUNT(*) AS nr FROM week9_data WHERE sp_graphic = '$sp_graphic' and sort='$sp_sort'");
if ($nr != '0')
exit;
$targetFileName = $image_basepath.$sp_graphic;
if (is_uploaded_file($_FILES["sp_graphic"]["tmp_name"]))
move_uploaded_file($_FILES["sp_graphic"]["tmp_name"], "$targetFileName");
echo "上傳" . $_FILES["sp_graphic"]["name"] . "失敗!!<br>";
exit;
$HTTP_POST_VARS['action']="insert";
// ###################### Start Add #######################
if ($action=="add") {
doformheader("faceset","insert",0,1,"addone");
maketableheader("添加單個形像圖片");
echo "
<td><p>添加到形像分類</p></td>
<td><p>
<select name=\"sp_sort\" onchange=\"facepath1.innerHTML=facepath2.innerHTML='images/face/'+document.addone.sp_sort.options[document.addone.sp_sort.selectedIndex].value+'/'\">
$faceleibie
</select>
</p></td>
makeinputcode("大圖片名(請確認此圖片位於:<font id='facepath1' color=red>images/face/2/</font>)","sp_graphic","name.gif");
makeinputcode("小圖片名(請確認此圖片位於:<font id='facepath2' color=red>images/face/2/</font>)","sp_sxgraphic","namex.gif");
echo "
<td><p>
</select>
doformfooter("添加形像圖片");
// Add multiple
doformheader("faceset","insertmultiple",0,1,"addmore");
maketableheader("添加一組形像圖片");
echo "
<td><p>
<select name=\"facesort\" onchange=\"document.addmore.facepath.value='images/face/'+document.addmore.facesort.options[document.addmore.facesort.selectedIndex].value\">
$faceleibie
</select>
</p></td>
makeinputcode("圖片路徑(要相對於vB論壇的主目錄)","facepath","images/face/1");
makeinputcode("每頁顯示的形像圖片數量?","facesperpage",20);
// ###################### Start Insert #######################
if ($HTTP_POST_VARS['action']=="insert") {
$DB_site->query("INSERT INTO week9_data (sort,sp_name,sp_money,sp_description,sp_wear,sp_fitherd,sp_graphic,sp_sxgraphic,sp_number) VALUES ('$sp_sort', '".addslashes($sp_name)."', '".trim($sp_money)."', '".addslashes($sp_description)."', '".trim($sp_wear)."', '$sp_fitherd','".addslashes($sp_graphic)."','".addslashes($sp_sxgraphic)."','".(int)($sp_number)."')");
$action="modify";
echo "記錄添加成功!<br><a href=\"javascript:history.back()\">返回</a>";
exit;
// ###################### Start Multi Prompt #######################
if ($action=="insertmultiple") {
<script language="JavaScript">
function CheckAll()
for (var i=0;i<document.form.elements.length;i++)
var e = document.form.elements;
if ((e.name != 'allbox') && (e.type=='checkbox'))
e.checked = document.form.allbox.checked;
function CheckCheckAll()
var TotalBoxes = 0;
var TotalOn = 0;
TotalBoxes++;
if (e.checked)
TotalOn++;
if (TotalBoxes==TotalOn)
{document.form.allbox.checked=true;}
{document.form.allbox.checked=false;}
</script>
<?php
if (intval($startpage)<1)
$startpage = 1;
if (intval($facesperpage)<1)
$facesperpage = 10;
$facepath = preg_replace("/\/$/s","",$facepath);
if($dirhandle=@opendir('../'.$facepath)) {
chdir('../'.$facepath);
$ok_exit='no';
doformheader("faceset","",0,0,"form");
echo "<input type='hidden' value='$facepath' name='facepath'><input type='hidden' value='$facesort' name='facesort'><input type='hidden' value='$facesperpage' name='facesperpage'>";
echo "<table align='center' border='0' cellspacing='1' cellpadding='5' class='tblborder'>";
echo "<tr class='secondalt'><td align='center' colspan='9'>添加多個形像圖片從<b>$bburl/$facepath</b>到 分類 $facesort</td></tr>";
echo "<tr class='tblhead'><td align='center'><b><span class='tblhead'>大圖片</span></b></td><td align='center'><b><span class='tblhead'>小圖片</span></b></td><td align='center'><b><span class='tblhead'>名稱</span></b></td><td align='center'><b><span class='tblhead'>介紹</span></b></td><td align='center'><b><span class='tblhead'>價錢</span></b></td><td align='center'><b><span class='tblhead'>耐用度</b></span></td><td align='center'><b><span class='tblhead'>數量</b></span></td><td align='center'><b><span class='tblhead'>適合人群</span></b></td>";
echo "<td align='center'><input name='allbox' type='checkbox' value='Check All' onClick='CheckAll();'></td>";
$faces=$DB_site->query("SELECT sp_graphic FROM week9_data WHERE sort='$facesort'");
while ($face=$DB_site->fetch_array($faces)) {
$faceArray[$face[sp_graphic]] = 'yes';
while ($filename=readdir($dirhandle)) {
$facename = $facepath . '/' . $filename;
if ($filename!='.' and $filename!='..' and $filename!='init.gif' and $filename!='initf.gif' and @is_file($filename) and !$faceArray[$filename] and (($filelen=strlen($filename))>=5)) {
$fileext1 = strtolower(substr($filename,$filelen-4,$filelen-1));
$fileext2 = strtolower(substr($filename,$filelen-5,$filelen-1));
$fileext3=substr($filename,0,strpos($filename,"."));
if ($fileext1==".gif"&&$fileext2!="x.gif") {
$FileArray[count($FileArray)] = $fileext3;
$facecount = count($FileArray);
if ((($facecount / $facesperpage) - ((int) ($facecount / $facesperpage))) == 0)
$numpages = $facecount / $facesperpage;
$numpages = (int) ($facecount / $facesperpage) + 1;
if ($startpage == 1) {
$startface = 0;
$endface = $facesperpage - 1;
} else {
$startface = ($startpage - 1) * $facesperpage;
$endface = ( $facesperpage * $startpage ) - 1 ;
for ($x = 0; $x < $facecount; $x++) {
if ($x >= $startface && $x <= $endface) {
// $imgname=substr($FileArray[$x],0,strpos($FileArray[$x],"."));
echo "<tr class='".getrowbg()."'>
echo "<td align='center'><img src='../$facepath/$FileArray[$x].gif' border=0 align='center'></td>
echo "<td align='center'><img src='../$facepath/$FileArray[$x]x.gif' border=0 align='center'></td>
echo "<td align='center'><input type='text' name='facename[$FileArray[$x]]' size=10 value='$FileArray[$x]'></td>
echo "<td align='center'><input type='text' name='faceinfo[$FileArray[$x]]' size=10 value='$FileArray[$x]'></td>
echo "<td align='center'><input type='text' name='facemoney[$FileArray[$x]]' size=5 value='100'></td>
echo "<td align='center'><input type='text' name='facetime[$FileArray[$x]]' size=5 value='300'></td>
echo "<td align='center'><input type='text' name='facenumber[$FileArray[$x]]' size=5 value='5'></td>
echo "<td><select name=\"faceuser[$FileArray[$x]]\"><option value=\"t\" selected>所有人</option><option value=\"m\">帥哥</option><option value=\"f\">美女</option></select>
echo "<td align='center'><input type='checkbox' name='faceuse[$FileArray[$x]]' value='yes'><input type='hidden' name='facepic[$FileArray[$x]]' value='$FileArray[$x].gif'><input type='hidden' name='facepicx[$FileArray[$x]]' value='$FileArray[$x]x.gif'><input type='hidden' value='$facesort' name='facesort[$FileArray[$x]]'></td></tr>
if ($numpages > 1) {
for ($x = 1; $x <= $numpages; $x++) {
if ($x == $startpage)
$pagelinks .= "<b> $x </b>";
$pagelinks .= " <a href=\"faceset.php?startpage=$x&facesperpage=$facesperpage&action=insertmultiple&facepath=$facepath&facesort=$facesort\">$x</a> ";
if ($startpage != $numpages) {
$nextstart = $startpage + 1;
$nextpage = " <a href='faceset.php?startpage=$nextstart&facesperpage=$facesperpage&action=insertmultiple&facepath=$facepath&facesort=$facesort'>></a>";
$eface = $endface + 1;
} else
$eface = $facecount;
if ($startpage!=1) {
$prevstart = $startpage - 1;
$prevpage = "<a href='faceset.php?startpage=$prevstart&facesperpage=$facesperpage&action=insertmultiple&facepath=$facepath&facesort=$facesort'><</a> ";
$sface = $startface + 1;
echo "<tr class='".getrowbg()."'><td align='center' colspan=8>顯示共 $facecount 個形像圖片中的 $sface 到 $eface 個<br><br>$prevpage $pagelinks $nextpage</td></tr>";
echo '</table>';
echo "<center><input type='hidden' name='facecount' value='$facecount'>
添加形像<input type='radio' name='action' value='domultiple' checked>
刪除圖片<input type='radio' name='action' value='del'></center>";
doformfooter("確定","重置",2,"返回");
closedir($dirhandle);
} else {
echo "<p><b>$facepath</b> 路徑沒有找到<br><input type=\"button\" value=\" 返回 \" onclick=\"history.back(1)\">";
// ###################### Start Del Multiple #######################
if ($HTTP_POST_VARS['action']=="del") {
if (is_array($faceuse)) {
$count=0;
while(list($key,$val)=each($faceuse)) {
$sp_graphic = $facepic[$key];
$sp_sxgraphic = $facepicx[$key];
$sp_sort = $facesort[$key];
if(@unlink("../images/face/$sp_sort/$sp_graphic")) echo "刪除 $sp_graphic 成功!<br>";else echo "刪除 $sp_graphic 失敗!<br>";
if(@unlink("../images/face/$sp_sort/$sp_sxgraphic")) echo "刪除 $sp_sxgraphic 成功!<br>";else echo "刪除 $sp_sxgraphic 失敗!<br>";
$count++;
} //end while
if ($count==$facecount) { // We inserted all of our available faces
$action="modify";
} else {
echo "<p><a href=\"faceset.php?action=insertmultiple&facepath=$facepath&facesperpage=$facesperpage&facesort=$sp_sort\">如果無法自動跳轉點擊這裡繼續</a></p>";
exit;
} else {
echo "<p>沒有選擇形像圖片<p><input type=button value=\" 返回 \" onclick=\"history.back(1)\">";
// ###################### Start Insert Multiple #######################
if ($HTTP_POST_VARS['action']=="domultiple") {
$count=0;
$sp_name = $facename[$key];
$sp_money = $facemoney[$key];
$sp_description = $faceinfo[$key];
$sp_wear = $facetime[$key];
$sp_fitherd = $faceuser[$key];
$sp_number = $facenumber[$key];
$DB_site->query("INSERT INTO week9_data (sort,sp_name,sp_money,sp_description,sp_wear,sp_fitherd,sp_graphic,sp_sxgraphic) VALUES ('$sp_sort', '".addslashes($sp_name)."', '".trim($sp_money)."', '".addslashes($sp_description)."', '".trim($sp_wear)."', '$sp_fitherd','".addslashes($sp_graphic)."','".addslashes($sp_sxgraphic)."','".(int)$sp_number."')");
$count++;
} //end while
$action="modify";
} else {
echo "<script language=\"javascript\">window.location=\"faceset.php?action=insertmultiple&facepath=$facepath&facesperpage=$facesperpage&facesort=$sp_sort\";</script>";
exit;
} else {
// ###################### Start Edit #######################
if ($action=="edit") {
$face=$DB_site->query_first("SELECT id,sort,sp_name,sp_description,sp_money,sp_wear,sp_graphic,sp_sxgraphic,sp_fitherd,sp_number FROM week9_data WHERE id=$faceid");
if("$facesort[id]"=="$face[sort]") $faceleibie .= " <option value=\"$facesort[id]\" selected>$facesort[name1]</option>";
else $faceleibie .= " <option value=\"$facesort[id]\">$facesort[name1]</option>";
doformheader("faceset","doupdate");
maketableheader("編輯形像圖片 $face[sp_name]");
makehiddencode("faceid","$faceid");
makehiddencode("sort","$sort");
makehiddencode("startpage","$startpage");
makehiddencode("perpage","$perpage");
echo "</td></tr><tr class='firstalt' ><td ><img src=\"../images/face/$face[sort]/$face[sp_graphic]\" alt='大圖片'>";
echo "<img src=\"../images/face/$face[sort]/$face[sp_sxgraphic]\" alt='小圖片'></td><td><table>";
makeinputcode("名稱","sp_name",$face[sp_name]);
makeinputcode("介紹","sp_description",$face[sp_description]);
makeinputcode("價格","sp_money",$face[sp_money]);
makeinputcode("耐用度","sp_wear",$face[sp_wear]);
makeinputcode("商品數量<br>(默認5個)","sp_number",$face[sp_number]);
echo "
<td><p>所屬分類</p></td>
<td><p>
<select name=\"sp_sort\" disabled>
$faceleibie
</select>分類無法更改,請將圖片添加到另一個分類,再把此分類中的刪除。
</p></td>
$sex=($face[sp_fitherd]=="m"?"sexm":($face[sp_fitherd]=="f"?"sexf":"sext"));
$$sex="selected";
echo "
<td><p>
<option value=\"t\" $sext>所有人</option>
<option value=\"m\" $sexm>帥哥</option>
<option value=\"f\" $sexf>美女</option>
</select>
echo "</table></td></tr>";
doformfooter("保存更改");
// ###################### Start Update #######################
if ($HTTP_POST_VARS['action']=="doupdate") {
$DB_site->query("UPDATE week9_data SET sp_name='".addslashes($sp_name)."',sp_description='".addslashes($sp_description)."',sp_money='".addslashes($sp_money)."',sp_wear='".addslashes($sp_wear)."',sp_fitherd='".addslashes($sp_fitherd)."',sp_number='".(int)$sp_number."' WHERE id='$faceid'");
echo "<p>形像圖片已更新!</p>";
$action="modify";
// ###################### Start Remove #######################
if ($action=="remove") {
doformheader("faceset","kill");
makehiddencode("faceid",$faceid);
makehiddencode("sort",$sort);
makehiddencode("sp_fitherd",$sp_fitherd);
makehiddencode("perpage",$perpage);
makehiddencode("startpage",$startpage);
maketableheader("確認刪除");
makedescription("你確實要刪除這個形像圖片嗎?");
doformfooter("是","",2,"否");
// ###################### Start Kill #######################
if ($HTTP_POST_VARS['action']=="kill") {
$DB_site->query("DELETE FROM week9_data WHERE id=$faceid");
echo "<p>已刪除!</p>";
$action="modify";
// ###################### Start Modify #######################
if ($action=="modify") {
$where=" where ";
if(!empty($sort)&&$sort<=25&&$sort>0) $where.="sort=$sort ";else $where.="1 ";
if($sp_number!="" && $sp_number>=0) $where.="and sp_number='$sp_number' ";
if(!empty($sp_fitherd)&&$sp_fitherd!="n") $where.="and sp_fitherd='$sp_fitherd' ";else $where.="and 1 ";
$startpage = 1;
if (intval($perpage)<1)
$perpage = 15;
$facecount=$DB_site->query_first("SELECT count(*) AS count FROM week9_data".$where);
$totalfaces = $facecount[count];
if (($startpage-1)*$perpage > $totalfaces) {
if ((($totalfaces / $perpage) - ((int) ($totalfaces / $perpage))) == 0)
$startpage = $totalfaces / $perpage;
$startpage = (int) ($totalfaces / $perpage) + 1;
$limitlower=($startpage-1)*$perpage+1;
$limitupper=($startpage)*$perpage;
if ($limitupper>$totalfaces) {
$limitupper=$totalfaces;
if ($limitlower>$totalfaces) {
$limitlower=$totalfaces-$perpage;
if ($limitlower<=0) {
$limitlower=1;
$faces=$DB_site->query("SELECT id,sort,sp_name,sp_description,sp_money,sp_wear,sp_sxgraphic,sp_fitherd,sp_number FROM week9_data ".$where."ORDER BY id LIMIT ".($limitlower-1).",$perpage");
if($facesort[id]==$sort) $faceleibie .= " <option value=\"$facesort[id]\" selected>$facesort[name1]</option>";
$liebie="<select name=\"facesort\" onchange=\"location.href='faceset.php?startpage=$prevstart&perpage=$perpage&action=modify&sp_fitherd=$sp_fitherd&sp_number=$sp_number&sort='+document.mod.facesort.options[document.mod.facesort.selectedIndex].value\"> <option value=\"26\">所有分類</option> $faceleibie </select>";
switch($sp_fitherd){
case "m":
$sex="sexm";break;
case "f":
$sex="sexf";break;
case "t":
$sex="sext";break;
default:$sex="sexn";
$$sex="selected";
$sex="<select name=\"sp_fitherd\" onchange=\"location.href='faceset.php?startpage=$prevstart&perpage=$perpage&action=modify&sort=$sort&sp_number=$sp_number&sp_fitherd='+document.mod.sp_fitherd.options[document.mod.sp_fitherd.selectedIndex].value\"><option value=\"n\" $sexn>列出全部</option><option value=\"t\" $sext>通用</option><option value=\"m\" $sexm>男用</option><option value=\"f\" $sexf>女用</option> </select>";
$chazhao="<input name=\"sp_number\" type=\"text\" value=\"$sp_number\" size=\"5\" maxlength=\"5\"> <input type=\"Submit\" name=\"Submit\" value=\"查找\"><input type=\"hidden\" name=\"sort\" value=\"$sort\">";
doformheader("faceset","modify",0,1,"mod");
maketableheader("形像類別:$liebie-------適用人群:$sex -------數量:$chazhao","",0,5);
$count=0;
$sex=($face[sp_fitherd]=="m"?"男用":($face[sp_fitherd]=="f"?"女用":"通用"));
$facesort = $DB_site->query("SELECT name1 FROM week9_class where id = '$face[sort]'");
$facesort=$DB_site->fetch_array($facesort);
$facesort=$facesort[name1];
//$sp_number=$DB_site->fetch_array($sp_number);
if ($count==0)
echo "<tr class='".getrowbg()."'>";
echo "<td valign='bottom'><img src=\"../images/face/$face[sort]/$face[sp_sxgraphic]\"><br>名稱/介紹:$face[sp_name]/$face[sp_description]<br>價格/耐用度:$face[sp_money]/$face[sp_wear]<br>數量:$face[sp_number]<br>適用/類別:$sex/$facesort<br>";
echo makelinkcode("編輯","faceset.php?s=$session[sessionhash]&action=edit&faceid=$face[id]&perpage=$perpage&startpage=$startpage&sp_fitherd=$sp_fitherd&sort=$sort");
echo makelinkcode("刪除","faceset.php?s=$session[sessionhash]&action=remove&faceid=$face[id]&perpage=$perpage&startpage=$startpage&sp_fitherd=$sp_fitherd&sort=$sort");
echo '</td>';
$count++;
if ($count==5) {
echo '</tr>';
$count = 0;
if ($count!=0) {
while ($count !=5) {
echo '<td> </td>';
$count++;
echo '</tr>';
$numpages = $totalfaces / $perpage;
$numpages = (int) ($totalfaces / $perpage) + 1;
$startface = 0;
$endface = $perpage - 1;
} else {
$startface = ($startpage - 1) * $perpage;
$endface = ( $perpage * $startpage ) - 1 ;
$pagelinks .= "<b> <font size=+1>$x</font> </b>";
$pagelinks .= " <a href=\"faceset.php?startpage=$x&perpage=$perpage&action=modify&sp_fitherd=$sp_fitherd&sort=$sort&sp_number=$sp_number\">$x</a> ";
$nextpage = " <a href='faceset.php?startpage=$nextstart&perpage=$perpage&action=modify&sp_fitherd=$sp_fitherd&sort=$sort'>></a>";
} else
$eface = $totalfaces;
$prevpage = "<a href='faceset.php?startpage=$prevstart&perpage=$perpage&action=modify'><</a> ";
echo "<tr class='".getrowbg()."'><td align=\"center\" colspan=5><table border=0><tr><td width=\"100%\" valign=\"top\" align=\"center\">";
echo "<b>顯示共 $totalfaces 個形像圖片中的 $sface 到 $eface 個</b></td><td nowrap><form action=\"face.php\" method=\"post\">";
echo "<b>每頁顯示:</b> <input type=\"text\" name=\"perpage\\" value=\"$perpage\" size=5> <input type=\"submit\" value=\"確定\">";
echo "</td></tr></table>$prevpage $pagelinks $nextpage</td></tr>";
echo "</table></td></tr></table></form>";
// ###################### Start update modifyclass #######################
if ($HTTP_POST_VARS['action']=="updatemodifyclass") {
if (is_array($classuse)) {
while(list($key,$val)=each($classuse)) {
$sql="UPDATE week9_class SET id=".(int)$key.",have='".(int)$have[$key]."',name1='".addslashes($name1[$key])."' where id=".(int)$key;
$DB_site->query($sql);
echo "<p>".(int)$key."修改成功!</p>";
} //end while
$action="modifyclass";
// ###################### Start modifyclass #######################
if ($action=="modifyclass") {
$leibie1 = $DB_site->query("SELECT * FROM week9_class");
while ($leibie = $DB_site->fetch_array($leibie1))
$faceleibie .= "<input value=\"".$leibie[id]."\" size=2>、<input name=\"name1[".$leibie[id]."]\" value=\"".StripSlashes($leibie[name1])."\"> <select name=\"have[".$leibie[id]."]\"><option value=\"1\" ".($leibie[have]=="1"?"selected":"").">顯示</option><option value=\"0\" ".($leibie[have]=="0"?"selected":"").">隱藏</option></select><input type='checkbox' name='classuse[".$leibie[id]."]' value='".$leibie[id]."'><br>
doformheader("faceset","updatemodifyclass");
maketableheader("編輯形像分類");
echo "
<td><p>編輯形像分類</p></td>
<td><p>
$faceleibie
</p></td>
doformfooter("保存修改");
cpfooter();
[/php]
動感超人
文章: 485
註冊時間: 2003-02-09 14:06
文章 由 動感超人 »
這是我改的
我試用過,應該可以用。
可能改的不好,其他高手可以幫忙改完美一點嗎^^?
[php]
<?php
define('IN_PHPBB', 1);
if( !empty($setmodules) )
$file = basename(__FILE__);
$module['face']['face_mod'] = $file."?action=modify";
$module['face']['face_add'] = $file."?action=add";
$module['face']['face_up'] = $file."?action=upload";
return;
// Let's set the root dir for phpBB
$phpbb_root_path = "./../";
require($phpbb_root_path . 'extension.inc');
require('./pagestart.' . $phpEx);
require($phpbb_root_path."includes/functions_face.php");
if (!empty($HTTP_POST_VARS['action']) || !empty($HTTP_GET_VARS['action']))
$action = (!empty($HTTP_POST_VARS['action'])) ? $HTTP_POST_VARS['action'] : $HTTP_GET_VARS['action'];
$action="modify";
if (!empty($HTTP_POST_VARS['sort']) || !empty($HTTP_GET_VARS['sort']))
$sort=(!empty($HTTP_POST_VARS['sort'])) ? $HTTP_POST_VARS['sort'] : $HTTP_GET_VARS['sort'];
if (!empty($HTTP_POST_VARS['sp_fitherd']) || !empty($HTTP_GET_VARS['sp_fitherd']))
$sp_fitherd=(!empty($HTTP_POST_VARS['sp_fitherd'])) ? $HTTP_POST_VARS['sp_fitherd'] : $HTTP_GET_VARS['sp_fitherd'];
if (!empty($HTTP_POST_VARS['startpage']) || !empty($HTTP_GET_VARS['startpage']))
$startpage=(!empty($HTTP_POST_VARS['startpage'])) ? $HTTP_POST_VARS['startpage'] : $HTTP_GET_VARS['startpage'];
if (!empty($HTTP_POST_VARS['perpage']) || !empty($HTTP_GET_VARS['perpage']))
$perpage=(!empty($HTTP_POST_VARS['perpage'])) ? $HTTP_POST_VARS['perpage'] : $HTTP_GET_VARS['perpage'];
if (!empty($HTTP_POST_VARS['faceid']) || !empty($HTTP_GET_VARS['faceid']))
$faceid=(!empty($HTTP_POST_VARS['faceid'])) ? $HTTP_POST_VARS['faceid'] : $HTTP_GET_VARS['faceid'];
$action="modify";
$leibie1 = $db->sql_query("SELECT * FROM week9_class where have = '1'");
while ($facesort = $db->sql_fetchrow($leibie1))
echo "<p><b>使用這項功能要求你的伺服器有PHP寫入檔的許可權。如果許可權不夠,操作將無法完成。</b></p>";
doformheader("admin_faceset","doupload",1);
maketableheader("從電腦中上傳新的形象圖片");
echo "
<td><p>上傳形象分類</p></td>
<td><p>
$faceleibie
</select>
</p></td>
makeuploadcode("圖示檔(大圖示)","sp_graphic");
makeuploadcode("圖示檔(小圖示)","sp_sxgraphic");
makeinputcode("形象名稱","sp_name");
makeinputcode("形象介紹","sp_description");
makeinputcode("商品數量<br>(預設5個)","sp_number","5");
echo "
<td><p>
</select>
doformfooter("上傳");
$sp_sort=$HTTP_POST_VARS['sp_sort'];
$sp_name=$HTTP_POST_VARS['sp_name'];
$sp_description=$HTTP_POST_VARS['sp_description'];
$sp_money=$HTTP_POST_VARS['sp_money'];
$sp_wear=$HTTP_POST_VARS['sp_wear'];
$sp_fitherd=$HTTP_POST_VARS['sp_fitherd'];
if("" == trim($name))
echo "上傳檔案名不能為空!<br> <a href=javascript:window.history.back()>點這裏返回修改</a>";
exit;
if("" == trim($namex))
exit;
if("" == trim($sp_name))
echo "<p align=center>名稱不能為空。<a href=javascript:history.back()>點這裏返回修改</a></p>";
exit;
if("" == trim($sp_description))
echo "<p align=center>介紹不能為空。<a href=javascript:history.back()>點這裏返回修改</a></p>";
exit;
if("" == trim($sp_money))
echo "<p align=center>售價不能為空。<a href=javascript:history.back()>點這裏返回修改</a></p>";
exit;
if("" == trim($sp_wear))
echo "<p align=center>使用時間不能為空。<a href=javascript:history.back()>點這裏返回修改</a></p>";
exit;
$sp_sortpath = trim($sp_sort);
if("" != $namex)
if(!preg_match("/.gif$/i",$namex))
echo "<p align=center>只允許上傳gif格式的檔。<a href=javascript:window.history.back()>點這裏返回修改</a></p>";
exit;
\s]'", "", $namex);
$result = $db->sql_query("SELECT COUNT(*) AS nr FROM week9_data WHERE sp_sxgraphic = '$sp_sxgraphic' and sort='$sp_sort'");
$faceidrows =$db->sql_fetchrow($result);
if ($nr != '0')
echo "這個檔已經存在在資料庫裏!<br> <a href=javascript:window.history.back()>點這裏返回修改</a>";
exit;
echo "<a href=javascript:window.history.back()>點這裏返回修改</a>";
exit;
if("" != $name)
if(!preg_match("/.gif$/i", $name))
exit;
}\r
\s]'", "", $name);
$result = $db->sql_query("SELECT COUNT(*) AS nr FROM week9_data WHERE sp_graphic = '$sp_graphic' and sort='$sp_sort'");
if ($nr != '0')
exit;
exit;
$db->sql_query("INSERT INTO week9_data (sort,sp_name,sp_money,sp_description,sp_wear,sp_fitherd,sp_graphic,sp_sxgraphic) VALUES ('$sp_sort', '".addslashes($sp_name)."', '".trim($sp_money)."', '".addslashes($sp_description)."', '".trim($sp_wear)."', '$sp_fitherd','".addslashes($sp_graphic)."','".addslashes($sp_sxgraphic)."')");
doformheader("admin_faceset","insert",0,1,"addone");
maketableheader("添加單個形象圖片");
echo "
<td><p>添加到形象分類</p></td>
<td><p>
$faceleibie
</select>
</p></td>
echo "
<td><p>
</select>
doformfooter("添加形象圖片");
// Add multiple
doformheader("admin_faceset","insertmultiple",0,1,"addmore");
maketableheader("添加一組形象圖片");
echo "
<td><p>
$faceleibie
</select>
</p></td>
makeinputcode("圖片路徑(要相對於vB論壇的主目錄)","facepath","images/face/2");
makeinputcode("每頁顯示的形象圖片數量?","facesperpage",20);
$sp_graphic=$HTTP_POST_VARS['sp_graphic'];
$sp_sxgraphic=$HTTP_POST_VARS['sp_sxgraphic'];
$db->sql_query("INSERT INTO week9_data (sort,sp_name,sp_money,sp_description,sp_wear,sp_fitherd,sp_graphic,sp_sxgraphic,sp_number) VALUES ('$sp_sort', '".addslashes($sp_name)."', '".trim($sp_money)."', '".addslashes($sp_description)."', '".trim($sp_wear)."', '$sp_fitherd','".addslashes($sp_graphic)."','".addslashes($sp_sxgraphic)."','".(int)($sp_number)."')");
exit;
function CheckAll()
var TotalBoxes = 0;
var TotalOn = 0;
TotalBoxes++;
if (e.checked)
TotalOn++;
</script>
<?php
if (!empty($HTTP_POST_VARS['facesort']) || !empty($HTTP_GET_VARS['facesort']))
$facesort=(!empty($HTTP_POST_VARS['facesort'])) ? $HTTP_POST_VARS['facesort'] : $HTTP_GET_VARS['facesort'];
if (!empty($HTTP_POST_VARS['facepath']) || !empty($HTTP_GET_VARS['facepath']))
$facepath=(!empty($HTTP_POST_VARS['facepath'])) ? $HTTP_POST_VARS['facepath'] : $HTTP_GET_VARS['facepath'];
if (!empty($HTTP_POST_VARS['facesperpage']) || !empty($HTTP_GET_VARS['facesperpage']))
$facesperpage=(!empty($HTTP_POST_VARS['facesperpage'])) ? $HTTP_POST_VARS['facesperpage'] : $HTTP_GET_VARS['facesperpage'];
$startpage = 1;
$facesperpage = 10;
$ok_exit='no';
doformheader("admin_faceset","",0,0,"form");
echo "<tr class='secondalt'><td align='center' colspan='8'>添加多個形象圖片從<b>$bburl/$facepath</b>到 分類 $facesort</td></tr>";
echo "<tr class='tblhead'><td align='center'><b><span class='tblhead'>大圖片</span></b></td><td align='center'><b><span class='tblhead'>小圖片</span></b></td><td align='center'><b><span class='tblhead'>名稱</span></b></td><td align='center'><b><span class='tblhead'>介紹</span></b></td><td align='center'><b><span class='tblhead'>價錢</span></b></td><td align='center'><b><span class='tblhead'>耐用度</b></span></td><td align='center'><b><span class='tblhead'>適合人群</span></b></td>";
$faces=$db->sql_query("SELECT sp_graphic FROM week9_data WHERE sort='$facesort'");
while ($face=$db->sql_fetchrow($faces)) {
$startface = 0;
} else {
echo "<td align='center'><img src='../$facepath/$FileArray[$x].gif' border=0 align='center'></td>";
echo "<td align='center'><img src='../$facepath/$FileArray[$x]x.gif' border=0 align='center'></td>";
echo "<td align='center'><input type='text' name='facename[$FileArray[$x]]' size=10 value='$FileArray[$x]'></td>";
echo "<td align='center'><input type='text' name='faceinfo[$FileArray[$x]]' size=10 value='$FileArray[$x]'></td>";
echo "<td align='center'><input type='text' name='facemoney[$FileArray[$x]]' size=5 value='100'></td>";
echo "<td align='center'><input type='text' name='facetime[$FileArray[$x]]' size=5 value='300'></td>";
echo "<td><select name=\"faceuser[$FileArray[$x]]\"><option value=\"t\" selected>所有人</option><option value=\"m\">帥哥</option><option value=\"f\">美女</option></select>";
echo "<td align='center'><input type='checkbox' name='faceuse[$FileArray[$x]]' value='yes'><input type='hidden' name='facepic[$FileArray[$x]]' value='$FileArray[$x].gif'><input type='hidden' name='facepicx[$FileArray[$x]]' value='$FileArray[$x]x.gif'><input type='hidden' value='$facesort' name='facesort[$FileArray[$x]]'></td></tr>";
$pagelinks .= " <a href=\"".append_sid("admin_faceset.php?startpage=$x&facesperpage=$facesperpage&action=insertmultiple&facepath=$facepath&facesort=$facesort")."\">$x</a> ";
$nextpage = " <a href=".append_sid("admin_faceset.php?startpage=$nextstart&facesperpage=$facesperpage&action=insertmultiple&facepath=$facepath&facesort=$facesort").">></a>";
} else
$prevpage = "<a href=".append_sid("admin_faceset.php?startpage=$prevstart&facesperpage=$facesperpage&action=insertmultiple&facepath=$facepath&facesort=$facesort")."><</a> ";
echo "<tr class='".getrowbg()."'><td align='center' colspan=8>顯示共 $facecount 個形象圖片中的 $sface 到 $eface 個<br><br>$prevpage $pagelinks $nextpage</td></tr>";
echo '</table>';
添加形象<input type='radio' name='action' value='domultiple' checked>
} else {
$faceuse=$HTTP_POST_VARS['faceuse'];
$facepic=$HTTP_POST_VARS['facepic'];
$facepicx=$HTTP_POST_VARS['facepicx'];
$facesort=$HTTP_POST_VARS['facesort'];
if (!empty($HTTP_POST_VARS['facecount']) || !empty($HTTP_GET_VARS['facecount']))
$facecount=(!empty($HTTP_POST_VARS['facecount'])) ? $HTTP_POST_VARS['facecount'] : $HTTP_GET_VARS['facecount'];
$count=0;
echo "../images/face/$sp_sort/$sp_graphic";
$count++;
} //end while
$action="modify";
} else {
echo "<p><a href=\"".append_sid("admin_faceset.php?action=insertmultiple&facepath=$facepath&facesperpage=$facesperpage&facesort=$sp_sort")."\">如果無法自動跳轉點擊這裏繼續</a></p>";
exit;
} else {
echo "<p>沒有選擇形象圖片<p><input type=button value=\" 返回 \" onclick=\"history.back(1)\">";
$facename=$HTTP_POST_VARS['facename'];
$facemoney=$HTTP_POST_VARS['facemoney'];
$faceinfo=$HTTP_POST_VARS['faceinfo'];
$facetime=$HTTP_POST_VARS['facetime'];
$faceuser=$HTTP_POST_VARS['faceuser'];
$count=0;
$db->sql_query("INSERT INTO week9_data (sort,sp_name,sp_money,sp_description,sp_wear,sp_fitherd,sp_graphic,sp_sxgraphic) VALUES ('$sp_sort', '".addslashes($sp_name)."', '".trim($sp_money)."', '".addslashes($sp_description)."', '".trim($sp_wear)."', '$sp_fitherd','".addslashes($sp_graphic)."','".addslashes($sp_sxgraphic)."','".(int)$sp_number."')");
$count++;
} //end while
$action="modify";
} else {
echo "<script language=\"javascript\">window.location=\"admin_faceset.php?action=insertmultiple&facepath=$facepath&facesperpage=$facesperpage&facesort=$sp_sort\";</script>";
echo "<p><a href=\"admin_faceset.php?action=insertmultiple&facepath=$facepath&facesperpage=$facesperpage&facesort=$sp_sort\">如果無法自動跳轉點擊這裏繼續</a></p>";
exit;
} else {
$result = $db->sql_query("SELECT id,sort,sp_name,sp_description,sp_money,sp_wear,sp_graphic,sp_sxgraphic,sp_fitherd,sp_number FROM week9_data WHERE id=$faceid");
$face=$db->sql_fetchrow($result);
doformheader("admin_faceset","doupdate");
maketableheader("編輯形象圖片 $face[sp_name]");
makeinputcode("商品數量<br>(預設5個)","sp_number",$face[sp_number]);
echo "
\n </tr>
<td><p>
$faceleibie
</p></td>
$$sex="selected";
echo "
<td><p>
</select>
\nif ($HTTP_POST_VARS['action']=="doupdate") {
$db->sql_query("UPDATE week9_data SET sp_name='".addslashes($sp_name)."',sp_description='".addslashes($sp_description)."',sp_money='".addslashes($sp_money)."',sp_wear='".addslashes($sp_wear)."',sp_fitherd='".addslashes($sp_fitherd)."',sp_number='".(int)$sp_number."' WHERE id='$faceid'");
echo "<p>形象圖片已更新!</p>";
$action="modify";
doformheader("admin_faceset","kill");
makedescription("你確實要刪除這個形象圖片嗎?");
$db->sql_query("DELETE FROM week9_data WHERE id=$faceid");
echo "<p>已刪除!</p>";
$action="modify";
$where=" where ";
$startpage = 1;
$perpage = 15;
$result = $db->sql_query("SELECT count(*) AS count FROM week9_data".$where);
$facecount=$db->sql_fetchrow($result);
$limitlower=1;
$faces=$db->sql_query("SELECT id,sort,sp_name,sp_description,sp_money,sp_wear,sp_sxgraphic,sp_fitherd,sp_number FROM week9_data ".$where."ORDER BY id LIMIT ".($limitlower-1).",$perpage");
$liebie="<select name=\"facesort\" onchange=\"location.href='".append_sid("admin_faceset.php?startpage=$prevstart&perpage=$perpage&action=modify&sp_fitherd=$sp_fitherd&sp_number=$sp_number")."&sort='+document.mod.facesort.options[document.mod.facesort.selectedIndex].value\"> <option value=\"26\">所有分類</option> $faceleibie </select>";
case "m":
$sex="sexm";break;
case "f":
$sex="sexf";break;
case "t":
$sex="sext";break;
$$sex="selected";
$sex="<select name=\"sp_fitherd\" onchange=\"location.href='".append_sid("admin_faceset.php?startpage=$prevstart&perpage=$perpage&action=modify&sort=$sort&sp_number=$sp_number")."&sp_fitherd='+document.mod.sp_fitherd.options[document.mod.sp_fitherd.selectedIndex].value\"><option value=\"n\" $sexn>列出全部</option><option value=\"t\" $sext>通用</option><option value=\"m\" $sexm>男用</option><option value=\"f\" $sexf>女用</option> </select>";
doformheader("admin_faceset","modify",0,1,"mod");
maketableheader("當前的形象圖片-------------形象類別:$liebie-------適用人群:$sex","",0,5);
$count=0;
$facesort = $db->sql_query("SELECT name1 FROM week9_class where id = '$face[sort]'");
$facesort=$db->sql_fetchrow($facesort);
if ($count==0)
echo makelinkcode("編輯","admin_faceset.php?s=$session[sessionhash]&action=edit&faceid=$face[id]&perpage=$perpage&startpage=$startpage&sp_fitherd=$sp_fitherd&sort=$sort");
echo makelinkcode("刪除","admin_faceset.php?s=$session[sessionhash]&action=remove&faceid=$face[id]&perpage=$perpage&startpage=$startpage&sp_fitherd=$sp_fitherd&sort=$sort");
echo '</td>';
$count++;
if ($count==5) {
echo '</tr>';
$count = 0;
if ($count!=0) {
echo '<td> </td>';
$count++;
echo '</tr>';
$startface = 0;
} else {
$pagelinks .= " <a href=\"".append_sid("admin_faceset.php?startpage=$x&perpage=$perpage&action=modify&sp_fitherd=$sp_fitherd&sort=$sort&sp_number=$sp_number")."\">$x</a> ";
$nextpage = " <a href='".append_sid("admin_faceset.php?startpage=$nextstart&perpage=$perpage&action=modify&sp_fitherd=$sp_fitherd&sort=$sort")."'>></a>";
} else
\n if ($startpage!=1) {
$prevpage = "<a href='".append_sid("admin_faceset.php?startpage=$prevstart&perpage=$perpage&action=modify")."'><</a> ";
echo "<b>顯示共 $totalfaces 個形象圖片中的 $sface 到 $eface 個</b></td><td nowrap><form action=\"face.php\" method=\"post\">";
echo "<b>每頁顯示:</b> <input type=\"text\" name=\"perpage\" value=\"$perpage\" size=5> <input type=\"submit\" value=\"確定\">";
//cpfooter();
[/php]
最後由 動感超人 於 2003-09-12 17:44 編輯,總共編輯了 3 次。
無限期蒸發中
Bot
文章: 26
註冊時間: 2002-11-13 01:05
文章 由 Bot »
表情符號偷跑出來了......
jiminkao
文章: 134
註冊時間: 2002-10-07 15:20
來自: 蜂炮之鄉
文章 由 jiminkao »
以下這兩段
[php]<?php
echo "
<td><p>
$faceleibie
</p></td>
?>[/php]
改成
[php]<?php
$db->sql_query($sql);
} //end while
$leibie1 = $db->sql_query("SELECT * FROM week9_class");
while ($leibie = $db->sql_fetchrow($leibie1))
doformheader("admin_faceset","updatemodifyclass");
echo "
<td><p>
$faceleibie
</p></td>
?>[/php]
然後在 " 動感超人 " PO 的檔案中找到\r
[php]<?php
?>[/php]
之下加入\r
[php]<?php
$module['face']['face_mcl'] = $file."?action=modifyclass";
?>[/php]
face_mcl 的名稱可自訂,如果想顯示中文,可直接改,或是在\r
lang_admin.php 中加入\r
[php]<?php
$lang['face_mcl'] = '分類編輯';
?>[/php]
目前使用版本 Nuke7.6
jiminkao
文章: 134
來自: 蜂炮之鄉
文章 由 jiminkao »
jiminkao 寫:以下這兩段
[php]<?php
} //end while
$faceleibie .= "<input value="".$leibie[id]."" size=2>、<input name="name1[".$leibie[id]."]" value="".StripSlashes($leibie[name1]).""> <select name="have[".$leibie[id]."]"><option value="1" ".($leibie[have]=="1"?"selected":"").">顯示</option><option value="0" ".($leibie[have]=="0"?"selected":"").">隱藏</option></select><input type='checkbox' name='classuse[".$leibie[id]."]' value='".$leibie[id]."'><br>
echo "
<td><p>
$faceleibie
</p></td>
?>[/php]
改成
[php]<?php
} //end while
\nwhile ($leibie = $db->sql_fetchrow($leibie1))
echo "
<td><p>
$faceleibie
</p></td>
?>[/php]
[php]<?php
?>[/php]
之下加入\r
[php]<?php
?>[/php]
[php]<?php
?>[/php]
目前使用版本 Nuke7.6
