使用版本:phpbb 2.05
網站位置:
Authors Notes:
## Instead of runing the SQL commands your self, I have also included a db_update.php file
## if you are loged in as ADMIN, you can run this file, witch will do the neasessary changes to the DB
## the file will by it self put prefix on your tables, else
## if you are using a prefix to you DB tabels then you have to add this to
## the [ADD SQL] commands, e.g. "phpbb_users" instead of just "users" - ONLY
## in the initial [ADD SQL] commands, not in the php code !
## The most important thing to keep in mind is, take your time, make
## sure you are finding the correct lines to modify, then take care to paste the new code.
## Please also keep in mind, if you are using more than one language file or theme at your
## site, you will need to edit the corrosponding files for each occurrence. Good Luck!
## and the Database
#-----[ ADD SQL ]------------------------------------------
SQL-query:
ALTER TABLE users ADD user_lastlogon INT (11) DEFAULT '0'
SQL-query:
UPDATE users SET user_lastlogon=user_lastvisit
SQL-query:
INSERT INTO config (config_name, config_value) VALUES ('hidde_last_logon', '0')
###############################################################這使我不敢安裝@@
還有的是在mod內有一個 dp_update.php 的
要把它上傳嗎??
謝謝^^
