[問題]論壇統計裡的字不見啦
夢幻LUGIA
文章: 352
註冊時間: 2003-11-16 07:27
來自: 竹貓不忠實會員
[問題]論壇統計裡的字不見啦
文章 由 夢幻LUGIA »
您的PHPBB版本:2.0.6
您的伺服器所在位置:http://members.lycos.co.uk/
您的問題敘述:我點選論壇統計這個頁面的時候,應該會出現的說明竟然都消失了
這是正常應該的樣子〈在自機測試〉
這是不正常的樣子〈在遠端主機的結果〉
以下是我在執行install/install_statistics.php時出現的錯誤訊息〈正常的部分就省略〉
>Installing Default Modules...
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 510
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 511
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 573
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 574
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 575
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 530
>Running :: SELECT max(module_order) as max_order FROM phpbb_modules -> COMPLETED
>Running :: INSERT INTO phpbb_modules (short_name, update_time, module_order, active) VALUES ('admin_statistics', 360, 10, 1) -> COMPLETED
>Running :: INSERT INTO phpbb_module_info (module_id, long_name, author, email, url, version, update_site, extra_info) VALUES (1, 'Administrative Statistics', 'Acyd Burn', 'acyd.burn@gmx.de', 'http://www.opentools.de', '3.0.0', 'http://www.opentools.de/board/show_modules.php', 'This Module displays some Admin Statistics about your Board. It is nearly the same you are able to see within the first Administration Panel visit.') -> COMPLETED
>Running :: INSERT INTO phpbb_module_cache (module_id, module_cache_time, db_cache, priority) VALUES (1, 0, '', 0) -> COMPLETED
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 540
>Warning: chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in 〈我的網站位置〉/install1/install_statistics.php on line 549
>Running :: INSERT INTO phpbb_modules (short_name, update_time, module_order, active) VALUES ('most_active_topics', 360, 20, 1) -> COMPLETED
>Running :: INSERT INTO phpbb_module_info (module_id, long_name, author, email, url, version, update_site, extra_info) VALUES (2, 'Most active Topics', 'Acyd Burn', 'acyd.burn@gmx.de', 'http://www.opentools.de', '3.0.0', 'http://www.opentools.de/board/show_modules.php', 'This Module displays the most active topics at your board.') -> COMPLETED
>Running :: INSERT INTO phpbb_module_cache (module_id, module_cache_time, db_cache, priority) VALUES (2, 0, '', 0) -> COMPLETED
>Running :: INSERT INTO phpbb_modules (short_name, update_time, module_order, active) VALUES ('most_viewed_topics', 360, 30, 1) -> COMPLETED
>Running :: INSERT INTO phpbb_module_info (module_id, long_name, author, email, url, version, update_site, extra_info) VALUES (3, 'Most viewed topics', 'Acyd Burn', 'acyd.burn@gmx.de', 'http://www.opentools.de', '3.0.0', 'http://www.opentools.de/board/show_modules.php', 'This Module displays the most viewed topics at your board.') -> COMPLETED
>Running :: INSERT INTO phpbb_module_cache (module_id, module_cache_time, db_cache, priority) VALUES (3, 0, '', 0) -> COMPLETED
>Running :: INSERT INTO phpbb_modules (short_name, update_time, module_order, active) VALUES ('top_posters', 360, 40, 1) -> COMPLETED
>Running :: INSERT INTO phpbb_module_info (module_id, long_name, author, email, url, version, update_site, extra_info) VALUES (4, 'Top Posters', 'Acyd Burn', 'acyd.burn@gmx.de', 'http://www.opentools.de', '3.0.0', 'http://www.opentools.de/board/show_modules.php', 'This Module displays the Top Posters from your board. Anonymous Poster are not counted.') -> COMPLETED
>Running :: INSERT INTO phpbb_module_cache (module_id, module_cache_time, db_cache, priority) VALUES (4, 0, '', 0) -> COMPLETED
>Running :: INSERT INTO phpbb_modules (short_name, update_time, module_order, active) VALUES ('top_smilies', 0, 50, 1) -> COMPLETED
>Running :: INSERT INTO phpbb_module_info (module_id, long_name, author, email, url, version, update_site, extra_info) VALUES (5, 'Top Smilies', 'Acyd Burn', 'acyd.burn@gmx.de', 'http://www.opentools.de', '3.0.0', 'http://www.opentools.de/board/show_modules.php', 'This Module displays the Top Smilies used at your board. This Module uses an Smilie Index Table for caching the smilie data and to not require re-indexing of all posts.') -> COMPLETED
>Running :: INSERT INTO phpbb_module_cache (module_id, module_cache_time, db_cache, priority) VALUES (5, 0, '', 0) -> COMPLETED
不知道這是不是跟安全性或是權限有關,我是架設在lycos的空間裡的
不知道有沒有辦法解決?
