[問題]有關管理人不受簽名檔限制
antony chan
文章: 18
註冊時間: 2003-12-12 15:46
[問題]有關管理人不受簽名檔限制
文章 由 antony chan »
未知能否同時加入版主呢?
這是原code:
<?php
##   Hack Title:   No signature length limit for admins.
##   Hack Version:   1.0.0
##   Author:      Antony Bailey
##   Description:   Removes the signature length limit for admins.
##   Compatibility:   2.0.0 - 2.0.6
##   Installation Level: Easy
##   Installation Time: 1 minute
##   Files To Edit: 1
##      usercp_register.php
##   History:
##      1.0.0:    Release.
##   Author Notes:
##      What? I wanted to do this for me as I roxor!
##   Support:      http://www.phpbbhacks.com/forums
\n##   Copyright:      ?003 No signature length limit for admins 1.0.0 - Antony Bailey
##   You downloaded this hack from phpBBHacks.com, the #1 source for phpBB related downloads.
##   Please visit http://www.phpbbhacks.com/forums for support.
##   This hack is released under the GPL License.
##   This hack can be freely used, but not distributed, without permission.
##   Intellectual Property is retained by the hack author(s) listed above.
includes/usercp_register.php
	if ( $signature != '' )
		if ( strlen(preg_replace('#(<)([\/]?.*?)(>)#is', "", preg_replace('#(\[)([\/]?.*?)(\])#is', "",$signature))) > $board_config['max_sig_chars'] )
			$error = TRUE;
			$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Signature_too_long'];
#-----[ REPLACE, WITH ]------------------------------------------
	if ($userdata['user_level'] != ADMIN )
			$error = TRUE;
#-----[ SAVE & CLOSE ALL FILES ]--------------------------
#End
最後由 antony chan 於 2003-12-30 01:52 編輯,總共編輯了 2 次。
aiken
文章: 1514
註冊時間: 2003-11-09 11:02
來自: 大頭真論壇
文章 由 aiken »
antony chan
文章: 18
文章 由 antony chan »
對不起啊....
已經補回有關的原mods了..>_<!
