[閒聊]這是傳說中的雙胞胎論壇互通MOD嗎
ilove1291
文章: 171
註冊時間: 2003-04-19 22:44
文章 由 ilove1291 »
http://www.phpbb.com/phpBB/viewtopic.ph ... highlight=
FIND - Forum Integrated News Delivery - Input
Updated: 20030807 @ 00:26 GMT
  • Current Version: 1.0.2
    confirmed 2.0.6 compatible
    Lots of fixes.
    Fixed annoying bug with forum list in admin page.
    Split newsfeed source to seperate admin page, now uses it's own rss
    Fixed parsing issues.
    Tested with EasyMod 0.0.10a
This mod takes your typical common or garden rss / xml news feeds and delivers them direct to your forums, i.e. inserts them as posts right into the forum(s) of your choice.
It should be setup to use an existing user account. Each feed can be delivered by a different user. Each news feed can be delivered to a different forum. You can limit the number of articles which will be returned from the news feed.
All the topic / post counts of both the forums and the user are kept up to date. Also all the search information is updated.
StickyKid
文章: 1019
註冊時間: 2003-01-31 10:32
來自: Taichung, Taiwan
文章 由 StickyKid »
應該不是吧 一口一.....
有News耶....
bu
文章: 443
註冊時間: 2003-02-23 12:46
來自: 25° 4′N 121° 29′E
文章 由 bu »
phpbb文件有指出如何讓二論壇用同一個會員資料表的文章
*譯文資料在phpBB 技術文件
*bu.femto-size
*和我聯絡,請寄 or Google Talk 圖檔
StickyKid
文章: 1019
文章 由 StickyKid »
bu 寫:phpbb文件有指出如何讓二論壇用同一個會員資料表的文章
哦~ 我沒看清楚 :oops:
ilove1291
文章: 171
[問題]RSS XML
文章 由 ilove1291 »
上面說的rss是不是這裡說的rss
http://phpbb-tw.net/phpbb/viewtopic.php ... hlight=rss
那我可不可以在我的fourm讀別人的rss放出來呢
