後台增加版塊出錯,可是原先的卻可以修改.
Couldn't insert row in forums table
SQL Error : 1064 You have an error in your SQL syntax near ' 0, 0, 0, 0, 1, 1, 3, 3, 1, 1, 1, 1)' at line 2
INSERT INTO phpbb_forums (forum_id, forum_name, cat_id, forum_desc, forum_order, forum_status, prune_enable.forum_topictypes, forum_topictype_today, auth_view, auth_read, auth_post, auth_reply, auth_edit, auth_delete, auth_sticky, auth_announce, auth_vote, auth_pollcreate, auth_attachments, auth_download) VALUES ('9', 'tewst', 1, 'tte', 30, 0, 0,'',, 0, 0, 0, 0, 1, 1, 3, 3, 1, 1, 1, 1)
Line : 412
File : /var/www/html/phpbb2/admin/admin_forums.php
[問題]後台增加版塊出錯!
你要先說一下做了什麼動作啊......!?
七點要求:
1. 發問前先搜尋,確定沒有重複後再發表
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
七點要求:
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
Re: [問題]後台增加版塊出錯!
把haiyun 寫:auth_pollcreate, auth_attachments, auth_download) VALUES ('9', 'tewst', 1, 'tte', 30, 0, 0,'',, 0, 0, 0, 0, 1, 1, 3, 3, 1, 1, 1, 1)
VALUES ('9', 'tewst', 1, 'tte', 30, 0, 0,'','', 0, 0, 0, 0, 1, 1, 3, 3, 1, 1, 1, 1)
