[問題]Last Visit MOD 1.27 安裝後出現!
VirtualCell
註冊時間: 2004-03-04 21:23
文章 由 VirtualCell »
我安裝了Last Visit MOD 1.27 之後
重新安裝phpBB討論區(連資料庫一並清空)
結果我安裝完成把install,contrib兩個資料夾殺掉
也上傳完config.php了
結果在首頁出現:
message_die() was called multiple times. This isn't supposed to happen. Was message_die() used in page_tail.php?
的字樣\r
但是page_tail.php裡根本沒呼叫到message_die()這個東西= =
經我判斷應該是Last Visit MOD 1.27 的問題.....
請各位大大幫個忙看一下是哪錯啦><
謝謝......
ps.我還裝了attach_mod這個外掛...不過應該沒關係吧(我想)
<?php
 *                                index.php
 *   $Id: index.php,v 1.99.2.1 2002/12/19 17:17:40 psotfx Exp $
define('IN_PHPBB', true);
$phpbb_root_path = './';
require($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_main_link.' . $phpEx);
// Start session management
init_userprefs($userdata);
// End session management
// Closed Category Mod
if (isset($HTTP_GET_VARS['cat_show']))
   setcookie($board_config['cookie_name'] . '_cat_' . $HTTP_GET_VARS['cat_show'] . '_hide', '0', (time() + 31536000), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
   header("Location: index.$phpEx");
if (isset($HTTP_GET_VARS['cat_hide']))
   setcookie($board_config['cookie_name'] . '_cat_' . $HTTP_GET_VARS['cat_hide'] . '_hide', '1', (time() + 31536000), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
$viewcat = ( !empty($HTTP_GET_VARS[POST_CAT_URL]) ) ? $HTTP_GET_VARS[POST_CAT_URL] : -1;
if( isset($HTTP_GET_VARS['mark']) || isset($HTTP_POST_VARS['mark']) )
	$mark_read = ( isset($HTTP_POST_VARS['mark']) ) ? $HTTP_POST_VARS['mark'] : $HTTP_GET_VARS['mark'];
	$mark_read = '';
// Handle marking posts
if( $mark_read == 'forums' )
		setcookie($board_config['cookie_name'] . '_f_all', time(), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
	$template->assign_vars(array(
		"META" => '<meta http-equiv="refresh" content="3;url='  .append_sid("index.$phpEx") . '">')
	$message = $lang['Forums_marked_read'] . '<br /><br />' . sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a> ');
// End handle marking posts
$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_t"]) : array();
$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_f"]) : array();
// If you don't use these stats on your index you may want to consider
// removing them
$total_posts = get_db_stat('postcount');
$total_users = get_db_stat('usercount');
$newest_userdata = get_db_stat('newestuser');
$newest_user = $newest_userdata['username'];
$newest_uid = $newest_userdata['user_id'];
if( $total_posts == 0 )
	$l_total_post_s = $lang['Posted_articles_zero_total'];
else if( $total_posts == 1 )
	$l_total_post_s = $lang['Posted_article_total'];
	$l_total_post_s = $lang['Posted_articles_total'];
if( $total_users == 0 )
	$l_total_user_s = $lang['Registered_users_zero_total'];
else if( $total_users == 1 )
	$l_total_user_s = $lang['Registered_user_total'];
	$l_total_user_s = $lang['Registered_users_total'];
// Start page proper
$sql = "SELECT c.cat_id, c.cat_title, c.cat_order
	FROM " . CATEGORIES_TABLE . " c
	ORDER BY c.cat_order";
	message_die(GENERAL_ERROR, 'Could not query categories list', '', __LINE__, __FILE__, $sql);
while( $category_rows[] = $db->sql_fetchrow($result) );
if( ( $total_categories = count($category_rows) ) )
	// Define appropriate SQL
	switch(SQL_LAYER)
		case 'postgresql':
			$sql = "SELECT f.*, p.post_time, p.post_username, u.username, u.user_id
				FROM " . FORUMS_TABLE . " f, " . POSTS_TABLE . " p, " . USERS_TABLE . " u
				WHERE p.post_id = f.forum_last_post_id
					AND u.user_id = p.poster_id
					UNION (
						SELECT f.*, NULL, NULL, NULL, NULL
						WHERE NOT EXISTS (
							SELECT p.post_time
							FROM " . POSTS_TABLE . " p
					ORDER BY cat_id, forum_order";
			break;
		case 'oracle':
				WHERE p.post_id = f.forum_last_post_id(+)
					AND u.user_id = p.poster_id(+)
			break;
		default:
				FROM (( " . FORUMS_TABLE . " f
				LEFT JOIN " . POSTS_TABLE . " p ON p.post_id = f.forum_last_post_id )
				LEFT JOIN " . USERS_TABLE . " u ON u.user_id = p.poster_id )
			break;
		message_die(GENERAL_ERROR, 'Could not query forums information', '', __LINE__, __FILE__, $sql);
	$forum_data = array();
		$forum_data[] = $row;
	if ( !($total_forums = count($forum_data)) )
		message_die(GENERAL_MESSAGE, $lang['No_forums']);
	// Obtain a list of topic ids which contain
	// posts made since user last visited
		$sql = "SELECT t.forum_id, t.topic_id, p.post_time
			FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
			WHERE p.post_id = t.topic_last_post_id
				AND p.post_time > " . $userdata['user_lastvisit'] . "
				AND t.topic_moved_id = 0";
			message_die(GENERAL_ERROR, 'Could not query new topic information', '', __LINE__, __FILE__, $sql);
		$new_topic_data = array();
		while( $topic_data = $db->sql_fetchrow($result) )
			$new_topic_data[$topic_data['forum_id']][$topic_data['topic_id']] = $topic_data['post_time'];
	// Obtain list of moderators of each forum
	// First users, then groups ... broken into two queries
	$sql = "SELECT aa.forum_id, u.user_id, u.username
		FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
		WHERE aa.auth_mod = " . TRUE . "
			AND g.group_single_user = 1
			AND ug.group_id = aa.group_id
			AND g.group_id = aa.group_id
			AND u.user_id = ug.user_id
		GROUP BY u.user_id, u.username, aa.forum_id
		ORDER BY aa.forum_id, u.user_id";
		message_die(GENERAL_ERROR, 'Could not query forum moderator information', '', __LINE__, __FILE__, $sql);
	$forum_moderators = array();
		$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '">' . $row['username'] . '</a>';
	$sql = "SELECT aa.forum_id, g.group_id, g.group_name
			AND g.group_single_user = 0
			AND g.group_type <> " . GROUP_HIDDEN . "
		GROUP BY g.group_id, g.group_name, aa.forum_id
		ORDER BY aa.forum_id, g.group_id";
		$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("groupcp.$phpEx?" . POST_GROUPS_URL . "=" . $row['group_id']) . '">' . $row['group_name'] . '</a>';
	// Find which forums are visible for this user
	$is_auth_ary = array();
	$is_auth_ary = auth(AUTH_VIEW, AUTH_LIST_ALL, $userdata, $forum_data);
               $sql = "SELECT *
		FROM ". LINK_CONFIG_TABLE;
	if(!$result = $db->sql_query($sql))
		message_die(GENERAL_ERROR, "Could not query Link config information", "", __LINE__, __FILE__, $sql);
		$link_config_name = $row['config_name'];
		$link_config_value = $row['config_value'];
		$link_config[$link_config_name] = $link_config_value;
		$link_self_img = $link_config['site_logo'];
		$site_logo_height = $link_config['height'];
		$site_logo_width = $link_config['width'];
// Start add - Last visit MOD
$time_now=time();
$time1Hour=$time_now-3600;
$minutes = date('is', $time_now);
$hour_now = $time_now - (60*($minutes[0].$minutes[1])) - ($minutes[2].$minutes[3]);
$dato=create_date('H', $time_now,$board_config['board_timezone']);
$timetoday = $hour_now - (3600*$dato);
$sql = 'SELECT session_ip, MAX(session_time) as session_time FROM '.SESSIONS_TABLE.' WHERE session_user_id="'.ANONYMOUS.'" AND session_time >= '.$timetoday.' AND session_time< '.($timetoday+86399).' GROUP BY session_ip';
if (!$result = $db->sql_query($sql)) message_die(GENERAL_ERROR, "Couldn't retrieve guest user today data", "", __LINE__, __FILE__, $sql);
while( $guest_list = $db->sql_fetchrow($result))
	if ($guest_list['session_time'] >$time1Hour) $users_lasthour++;
$guests_today = $db->sql_numrows($result);
$sql = 'SELECT user_id,username,user_allow_viewonline,user_level,user_lastlogon FROM ' . USERS_TABLE . ' WHERE user_id!="'.ANONYMOUS.'" AND user_session_time >= '.$timetoday.' AND user_session_time< '.($timetoday+86399).' ORDER BY username';
if (!$result = $db->sql_query($sql)) message_die(GENERAL_ERROR, "Couldn't retrieve user today data", "", __LINE__, __FILE__, $sql);
while( $todayrow = $db->sql_fetchrow($result))
	$style_color = "";
	if ($todayrow['user_lastlogon']>=$time1Hour)
		$users_lasthour++;
	switch ($todayrow['user_level'])
		case ADMIN :
		      $todayrow['username'] = '<b>' . $todayrow['username'] . '</b>';
      		$style_color = 'style="color:#' . $theme['fontcolor3'] . '"';
			break;
		case MOD :
      		$style_color = 'style="color:#' . $theme['fontcolor2'] . '"';
			break;
 	$users_today_list.=( $todayrow['user_allow_viewonline'])?' <a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $todayrow['user_id']) . '"' . $style_color .'>' . $todayrow['username'] . '</a>,' : (($userdata[user_level]==ADMIN) ? ' <a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $todayrow['user_id']) . '"' . $style_color .'><i>' . $todayrow['username'] . '</i></a>,' : '');
	if (!$todayrow['user_allow_viewonline']) $logged_hidden_today++;
	else $logged_visible_today++;
if ($users_today_list)
	$users_today_list[ strlen( $users_today_list)-1] = ' ';
} else
	$users_today_list = $lang['None'];
$total_users_today = $db->sql_numrows($result)+$guests_today;
$users_today_list = $lang['Registered_users'].' ' . $users_today_list;
$l_today_user_s = ($total_users_today) ? ( ( $total_users_today == 1 )? $lang['User_today_total'] : $lang['Users_today_total'] ) : $lang['Users_today_zero_total'];
$l_today_r_user_s = ($logged_visible_today) ? ( ( $logged_visible_today == 1 ) ? $lang['Reg_user_total'] : $lang['Reg_users_total'] ) : $lang['Reg_users_zero_total'];
$l_today_h_user_s = ($logged_hidden_today) ? (($logged_hidden_today == 1) ? $lang['Hidden_user_total'] : $lang['Hidden_users_total'] ) : $lang['Hidden_users_zero_total'];
$l_today_g_user_s = ($guests_today) ? (($guests_today == 1) ? $lang['Guest_user_total'] : $lang['Guest_users_total']) : $lang['Guest_users_zero_total'];
$l_today_users = sprintf($l_today_user_s, $total_users_today);
$l_today_users .= sprintf($l_today_r_user_s, $logged_visible_today);
$l_today_users .= sprintf($l_today_h_user_s, $logged_hidden_today);
$l_today_users .= sprintf($l_today_g_user_s, $guests_today);
// End add - Last visit MOD
	// Start output of page
	define('SHOW_ONLINE', true);
	$page_title = $lang['Index'];
	include($phpbb_root_path . 'includes/page_header.'.$phpEx);\r
                              'news' => 'index_news.tpl',
		'body' => 'index_body.tpl')
		'TOTAL_POSTS' => sprintf($l_total_post_s, $total_posts),
		'TOTAL_USERS' => sprintf($l_total_user_s, $total_users),
		'NEWEST_USER' => sprintf($lang['Newest_user'], '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$newest_uid") . '">', $newest_user, '</a>'),
		'FORUM_IMG' => $images['forum'],
		'FORUM_NEW_IMG' => $images['forum_new'],
        'USERS_TODAY_LIST' => $users_today_list,
        'L_USERS_LASTHOUR' =>($users_lasthour)?sprintf($lang['Users_lasthour_explain'],$users_lasthour):$lang['Users_lasthour_none_explain'],
		'L_USERS_TODAY' =>$l_today_users,
\n        // End add - Last visit MOD
                              'U_SHOUTBOX' => append_sid("shoutbox.$phpEx"),
                              'L_SHOUTBOX' => $lang['Shoutbox'],
                              'U_SHOUTBOX_MAX' => append_sid("shoutbox_max.$phpEx"),
		'L_FORUM' => $lang['Forum'],
		'L_TOPICS' => $lang['Topics'],
		'L_REPLIES' => $lang['Replies'],
		'L_VIEWS' => $lang['Views'],
		'L_POSTS' => $lang['Posts'],
		'L_LASTPOST' => $lang['Last_Post'],
		'L_NO_NEW_POSTS' => $lang['No_new_posts'],
		'L_NEW_POSTS' => $lang['New_posts'],
		'L_NO_NEW_POSTS_LOCKED' => $lang['No_new_posts_locked'],
		'L_NEW_POSTS_LOCKED' => $lang['New_posts_locked'],
		'L_ONLINE_EXPLAIN' => $lang['Online_explain'],
                              'L_LINKS' => $lang['Site_links'],
		'U_LINKS' => append_sid("links.$phpEx"),
		'U_LINKS_JS' => "links.js.$phpEx",
		'U_SITE_LOGO' => $link_self_img,
		'SITE_LOGO_WIDTH' => $site_logo_width,
		'SITE_LOGO_HEIGHT' => $site_logo_height,
		'L_MODERATOR' => $lang['Moderators'],
		'L_FORUM_LOCKED' => $lang['Forum_is_locked'],
		'L_MARK_FORUMS_READ' => $lang['Mark_all_forums'],
		'U_MARK_READ' => append_sid("index.$phpEx?mark=forums"))
               if( isset($board_config['news_display']) && $board_config['news_display'] )
		include($phpbb_root_path . 'includes/news.'.$phpEx);
		$template->assign_var_from_handle('NEWS', 'news');
	// Okay, let's build the index
	for($i = 0; $i < $total_categories; $i++)
		$cat_id = $category_rows[$i]['cat_id'];
		// Should we display this category/forum set?
		$display_forums = false;
		for($j = 0; $j < $total_forums; $j++)
			if ( $is_auth_ary[$forum_data[$j]['forum_id']]['auth_view'] && $forum_data[$j]['cat_id'] == $cat_id )
				$display_forums = true;
		// Yes, we should, so first dump out the category
		// title, then, if appropriate the forum list
		if ( $display_forums )
         // Hide Category Mod (Note. 預設關閉的分區, 請將分區名稱之前加上 ::NC::, ::NC:: 將不會被顯示出來)
         if (!isset($HTTP_COOKIE_VARS[ $board_config['cookie_name'] . '_cat_' . $cat_id . '_hide']))
            $hide_cat[$cat_id] = (substr($category_rows[$i]['cat_title'], 0, 6) == "::NC::") ? 1 : 0;
            $hide_cat[$cat_id] = $HTTP_COOKIE_VARS[ $board_config['cookie_name'] . '_cat_' . $cat_id . '_hide'];
         $cat_title = (substr($category_rows[$i]['cat_title'], 0, 6) == "::NC::") ? ltrim(substr($category_rows[$i]['cat_title'], 6)) : $category_rows[$i]['cat_title'];
         if ($hide_cat[$cat_id] == 1)
            $cat_showhide = 'cat_show';
            $cat_showhide_img = 'icon_plus.gif';
            $cat_showhide = 'cat_hide';
            $cat_showhide_img = 'icon_minus.gif';
         $template->assign_block_vars('catrow', array(
            'CAT_ID' => $cat_id,
            'CAT_DESC' => $cat_title,
            'CAT_TYPE' => '<a href="' . append_sid("index.$phpEx?" . $cat_showhide . "=" . $cat_id) . "\" class=\"cattitle\"><img src=\"images/$cat_showhide_img\" hspace=\"1\" border=\"0\" /></a> ",
            'U_VIEWCAT' => append_sid("index.$phpEx?" . POST_CAT_URL . "=$cat_id")
            continue;
			if ( $viewcat == $cat_id || $viewcat == -1 )
					if ( $forum_data[$j]['cat_id'] == $cat_id )
						$forum_id = $forum_data[$j]['forum_id'];
						if ( $is_auth_ary[$forum_id]['auth_view'] )
							if ( $forum_data[$j]['forum_status'] == FORUM_LOCKED )
								$folder_image = $images['forum_locked'];
								$folder_alt = $lang['Forum_locked'];
								$unread_topics = false;
									if ( !empty($new_topic_data[$forum_id]) )
										$forum_last_post_time = 0;
										while( list($check_topic_id, $check_post_time) = @each($new_topic_data[$forum_id]) )
											if ( empty($tracking_topics[$check_topic_id]) )
												$unread_topics = true;
												$forum_last_post_time = max($check_post_time, $forum_last_post_time);
												if ( $tracking_topics[$check_topic_id] < $check_post_time )
										if ( !empty($tracking_forums[$forum_id]) )
											if ( $tracking_forums[$forum_id] > $forum_last_post_time )
										if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all']) )
											if ( $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all'] > $forum_last_post_time )
								$folder_image = ( $unread_topics ) ? $images['forum_new'] : $images['forum'];
								$folder_alt = ( $unread_topics ) ? $lang['New_posts'] : $lang['No_new_posts'];
							$posts = $forum_data[$j]['forum_posts'];
							$topics = $forum_data[$j]['forum_topics'];
							if ( $forum_data[$j]['forum_last_post_id'] )
								$last_post_time = create_date($board_config['default_dateformat'], $forum_data[$j]['post_time'], $board_config['board_timezone']);
								$last_post = $last_post_time . '<br />';
								$last_post .= ( $forum_data[$j]['user_id'] == ANONYMOUS ) ? ( ($forum_data[$j]['post_username'] != '' ) ? $forum_data[$j]['post_username'] . ' ' : $lang['Guest'] . ' ' ) : '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '='  . $forum_data[$j]['user_id']) . '">' . $forum_data[$j]['username'] . '</a> ';
								$last_post .= '<a href="' . append_sid("viewtopic.$phpEx?"  . POST_POST_URL . '=' . $forum_data[$j]['forum_last_post_id']) . '#' . $forum_data[$j]['forum_last_post_id'] . '"><img src="' . $images['icon_latest_reply'] . '" border="0" alt="' . $lang['View_latest_post'] . '" title="' . $lang['View_latest_post'] . '" /></a>';
								$last_post = $lang['No_Posts'];
							if ( count($forum_moderators[$forum_id]) > 0 )
								$l_moderators = ( count($forum_moderators[$forum_id]) == 1 ) ? $lang['Moderator'] : $lang['Moderators'];
								$moderator_list = implode(', ', $forum_moderators[$forum_id]);
								$l_moderators = ' ';
								$moderator_list = ' ';
							$template->assign_block_vars('catrow.forumrow',	array(
								'ROW_CLASS' => $row_class,
								'FORUM_FOLDER_IMG' => $folder_image,
								'FORUM_NAME' => $forum_data[$j]['forum_name'],
								'FORUM_DESC' => $forum_data[$j]['forum_desc'],
								'POSTS' => $forum_data[$j]['forum_posts'],
								'TOPICS' => $forum_data[$j]['forum_topics'],
								'LAST_POST' => $last_post,
								'MODERATORS' => $moderator_list,
								'L_MODERATOR' => $l_moderators,
								'L_FORUM_FOLDER_ALT' => $folder_alt,
								'U_VIEWFORUM' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"))
	} // for ... categories
}// if ... total_categories
// Generate the page
$template->pparse('body');
aiken
文章: 1514
註冊時間: 2003-11-09 11:02
來自: 大頭真論壇
文章 由 aiken »
http://phpbb-tw.net/phpbb/search.php
關鍵字"message_die()"
第三篇, 第七篇的方法先試試看
歡迎多加利用搜尋功能
VirtualCell
文章 由 VirtualCell »
我看過了.....這是有關於原本資料表就存在時的問題
但是本人的是全新安裝的喔!!
arti
文章: 52
註冊時間: 2003-09-28 09:00
文章 由 arti »
這Last Visit MOD 1.27 外掛我有安裝,
沒遇到大大說的這問題,
會不會是哪兒沒改好,要不要再檢查一次,
不要忘了SQL要新增進去。
