[問題]快速回覆PLUS進階版1.11 + 黃牌系統(解決)
athlon
文章: 82
註冊時間: 2002-09-23 04:00
文章 athlon »
問題外掛: 快速回覆PLUS進階版1.11 + 黃牌系統
快速回覆PLUS進階版
黃牌系統官方討論版
使用版本:PBPBB206
網站位置:建構中
快速回覆PLUS進階版安裝後,無法使用快速回覆或引用文章
會出現網頁出現錯誤
連預覽也出現一樣的錯誤訊息\r
其他黃牌功能沒有問題
一般錯誤
No action specified
mode=""
Line : 87
File : c:\appserv\www\phpbb\card.php
card.php小弟並未做任何修改\r
附上
define('IN_PHPBB', true);
// Load default header
$phpbb_root_path = "./";
// Find what we are to do
$mode = ( isset($HTTP_POST_VARS['report_x']) ) ? 'report' :
		((isset($HTTP_POST_VARS['report_reset_x']) ) ? 'report_reset' :
			((isset($HTTP_POST_VARS['ban_x']) ) ? 'ban' :
				((isset($HTTP_POST_VARS['unban_x']) ) ? 'unban' :
					((isset($HTTP_POST_VARS['warn_x']) ) ? 'warn' :
						((isset($HTTP_POST_VARS['block_x']) ) ? 'block' : ''
$post_id = ( isset($HTTP_POST_VARS['post_id']) ) ? intval ($HTTP_POST_VARS['post_id']) : '';
$user_id = ( isset($HTTP_POST_VARS[POST_USERS_URL]) ) ? intval ($HTTP_POST_VARS[POST_USERS_URL]) : '';
// check that we have all what is needed to know
if ( !( $post_id + $user_id ) )
	message_die(GENERAL_ERROR, "No user/post specified", "", __LINE__, __FILE__,'post_id="'.$post_id.'", user_id="'.$user_id.'"');
if ( empty($mode) )
	message_die(GENERAL_ERROR, "No action specified", "", __LINE__, __FILE__,'mode="'.$mode.'"');
$sql = 'SELECT DISTINCT forum_id, poster_id, post_bluecard FROM ' . POSTS_TABLE . ' WHERE post_id = "'.$post_id.'"';
      message_die(GENERAL_ERROR, "Couldn't obtain forums information.", "", __LINE__, __FILE__, $sql);
$result = $db->sql_fetchrow($result);
$blue_card = $result['post_bluecard'];
if ( $post_id )
	// post mode
	$forum_id = $result['forum_id'];
	$poster_id = $result['poster_id'];
} else
if ( $user_id )
	//user mode
	//forum_id will control witch permission, when no post_id is given, and a user_id is given instead
	//disable the frum_id line will give no default access when no post_id is given
	// installe extra permission mod, in order to enable this feature
//	$forum_id = PAGE_CARD;
	$poster_id = $user_id;
$userdata = session_pagestart($user_ip, PAGE_CARD);
init_userprefs($userdata);
// Start auth check
$is_auth = array();
$is_auth = auth(AUTH_ALL, $forum_id, $userdata);
if ($mode=="report_reset")
	if (! $is_auth['auth_mod'])
		message_die(GENERAL_ERROR, $lang['Not_Authorised']);
	$sql = 'SELECT pt.post_subject, f.forum_name FROM '.POSTS_TEXT_TABLE.' pt, '.POSTS_TABLE.' p, '.FORUMS_TABLE.' f WHERE pt.post_id="'.$post_id.'" AND p.post_id=pt.post_id AND p.forum_id=f.forum_id';
	     	message_die(GENERAL_ERROR, "Couldn't get post subject information".$sql);
	$subject = $db->sql_fetchrow($result);
	$post_subject=$subject['post_subject'];
	$forum_name=$subject['forum_name'];
 	$sql = 'UPDATE ' . POSTS_TABLE . ' SET post_bluecard="0" WHERE post_id="'.$post_id.'"';
	      	message_die(GENERAL_ERROR, "Couldn't update blue card information");
	message_die(GENERAL_MESSAGE, $lang['Post_reset']."<br /><br />".
	sprintf($lang['Click_return_viewtopic'], "<a href=\"" . append_sid("viewtopic.$phpEx?p=".$post_id."#".$post_id). "\">", "</a>"));
} else
if ($mode=="report")
	if (!$is_auth['auth_bluecard'])
	$sql = 'SELECT f.forum_name, p.topic_id  FROM '.POSTS_TABLE.' p, '.FORUMS_TABLE.' f WHERE p.post_id="'.$post_id.'" AND  p.forum_id=f.forum_id';
	     	message_die(GENERAL_ERROR, "Couldn't get post subject information");
	$post_details = $db->sql_fetchrow($result);
	$forum_name=$post_details['forum_name'];
	$topic_id=$post_details['topic_id'];
	$sql = 'SELECT pt.post_subject FROM '.POSTS_TEXT_TABLE.' pt, '.TOPICS_TABLE.' t WHERE t.topic_id="'.$topic_id.'" AND pt.post_id=t.topic_first_post_id';
     		message_die(GENERAL_ERROR, "Couldn't get topic subject information".$sql);
	$post_subject=$post_details['post_subject'];
	$sql = 'SELECT p.topic_id FROM '.POSTS_TEXT_TABLE.' pt, '.POSTS_TABLE.' p  WHERE pt.post_subject="('.$post_id.')'.$post_subject.'" AND pt.post_id=p.post_id';
	$allready_reported= ($blue_card) ? $post_details['topic_id'] : '';
	$blue_card++;
	$sql = 'UPDATE ' . POSTS_TABLE . ' SET post_bluecard="'.$blue_card.'" WHERE post_id="'.$post_id.'"';
      // Obtain list of moderators of this forum
     	$sql = "SELECT g.group_name, u.username, u.user_email, u.user_lang
     		FROM " . AUTH_ACCESS_TABLE . " aa,  " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
	      WHERE aa.forum_id = $forum_id   AND aa.auth_mod = " . TRUE . "
     		AND ug.group_id = aa.group_id   AND g.group_id = aa.group_id AND u.user_id = ug.user_id";
      if( !$result_mods = $db->sql_query($sql) )
		message_die(GENERAL_ERROR, "Couldn't obtain moderators information.", "", __LINE__, __FILE__, $sql);
	$total_mods = $db->sql_numrows($result_mods);
	$i=0;
      if (!$total_mods)
		 message_die(GENERAL_MESSAGE, $lang['No_moderators']."<br /><br />".
		(($board_config['report_forum'])? sprintf($lang['Send_message'], "<a href=\"" . append_sid("posting.$phpEx?mode=".(($allready_reported)?"reply&t=".$allready_reported:"newtopic&f=".$board_config['report_forum'])."&postreport=".$post_id). "\">", "</a>"):"").
      if ((	$blue_card>=$board_config['bluecard_limit_2'] && (!(($blue_card-$board_config['bluecard_limit_2'])%$board_config['bluecard_limit']))) || $blue_card==$board_config['bluecard_limit_2'])
		$mods_rowset = $db->sql_fetchrowset($result_mods);
	      include($phpbb_root_path . 'includes/emailer.'.$phpEx);
	      while ($i<$total_mods)
			$script_name = preg_replace('/^\/?(.*?)\/?$/', '\1', trim($board_config['script_path'])). '/viewtopic.'.$phpEx;
			$server_name = trim($board_config['server_name']);
			$server_protocol = ( $board_config['cookie_secure'] ) ? 'https://' : 'http://';
			$server_port = ( $board_config['server_port'] <> 80 ) ? ':' . trim($board_config['server_port']) . '/' : '/';
            	$emailer = new emailer($board_config['smtp_delivery']);
	            $emailer->email_address($mods_rowset[$i]['user_email']);
      	      $email_headers = "To: \"".$mods_rowset[$i]['username']."\" <".$mods_rowset[$i]['user_email']. ">
	            $email_headers .= "From: \"".$board_config['sitename']."\" <".$board_config['board_email'].">
      	      $email_headers .= "Return-Path: " . (($userdata['user_email']&&$userdata['user_viewemail'])? $userdata['user_email']."
            	$email_headers .= "X-AntiAbuse: Board servername - " . $server_name . "
	            $email_headers .= "X-AntiAbuse: User_id - " . $userdata['user_id'] . "
      	      $email_headers .= "X-AntiAbuse: Username - " . $userdata['username'] . "
            	$email_headers .= "X-AntiAbuse: User IP - " . decode_ip($user_ip) . "
	            $emailer->use_template("repport_post",(file_exists($phpbb_root_path . "language/lang_" . $mods_rowset[$i]['user_lang'] . "/email/repport_post.tpl"))?$mods_rowset[$i]['user_lang'] : "");
      	      $i++;
//            	$emailer->set_subject($lang['Post_repport']);
	            $emailer->extra_headers($email_headers);
      	      $emailer->assign_vars(array(
			   'POST_URL' => $server_protocol . $server_name . $server_port . $script_name . '?' . POST_POST_URL . "=$post_id#$post_id",
			   'POST_SUBJECT' => $post_subject,
			   'FORUM_NAME' => $forum_name,
	               'USER' => '"'.$userdata['username'].'"',
            	   'NUMBER_OF_REPPORTS' => $blue_card,
	               'SITENAME' => $board_config['sitename'],
      	         'BOARD_EMAIL' => $board_config['board_email']));
            	$emailer->send();
	            $emailer->reset();
	message_die(GENERAL_MESSAGE, (($total_mods)?sprintf($lang['Post_repported'],$total_mods):$lang['Post_repported_1'])."<br /><br />".
} else
if ( $mode == 'unban' )
      $no_error_ban=FALSE;
	if (! $is_auth['auth_greencard'] )
	// look up the user
	$sql = 'SELECT user_active, user_warnings FROM ' . USERS_TABLE . ' WHERE user_id="'.$poster_id.'"';
      	message_die(GENERAL_ERROR, "Couldn't obtain judge information.", "", __LINE__, __FILE__, $sql);
	$the_user = $db->sql_fetchrow($result);
      // remove the user from ban list
      $sql = 'DELETE FROM ' . BANLIST_TABLE . ' WHERE ban_userid="'.$poster_id.'"';
      if (! $result = $db->sql_query($sql) )
            message_die(GENERAL_ERROR, "Couldn't remove ban_userid info into database", "", __LINE__, __FILE__, $sql);
      // update the user table with new status
      $sql = 'UPDATE ' . USERS_TABLE . ' SET user_warnings="0" WHERE user_id="'.$poster_id.'"';
      if(! $result = $db->sql_query($sql) )
		message_die(GENERAL_ERROR, "Couldn't update user status information", "", __LINE__, __FILE__, $sql);
	$message = $lang['Ban_update_green']."<br /><br />".
		sprintf($lang['Send_PM_user'], "<a href=\"" . append_sid("privmsg.$phpEx?mode=post&u=$poster_id"). "\">", "</a>");
      $e_temp="ban_reactivated";
//      $e_subj=$lang['Ban_reactivate'];
      $no_error_ban=true;
} else
if ( $mode == 'ban' )
	if (! $is_auth['auth_ban'] )
	// look up the user
	$sql = 'SELECT user_active, user_level FROM ' . USERS_TABLE . ' WHERE user_id="'.$poster_id.'"';
	if ($the_user['user_level']== ADMIN )
		message_die(GENERAL_ERROR, $lang['Ban_no_admin']);
	// insert the user in the ban list
      $sql = 'SELECT ban_userid FROM ' . BANLIST_TABLE . ' WHERE ban_userid="'.$poster_id.'"';
      if( $result = $db->sql_query($sql) )
		if (!$db->sql_fetchrowset($result))
			$sql = "INSERT INTO " . BANLIST_TABLE . " (ban_userid) VALUES ($poster_id)";
			if (!$result = $db->sql_query($sql) )
				message_die(GENERAL_ERROR, "Couldn't insert ban_userid info into database", "", __LINE__, __FILE__, $sql);
 			$sql = 'UPDATE ' . USERS_TABLE . ' SET user_warnings="'.$board_config['max_user_bancard'].'" WHERE user_id="'.$poster_id.'"';
			$sql = 'UPDATE ' . SESSIONS_TABLE . ' SET session_logged_in="0" WHERE session_user_id="'.$poster_id.'"';
			if ( !$db->sql_query($sql) )
				message_die(GENERAL_ERROR, "Couldn't update banned sessions from database", "", __LINE__, __FILE__, $sql);
			$no_error_ban=true;
			$message = $lang['Ban_update_red'];
			$e_temp="ban_block";
//			$e_subj=$lang['Card_banned'];
		} else
      		$no_error_ban = true;
			$message = $lang['user_already_banned'];
	} else message_die(GENERAL_ERROR, "Couldn't obtain banlist information", "", __LINE__, __FILE__, $sql);
} else
if ( $mode == 'block' )
	if (empty($board_config['block_time']) )
		message_die(GENERAL_ERROR, "Protect user account mod not installed, this is required for this operation");
	// look up the user
		message_die(GENERAL_ERROR, $lang['Block_no_admin']);
	$sql = 'UPDATE ' . USERS_TABLE . ' SET user_block_by="'.$user_ip.'", user_blocktime="'.(time()+$board_config['RY_block_time']*60).'" WHERE user_id="'.$poster_id.'"';
	$sql = 'UPDATE ' . SESSIONS_TABLE . ' SET session_logged_in="0", session_user_id=".ANONYMOUS." WHERE session_user_id="'.$poster_id.'"';
		message_die(GENERAL_ERROR, "Couldn't update blocked sessions from database", "", __LINE__, __FILE__, $sql);
	$no_error_ban=true;
	$block_time = make_time_text ($board_config['RY_block_time']);
	$message = sprintf($lang['Block_update'],$block_time) . "<br /><br />".
	$e_temp="card_block";
//	$e_subj=sprintf($lang['Card_blocked'],$block_time);
} else
if ( $mode == 'warn' )
	// look up the user
	$sql = 'SELECT user_active, user_warnings, user_level FROM ' . USERS_TABLE . ' WHERE user_id="'.$poster_id.'"';
	//update the warning counter
	$sql = 'UPDATE ' . USERS_TABLE . ' SET user_warnings=user_warnings+1 WHERE user_id="'.$poster_id.'"';
      // se if the user are to be banned, if so do it ...
      if ($the_user['user_warnings']+1>=$board_config['max_user_bancard'])
			$no_error_ban=true;
//			$e_subj=$lang['Ban_blocked'];
            } else
	} else
		// the user shall not be baned this time, update the counter
	      $message = sprintf($lang['Ban_update_yellow'],$the_user['user_warnings']+1,$board_config['max_user_bancard'])."<br /><br />".
sprintf($lang['Send_PM_user'], "<a href=\"" . append_sid("privmsg.$phpEx?mode=post&u=$poster_id"). "\">", "</a>");		$no_error_ban=true;
	      $e_temp="ban_warning";
//	      $e_subj=$lang['Ban_warning'];
if ($no_error_ban)
	$sql = 'SELECT username, user_warnings, user_email, user_lang FROM ' . USERS_TABLE . ' WHERE user_id="'.$poster_id.'"';
		message_die(GENERAL_ERROR, "Couldn't find the users personal information", "", __LINE__, __FILE__, $sql);
	$warning_data=$db->sql_fetchrow($result);
      if (!empty($warning_data['user_email']))
            $email_headers = "TO: '".$warning_data['username']."' <".$warning_data['user_email']. ">
		$email_headers .= ($userdata['user_email'] && $userdata['user_viewemail']) ?
			"FROM: \"".$userdata['username']."\" <".$userdata['user_email'].">
			"FROM: \"".$board_config['sitename']."\" <" .$board_config['board_email'] . ">
	      $emailer->use_template($e_temp, stripslashes($warning_data['user_lang']));
            $emailer->email_address($warning_data['user_email']);
//            $emailer->set_subject($e_subj);
	            'WARNINGS' => $warning_data['user_warnings'],
      	      'TOTAL_WARN' => $board_config['max_user_bancard'],
      	      'EMAIL_SIG' => str_replace("<br />", "
" . $board_config['board_email_sig']),
            	'WARNER' => $userdata['username'],
			'BLOCK_TIME' => $block_time,
	            'WARNED_POSTER' => $warning_data['username'])
//            if ($e_subj)
			$emailer->send();
            $emailer->reset();
	 	$message .= "<br/><br/>".$lang['user_no_email'];
	$message = 'Error card.php file';
}\r
$message .= ( $post_id != '-1' ) ? "<br /><br />". sprintf($lang['Click_return_viewtopic'], "<a href=\"" . append_sid("viewtopic.$phpEx?p=".$post_id."#".$post_id). "\">", "</a>"):"<br /><br />". sprintf($lang['Click_return_index'], "<a href=\"" . append_sid("index.".$phpEx). "\">", "</a>");
重新安裝數次結果依然相同,檢查了一整天無法解決,請教各位前輩有無解答,謝謝~
補充:
CASH MOD
黃卡\r
快速回覆PLUS進階版
最後由 athlon 於 2004-03-05 23:01 編輯,總共編輯了 1 次。
吉川拓也
文章: 1215
註冊時間: 2003-02-09 18:24
來自: [ G.I.T ]
文章 吉川拓也 »
這個跟你的安裝外掛沒有關係 ..
你應該是更動了黃卡系統的預設位置所以會這樣 @_@
直接把 viewtopic_body.tpl 要修改的部份"按照"修改即可 !!
善用 搜尋 可以解決您 90% 的問題
頭腦清晰,選擇正確。 (╯▔︹▔)╯~╘═╛
athlon
文章: 82
文章 athlon »
謝謝大大的回覆
我找到的原因是因為黃卡系統的這一段\r
viewtopic_body.tpl
<!-- Start add - Yellow card admin MOD -->
</form>
<!-- End add - Yellow card admin MOD -->
小弟測試了放置的位置\r
要在整段</td>之後...
再一次的謝謝大大
吉川拓也
文章: 1215
來自: [ G.I.T ]
文章 吉川拓也 »
athlon 寫:謝謝大大的回覆
我找到的原因是因為黃卡系統的這一段\r
viewtopic_body.tpl
</form>
小弟測試了放置的位置\r
要在整段</td>之後...
再一次的謝謝大大
請不用客氣 (因為之前也有相同經驗= =..)
能幫上妳我很開心 :oops:
善用 搜尋 可以解決您 90% 的問題
