[問題]裝完水怪和虛擬銀行(bank_cv2)遇到的問題.....
barkleyc
註冊時間: 2004-03-06 22:48
文章 由 barkleyc »
●架設主機作業系統:win XP
●快速架站程式:Appserv
●您的上網方式:hinet ADSL\r
●您安裝的程式:Apache + php + MySql
●您的 phpBB2 版本:phpBB 2.0.5
●您的 domain(網域名稱) :whasdo.no-ip.info
●您的 phpBB2 連結網址: http://whasdo.no-ip.info/phpbb/index.php
●錯誤:
裝完cash mod以後,我按畫面上方的"銀行" 結果他顯示:
Warning: main(rpg/function_rpg.): failed to open stream: No such file or directory in c:\appserv\www\phpbb\bank.php on line 3
Warning: main(): Failed opening 'rpg/function_rpg.' for inclusion (include_path='.;c:\php4\pear') in c:\appserv\www\phpbb\bank.php on line 3
Hacking attempt
另外我按"水怪rpg"則出現:
Warning: main(./rpg/menu.php): failed to open stream: No such file or directory in c:\appserv\www\phpbb
pg.php on line 31
Warning: main(): Failed opening './rpg/menu.php' for inclusion (include_path='.;c:\php4\pear') in c:\appserv\www\phpbb
pg.php on line 31
還有阿~
我現在版內的文章點進去看後 都跑出:
Could not obtain post/user information.
SQL Error : 1054 Unknown column 'u.user_robfail' in 'field list'
SELECT u.username, u.user_money, u.user_id, u.user_posts, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile,u.user_robfail, u.rpg_level, u.rpg_cur_hp, u.rpg_max_hp, u.rpg_cur_mp, u.rpg_max_mp, u.rpg_cur_exp, u.rpg_max_exp, u.rpg_attack, u.rpg_defense, u.rpg_magic, u.rpg_speed, u.rpg_medals, p.*, pt.post_text, pt.post_subject, pt.bbcode_uid FROM phpbb_posts p, phpbb_users u, phpbb_posts_text pt WHERE p.topic_id = 5 AND pt.post_id = p.post_id AND u.user_id = p.poster_id ORDER BY p.post_time ASC LIMIT 0, 15
Line : 395
File : c:\appserv\www\phpbb\viewtopic.php
(ps.第三個問題 我的站先用備份檔了,所以看不到這問題)
可以請問一下該怎麼作嗎?
我剛開始學phpbb,找了好多文章 可是還是不知道該怎麼辦耶\r
麻煩幫幫我吧!!
barkleyc
文章 由 barkleyc »
除此之外 有時候我要po文章時 再整個畫面的最上方(phpbb的結構之外)
會出現\r
Warning: main(./rpg/function_rpg.php): failed to open stream: No such file or directory in c:\appserv\www\phpbb\includes\functions_post.php on line 26
Warning: main(): Failed opening './rpg/function_rpg.php' for inclusion (include_path='.;c:\php4\pear') in c:\appserv\www\phpbb\includes\functions_post.php on line 26
然後文章發表完畫面會出現\r
Error in postingUPDATE phpbb_users SET user_posts = user_posts + 1 , rpg_cur_hp = rpg_cur_hp - 3, rpg_cur_mp = rpg_cur_mp - 3, rpg_cur_exp = rpg_cur_exp + 3 WHERE user_id = 2
SQL Error : 1196 Warning: Some non-transactional changed tables couldn't be rolled back
Line : 482
File : c:\appserv\www\phpbb\includes\functions_post.php
不過文章還是可以發表就是了
還有阿 同一個主題的所有文章的畫面中,本來各作者的錢應該會在她的名字下面...
可是現在變成每個人錢的數量通通跑到最上面去了.....@@"
裝完水怪以後才這樣的
