[問題]Re全區公告外掛之問題?(已解決)
Andy Lee
文章: 83
註冊時間: 2004-02-25 15:16
文章 由 Andy Lee »
:idea: 小弟已依說明將Global Announcement 1.2.8版安裝及修改,但進入後發現畫面一點都沒變,why?
可是其他功能似乎完全正常咧!!!
最後由 Andy Lee 於 2004-03-11 11:09 編輯,總共編輯了 1 次。
天霜
文章: 882
註冊時間: 2003-04-15 19:40
來自: 星之鄉學園
文章 由 天霜 »
在發表主題的頁面\r
看"發表主題為:"後面有沒有多出東西來
除非是個人疏失所造成的問題
這世界還有拼命守護的價值嗎...
Andy Lee
文章: 83
文章 由 Andy Lee »
哈哈!天霜兄,我發現是自己把操作順序顛倒,後來試著進入文章看,才發現已經進不去了。剛把所有修改的部份還原,正努力重新掛上,有問題再請教您了!
~左手翻雲、右手覆雨~
http://www.gagawulala.net/phpBB2
jessie
文章: 149
註冊時間: 2004-03-05 19:49
來自: Fann.City
文章 由 jessie »
[php]<?php
Failed obtaining forum access control lists
SQL Error : 1054 Unknown column 'a.auth_globalannounce' in 'field list'
SELECT a.forum_id, a.auth_view, a.auth_read, a.auth_post, a.auth_reply, a.auth_edit, a.auth_delete, a.auth_sticky, a.auth_announce, a.auth_vote, a.auth_pollcreate, a.auth_globalannounce, a.auth_mod FROM phpbb_auth_access a, phpbb_user_group ug WHERE ug.user_id = 2 AND ug.user_pending = 0 AND a.group_id = ug.group_id
Line : 160
File : c:\appserv\www\phpbb\includes\auth.php
?>[/php]
請問我這是什麼問題呢?
附上檔案..
case AUTH_ALL:
			$a_sql = 'a.auth_view, a.auth_read, a.auth_post, a.auth_reply, a.auth_edit, a.auth_delete, a.auth_sticky, a.auth_announce, a.auth_vote, a.auth_pollcreate, a.auth_globalannounce';
			$auth_fields = array('auth_view', 'auth_read', 'auth_post', 'auth_reply', 'auth_edit', 'auth_delete', 'auth_sticky', 'auth_announce', 'auth_vote', 'auth_pollcreate', 'auth_globalannounce');
			break;
		case AUTH_VIEW:
			$a_sql = 'a.auth_view';
			$auth_fields = array('auth_view');
			break;
		case AUTH_READ:
			$a_sql = 'a.auth_read';
			$auth_fields = array('auth_read');
			break;
		case AUTH_POST:
			$a_sql = 'a.auth_post';
			$auth_fields = array('auth_post');
			break;
		case AUTH_REPLY:
			$a_sql = 'a.auth_reply';
			$auth_fields = array('auth_reply');
			break;
		case AUTH_EDIT:
			$a_sql = 'a.auth_edit';
			$auth_fields = array('auth_edit');
			break;
		case AUTH_DELETE:
			$a_sql = 'a.auth_delete';
			$auth_fields = array('auth_delete');
			break;
		case AUTH_ANNOUNCE:
			$a_sql = 'a.auth_announce';
			$auth_fields = array('auth_announce');
			break;
		case AUTH_STICKY:
			$a_sql = 'a.auth_sticky';
			$auth_fields = array('auth_sticky');
			break;
		case AUTH_POLLCREATE:
			$a_sql = 'a.auth_pollcreate';
			$auth_fields = array('auth_pollcreate');
			break;
		case AUTH_VOTE:
			$a_sql = 'a.auth_vote';
			$auth_fields = array('auth_vote');
			break;
		case AUTH_ATTACH:
			break;
		case AUTH_GLOBALANNOUNCE:
$a_sql = 'a.auth_globalannounce';
$auth_fields = array('auth_globalannounce');
●架設主機作業系統:WindowsXP
●快速架站程式:Appserv2.3.0
●上網方式:中華電信ADSL
●安裝的程式:Apache + php + MySql
●phpBB2 版本: 2.0.8a
●安裝的外掛
