外掛名稱:Multiple BBCode Mod
外掛版本:1.2.1
綠色部份看不明,請問要把紅色的部份加到那裡??
#-----[ OPEN ]---------------------------------
templates/subSilver/posting_body.tpl
#-----[ FIND ]---------------------------------
# NOTE - the complete line to find is:
# function helpline(help) {
function helpline(
// MULTI BBCODE-start
// put an "n" in front of the value to make it an acceptable variable name
if ((help == '1') || (help == '2') || (help == '3') || (help == '4') || (help == '5') || (help == '6') || (help == '7') || (help == '8') || (help == '9') || (help == '0'))
help = 'n' + help ;
// MULTI BBCODE-end
[問題]Multiple BBCode MOD安裝說明看不明
FIND=>搜尋字串\r
AFTER, ADD=字串下方加入\r
這篇都有明寫了
http://phpbb-tw.net/phpbb/viewtopic.php?t=22832
但是你好像都沒爬文章唷\r
[主題鎖定]
AFTER, ADD=字串下方加入\r
這篇都有明寫了
但是你好像都沒爬文章唷\r
[主題鎖定]
