[問題]裝完split topic type沒顥示(己解決)
sky0610
文章: 32
註冊時間: 2004-04-05 09:20
文章 由 sky0610 »
問題外掛:公告置頂分區Split topic type2.0.1
使用版本:(phpBB 2.0.8a)
網站位置:建立中\r
裝完在首頁完全沒有顯示公告置頂分區
在後台是有Configuration +
我的code
viewforum_body.tpl
<form method="post" action="{S_POST_DAYS_ACTION}">
  <table width="100%" cellspacing="2" cellpadding="2" border="0" align="center">
	  <td align="left" valign="bottom" colspan="2"><span class="gensmall"><b>{L_MODERATOR}: {MODERATORS}<br />{LOGGED_IN_USER_LIST}</b></span></td>
	  <td align="right" valign="bottom" nowrap="nowrap"><span class="gensmall"><b>{PAGINATION}</b></span></td>
	  <td align="left" valign="middle" width="50"><a href="{U_POST_NEW_TOPIC}"><img src="{POST_IMG}" border="0" alt="{L_POST_NEW_TOPIC}" /></a></td>
	  <td align="left" valign="middle" class="nav" width="100%"><span class="nav">   <a href="{U_INDEX}" class="nav">{L_INDEX}</a> » <a class="nav" href="{U_VIEW_FORUM}">{FORUM_NAME}</a></span></td>
	  <td align="right" valign="bottom" class="nav" nowrap="nowrap"><span class="gensmall"><a href="{U_MARK_READ}">{L_MARK_TOPICS_READ}</a></span></td>
  </table>
{TOPICS_LIST_BOX}
  <table width="100%" cellspacing="2" border="0" align="center" cellpadding="2">
	  <td align="left" valign="middle" width="100%"><span class="nav">   <a href="{U_INDEX}" class="nav">{L_INDEX}</a> » <a class="nav" href="{U_VIEW_FORUM}">{FORUM_NAME}</a></span></td>
	  <td align="right" valign="middle" nowrap="nowrap"><span class="gensmall">{S_TIMEZONE}</span><br /><span class="nav">{PAGINATION}</span>
		</td>
	  <td align="left" colspan="3"><span class="nav">{PAGE_NUMBER}</span></td>
  </table>
</form>
<table width="100%" border="0" cellspacing="0" cellpadding="0">
	<td align="right">{JUMPBOX}</td>
</table>
<table width="100%" cellspacing="0" border="0" align="center" cellpadding="0">
		<td align="left" valign="top"><table cellspacing="3" cellpadding="0" border="0">
				<td width="20" align="left"><img src="{FOLDER_NEW_IMG}" alt="{L_NEW_POSTS}" width="19" height="18" /></td>
				<td class="gensmall">{L_NEW_POSTS}</td>
				<td>  </td>
				<td width="20" align="center"><img src="{FOLDER_IMG}" alt="{L_NO_NEW_POSTS}" width="19" height="18" /></td>
				<td class="gensmall">{L_NO_NEW_POSTS}</td>
				<td width="20" align="center"><img src="{FOLDER_HOT_NEW_IMG}" alt="{L_NEW_POSTS_HOT}" width="19" height="18" /></td>
				<td class="gensmall">{L_NEW_POSTS_HOT}</td>
				<td>  </td>
				<td width="20" align="center"><img src="{FOLDER_HOT_IMG}" alt="{L_NO_NEW_POSTS_HOT}" width="19" height="18" /></td>
				<td class="gensmall">{L_NO_NEW_POSTS_HOT}</td>
				<td class="gensmall"><img src="{FOLDER_LOCKED_NEW_IMG}" alt="{L_NEW_POSTS_TOPIC_LOCKED}" width="19" height="18" /></td>
				<td class="gensmall">{L_NEW_POSTS_LOCKED}</td>
				<td>  </td>
				<td class="gensmall"><img src="{FOLDER_LOCKED_IMG}" alt="{L_NO_NEW_POSTS_TOPIC_LOCKED}" width="19" height="18" /></td>
				<td class="gensmall">{L_NO_NEW_POSTS_LOCKED}</td>
		</table></td>
		<td align="right"><span class="gensmall">{S_AUTH_LIST}</span></td>
</table>
functions.php
<?php
//-- mod : mods settings ---------------------------------------------------------------------------
//-- mod : language settings -----------------------------------------------------------------------
 *                               functions.php
 *   $Id: functions.php,v 1.133.2.31 2003/07/20 13:14:27 acydburn Exp $
function get_db_stat($mode)
	global $db;
	switch( $mode )
		case 'usercount':
			$sql = "SELECT COUNT(user_id) AS total
				FROM " . USERS_TABLE . "
				WHERE user_id <> " . ANONYMOUS;
			break;
		case 'newestuser':
			$sql = "SELECT user_id, username
				WHERE user_id <> " . ANONYMOUS . "
				ORDER BY user_id DESC
				LIMIT 1";
			break;
		case 'postcount':
		case 'topiccount':
			$sql = "SELECT SUM(forum_topics) AS topic_total, SUM(forum_posts) AS post_total
				FROM " . FORUMS_TABLE;
			break;
		return false;
	switch ( $mode )
		case 'usercount':
			return $row['total'];
			break;
		case 'newestuser':
			return $row;
			break;
		case 'postcount':
			return $row['post_total'];
			break;
		case 'topiccount':
			return $row['topic_total'];
			break;
	return false;
// Get Userdata, $user can be username or user_id. If force_str is true, the username will be forced.
function get_userdata($user, $force_str = false)
	global $db;
	if (intval($user) == 0 || $force_str)
		$user = trim(htmlspecialchars($user));
		$user = substr(str_replace("\\\'", "'", $user), 0, 25);
		$user = str_replace("'", "\\\'", $user);
		$user = intval($user);
	$sql = "SELECT *
		WHERE ";
	$sql .= ( ( is_integer($user) ) ? "user_id = $user" : "username = '" .  $user . "'" ) . " AND user_id <> " . ANONYMOUS;
		message_die(GENERAL_ERROR, 'Tried obtaining data for a non-existent user', '', __LINE__, __FILE__, $sql);
	return ( $row = $db->sql_fetchrow($result) ) ? $row : false;
function make_jumpbox($action, $match_forum_id = 0)
	global $template, $userdata, $lang, $db, $nav_links, $phpEx, $SID;
//	$is_auth = auth(AUTH_VIEW, AUTH_LIST_ALL, $userdata);
	$sql = "SELECT c.cat_id, c.cat_title, c.cat_order
		FROM " . CATEGORIES_TABLE . " c, " . FORUMS_TABLE . " f
		WHERE f.cat_id = c.cat_id
		GROUP BY c.cat_id, c.cat_title, c.cat_order
		ORDER BY c.cat_order";
		message_die(GENERAL_ERROR, "Couldn't obtain category list.", "", __LINE__, __FILE__, $sql);
	$category_rows = array();
		$category_rows[] = $row;
	if ( $total_categories = count($category_rows) )
		$sql = "SELECT *
			FROM " . FORUMS_TABLE . "
			ORDER BY cat_id, forum_order";
			message_die(GENERAL_ERROR, 'Could not obtain forums information', '', __LINE__, __FILE__, $sql);
		$boxstring = '<select name="' . POST_FORUM_URL . '" onchange="if(this.options[this.selectedIndex].value != -1){ forms[\'jumpbox\'].submit() }"><option value="-1">' . $lang['Select_forum'] . '</option>';
		$forum_rows = array();
			$forum_rows[] = $row;
		if ( $total_forums = count($forum_rows) )
			for($i = 0; $i < $total_categories; $i++)
				$boxstring_forums = '';
				for($j = 0; $j < $total_forums; $j++)
					if ( $forum_rows[$j]['cat_id'] == $category_rows[$i]['cat_id'] && $forum_rows[$j]['auth_view'] <= AUTH_REG )
//					if ( $forum_rows[$j]['cat_id'] == $category_rows[$i]['cat_id'] && $is_auth[$forum_rows[$j]['forum_id']]['auth_view'] )
						$selected = ( $forum_rows[$j]['forum_id'] == $match_forum_id ) ? 'selected="selected"' : '';
						$boxstring_forums .=  '<option value="' . $forum_rows[$j]['forum_id'] . '"' . $selected . '>' . $forum_rows[$j]['forum_name'] . '</option>';
						// Add an array to $nav_links for the Mozilla navigation bar.
						// 'chapter' and 'forum' can create multiple items, therefore we are using a nested array.
						$nav_links['chapter forum'][$forum_rows[$j]['forum_id']] = array (
							'url' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=" . $forum_rows[$j]['forum_id']),
							'title' => $forum_rows[$j]['forum_name']
				if ( $boxstring_forums != '' )
					$boxstring .= '<option value="-1"> </option>';
					$boxstring .= '<option value="-1">' . $category_rows[$i]['cat_title'] . '</option>';
					$boxstring .= '<option value="-1">----------------</option>';
					$boxstring .= $boxstring_forums;
		$boxstring .= '</select>';
		$boxstring .= '<select name="' . POST_FORUM_URL . '" onchange="if(this.options[this.selectedIndex].value != -1){ forms[\'jumpbox\'].submit() }"></select>';
	if ( !empty($SID) )
		$boxstring .= '<input type="hidden" name="sid" value="' . $userdata['session_id'] . '" />';
		'jumpbox' => 'jumpbox.tpl')
	$template->assign_vars(array(
		'L_GO' => $lang['Go'],
		'L_JUMP_TO' => $lang['Jump_to'],
		'L_SELECT_FORUM' => $lang['Select_forum'],
		'S_JUMPBOX_SELECT' => $boxstring,
		'S_JUMPBOX_ACTION' => append_sid($action))
	$template->assign_var_from_handle('JUMPBOX', 'jumpbox');
	return;
// Initialise user settings on page load
function init_userprefs($userdata)
	global $board_config, $theme, $images;
	global $template, $lang, $phpEx, $phpbb_root_path;
	global $nav_links;
//-- add
	global $db, $mods, $list_yes_no, $userdata;
	//	get all the mods settings
	$dir = @opendir($phpbb_root_path . 'includes/mods_settings');
	while( $file = @readdir($dir) )
		if( preg_match("/^mod_.*?\." . $phpEx . "$/", $file) )
			include_once($phpbb_root_path . 'includes/mods_settings/' . $file);
	@closedir($dir);
//-- fin mod : profile cp --------------------------------------------------------------------------
	if ( $userdata['user_id'] != ANONYMOUS )
		if ( !empty($userdata['user_lang']))
			$board_config['default_lang'] = $userdata['user_lang'];
		if ( !empty($userdata['user_dateformat']) )
			$board_config['default_dateformat'] = $userdata['user_dateformat'];
		if ( isset($userdata['user_timezone']) )
			$board_config['board_timezone'] = $userdata['user_timezone'];
	if ( !file_exists(@phpbb_realpath($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_main.'.$phpEx)) )
		$board_config['default_lang'] = 'english';
	include($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_main.' . $phpEx);
	if ( defined('IN_ADMIN') )
		if( !file_exists(@phpbb_realpath($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_admin.'.$phpEx)) )
		include($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_admin.' . $phpEx);
//-- add
	include($phpbb_root_path . './includes/lang_extend_mac.' . $phpEx);
//-- fin mod : language settings -------------------------------------------------------------------
	// Set up style
	if ( !$board_config['override_user_style'] )
		if ( $userdata['user_id'] != ANONYMOUS && $userdata['user_style'] > 0 )
			if ( $theme = setup_style($userdata['user_style']) )
				return;
	$theme = setup_style($board_config['default_style']);
	// Mozilla navigation bar
	// Default items that should be valid on all pages.
	// Defined here to correctly assign the Language Variables
	// and be able to change the variables within code.
	$nav_links['top'] = array (
		'url' => append_sid($phpbb_root_path . 'index.' . $phpEx),
		'title' => sprintf($lang['Forum_Index'], $board_config['sitename'])
	$nav_links['search'] = array (
		'url' => append_sid($phpbb_root_path . 'search.' . $phpEx),
		'title' => $lang['Search']
	$nav_links['help'] = array (
		'url' => append_sid($phpbb_root_path . 'faq.' . $phpEx),
		'title' => $lang['FAQ']
	$nav_links['author'] = array (
		'url' => append_sid($phpbb_root_path . 'memberlist.' . $phpEx),
		'title' => $lang['Memberlist']
	return;
function setup_style($style)
	global $db, $board_config, $template, $images, $phpbb_root_path;
	$sql = "SELECT *
		FROM " . THEMES_TABLE . "
		WHERE themes_id = $style";
		message_die(CRITICAL_ERROR, 'Could not query database for theme info');
	if ( !($row = $db->sql_fetchrow($result)) )
		message_die(CRITICAL_ERROR, "Could not get theme data for themes_id [$style]");
	$template_path = 'templates/' ;
	$template_name = $row['template_name'] ;
	$template = new Template($phpbb_root_path . $template_path . $template_name);
	if ( $template )
		$current_template_path = $template_path . $template_name;
		@include($phpbb_root_path . $template_path . $template_name . '/' . $template_name . '.cfg');
		if ( !defined('TEMPLATE_CONFIG') )
			message_die(CRITICAL_ERROR, "Could not open $template_name template config file", '', __LINE__, __FILE__);
		$img_lang = ( file_exists(@phpbb_realpath($phpbb_root_path . $current_template_path . '/images/lang_' . $board_config['default_lang'])) ) ? $board_config['default_lang'] : 'english';
		while( list($key, $value) = @each($images) )
			if ( !is_array($value) )
				$images[$key] = str_replace('{LANG}', 'lang_' . $img_lang, $value);
	return $row;
function encode_ip($dotquad_ip)
	$ip_sep = explode('.', $dotquad_ip);
	return sprintf('%02x%02x%02x%02x', $ip_sep[0], $ip_sep[1], $ip_sep[2], $ip_sep[3]);
function decode_ip($int_ip)
	$hexipbang = explode('.', chunk_split($int_ip, 2, '.'));
	return hexdec($hexipbang[0]). '.' . hexdec($hexipbang[1]) . '.' . hexdec($hexipbang[2]) . '.' . hexdec($hexipbang[3]);
// Create date/time from format and timezone
function create_date($format, $gmepoch, $tz)
	global $board_config, $lang;
	static $translate;
	if ( empty($translate) && $board_config['default_lang'] != 'english' )
		@reset($lang['datetime']);
		while ( list($match, $replace) = @each($lang['datetime']) )
			$translate[$match] = $replace;
	return ( !empty($translate) ) ? strtr(@gmdate($format, $gmepoch + (3600 * $tz)), $translate) : @gmdate($format, $gmepoch + (3600 * $tz));
// Pagination routine, generates
// page number sequence
function generate_pagination($base_url, $num_items, $per_page, $start_item, $add_prevnext_text = TRUE)
	global $lang;
	$total_pages = ceil($num_items/$per_page);
	if ( $total_pages == 1 )
		return '';
	$on_page = floor($start_item / $per_page) + 1;
	$page_string = '';
	if ( $total_pages > 10 )
		$init_page_max = ( $total_pages > 3 ) ? 3 : $total_pages;
		for($i = 1; $i < $init_page_max + 1; $i++)
			$page_string .= ( $i == $on_page ) ? '<b>' . $i . '</b>' : '<a href="' . append_sid($base_url . "&start=" . ( ( $i - 1 ) * $per_page ) ) . '">' . $i . '</a>';
			if ( $i <  $init_page_max )
				$page_string .= ", ";
		if ( $total_pages > 3 )
			if ( $on_page > 1  && $on_page < $total_pages )
				$page_string .= ( $on_page > 5 ) ? ' ... ' : ', ';
				$init_page_min = ( $on_page > 4 ) ? $on_page : 5;
				$init_page_max = ( $on_page < $total_pages - 4 ) ? $on_page : $total_pages - 4;
				for($i = $init_page_min - 1; $i < $init_page_max + 2; $i++)
					$page_string .= ($i == $on_page) ? '<b>' . $i . '</b>' : '<a href="' . append_sid($base_url . "&start=" . ( ( $i - 1 ) * $per_page ) ) . '">' . $i . '</a>';
					if ( $i <  $init_page_max + 1 )
						$page_string .= ', ';
				$page_string .= ( $on_page < $total_pages - 4 ) ? ' ... ' : ', ';
				$page_string .= ' ... ';
			for($i = $total_pages - 2; $i < $total_pages + 1; $i++)
				if( $i <  $total_pages )
		for($i = 1; $i < $total_pages + 1; $i++)
			if ( $i <  $total_pages )
	if ( $add_prevnext_text )
		if ( $on_page > 1 )
			$page_string = ' <a href="' . append_sid($base_url . "&start=" . ( ( $on_page - 2 ) * $per_page ) ) . '">' . $lang['Previous'] . '</a>  ' . $page_string;
		if ( $on_page < $total_pages )
			$page_string .= '  <a href="' . append_sid($base_url . "&start=" . ( $on_page * $per_page ) ) . '">' . $lang['Next'] . '</a>';
	$page_string = $lang['Goto_page'] . ' ' . $page_string;
	return $page_string;
// This does exactly what preg_quote() does in PHP 4-ish
// If you just need the 1-parameter preg_quote call, then don't bother using this.
function phpbb_preg_quote($str, $delimiter)
	$text = preg_quote($str);
	$text = str_replace($delimiter, '\\\' . $delimiter, $text);
	return $text;
// Obtain list of naughty words and build preg style replacement arrays for use by the
// calling script, note that the vars are passed as references this just makes it easier
// to return both sets of arrays
function obtain_word_list(&$orig_word, &$replacement_word)
	global $db;
	// Define censored word matches
	$sql = "SELECT word, replacement
		FROM  " . WORDS_TABLE;
		message_die(GENERAL_ERROR, 'Could not get censored words from database', '', __LINE__, __FILE__, $sql);
		do
			$orig_word[] = '#\b(' . str_replace('\*', '\w*?', phpbb_preg_quote($row['word'], '#')) . ')\b#i';
			$replacement_word[] = $row['replacement'];
	return true;
// This is general replacement for die(), allows templated
// output in users (or default) language, etc.
// $msg_code can be one of these constants:
// GENERAL_MESSAGE : Use for any simple text message, eg. results
// of an operation, authorisation failures, etc.
// GENERAL ERROR : Use for any error which occurs _AFTER_ the
// common.php include and session code, ie. most errors in
// pages/functions
// CRITICAL_MESSAGE : Used when basic config data is available but
// a session may not exist, eg. banned users
// CRITICAL_ERROR : Used when config data cannot be obtained, eg
// no database connection. Should _not_ be used in 99.5% of cases
function message_die($msg_code, $msg_text = '', $msg_title = '', $err_line = '', $err_file = '', $sql = '')
	global $db, $template, $board_config, $theme, $lang, $phpEx, $phpbb_root_path, $nav_links, $gen_simple_header, $images;
	global $userdata, $user_ip, $session_length;
	global $starttime;
	if(defined('HAS_DIED'))
		die("message_die() was called multiple times. This isn't supposed to happen. Was message_die() used in page_tail.php?");
\n	define(HAS_DIED, 1);
	$sql_store = $sql;
	// Get SQL error if we are debugging. Do this as soon as possible to prevent
	// subsequent queries from overwriting the status of sql_error()
	if ( DEBUG && ( $msg_code == GENERAL_ERROR || $msg_code == CRITICAL_ERROR ) )
		$sql_error = $db->sql_error();
		$debug_text = '';
		if ( $sql_error['message'] != '' )
			$debug_text .= '<br /><br />SQL Error : ' . $sql_error['code'] . ' ' . $sql_error['message'];
		if ( $sql_store != '' )
			$debug_text .= "<br /><br />$sql_store";
		if ( $err_line != '' && $err_file != '' )
			$debug_text .= '</br /><br />Line : ' . $err_line . '<br />File : ' . $err_file;
	if( empty($userdata) && ( $msg_code == GENERAL_MESSAGE || $msg_code == GENERAL_ERROR ) )
		init_userprefs($userdata);
	// If the header hasn't been output then do it
	if ( !defined('HEADER_INC') && $msg_code != CRITICAL_ERROR )
		if ( empty($lang) )
			if ( !empty($board_config['default_lang']) )
				include($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_main.'.$phpEx);
				include($phpbb_root_path . 'language/lang_english/lang_main.'.$phpEx);
//-- add
		if ( empty($template) )
			$template = new Template($phpbb_root_path . 'templates/' . $board_config['board_template']);
		if ( empty($theme) )
		// Load the Page Header
		if ( !defined('IN_ADMIN') )
			include($phpbb_root_path . 'admin/page_header_admin.'.$phpEx);
	switch($msg_code)
		case GENERAL_MESSAGE:
			if ( $msg_title == '' )
				$msg_title = $lang['Information'];
			break;
		case CRITICAL_MESSAGE:
				$msg_title = $lang['Critical_Information'];
			break;
		case GENERAL_ERROR:
			if ( $msg_text == '' )
				$msg_text = $lang['An_error_occured'];
				$msg_title = $lang['General_Error'];
			break;
		case CRITICAL_ERROR:
			// Critical errors mean we cannot rely on _ANY_ DB information being
			// available so we're going to dump out a simple echo'd statement
				$msg_text = $lang['A_critical_error'];
				$msg_title = 'phpBB : <b>' . $lang['Critical_Error'] . '</b>';
			break;
	// Add on DEBUG info if we've enabled debug mode and this is an error. This
	// prevents debug info being output for general messages should DEBUG be
	// set TRUE by accident (preventing confusion for the end user!)
		if ( $debug_text != '' )
			$msg_text = $msg_text . '<br /><br /><b><u>DEBUG MODE</u></b>' . $debug_text;
	if ( $msg_code != CRITICAL_ERROR )
		if ( !empty($lang[$msg_text]) )
			$msg_text = $lang[$msg_text];
				'message_body' => 'message_body.tpl')
				'message_body' => 'admin/admin_message_body.tpl')
			'MESSAGE_TITLE' => $msg_title,
			'MESSAGE_TEXT' => $msg_text)
		$template->pparse('message_body');
			include($phpbb_root_path . 'admin/page_footer_admin.'.$phpEx);
		echo "<html>
<body>
" . $msg_title . "
<br /><br />
" . $msg_text . "</body>
</html>";
	exit;
// This function is for compatibility with PHP 4.x's realpath()
// function.  In later versions of PHP, it needs to be called
// to do checks with some functions.  Older versions of PHP don't
// seem to need this, so we'll just return the original value.
// dougk_ff7 <October 5, 2002>
function phpbb_realpath($path)
	global $phpbb_root_path, $phpEx;
	return (!@function_exists('realpath') || !@realpath($phpbb_root_path . 'includes/functions.'.$phpEx)) ? $path : @realpath($path);
function redirect($url)
	global $db, $board_config;
	if (!empty($db))
		$db->sql_close();
	$server_protocol = ($board_config['cookie_secure']) ? 'https://' : 'http://';
	$server_name = preg_replace('#^\/?(.*?)\/?$#', '\1', trim($board_config['server_name']));
	$server_port = ($board_config['server_port'] <> 80) ? ':' . trim($board_config['server_port']) : '';
	$script_name = preg_replace('#^\/?(.*?)\/?$#', '\1', trim($board_config['script_path']));
	$script_name = ($script_name == '') ? $script_name : '/' . $script_name;
	$url = preg_replace('#^\/?(.*?)\/?$#', '/\1', trim($url));
	// Redirect via an HTML form for PITA webservers
	if (@preg_match('/Microsoft|WebSTAR|Xitami/', getenv('SERVER_SOFTWARE')))
		header('Refresh: 0; URL=' . $server_protocol . $server_name . $server_port . $script_name . $url);
		echo '<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"><html><head><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"><meta http-equiv="refresh" content="0; url=' . $server_protocol . $server_name . $server_port . $script_name . $url . '"><title>Redirect</title></head><body><div align="center">If your browser does not support meta redirection please click <a href="' . $server_protocol . $server_name . $server_port . $script_name . $url . '">HERE</a> to be redirected</div></body></html>';
		exit;
	// Behave as per HTTP/1.1 spec for others
	header('Location: ' . $server_protocol . $server_name . $server_port . $script_name . $url);
	exit;
viewforum.php
<?php
//-- mod : split topic type
 *                               viewforum.php
 *   $Id: viewforum.php,v 1.139.2.12 2004/03/13 15:08:23 acydburn Exp $
define('IN_PHPBB', true);
$phpbb_root_path = './';
//-- mod : split topic type ------------------------------------------------------------------------
//-- add
include_once($phpbb_root_path . 'includes/functions_topics_list.'. $phpEx);
//-- fin mod : split topic type --------------------------------------------------------------------
// Start initial var setup
if ( isset($HTTP_GET_VARS[POST_FORUM_URL]) || isset($HTTP_POST_VARS[POST_FORUM_URL]) )
	$forum_id = ( isset($HTTP_GET_VARS[POST_FORUM_URL]) ) ? intval($HTTP_GET_VARS[POST_FORUM_URL]) : intval($HTTP_POST_VARS[POST_FORUM_URL]);
else if ( isset($HTTP_GET_VARS['forum']))
	$forum_id = intval($HTTP_GET_VARS['forum']);
	$forum_id = '';
\n
$start = ( isset($HTTP_GET_VARS['start']) ) ? intval($HTTP_GET_VARS['start']) : 0;
if ( isset($HTTP_GET_VARS['mark']) || isset($HTTP_POST_VARS['mark']) )
	$mark_read = (isset($HTTP_POST_VARS['mark'])) ? $HTTP_POST_VARS['mark'] : $HTTP_GET_VARS['mark'];
	$mark_read = '';
// End initial var setup
// Check if the user has actually sent a forum ID with his/her request
// If not give them a nice error page.
if ( !empty($forum_id) )
	$sql = "SELECT *
		WHERE forum_id = $forum_id";
	message_die(GENERAL_MESSAGE, 'Forum_not_exist');
// If the query doesn't return any rows this isn't a valid forum. Inform
// the user.
if ( !($forum_row = $db->sql_fetchrow($result)) )
// Start session management
$userdata = session_pagestart($user_ip, $forum_id);
// End session management
// Start auth check
$is_auth = array();
$is_auth = auth(AUTH_ALL, $forum_id, $userdata, $forum_row);
if ( !$is_auth['auth_read'] || !$is_auth['auth_view'] )
		$redirect = POST_FORUM_URL . "=$forum_id" . ( ( isset($start) ) ? "&start=$start" : '' );
		redirect(append_sid("login.$phpEx?redirect=viewforum.$phpEx&$redirect", true));
	// The user is not authed to read this forum ...
	$message = ( !$is_auth['auth_view'] ) ? $lang['Forum_not_exist'] : sprintf($lang['Sorry_auth_read'], $is_auth['auth_read_type']);
// End of auth check
// Handle marking posts
if ( $mark_read == 'topics' )
		$sql = "SELECT MAX(post_time) AS last_post
			FROM " . POSTS_TABLE . "
			$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) : array();
			$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) : array();
			if ( ( count($tracking_forums) + count($tracking_topics) ) >= 150 && empty($tracking_forums[$forum_id]) )
				asort($tracking_forums);
				unset($tracking_forums[key($tracking_forums)]);
\r
			if ( $row['last_post'] > $userdata['user_lastvisit'] )
				$tracking_forums[$forum_id] = time();
				setcookie($board_config['cookie_name'] . '_f', serialize($tracking_forums), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
			'META' => '<meta http-equiv="refresh" content="3;url=' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id") . '">')
	$message = $lang['Topics_marked_read'] . '<br /><br />' . sprintf($lang['Click_return_forum'], '<a href="' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id") . '">', '</a> ');
// End handle marking posts
$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) : '';
$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) : '';
// Do the forum Prune
if ( $is_auth['auth_mod'] && $board_config['prune_enable'] )
	if ( $forum_row['prune_next'] < time() && $forum_row['prune_enable'] )
		include($phpbb_root_path . 'includes/prune.'.$phpEx);
		require($phpbb_root_path . 'includes/functions_admin.'.$phpEx);
		auto_prune($forum_id);
// End of forum prune
// Obtain list of moderators of each forum
// First users, then groups ... broken into two queries
$sql = "SELECT u.user_id, u.username
	FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
	WHERE aa.forum_id = $forum_id
		AND aa.auth_mod = " . TRUE . "
		AND g.group_single_user = 1
		AND ug.group_id = aa.group_id
		AND g.group_id = aa.group_id
		AND u.user_id = ug.user_id
	GROUP BY u.user_id, u.username
	ORDER BY u.user_id";
	message_die(GENERAL_ERROR, 'Could not query forum moderator information', '', __LINE__, __FILE__, $sql);
$moderators = array();
	$moderators[] = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '">' . $row['username'] . '</a>';
$sql = "SELECT g.group_id, g.group_name
		AND g.group_single_user = 0
		AND g.group_type <> ". GROUP_HIDDEN ."
	GROUP BY g.group_id, g.group_name
	ORDER BY g.group_id";
	$moderators[] = '<a href="' . append_sid("groupcp.$phpEx?" . POST_GROUPS_URL . "=" . $row['group_id']) . '">' . $row['group_name'] . '</a>';
$l_moderators = ( count($moderators) == 1 ) ? $lang['Moderator'] : $lang['Moderators'];
$forum_moderators = ( count($moderators) ) ? implode(', ', $moderators) : $lang['None'];
unset($moderators);
// Generate a 'Show topics in previous x days' select box. If the topicsdays var is sent
// then get it's value, find the number of topics with dates newer than it (to properly
// handle pagination) and alter the main query
$previous_days = array(0, 1, 7, 14, 30, 90, 180, 364);
$previous_days_text = array($lang['All_Topics'], $lang['1_Day'], $lang['7_Days'], $lang['2_Weeks'], $lang['1_Month'], $lang['3_Months'], $lang['6_Months'], $lang['1_Year']);
if ( !empty($HTTP_POST_VARS['topicdays']) || !empty($HTTP_GET_VARS['topicdays']) )
	$topic_days = ( !empty($HTTP_POST_VARS['topicdays']) ) ? intval($HTTP_POST_VARS['topicdays']) : intval($HTTP_GET_VARS['topicdays']);
	$min_topic_time = time() - ($topic_days * 86400);
	$sql = "SELECT COUNT(t.topic_id) AS forum_topics
		FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
		WHERE t.forum_id = $forum_id
			AND p.post_id = t.topic_last_post_id
			AND p.post_time >= $min_topic_time";
		message_die(GENERAL_ERROR, 'Could not obtain limited topics count information', '', __LINE__, __FILE__, $sql);
	$topics_count = ( $row['forum_topics'] ) ? $row['forum_topics'] : 1;
	$limit_topics_time = "AND p.post_time >= $min_topic_time";
	if ( !empty($HTTP_POST_VARS['topicdays']) )
		$start = 0;
	$topics_count = ( $forum_row['forum_topics'] ) ? $forum_row['forum_topics'] : 1;
	$limit_topics_time = '';
	$topic_days = 0;
$select_topic_days = '<select name="topicdays">';
for($i = 0; $i < count($previous_days); $i++)
	$selected = ($topic_days == $previous_days[$i]) ? ' selected="selected"' : '';
	$select_topic_days .= '<option value="' . $previous_days[$i] . '"' . $selected . '>' . $previous_days_text[$i] . '</option>';
$select_topic_days .= '</select>';
// All announcement data, this keeps announcements
// on each viewforum page ...
$sql = "SELECT t.*, u.username, u.user_id, u2.username as user2, u2.user_id as id2, p.post_time, p.post_username
	FROM " . TOPICS_TABLE . " t, " . USERS_TABLE . " u, " . POSTS_TABLE . " p, " . USERS_TABLE . " u2
		AND t.topic_poster = u.user_id
		AND p.poster_id = u2.user_id
		AND t.topic_type = " . POST_ANNOUNCE . "
	ORDER BY t.topic_last_post_id DESC ";
   message_die(GENERAL_ERROR, 'Could not obtain topic information', '', __LINE__, __FILE__, $sql);
$topic_rowset = array();
$total_announcements = 0;
	$topic_rowset[] = $row;
	$total_announcements++;
$db->sql_freeresult($result);
// Grab all the basic data (all topics except announcements)
// for this forum
$sql = "SELECT t.*, u.username, u.user_id, u2.username as user2, u2.user_id as id2, p.post_username, p2.post_username AS post_username2, p2.post_time
	FROM " . TOPICS_TABLE . " t, " . USERS_TABLE . " u, " . POSTS_TABLE . " p, " . POSTS_TABLE . " p2, " . USERS_TABLE . " u2
		AND p.post_id = t.topic_first_post_id
		AND p2.post_id = t.topic_last_post_id
		AND u2.user_id = p2.poster_id
		AND t.topic_type <> " . POST_ANNOUNCE . "
		$limit_topics_time
	ORDER BY t.topic_type DESC, t.topic_last_post_id DESC
	LIMIT $start, ".$board_config['topics_per_page'];
$total_topics = 0;
	$total_topics++;
// Total topics ...
$total_topics += $total_announcements;
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
// Post URL generation for templating vars
	'L_DISPLAY_TOPICS' => $lang['Display_topics'],
	'U_POST_NEW_TOPIC' => append_sid("posting.$phpEx?mode=newtopic&" . POST_FORUM_URL . "=$forum_id"),
	'S_SELECT_TOPIC_DAYS' => $select_topic_days,
	'S_POST_DAYS_ACTION' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=" . $forum_id . "&start=$start"))
// User authorisation levels output
$s_auth_can = ( ( $is_auth['auth_post'] ) ? $lang['Rules_post_can'] : $lang['Rules_post_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_reply'] ) ? $lang['Rules_reply_can'] : $lang['Rules_reply_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_edit'] ) ? $lang['Rules_edit_can'] : $lang['Rules_edit_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_delete'] ) ? $lang['Rules_delete_can'] : $lang['Rules_delete_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_vote'] ) ? $lang['Rules_vote_can'] : $lang['Rules_vote_cannot'] ) . '<br />';
if ( $is_auth['auth_mod'] )
	$s_auth_can .= sprintf($lang['Rules_moderate'], "<a href=\"modcp.$phpEx?" . POST_FORUM_URL . "=$forum_id&start=" . $start . "&sid=" . $userdata['session_id'] . '">', '</a>');
$nav_links['up'] = array(
	'url' => append_sid('index.'.$phpEx),
// Dump out the page header and load viewforum template
define('SHOW_ONLINE', true);
$page_title = $lang['View_forum'] . ' - ' . $forum_row['forum_name'];
	'body' => 'viewforum_body.tpl')
make_jumpbox('viewforum.'.$phpEx);
	'FORUM_ID' => $forum_id,
	'FORUM_NAME' => $forum_row['forum_name'],
	'FORUM_ICON_IMG' => ($forum_row['forum_icon']) ? '<img src="' . $phpbb_root_path . $forum_row['forum_icon'] . '" alt="'.$forum_row['forum_name'].'" title="'.$forum_row['forum_name'].'" /> ' : '',	// Forum Icon Mod Icon Mod
	'MODERATORS' => $forum_moderators,
	'POST_IMG' => ( $forum_row['forum_status'] == FORUM_LOCKED ) ? $images['post_locked'] : $images['post_new'],
	'FOLDER_IMG' => $images['folder'],
	'FOLDER_NEW_IMG' => $images['folder_new'],
	'FOLDER_HOT_IMG' => $images['folder_hot'],
	'FOLDER_HOT_NEW_IMG' => $images['folder_hot_new'],
	'FOLDER_LOCKED_IMG' => $images['folder_locked'],
	'FOLDER_LOCKED_NEW_IMG' => $images['folder_locked_new'],
	'FOLDER_STICKY_IMG' => $images['folder_sticky'],
	'FOLDER_STICKY_NEW_IMG' => $images['folder_sticky_new'],
	'FOLDER_ANNOUNCE_IMG' => $images['folder_announce'],
	'FOLDER_ANNOUNCE_NEW_IMG' => $images['folder_announce_new'],
	'L_TOPICS' => $lang['Topics'],
	'L_REPLIES' => $lang['Replies'],
	'L_VIEWS' => $lang['Views'],
	'L_POSTS' => $lang['Posts'],
	'L_LASTPOST' => $lang['Last_Post'],
	'L_MODERATOR' => $l_moderators,
	'L_MARK_TOPICS_READ' => $lang['Mark_all_topics'],
	'L_POST_NEW_TOPIC' => ( $forum_row['forum_status'] == FORUM_LOCKED ) ? $lang['Forum_locked'] : $lang['Post_new_topic'],
	'L_NO_NEW_POSTS' => $lang['No_new_posts'],
	'L_NEW_POSTS' => $lang['New_posts'],
	'L_NO_NEW_POSTS_LOCKED' => $lang['No_new_posts_locked'],
	'L_NEW_POSTS_LOCKED' => $lang['New_posts_locked'],
	'L_NO_NEW_POSTS_HOT' => $lang['No_new_posts_hot'],
	'L_NEW_POSTS_HOT' => $lang['New_posts_hot'],
	'L_ANNOUNCEMENT' => $lang['Post_Announcement'],
	'L_STICKY' => $lang['Post_Sticky'],
	'L_POSTED' => $lang['Posted'],
	'L_JOINED' => $lang['Joined'],
	'L_AUTHOR' => $lang['Author'],
	'S_AUTH_LIST' => $s_auth_can,
	'U_VIEW_FORUM' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL ."=$forum_id"),
	'U_MARK_READ' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id&mark=topics"))
// End header
// Okay, lets dump out the page ...
#					NOTE :
# /!\ Important : I strongly recommand to mute all the lines between the nexts
#     ---------  			/* and */
#		by adding // in front of each lines or by deleting all.
# ie: // if( $total_topics )
//-- add
// adjust the item id
for ($i=0; $i < count($topic_rowset); $i++)
	$topic_rowset[$i]['topic_id'] = POST_TOPIC_URL . $topic_rowset[$i]['topic_id'];
// set the bottom sort option
$footer = $lang['Display_topics'] . ': ' . $select_topic_days . ' ' . ( !empty($s_display_order) ? $s_display_order : '') . '<input type="submit" class="liteoption" value="' . $lang['Go'] . '" name="submit" />';
// send the list
$allow_split_type = true;
$display_nav_tree = false;
topic_list('TOPICS_LIST_BOX', 'topics_list_box', $topic_rowset, '', $allow_split_type, $display_nav_tree, $footer);
//-- delete
// Note : all the code that was standing there stands now in functions_topics_list.php, topic_list() func
if( $total_topics )
	for($i = 0; $i < $total_topics; $i++)
		$topic_id = $topic_rowset[$i]['topic_id'];
		$topic_title = ( count($orig_word) ) ? preg_replace($orig_word, $replacement_word, $topic_rowset[$i]['topic_title']) : $topic_rowset[$i]['topic_title'];
		$replies = $topic_rowset[$i]['topic_replies'];
		$topic_type = $topic_rowset[$i]['topic_type'];
		if( $topic_type == POST_ANNOUNCE )
			$topic_type = $lang['Topic_Announcement'] . ' ';
		else if( $topic_type == POST_STICKY )
			$topic_type = $lang['Topic_Sticky'] . ' ';
			$topic_type = '';
		if( $topic_rowset[$i]['topic_vote'] )
			$topic_type .= $lang['Topic_Poll'] . ' ';
		if( $topic_rowset[$i]['topic_status'] == TOPIC_MOVED )
			$topic_type = $lang['Topic_Moved'] . ' ';
			$topic_id = $topic_rowset[$i]['topic_moved_id'];
			$folder_image =  $images['folder'];
			$folder_alt = $lang['Topics_Moved'];
			$newest_post_img = '';
			if( $topic_rowset[$i]['topic_type'] == POST_ANNOUNCE )
				$folder = $images['folder_announce'];
				$folder_new = $images['folder_announce_new'];
			else if( $topic_rowset[$i]['topic_type'] == POST_STICKY )
				$folder = $images['folder_sticky'];
				$folder_new = $images['folder_sticky_new'];
			else if( $topic_rowset[$i]['topic_status'] == TOPIC_LOCKED )
				$folder = $images['folder_locked'];
				$folder_new = $images['folder_locked_new'];
				if($replies >= $board_config['hot_threshold'])
					$folder = $images['folder_hot'];
					$folder_new = $images['folder_hot_new'];
					$folder = $images['folder'];
					$folder_new = $images['folder_new'];
				if( $topic_rowset[$i]['post_time'] > $userdata['user_lastvisit'] )
					if( !empty($tracking_topics) || !empty($tracking_forums) || isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all']) )
						$unread_topics = true;
						if( !empty($tracking_topics[$topic_id]) )
							if( $tracking_topics[$topic_id] >= $topic_rowset[$i]['post_time'] )
								$unread_topics = false;
						if( !empty($tracking_forums[$forum_id]) )
							if( $tracking_forums[$forum_id] >= $topic_rowset[$i]['post_time'] )
						if( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all']) )
							if( $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all'] >= $topic_rowset[$i]['post_time'] )
						if( $unread_topics )
							$folder_image = $folder_new;
							$folder_alt = $lang['New_posts'];
							$newest_post_img = '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&view=newest") . '"><img src="' . $images['icon_newest_reply'] . '" alt="' . $lang['View_newest_post'] . '" title="' . $lang['View_newest_post'] . '" border="0" /></a> ';
							$folder_image = $folder;
							$folder_alt = ( $topic_rowset[$i]['topic_status'] == TOPIC_LOCKED ) ? $lang['Topic_locked'] : $lang['No_new_posts'];
						$folder_alt = ( $topic_rowset[$i]['topic_status'] == TOPIC_LOCKED ) ? $lang['Topic_locked'] : $lang['New_posts'];
		if( ( $replies + 1 ) > $board_config['posts_per_page'] )
			$total_pages = ceil( ( $replies + 1 ) / $board_config['posts_per_page'] );
			$goto_page = ' [ <img src="' . $images['icon_gotopost'] . '" alt="' . $lang['Goto_page'] . '" title="' . $lang['Goto_page'] . '" />' . $lang['Goto_page'] . ': ';
			$times = 1;
			for($j = 0; $j < $replies + 1; $j += $board_config['posts_per_page'])
				$goto_page .= '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=" . $topic_id . "&start=$j") . '">' . $times . '</a>';
				if( $times == 1 && $total_pages > 4 )
					$goto_page .= ' ... ';
					$times = $total_pages - 3;
					$j += ( $total_pages - 4 ) * $board_config['posts_per_page'];
				else if ( $times < $total_pages )
					$goto_page .= ', ';
				$times++;
			$goto_page .= ' ] ';
			$goto_page = '';
		$view_topic_url = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id");
		$topic_author = ( $topic_rowset[$i]['user_id'] != ANONYMOUS ) ? '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '=' . $topic_rowset[$i]['user_id']) . '">' : '';
		$topic_author .= ( $topic_rowset[$i]['user_id'] != ANONYMOUS ) ? $topic_rowset[$i]['username'] : ( ( $topic_rowset[$i]['post_username'] != '' ) ? $topic_rowset[$i]['post_username'] : $lang['Guest'] );
		$topic_author .= ( $topic_rowset[$i]['user_id'] != ANONYMOUS ) ? '</a>' : '';
		$first_post_time = create_date($board_config['default_dateformat'], $topic_rowset[$i]['topic_time'], $board_config['board_timezone']);
		$last_post_time = create_date($board_config['default_dateformat'], $topic_rowset[$i]['post_time'], $board_config['board_timezone']);
		$last_post_author = ( $topic_rowset[$i]['id2'] == ANONYMOUS ) ? ( ($topic_rowset[$i]['post_username2'] != '' ) ? $topic_rowset[$i]['post_username2'] . ' ' : $lang['Guest'] . ' ' ) : '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '='  . $topic_rowset[$i]['id2']) . '">' . $topic_rowset[$i]['user2'] . '</a>';
		$last_post_url = '<a href="' . append_sid("viewtopic.$phpEx?"  . POST_POST_URL . '=' . $topic_rowset[$i]['topic_last_post_id']) . '#' . $topic_rowset[$i]['topic_last_post_id'] . '"><img src="' . $images['icon_latest_reply'] . '" alt="' . $lang['View_latest_post'] . '" title="' . $lang['View_latest_post'] . '" border="0" /></a>';
		$views = $topic_rowset[$i]['topic_views'];
		$template->assign_block_vars('topicrow', array(
			'ROW_COLOR' => $row_color,
			'ROW_CLASS' => $row_class,
			'TOPIC_ID' => $topic_id,
			'TOPIC_FOLDER_IMG' => $folder_image,
			'TOPIC_AUTHOR' => $topic_author,
			'GOTO_PAGE' => $goto_page,
			'REPLIES' => $replies,
			'NEWEST_POST_IMG' => $newest_post_img,
			'TOPIC_TITLE' => $topic_title,
			'TOPIC_TYPE' => $topic_type,
			'VIEWS' => $views,
			'FIRST_POST_TIME' => $first_post_time,
			'LAST_POST_TIME' => $last_post_time,
			'LAST_POST_AUTHOR' => $last_post_author,
			'LAST_POST_IMG' => $last_post_url,
			'L_TOPIC_FOLDER_ALT' => $folder_alt,
			'U_VIEW_TOPIC' => $view_topic_url)
	$topics_count -= $total_announcements;
		'PAGINATION' => generate_pagination("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id&topicdays=$topic_days", $topics_count, $board_config['topics_per_page'], $start),
		'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / $board_config['topics_per_page'] ) + 1 ), ceil( $topics_count / $board_config['topics_per_page'] )),
		'L_GOTO_PAGE' => $lang['Goto_page'])
//-- delete
	// No topics
	$no_topics_msg = ( $forum_row['forum_status'] == FORUM_LOCKED ) ? $lang['Forum_locked'] : $lang['No_topics_post_one'];
		'L_NO_TOPICS' => $no_topics_msg)
\r
	$template->assign_block_vars('switch_no_topics', array() );
// Parse the page and print
$template->pparse('body');
// Page footer
參考http://phpbb-tw.net/phpbb/viewtopic.php ... topic+type
所以這段sql我沒有加
#-----[ SQL ]-------------------------------------------------
# This part is optional : do it only if you want your users to be able to choose their setup
#	if you want so, you'll have to install the MOD-mods_settings mod included in the pack
# note also you haven't to add the user_split_global_announce if you don't use global announces mod
ALTER TABLE phpbb_users ADD user_split_global_announce TINYINT(1) DEFAULT '1' NOT NULL;
ALTER TABLE phpbb_users ADD user_split_announce TINYINT(1) DEFAULT '1' NOT NULL;
ALTER TABLE phpbb_users ADD user_split_sticky TINYINT(1) DEFAULT '1' NOT NULL;
ALTER TABLE phpbb_users ADD user_split_topic_split TINYINT(1) DEFAULT '0' NOT NULL;
己爬文過但找不到相關文章
自己查了好久也找不到原因
己重裝二次了找不到原因請幫助我
最後由 sky0610 於 2004-04-27 16:12 編輯,總共編輯了 1 次。
sky0610
文章: 32
文章 由 sky0610 »
原來發公告就可顯示 :-o
是我笨....白白花了二天的時間
又改資料庫改到不能登入.... :-o
又花時間去改回來.....哎
dae
文章: 11
註冊時間: 2003-08-03 09:23
文章 由 dae »
既然你已經裝好了
那我順便問你好了
要裝這個mod以前是不是要先裝
Modcp Extension 1.1.2 by netclectic
可以讓moderators控制文章是否一般/置頂/公告
應該不會有conflict吧?
可不可以告訴我有裝split跟沒裝split差在哪?
難道沒裝的話"置頂"就不會"置頂"?
這所謂的分區到底是多"分"開呢... :?: :?: :?:
