[問題]Cash Mod 221的安裝問題(己解決)
killua316
文章: 7
註冊時間: 2004-05-14 12:51
文章 由 killua316 »
問題外掛:Cash Mod 221 的安裝問題
參考連結:http://phpbb-tw.net/phpbb/viewtopic.php?t=20846
使用版本:phpBB 2.0.3
狀況描述: 當我打.../phpbb/sql_install.php
Fatal error: Call to undefined function: redirect() in c:\appserv\www\phpbb\sql_install.php on line 50
[php]<?php
* sql_install.php
* begin : Thursday, Apr 17, 2003
* copyright : (C) 2003 Xore
* email : mods@xore.ca
* $Id: sql_install.php,v 2.2.0.0 2003/10/18 00:49:26 Xore $
define('IN_PHPBB', true);
$phpbb_root_path = './';
$i = 0;
while ( !file_exists($phpbb_root_path . 'extension.inc') && ($i++ < 4) )
$phpbb_root_path .= '../';
if ( $i > 4 )
message_die(GENERAL_MESSAGE, 'Unable to find extension.inc, terminating. Please move this file into your main/"root" phpbb directory and try again.');
// Start session management
init_userprefs($userdata);
// End session management
if( !$userdata['session_logged_in'] )
redirect(append_sid("login.$phpEx?redirect=sql_install.$phpEx", true));
if( $userdata['user_level'] != ADMIN )
message_die(GENERAL_MESSAGE, 'You are not authorised to access this page');
$page_title = 'Installing Cash Mod v 2.2.0 Tables, Updating Configuration settings';
print<<<DELIM
<table width="100%" cellspacing="1" cellpadding="2" border="0" class="forumline">
<th class="thHead">Updating the database</th>
<td>
<span class="genmed">
<ul type="circle">
DELIM;
$current_time = time();
switch ( SQL_LAYER )
case 'msaccess':
break;
case 'postgresql':
break;
case 'mssql':
case 'mssql-odbc':
$sql = array(
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_disable',0);",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_display_after_posts',1);",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_post_message','You earned %s for that post');",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_disable_spam_num',10);",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_disable_spam_time',24);",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_disable_spam_message','You have exceeded the alloted amount of posts and will not earn anything for your post');",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_installed','yes');",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_version','2.2.1');",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('points_name','Points');",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_adminnavbar','1');",
"INSERT INTO {$table_prefix}config (config_name, config_value) VALUES ('cash_adminbig','0');",
"CREATE TABLE [userid].[{$table_prefix}cash] (
[cash_id] [int] IDENTITY (1, 1) NOT NULL,
[cash_order] [int] NOT NULL,
[cash_settings] [int] NOT NULL,
[cash_dbfield] [varchar] (64) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
[cash_name] [varchar] (64) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
[cash_default] [int] NOT NULL,
[cash_decimals] [int] NOT NULL,
[cash_imageurl] [varchar] (255) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
[cash_exchange] [int] NOT NULL,
[cash_perpost] [int] NOT NULL,
[cash_postbonus] [int] NOT NULL,
[cash_perreply] [int] NOT NULL,
[cash_maxearn] [int] NOT NULL,
[cash_perpm] [int] NOT NULL,
[cash_perchar] [int] NOT NULL,
[cash_allowance] [int] NOT NULL,
[cash_allowanceamount] [int] NOT NULL,
[cash_allowancetime] [int] NOT NULL,
[cash_allowancenext] [int] NOT NULL,
[cash_forumlist] [varchar] (255) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL
) ON [PRIMARY]",
"ALTER TABLE [userid].[{$table_prefix}cash] WITH NOCHECK ADD
CONSTRAINT [PK_{$table_prefix}cash] PRIMARY KEY CLUSTERED
[cash_id]
) ON [PRIMARY]",
CONSTRAINT [DF_{$table_prefix}cash_cash_order] DEFAULT (0) FOR [cash_order],
CONSTRAINT [DF_{$table_prefix}cash_cash_settings] DEFAULT (3313) FOR [cash_settings],
CONSTRAINT [DF_{$table_prefix}cash_cash_dbfield] DEFAULT ('user_cash') FOR [cash_dbfield],
CONSTRAINT [DF_{$table_prefix}cash_cash_name] DEFAULT ('cash') FOR [cash_name],
CONSTRAINT [DF_{$table_prefix}cash_cash_default] DEFAULT (0) FOR [cash_default],
CONSTRAINT [DF_{$table_prefix}cash_cash_decimals] DEFAULT (0) FOR [cash_decimals],
CONSTRAINT [DF_{$table_prefix}cash_cash_imageurl] DEFAULT (' ') FOR [cash_imageurl],
CONSTRAINT [DF_{$table_prefix}cash_cash_exchange] DEFAULT (1) FOR [cash_exchange],
CONSTRAINT [DF_{$table_prefix}cash_cash_perpost] DEFAULT (25) FOR [cash_perpost],
CONSTRAINT [DF_{$table_prefix}cash_cash_postbonus] DEFAULT (2) FOR [cash_postbonus],
CONSTRAINT [DF_{$table_prefix}cash_cash_perreply] DEFAULT (25) FOR [cash_perreply],
CONSTRAINT [DF_{$table_prefix}cash_cash_maxearn] DEFAULT (75) FOR [cash_maxearn],
CONSTRAINT [DF_{$table_prefix}cash_cash_perpm] DEFAULT (0) FOR [cash_perpm],
CONSTRAINT [DF_{$table_prefix}cash_cash_perchar] DEFAULT (20) FOR [cash_perchar],
CONSTRAINT [DF_{$table_prefix}cash_cash_allowance] DEFAULT (0) FOR [cash_allowance],
CONSTRAINT [DF_{$table_prefix}cash_cash_allowanceamount] DEFAULT (0) FOR [cash_allowanceamount],
CONSTRAINT [DF_{$table_prefix}cash_cash_allowancetime] DEFAULT (2) FOR [cash_allowancetime],
CONSTRAINT [DF_{$table_prefix}cash_cash_allowancenext] DEFAULT (0) FOR [cash_allowancenext],
CONSTRAINT [DF_{$table_prefix}cash_cash_forumlist] DEFAULT (' ') FOR [cash_forumlist]",
"CREATE TABLE [userid].[{$table_prefix}cash_events] (
[event_name] [varchar] (32) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
[event_data] [varchar] (255) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
) ON [PRIMARY]",
"ALTER TABLE [userid].[{$table_prefix}cash_events] WITH NOCHECK ADD
CONSTRAINT [PK_{$table_prefix}cash_events] PRIMARY KEY CLUSTERED
[event_name]
) ON [PRIMARY]",
CONSTRAINT [DF_{$table_prefix}cash_events_event_name] DEFAULT (' ') FOR [event_name],
CONSTRAINT [DF_{$table_prefix}cash_events_event_data] DEFAULT (' ') FOR [event_data]",
"CREATE TABLE [userid].[{$table_prefix}cash_exchange] (
[ex_cash_id1] [int] NOT NULL ,
[ex_cash_id2] [int] NOT NULL ,
[ex_cash_enabled] [int] NOT NULL
) ON [PRIMARY]",
"ALTER TABLE [userid].[{$table_prefix}cash_exchange] WITH NOCHECK ADD
CONSTRAINT [PK_{$table_prefix}cash_exchange] PRIMARY KEY CLUSTERED
[ex_cash_id1],
[ex_cash_id2]
) ON [PRIMARY]",
CONSTRAINT [DF_{$table_prefix}cash_exchange_cash_enabled] DEFAULT (1) FOR [ex_cash_enabled]",
"CREATE TABLE [userid].[{$table_prefix}cash_groups] (
[group_id] [int] NOT NULL,
[group_type] [int] NOT NULL,
[cash_id] [int] NOT NULL,
) ON [PRIMARY]",
"ALTER TABLE [userid].[{$table_prefix}cash_groups] WITH NOCHECK ADD
CONSTRAINT [PK_{$table_prefix}cash_groups] PRIMARY KEY CLUSTERED
[group_id],[group_type],[cash_id]
) ON [PRIMARY]",
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_perpost] DEFAULT (0) FOR [cash_perpost],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_postbonus] DEFAULT (0) FOR [cash_postbonus],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_perreply] DEFAULT (0) FOR [cash_perreply],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_perchar] DEFAULT (0) FOR [cash_perchar],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_maxearn] DEFAULT (0) FOR [cash_maxearn],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_perpm] DEFAULT (0) FOR [cash_perpm],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_allowance] DEFAULT (0) FOR [cash_allowance],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_allowanceamount] DEFAULT (0) FOR [cash_allowanceamount],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_allowancetime] DEFAULT (2) FOR [cash_allowancetime],
CONSTRAINT [DF_{$table_prefix}cash_groups_cash_allowancenext] DEFAULT (0) FOR [cash_allowancenext]",
"CREATE TABLE [userid].[{$table_prefix}cash_log] (
log_id [int] IDENTITY (1, 1) NOT NULL,
log_time [int] NOT NULL,
log_type [int] NOT NULL,
log_action [varchar] (255) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
log_text [varchar] (255) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
) ON [PRIMARY]",
"ALTER TABLE [userid].[{$table_prefix}cash_log] WITH NOCHECK ADD
CONSTRAINT [PK_{$table_prefix}cash_log] PRIMARY KEY CLUSTERED
[log_id]
) ON [PRIMARY]",
CONSTRAINT [DF_{$table_prefix}cash_log_log_time] DEFAULT (0) FOR [log_time],
CONSTRAINT [DF_{$table_prefix}cash_log_log_type] DEFAULT (0) FOR [log_type],
CONSTRAINT [DF_{$table_prefix}cash_log_log_action] DEFAULT (' ') FOR [log_action],
CONSTRAINT [DF_{$table_prefix}cash_log_log_text] DEFAULT (' ') FOR [log_text]"
break;
case 'mysql':
case 'mysql4':
default:
$sql = array(
"CREATE TABLE {$table_prefix}cash (
cash_id smallint(6) NOT NULL auto_increment,
cash_order smallint(6) NOT NULL default '0',
cash_settings smallint(4) NOT NULL default '3313',
cash_dbfield varchar(64) NOT NULL default 'user_cash',
cash_name varchar(64) NOT NULL default 'cash',
cash_default int(11) NOT NULL default '0',
cash_decimals tinyint(2) NOT NULL default '0',
cash_imageurl varchar(255) NOT NULL default ' ',
cash_exchange int(11) NOT NULL default '1',
cash_perpost int(11) NOT NULL default '25',
cash_postbonus int(11) NOT NULL default '2',
cash_perreply int(11) NOT NULL default '25',
cash_maxearn int(11) NOT NULL default '75',
cash_perpm int(11) NOT NULL default '0',
cash_perchar int(11) NOT NULL default '20',
cash_allowance tinyint(1) NOT NULL default '0',
cash_allowanceamount int(11) NOT NULL default '0',
cash_allowancetime tinyint(2) NOT NULL default '2',
cash_allowancenext int(11) NOT NULL default '0',
cash_forumlist varchar(255) NOT NULL default ' ',
PRIMARY KEY (cash_id)
"CREATE TABLE {$table_prefix}cash_events (
event_name varchar(32) NOT NULL default ' ',
event_data varchar(255) NOT NULL default ' ',
PRIMARY KEY (event_name)
"CREATE TABLE {$table_prefix}cash_exchange (
ex_cash_id1 int(11) NOT NULL default '0',
ex_cash_id2 int(11) NOT NULL default '0',
ex_cash_enabled int(1) NOT NULL default '0',
PRIMARY KEY (ex_cash_id1,ex_cash_id2)
"CREATE TABLE {$table_prefix}cash_groups (
group_id mediumint(6) NOT NULL default '0',
group_type tinyint(2) NOT NULL default '0',
cash_id smallint(6) NOT NULL default '0',
cash_perpost int(11) NOT NULL default '0',
cash_postbonus int(11) NOT NULL default '0',
cash_perreply int(11) NOT NULL default '0',
cash_perchar int(11) NOT NULL default '0',
cash_maxearn int(11) NOT NULL default '0',
PRIMARY KEY (group_id,group_type,cash_id)
"CREATE TABLE {$table_prefix}cash_log (
log_id int(11) NOT NULL auto_increment,
log_time int(11) NOT NULL default '0',
log_type smallint(6) NOT NULL default '0',
log_action varchar(255) NOT NULL default ' ',
log_text varchar(255) NOT NULL default ' ',
PRIMARY KEY (log_id)
break;
foreach ( $sql AS $query )
if ( !($result = $db->sql_query($query)) )
$error = $db->sql_error();
print('<li>' . nl2br($query) . '<br /> +++ <font color="#FF0000"><b>Error:</b></font> ' . $error['message'] . '</li><br />');
print('<li>' . nl2br($query) . '<br /> +++ <font color="#00AA00"><b>Successfull</b></font></li><br />');
$forum_url = append_sid($phpbb_root_path . "index.$phpEx");
$phpbb_url = "http://www.phpbb.com/phpBB/viewtopic.php?t=94055#623226";
print<<<DELIM
</ul>
</span>
</td>
<td class="catBottom" height="28"> </td>
<td class="catBottom" colspan="2" align="center">Finished</td>
</table>
<br />
<br />
<th class="thHead">SQL Installation complete</th>
<td>
<span class="genmed">Please delete this file (sql_install.{$phpEx}).<br />
If you have any problems, please visit <a href="{$phpbb_url}" target="_new">phpbb.com (CashMod v 2.2.0 Support Thread)</a> and ask for help.</span>
</td>
<td class="catBottom" height="28" align="center">
<span class="genmed"><a href="{$forum_url}">Click Here to return to your forum.</a>
</span>
</td>
</table>
DELIM;
[/php]
補充:
我曾裝過的外掛:attach_mod_v237[php]
[/url]
killua316
文章: 7
文章 由 killua316 »
剛剛把論壇升至phpBB208a
問題已解決
