[問題]修改了程式碼之後...主題長度還是被切掉耶...
bitemancat
文章: 40
註冊時間: 2004-05-23 21:54
來自: 從零開始的領域
文章 由 bitemancat »
問題外掛: Long Subject (120 letters)
\n參考連結:http://phpbb-tw.net/phpbb/viewtopic.php ... ng+Subject
使用版本:phpbb2.0.8a
網站位置:http://www.bitenancat.adsldns.org
我照著以下的程式碼修改過了
SQL的語法我也增加過了
但是我的主題長度還是被切掉了耶\r
搜尋過了文章...但修改的方法還是跟下面的程式碼一樣\r
請問一下還有哪裡需要修改呢?
麻煩指教一下....thx!!!
:oops:
## MOD Title: Long Subject (120 letters)
## MOD Author: Ralendil < ralendil@hotmail.com > Ravaille Franck - http://civs.org
## MOD Description: Put to 120 subject limit.
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: 1 minute
## Files to Edit: templates/subSilver/posting_body.tpl
## Included Files: N/A
## For Security Purposes, Please Check: http://www.phpbb.com/mods/downloads/ for the
## in our MOD-Database, located at: http://www.phpbb.com/mods/downloads/
## Author Notes:
## MOD History:
## 1.0.0 Release
ALTER TABLE `phpbb_topics` CHANGE `topic_title` `topic_title` CHAR(120) NOT NULL
ALTER TABLE `phpbb_posts_text` CHANGE `post_subject` `post_subject` VARCHAR(120) DEFAULT NULL
<input type="text" name="subject" size="45" maxlength="60" style="width:450px" tabindex="2" class="post" value="{SUBJECT}" />
<input type="text" name="subject" size="45" maxlength="120" style="width:450px" tabindex="2" class="post" value="{SUBJECT}" />
#-----[ SAVE/CLOSE ALL FILES ]----------------------------------------
# EoM
