可到 http://phpbb.com/ 官方站的 Community 裡, 尋找更多 aiml 檔,
或 自己製作~
[問題]Artificial intelligence 2
kevinyung 在 侏羅紀時代 作了第 1 次修改
.::藍色的天空::.
- 文章: 587
- 註冊時間: 2003-09-14 17:29
- 來自: 我不知道
- 聯繫:
AI 在史上沒人做到 =.=
電腦沒有人腦的感情等等學習功能...
其實找一個人開個腦研究就好了。
電腦沒有人腦的感情等等學習功能...
其實找一個人開個腦研究就好了。
i-Web System 隨坊出來耶
新聞:
遊戲區開幕啦! 打造隨城最強的遊戲王國!
宣傳車出動! 賣力宣傳隨坊吧!
版主召募!版主魂激發!
中文好好學,不要方言通天飛
i-Web System 正式版上架測試!
新聞:
宣傳車出動! 賣力宣傳隨坊吧!
版主召募!版主魂激發!
中文好好學,不要方言通天飛
自己隨便翻的
翻不好請見諒^^"
另外有人有做後台的中文化喔 自己找一找\r
因為原來的檔案是附英文的語言檔
純文字檔按此下載
翻不好請見諒^^"
因為原來的檔案是附英文的語言檔
## 外掛名稱: Forum AI論壇人工智慧機器人
## Project Homepage/Demo: http://palgn.com/iai/
## 外掛作者: zemaj < zemaj@palgn.com > (James Gay) http://www.palgn.com/
## Description: This mod with give your forums an "artifical intelligence" bot based on the ALICE system
## (& Program E by Paul Rydell) which will respond to users' posts/pms in your forum and chat with users.
## 外掛版本: 0.2.0
## 安裝難度: 難\r
## 安裝時間: ~25 分 (再加裝AIML語言可能要在多10分鐘)
## 要修改的檔案: posting.php
## includes/functions_post.php
## privmsg.php
## includes/usercp_register.php
## 附加的檔案: 40 (including extra mods)
## This MOD is released under the GPL License.
## Intellectual Property is retained by the MOD Author(s) listed above
## For Security Purposes, Please Check: http://www.phpbb.com/mods/downloads/ for the
## in our MOD-Database, located at: http://www.phpbb.com/mods/downloads/
## Authors Notes:
## It's ALIVE.... welcome to IAI v0.2.0!
## PLEASE NOTE:
## >> this modification is quite different from most mods, I have tried to be quite intensive
## with the installation notes here in order to compensate, but you still need quite some grasp
## of what is going on to get it right.
## At the same time I have also made a few changes to the layout of this file, rather than the usual mod
## template, to make it easier to go through and follow all the various steps which extend beyond
## simply editing a few files. Thus:
## - MAKE SURE YOU TAKE NOTE OF THE BEFORE INSTALLATION AND AFTER INSTALLATION PANELS -
## New to v0.2.0:
## o various bug fixes (esp. blank posts fix)
## o some degree of coding clean up, but needs more work (I got bored after about 3 hours :P )
## o SRS (Salient Response System) - makes bot give far more salient (succinct and to the point) responses
## o response for private messages to bot's username
## o waaaay better variable tracking
## o customisable welcome message from bot to newly registering users
## o much, much better AIML updating from admin panel
## o move away from various traditional ALICE systems to better suit phpBB/forum systems
## o repositioning of files to better fit phpBB standards
## o improved installation procedure in install.php (now loads initial aiml files at same time)
## o added some intergration mods (note the ChatBox intergration mod - this is REALLY cool ;) )
\n##############################################################
## 安裝須知:
## 安裝本外掛之前,請自行備份所有相關檔案以及資料庫,以防不測。
## 解壓縮ZIP檔案並將資料夾內全部檔案放置於相對位置\r
## 請先確認你已將全部檔案上傳至你PHPBB的位置\r
## 在 (phpbb_root_dir)/mods/iai/ 應該有以下三個檔案:
## o install.php
## o upgrade.php
## o uninstall.php
## 這是寫入MYAQL的檔案如果妳是全新安裝請使用install.php檔(在網址列打上http://www.yoursite.com/(phpbb_root_dir)/mods/iai/install.php)
##如果妳是升級就用upgrade.php
## Once you have used your respective file, ALL should be deleted for security purposes.
## If you are upgrading then please stop using this file and use UPGRADE.txt
## Otherwise continue with the commands below.
#-----[ 開啟 ]------------------------------------------
posting.php
update_post_stats($mode, $post_data, $forum_id, $topic_id, $post_id, $user_id);
#-----[ 之後加入 ]------------------------------------------
// Begin IAI system
// Note: the switch statements here can be quite complicated, so I've used
// some weird setting out. This helps to show exactly what is going on and
// allows me to bear down on the problems that were occuring before.
// Do seed for random replies
list($usec, $sec) = explode(' ', microtime());
mt_srand((float) $sec + ((float) $usec * 100000));
$iai_rand = mt_rand(0, 100);
// Initial should IAI run check
$run_iai =
$mode == 'newtopic'
$mode == 'reply'
$iai_rand <= $board_config['iai_percentage_all']
$board_config['iai_percentage_all'] != 0
$board_config['iai_active_all']
) ? TRUE : FALSE;
// Check if forum has settings which overide this
if($post_info['iai_override'])
$run_iai = (($iai_rand <= $post_info['iai_percentage']) && ($post_info['iai_percentage'] != 0)) ? TRUE : FALSE;
// If IAI is not currently set to run, then it should find any call words
// in the post which might overide this.
// Not in the usual set out, but it allows you to actually understand what's going on.
if(
!($run_iai)
$post_info['iai_stop_words']
!($post_info['iai_override'])
// See if there is any match in the respond words array.
// I know this system is pretty bad (there must be a faster way), but I haven't had much experience with it, so any help would be greatly appreciated
$res_words = str_replace(", ", ",", $board_config['iai_respond_words']);
$res_words = str_replace("!", "", $res_words);
$res_words = str_replace("?", "", $res_words);
$res_words = str_replace("'", "", $res_words);
$res_words = str_replace('"', '', $res_words);
$res_words = explode(",", $res_words);
$words = str_replace(".", "", $HTTP_POST_VARS['message']);
$words = str_replace("!", "", $words);
$words = str_replace("?", "", $words);
$words = str_replace(",", "", $words);
$words = str_replace("'", "", $words);
$words = str_replace('"', '', $words);
$words = explode(" ", $words);
for($i = 0; $i < count($res_words); $i++)
$words = str_replace($res_words[$i] . " ", " " . $res_words[$i] . " ", $words);
$words = str_replace(" " . $res_words[$i], " " . $res_words[$i] . " ", $words);
for($g = 0; $g < count($words); $g++)
if($res_words[$i] == $words[$g])
$run_iai = TRUE;
// START IAI response and entry to db (if active)
if ($run_iai)
$iai_root_path = $phpbb_root_path . "mods/iai/";
include($iai_root_path . 'includes/iai_functions.'.$phpEx);
// Initialise variables
$iai_mode = 'reply';
$iai_post_id = '';
$iai_id = $board_config['iai_userid'];
$iai_subject = '';
$iai_username = $board_config['iai_username'];
$iai_topic_type = POST_NORMAL;
$numselects = 0;
$user_id = ($userdata['session_logged_in']) ? $userdata['user_id'] : 0;
// $topic_id should be set already
$sesh_id = $userdata['session_id']; // should NOT be null in any situation
$iai_reply_to = str_replace("is " . $iai_username, "are you", $HTTP_POST_VARS['message']);
$iai_reply_to = str_replace( $iai_username, "you", $iai_reply_to);
// Get IAI reply
$iai_reply = reply($iai_reply_to,$user_id,$topic_id,$sesh_id);
$iai_message = $iai_reply->response;
// prepare IAI message(IAI may have used html, smilies etc...)
$bbcode_uid = ( $bbcode_on ) ? make_bbcode_uid() : '';
$iai_message = str_replace("'", "''", $iai_message);
$iai_message = prepare_message(trim($iai_message), 0, 1, 1, $bbcode_uid);
if ( $error_msg == '' && !empty($iai_message) )
// Submit IAI's response to DB & update stats
iai_submit_post($iai_mode, $iai_id, $forum_id, $topic_id, $iai_post_id, $iai_topic_type, 1, 1, 1, 1, $bbcode_uid, str_replace("\'", "''", $iai_username), str_replace("\'", "''", $iai_subject), str_replace("\'", "''", $iai_message));
iai_update_post_stats($forum_id, $topic_id, $iai_post_id, $iai_id);
// END IAI response and entry to db
// END IAI system
// This function will prepare a posted message for
// entry into the database.
#-----[ 之前加入 ]------------------------------------------
// Post IAI's response to database
function iai_submit_post($mode, &$iai_id, &$forum_id, &$topic_id, &$iai_post_id, &$topic_type, $bbcode_on, $html_on, $smilies_on, $attach_sig, &$bbcode_uid, &$iai_username, &$iai_subject, &$iai_message)
global $board_config, $lang, $db, $phpbb_root_path, $phpEx;
//Stores user's IP since IAI has none. Can be changed as wished.
global $user_ip;
$current_time = time();
$sql = "INSERT INTO " . POSTS_TABLE . " (topic_id, forum_id, poster_id, post_username, post_time, poster_ip, enable_bbcode, enable_html, enable_smilies, enable_sig) VALUES ($topic_id, $forum_id, $iai_id, '$iai_username', $current_time, '$user_ip', $bbcode_on, $html_on, $smilies_on, $attach_sig)";
if ( !($result = $db->sql_query($sql, BEGIN_TRANSACTION)) )
message_die(GENERAL_ERROR, 'Error in posting', '', __LINE__, __FILE__, $sql);
$iai_post_id = $db->sql_nextid();
$sql = "INSERT INTO " . POSTS_TEXT_TABLE . " (post_id, post_subject, bbcode_uid, post_text) VALUES ($iai_post_id, '$iai_subject', '$bbcode_uid', '$iai_message')";
add_search_words($iai_post_id, stripslashes($iai_message), stripslashes($iai_subject));
return false;
// Update Stats for IAI: must be run AFTER update_post_stats() for original post
function iai_update_post_stats(&$forum_id, &$topic_id, &$iai_post_id, &$iai_id)
global $db;
//This simply runs the 3 db updating functions (only used for IAI replies).
$sql = "UPDATE " . FORUMS_TABLE . "
SET forum_posts = forum_posts + 1, forum_last_post_id = $iai_post_id
WHERE forum_id = $forum_id";
$sql = "UPDATE " . TOPICS_TABLE . "
SET topic_last_post_id = $iai_post_id, topic_replies = topic_replies + 1
WHERE topic_id = $topic_id";
// Comment out the next 7 lines if you don't want user posts to be updated (it will annoy some users otherwise).
SET user_posts = user_posts + 1
WHERE user_id = $iai_id";
if ( !($result = $db->sql_query($sql, END_TRANSACTION)) )
return;
// Allows bot to send pms requiring only subject, message and user_id of user it is being sent to.
// I've made it an easy to use function so you can adapt it to use in many situations on your site
// an example is in the welcome message system which is included with this package. The function
// also sends emails (if $send_email set) and does all the inbox checking stuff that normal pms do.
function iai_send_pm($user_to_id, $iai_subject, $iai_message, $send_email)
$sql = "SELECT *
FROM " . USERS_TABLE . "
WHERE user_id = " . $user_to_id . "
AND user_id <> " . ANONYMOUS;
message_die(GENERAL_ERROR, 'Tried obtaining data for a non-existent user', '', __LINE__, __FILE__, $sql);
$usertodata = $db->sql_fetchrow($result);
// prepare IAI message (IAI may have used html, smilies etc...)
$bbcode_uid = make_bbcode_uid();
// This is to fix up some of the bad formatting which comes out of the AI
if(empty($iai_message))
$iai_message = "Thank you.";
$msg_time = time();
// Do inbox limit stuff
$sql = "SELECT COUNT(privmsgs_id) AS inbox_items, MIN(privmsgs_date) AS oldest_post_time
FROM " . PRIVMSGS_TABLE . "
WHERE ( privmsgs_type = " . PRIVMSGS_NEW_MAIL . "
OR privmsgs_type = " . PRIVMSGS_READ_MAIL . "
OR privmsgs_type = " . PRIVMSGS_UNREAD_MAIL . " )
AND privmsgs_to_userid = " . $usertodata['user_id'];
message_die(GENERAL_MESSAGE, $lang['No_such_user']);
$sql_priority = ( SQL_LAYER == 'mysql' ) ? 'LOW_PRIORITY' : '';
if ( $inbox_info = $db->sql_fetchrow($result) )
if ( $inbox_info['inbox_items'] >= $board_config['max_inbox_privmsgs'] )
$sql = "DELETE $sql_priority FROM " . PRIVMSGS_TABLE . "
AND privmsgs_date = " . $inbox_info['oldest_post_time'] . "
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, 'Could not delete your oldest privmsgs', '', __LINE__, __FILE__, $sql);
$sql_info = "INSERT INTO " . PRIVMSGS_TABLE . " (privmsgs_type, privmsgs_subject, privmsgs_from_userid, privmsgs_to_userid, privmsgs_date, privmsgs_ip, privmsgs_enable_html, privmsgs_enable_bbcode, privmsgs_enable_smilies, privmsgs_attach_sig)
VALUES (" . PRIVMSGS_NEW_MAIL . ", '" . str_replace("\'", "''", $iai_subject) . "', " . $board_config['iai_userid'] . ", " . $usertodata['user_id'] . ", $msg_time, '$user_ip', 0, 1, 1, 1)";
if ( !($result = $db->sql_query($sql_info, BEGIN_TRANSACTION)) )
message_die(GENERAL_ERROR, "Could not insert private message sent info.", "", __LINE__, __FILE__, $sql_info);
$privmsg_sent_id = $db->sql_nextid();
$sql = "INSERT INTO " . PRIVMSGS_TEXT_TABLE . " (privmsgs_text_id, privmsgs_bbcode_uid, privmsgs_text)
VALUES ($privmsg_sent_id, '" . $bbcode_uid . "', '" . str_replace("\'", "''", $iai_message) . "')";
if ( !$db->sql_query($sql, END_TRANSACTION) )
message_die(GENERAL_ERROR, "Could not insert/update private message sent text.", "", __LINE__, __FILE__, $sql_info);
// Add to the users new pm counter
SET user_new_privmsg = user_new_privmsg + 1, user_last_privmsg = " . time() . "
WHERE user_id = " . $usertodata['user_id'];
if ( !$status = $db->sql_query($sql) )
message_die(GENERAL_ERROR, 'Could not update private message new/read status for user', '', __LINE__, __FILE__, $sql);
// now send email if all the usual conditions & $send_email is set
if ( $send_email && $usertodata['user_notify_pm'] && !empty($usertodata['user_email']) && $usertodata['user_active'] )
$email_headers = 'From: ' . $board_config['board_email'] . "
Return-Path: " . $board_config['board_email'] . "
$script_name = preg_replace('/^\/?(.*?)\/?$/', "\\\1", trim($board_config['script_path']));
$script_name = ( $script_name != '' ) ? $script_name . '/privmsg.'.$phpEx : 'privmsg.'.$phpEx;
$server_name = trim($board_config['server_name']);
$server_protocol = ( $board_config['cookie_secure'] ) ? 'https://' : 'http://';
$server_port = ( $board_config['server_port'] <> 80 ) ? ':' . trim($board_config['server_port']) . '/' : '/';
include($phpbb_root_path . 'includes/emailer.'.$phpEx);
$emailer = new emailer($board_config['smtp_delivery']);
$emailer->use_template('privmsg_notify', $usertodata['user_lang']);
$emailer->extra_headers($email_headers);
$emailer->email_address($usertodata['user_email']);
$emailer->set_subject(); //$lang['Notification_subject']
$emailer->assign_vars(array(
'USERNAME' => $usertodata['username'],
'SITENAME' => $board_config['sitename'],
'EMAIL_SIG' => str_replace('<br />', "
" . $board_config['board_email_sig']),
'U_INBOX' => $server_protocol . $server_name . $server_port . $script_name . '?folder=inbox')
$emailer->send();
$emailer->reset();
return;
privmsg.php
$template->assign_vars(array(
'META' => '<meta http-equiv="refresh" content="3;url=' . append_sid("privmsg.$phpEx?folder=inbox") . '">')
// START PM SYSTEM FOR IAI
// Should IAI respond to this pm?
if (
$mode != "edit"
$to_userdata['user_id'] == $board_config['iai_userid']
$board_config['iai_active_pm']
// Init IAI specific vars
$iai_subject = ( ( !preg_match('/^Re:/', $privmsg_subject) ) ? 'Re: ' : '' ) . $privmsg_subject;
// Get IAI reply
$topic_id = 0; // the null topic
$numselects = 0;
// set bot to reply to subject as well as message as long as subject is not a reply (i.e. has Re: out the front)
$iai_reply_to = ( ( !preg_match('/^Re:/', $privmsg_subject) ) ? $privmsg_subject . " " : "" ) . $privmsg_message;
$iai_reply_to = str_replace("is " . $board_config['iai_username'], "are you", $iai_reply_to);
$iai_reply_to = str_replace($board_config['iai_username'], "you", $iai_reply_to);
// START Delete user's message from bot's inbox/user's outbox (it gets too full and wastes space otherwise).
// Note that this wipes ALL PAST pms in the bot's inbox from the user. This ensures that any backlog of pms
// sent while bot was inactive are also wiped.
SET user_unread_privmsg = user_unread_privmsg - 1
WHERE user_id = " . $board_config['iai_userid'];
message_die(GENERAL_ERROR, 'Could not update private message read status for user', '', __LINE__, __FILE__, $sql);
$sql = "SELECT privmsgs_id
WHERE privmsgs_to_userid = " . $board_config['iai_userid'] . " AND (privmsgs_type = " . PRIVMSGS_READ_MAIL . " OR privmsgs_type = " . PRIVMSGS_NEW_MAIL . " OR privmsgs_type = " . PRIVMSGS_UNREAD_MAIL . " )";
message_die(GENERAL_ERROR, 'Could not obtain id list to delete all messages', '', __LINE__, __FILE__, $sql);
$mark_list = array();
$mark_list[] = $row['privmsgs_id'];
unset($delete_type);
if ( count($mark_list) )
$delete_sql_id = implode(', ', $mark_list);
$delete_text_sql = "DELETE FROM " . PRIVMSGS_TEXT_TABLE . "
WHERE privmsgs_text_id IN ($delete_sql_id)";
$delete_sql = "DELETE FROM " . PRIVMSGS_TABLE . "
WHERE privmsgs_id IN ($delete_sql_id)
AND privmsgs_to_userid = " . $board_config['iai_userid'] . "
if ( !$db->sql_query($delete_sql, BEGIN_TRANSACTION) )
message_die(GENERAL_ERROR, 'Could not delete private message info', '', __LINE__, __FILE__, $delete_sql);
if ( !$db->sql_query($delete_text_sql, END_TRANSACTION) )
message_die(GENERAL_ERROR, 'Could not delete private message text', '', __LINE__, __FILE__, $delete_text_sql);
// END delete sent pms
// run iai pm send function
$iai_message = str_replace(".", ". ", $iai_message);
$iai_message = str_replace("!", "! ", $iai_message);
$iai_message = str_replace("?", "? ", $iai_message);
iai_send_pm($userdata['user_id'], $iai_subject, $iai_message, 0);
// END PM SYSTEM FOR IAI
} // if mode == register
} // End of submit
// START IAI welcome pm message
include($iai_root_path.'includes/constants.'.$phpEx);
if($board_config['iai_active_wpm'])
$sql = "SELECT *
FROM " . IAI_BOT_T;
if(!$result = $db->sql_query($sql))
message_die(GENERAL_ERROR, "Could not query bot information", "", __LINE__, __FILE__, $sql);
while($row = $db->sql_fetchrow($result))
$bot_config[$row['name']] = $row['value'];
// Just a couple of replaces for better customisation on a per user basis
// no point making a special function since there are so few needed
$iai_wpm_subject = str_replace("[username]", $username, $bot_config['iai_wpm_subject']);
$iai_wpm_subject = str_replace("[user_id]", $user_id, $iai_wpm_subject);
$iai_wpm_subject = str_replace("[sitename]", $board_config['sitename'], $iai_wpm_subject);
$iai_wpm_subject = str_replace("[botname]", $bot_config['name'], $iai_wpm_subject);
$iai_wpm_message = str_replace("[username]", $username, $bot_config['iai_wpm_message']);
$iai_wpm_message = str_replace("[user_id]", $user_id, $iai_wpm_message);
$iai_wpm_message = str_replace("[sitename]", $board_config['sitename'], $iai_wpm_message);
$iai_wpm_message = str_replace("[botname]", $bot_config['name'], $iai_wpm_message);
// Will not send a pm notification via email (already sent the standard welcome email)
// Simply change the 0 to a 1 to turn it on
iai_send_pm($user_id, $iai_wpm_subject, $iai_wpm_message, 0);
// END IAI welcome pm message
#-----[ 儲存並關閉所有檔案 ]------------------------------------------
## 安裝後說明:
## AIML 檔案安裝:
## o 要讓妳的機器人更人性化, 妳須到 http://palgn.com/iai/aiml/
## 並下載 iai_alice.zip (如果妳有額外的空間 妳也可以下載其他檔案).
## o 解壓縮後上傳至 (phpbb_root_dir)/mods/iai/aiml/
## o 到系統管理控制台的Forum AI 點選 "AIML files" 頁面\r
## o 點"學習智慧"(中文版感覺怪怪的英文的話是"INSTALL ALL")
## 妳也可以用相同方式設定妳之後新增的檔案
## 安裝後妳可以從妳的電腦移除AIML檔案在 (phpbb_root_dir)/mods/iai/aiml/
## if you wish, as they will stay in the brain untill you click the "Wipe AIML files" button.
## 如果妳的機器人似乎極笨那妳可以安裝更多的AIML或試試以下步驟
## Now go through the various pages in the "Forum AI" section of your admin panel and put your
## preferences in.
## o "AI Settings" is for the basic personality/likes/dislikes settings
## o "PM Settings" is for the way your bot sends pms
## o "Forum Settings" is for the way your bot replies to messages in your forum
## OTHER MODS:
## Some other mods have an obvious conflict with this mod, so if you are using any of the mods below
## then use their respective text file to fix the problem:
## o "Points Mod" use docs/mod_intergration/iai_points.txt
## o "Send PM On User Registration" use docs/mod_intergration/iai_reg_pm.txt
## o "ChatBox for phpBB2" use docs/mod_intergration/iai_chat_box.txt *** awesome intergration system
## If you make any files which can fix conflicts with other mods then please send them to me so I can
## include them here.
## 妳機器人的聊天頁面在 (phpbb_root_dir)/mods/iai/index.html or (phpbb_root_dir)/bot/index.html
## 不是 (phpbb_root_dir)/mods/iai/jsrs/jsrs.php file.
## 妳必須改 (phpbb_root_dir)/bot/ 成 (phpbb_root_dir)/(妳的機器人名稱)/
## 以下的修改也是必須的:
(妳的機器人名稱)/index.html
document.all('ChatPane').innerHTML += '<span id="a' + mycount + '"><font face="Verdana, Arial, Helvetica, sans-serif" size="1"><b><font color="#003366">Bot: </font></b><font color="#003366">' + returnstring + '</font></font><BR></span>';
#-----[ 在同行中尋找 ]------------------------------------------
Bot:
#-----[ 取代 ]------------------------------------------
(妳的機器人名稱):
#-----[ 存檔並關閉所有檔案 ]------------------------------------------
## I haven't templated and left the code raw since people choose to do different things with this page.
## Some people add it the template of their index.php page.
## A link to it in your header may also be a good idea for some (unless you are pretending the bot is
## an actual user).
## Yay, you made it! Congrats. Now have fun chatting with your bot, but remember, winners don't do drugs :|
## Make sure you look at http://palgn.com/iai/ for the latest info about this system and how to work with it.
## Anyone who spells zemaj with a capital Z will not recieve support ;)
# EoM
