●免費空間連結:http://www.mushy.org/
●我安裝的程式:CashMod 2.2.1
●我的 phpBB2 版本:phpBB 2.0.8
●我的 phpBB2 連結網址: http://shing.mushy.org/phpBB2/
當進入後台->按細部設定
●錯誤代碼:
Fatal error: Call to a member function on a non-object in /home/shing/phpBB2/admin/cash_settings.php on line 188cash_settings.php:
<?php
* cash_settings.php
* begin : Thursday, Jul 14, 2003
* copyright : (C) 2003 Xore
* email : mods@xore.ca
* $Id: cash_settings.php,v 2.1.1.0 2003/09/18 22:57:57 Xore $
define('IN_PHPBB', 1);
define('IN_CASHMOD', 1);
// Let's set the root dir for phpBB
$phpbb_root_path = "./../";
require($phpbb_root_path . 'extension.inc');
require('./pagestart.' . $phpEx);
include($phpbb_root_path . 'includes/functions_selects.'.$phpEx);
if ( $board_config['cash_adminnavbar'] )
$navbar = 1;
include('./admin_cash.'.$phpEx);
if ( !$cash->currency_count() )
message_die(GENERAL_MESSAGE, $lang['Insufficient_currencies']);
$update_set = array(CURRENCY_ENABLED => 'bool',
CURRENCY_IMAGE => 'bool', 'cash_imageurl' => 'text', CURRENCY_PREFIX => 'bool',
'cash_perpost' => 'float', 'cash_postbonus' => 'float', 'cash_perreply' => 'float', 'cash_perchar' => 'float', 'cash_maxearn' => 'float', 'cash_perpm' => 'float',
CURRENCY_VIEWPROFILE => 'bool', CURRENCY_VIEWTOPIC => 'bool', CURRENCY_VIEWMEMBERLIST => 'bool',
CURRENCY_INCLUDEQUOTES => 'bool', CURRENCY_EXCHANGEABLE => 'bool', CURRENCY_DONATE => 'bool', CURRENCY_MODEDIT => 'bool', CURRENCY_ALLOWNEG => 'bool',
'cash_allowance' => 'int', 'cash_allowanceamount' => 'float', 'cash_allowancetime' => 'int', 'cash_max_sellingprice' => 'float', 'cash_min_sellingprice' => 'float', 'cash_max_fortunerequired' => 'float', 'cash_min_fortunerequired' => 'float');
$table_updated = false;
while ( $c_cur = &$cash->currency_next($cm_i) )
$varname = 'cash_' . $c_cur->id();
if ( isset($HTTP_POST_VARS['submit']) &&
isset($HTTP_POST_VARS[$varname]) &&
is_array($HTTP_POST_VARS[$varname]) )
$updates = array();
$settings = $c_cur->data('cash_settings');
$settings_update = false;
while ( list($key,$type) = each ( $update_set ) )
if ( isset($HTTP_POST_VARS[$varname][$key]) )
$data = $HTTP_POST_VARS[$varname][$key];
switch ( $type )
case 'bool':
if ( ($data == '0') || ($data == '1') )
$data = intval($data);
$key = intval($key);
if ( $data )
$settings |= $key;
$settings &= ~$key;
$settings_update = true;
break;
case 'text':
$updates[] = $key . ' = \'' . str_replace("\'", "''", $data) . '\'';
break;
case 'int':
if ( is_numeric($data) )
$updates[] = $key . ' = ' . intval($data);
break;
case 'float':
$updates[] = $key . ' = ' . $c_cur->attribute_pack($key,$data);
break;
if ( $settings_update )
$updates[] = 'cash_settings = ' . $settings;
reset ( $update_set );
if ( count($updates) > 0 )
$sql = "UPDATE " . CASH_TABLE . "
SET " . implode(", ",$updates) . "
WHERE cash_id = " . $c_cur->id();
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, "Failed to update Cash Mod settings for Cash Mod set " . $c_cur->id(), "", __LINE__, __FILE__, $sql);
$table_updated = true;
if ( $table_updated )
$cash->refresh_table();
if ( isset($HTTP_POST_VARS['submit']) )
$message = $lang['Cash_settings_updated'] . "<br /><br />" . sprintf($lang['Click_return_cash_settings'], "<a href=\"" . append_sid("cash_settings.$phpEx") . "\">", "</a>") . "<br /><br />" . sprintf($lang['Click_return_admin_index'], "<a href=\"" . append_sid("index.$phpEx?pane=right") . "\">", "</a>");
"body" => "admin/cash_settings.tpl")
$template->assign_vars(array(
"S_CASH_SETTINGS_ACTION" => append_sid("cash_settings.$phpEx"),
"NUM_COLUMNS" => ($cash->currency_count() + 1),
"L_DISPLAY" => $lang['Display'],
"L_IMPLEMENTATION" => $lang['Implementation'],
"L_ALLOWANCES" => $lang['Allowances'],
"L_ALLOWANCES_EXPLAIN" => $lang['Allowances_explain'],
"L_YES" => $lang['Yes'],
"L_NO" => $lang['No'],
"L_CASH_SETTINGS_TITLE" => $lang['Cash_settings'],
"L_CASH_SETTINGS_EXPLAIN" => $lang['Cash_settings_explain'],
"L_CASH_ENABLED" => $lang['Cash_enabled'],
"L_CASH_CURRENCY" => $lang['Cash_custom_currency'],
"L_PREFIX" => $lang['Prefix'],
"L_POSTFIX" => $lang['Postfix'],
"L_CASH_IMAGE" => $lang['Cash_image'],
"L_CASH_IMAGEURL" => $lang['Cash_imageurl'],
"L_CASH_IMAGEURL_EXPLAIN" => $lang['Cash_imageurl_explain'],
"L_CASH_CURRENCY_STYLE" => $lang['Cash_currency_style'],
"L_CASH_CURRENCY_STYLE_EXPLAIN" => $lang['Cash_currency_style_explain'],
"L_CASH_DISPLAY_USERCP" => $lang['Cash_display_usercp'],
"L_CASH_DISPLAY_USERPOST" => $lang['Cash_display_userpost'],
"L_CASH_DISPLAY_MEMBERLIST" => $lang['Cash_display_memberlist'],
"L_CASH_AMOUNT_PER_POST" => $lang['Cash_amount_per_post'],
"L_CASH_AMOUNT_POST_BONUS" => $lang['Cash_amount_post_bonus'],
"L_CASH_AMOUNT_PER_REPLY" => $lang['Cash_amount_per_reply'],
"L_CASH_AMOUNT_PER_CHARACTER" => $lang['Cash_amount_per_character'],
"L_CASH_MAXEARN" => $lang['Cash_maxearn'],
"L_CASH_AMOUNT_PER_PM" => $lang['Cash_amount_per_pm'],
"L_CASH_INCLUDE_QUOTES" => $lang['Cash_include_quotes'],
"L_CASH_ALLOW_EXCHANGE" => $lang['Cash_exchangeable'],
"L_CASH_ALLOW_DONATE" => $lang['Cash_allow_donate'],
"L_CASH_ALLOW_MOD_EDIT" => $lang['Cash_allow_mod_edit'],
"L_CASH_ALLOW_NEGATIVE" => $lang['Cash_allow_negative'],
"L_CASH_ALLOWANCE_ENABLED" => $lang['Cash_allowance_enabled'],
"L_CASH_ALLOWANCE_AMOUNT" => $lang['Cash_allowance_amount'],
"L_CASH_ALLOWANCE_FREQUNECY" => $lang['Cash_allownace_frequency'],
"L_CASH_ALLOWANCE_FREQUNECIES_DAY" => $lang['Cash_allownace_frequencies'][CASH_ALLOW_DAY],
"L_CASH_ALLOWANCE_FREQUNECIES_WEEK" => $lang['Cash_allownace_frequencies'][CASH_ALLOW_WEEK],
"L_CASH_ALLOWANCE_FREQUNECIES_MONTH" => $lang['Cash_allownace_frequencies'][CASH_ALLOW_MONTH],
"L_CASH_ALLOWANCE_FREQUNECIES_YEAR" => $lang['Cash_allownace_frequencies'][CASH_ALLOW_YEAR],
"L_CASH_ALLOWANCE_NEXT" => $lang['Cash_allowance_next'],
"MAX_PRICE" => $c_cur->cashmaxsellingprice(),
"MIN_PRICE" => $c_cur->cashminsellingprice(),
"MAX_FORTUNE" => $c_cur->cashmaxfortunerequired(),
"MIN_FORTUNE" => $c_cur->cashminfortunerequired(),
"CURRENCY_ENABLED" => CURRENCY_ENABLED,
"CURRENCY_IMAGE" => CURRENCY_IMAGE,
"CURRENCY_PREFIX" => CURRENCY_PREFIX,
"CURRENCY_VIEWPROFILE" => CURRENCY_VIEWPROFILE,
"CURRENCY_VIEWTOPIC" => CURRENCY_VIEWTOPIC,
"CURRENCY_VIEWMEMBERLIST" => CURRENCY_VIEWMEMBERLIST,
"CURRENCY_INCLUDEQUOTES" => CURRENCY_INCLUDEQUOTES,
"CURRENCY_EXCHANGEABLE" => CURRENCY_EXCHANGEABLE,
"CURRENCY_DONATE" => CURRENCY_DONATE,
"CURRENCY_MODEDIT" => CURRENCY_MODEDIT,
"CURRENCY_ALLOWNEG" => CURRENCY_ALLOWNEG,
"CURRENCY_ALLOWANCE" => CURRENCY_ALLOWANCE,
"L_SUBMIT" => $lang['Submit'],
"L_RESET" => $lang['Reset'])
$enabled_cash_yes = ( $c_cur->mask(CURRENCY_ENABLED) ) ? "checked=\"checked\"" : "";
$enabled_cash_no = ( !$c_cur->mask(CURRENCY_ENABLED) ) ? "checked=\"checked\"" : "";
$image_yes = ( $c_cur->mask(CURRENCY_IMAGE) ) ? "checked=\"checked\"" : "";
$image_no = ( !$c_cur->mask(CURRENCY_IMAGE) ) ? "checked=\"checked\"" : "";
$currency_style_before = ( $c_cur->mask(CURRENCY_PREFIX) ) ? "checked=\"checked\"" : "";
$currency_style_after = ( !$c_cur->mask(CURRENCY_PREFIX) ) ? "checked=\"checked\"" : "";
$include_quotes_yes = ( $c_cur->mask(CURRENCY_INCLUDEQUOTES) ) ? "checked=\"checked\"" : "";
$include_quotes_no = ( !$c_cur->mask(CURRENCY_INCLUDEQUOTES) ) ? "checked=\"checked\"" : "";
$display_in_profile_yes = ( $c_cur->mask(CURRENCY_VIEWPROFILE) ) ? "checked=\"checked\"" : "";
$display_in_profile_no = ( !$c_cur->mask(CURRENCY_VIEWPROFILE) ) ? "checked=\"checked\"" : "";
$allow_exchange_yes = ( $c_cur->mask(CURRENCY_EXCHANGEABLE) ) ? "checked=\"checked\"" : "";
$allow_exchange_no = ( !$c_cur->mask(CURRENCY_EXCHANGEABLE) ) ? "checked=\"checked\"" : "";
$allow_donate_yes = ( $c_cur->mask(CURRENCY_DONATE) ) ? "checked=\"checked\"" : "";
$allow_donate_no = ( !$c_cur->mask(CURRENCY_DONATE) ) ? "checked=\"checked\"" : "";
$allow_mod_edit_yes = ( $c_cur->mask(CURRENCY_MODEDIT) ) ? "checked=\"checked\"" : "";
$allow_mod_edit_no = ( !$c_cur->mask(CURRENCY_MODEDIT) ) ? "checked=\"checked\"" : "";
$allow_negative_yes = ( $c_cur->mask(CURRENCY_ALLOWNEG) ) ? "checked=\"checked\"" : "";
$allow_negative_no = ( !$c_cur->mask(CURRENCY_ALLOWNEG) ) ? "checked=\"checked\"" : "";
$display_in_posts_yes = ( $c_cur->mask(CURRENCY_VIEWTOPIC) ) ? "checked=\"checked\"" : "";
$display_in_posts_no = ( !$c_cur->mask(CURRENCY_VIEWTOPIC) ) ? "checked=\"checked\"" : "";
$display_in_memberlist_yes = ( $c_cur->mask(CURRENCY_VIEWMEMBERLIST) ) ? "checked=\"checked\"" : "";
$display_in_memberlist_no = ( !$c_cur->mask(CURRENCY_VIEWMEMBERLIST) ) ? "checked=\"checked\"" : "";
$allowances_enabled_yes = (( !defined(CASH_ALLOWANCES_ENABLED) ) ? "disabled=\"disabled\" " : "") . (( $c_cur->data('cash_allowance') ) ? "checked=\"checked\"" : "");
$allowances_enabled_no = ( !$c_cur->data('cash_allowance') ) ? "checked=\"checked\"" : "";
$allowances_freq_day = ( $c_cur->data('cash_allowancetime') == CASH_ALLOW_DAY ) ? "checked=\"checked\"" : "";
$allowances_freq_week = ( $c_cur->data('cash_allowancetime') == CASH_ALLOW_WEEK ) ? "checked=\"checked\"" : "";
$allowances_freq_month = ( $c_cur->data('cash_allowancetime') == CASH_ALLOW_MONTH ) ? "checked=\"checked\"" : "";
$allowances_freq_year = ( $c_cur->data('cash_allowancetime') == CASH_ALLOW_YEAR ) ? "checked=\"checked\"" : "";
$allowances_next = $c_cur->data('cash_allowancenext');
$template->assign_block_vars("cashrow",array( "CASH_INDEX" => $c_cur->id(),
"ENABLED_CASH_YES" => $enabled_cash_yes,
"ENABLED_CASH_NO" => $enabled_cash_no,
"CURRENCY" => $c_cur->name(),
"IMAGE_YES" => $image_yes,
"IMAGE_NO" => $image_no,
"IMAGEURL" => $c_cur->data('cash_imageurl'),
"CURRENCY_STYLE_BEFORE" => $currency_style_before,
"CURRENCY_STYLE_AFTER" => $currency_style_after,
"AMOUNT_PER_POST" => $c_cur->perpost(),
"AMOUNT_POST_BONUS" => $c_cur->postbonus(),
"AMOUNT_PER_REPLY" => $c_cur->perreply(),
"AMOUNT_PER_CHAR" => $c_cur->perchar(),
"MAXEARN" => $c_cur->maxearn(),
"AMOUNT_PER_PM" => $c_cur->perpm(),
"INCLUDE_QUOTES_YES" => $include_quotes_yes,
"INCLUDE_QUOTES_NO" => $include_quotes_no,
"DISPLAY_IN_PROFILE_YES" => $display_in_profile_yes,
"DISPLAY_IN_PROFILE_NO" => $display_in_profile_no,
"ALLOW_EXCHANGE_YES" => $allow_exchange_yes,
"ALLOW_EXCHANGE_NO" => $allow_exchange_no,
"ALLOW_DONATE_YES" => $allow_donate_yes,
"ALLOW_DONATE_NO" => $allow_donate_no,
"ALLOW_MOD_EDIT_YES" => $allow_mod_edit_yes,
"ALLOW_MOD_EDIT_NO" => $allow_mod_edit_no,
"ALLOW_NEGATIVE_YES" => $allow_negative_yes,
"ALLOW_NEGATIVE_NO" => $allow_negative_no,
"DISPLAY_IN_POSTS_YES" => $display_in_posts_yes,
"DISPLAY_IN_POSTS_NO" => $display_in_posts_no,
"DISPLAY_IN_MEMBERLIST_YES" => $display_in_memberlist_yes,
"DISPLAY_IN_MEMBERLIST_NO" => $display_in_memberlist_no,
"ALLOWANCES_ENABLED_YES" => $allowances_enabled_yes,
"ALLOWANCES_ENABLED_NO" => $allowances_enabled_no,
"ALLOWANCE_AMOUNT" => $c_cur->allowanceamount(),
"ALLOWANCES_FREQ_DAY" => $allowances_freq_day,
"ALLOWANCES_FREQ_WEEK" => $allowances_freq_week,
"ALLOWANCES_FREQ_MONTH" => $allowances_freq_month,
"ALLOWANCES_FREQ_YEAR" => $allowances_freq_year,
"ALLOWANCE_NEXT" => $allowances_next
$template->pparse("body");
include('./page_footer_admin.'.$phpEx);
