[問題]PHPBB有沒有類似軟體下載區的MOD?
simonlee9111
註冊時間: 2004-06-20 21:35
來自: 台北
文章 simonlee9111 »
我想在我的討論區提供會員大量的檔案下載???
請問有誰知道阿!!!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
你可以試試看附件外掛 (Attachment MOD)
可以用 http://phpbb-tw.net/phpbb/search.php 搜尋你要的外掛
p.s. 外掛問題請至外掛問題區詢問
~Mac
william91
文章: 642
註冊時間: 2003-04-16 20:53
來自: 牛牛農場
文章 william91 »
paFileDB
paFileDB 整合 phpBB:
## MOD Title: pafiledb integration
## MOD Version: 0.0.9d
## MOD Author: Mohd < mohdalbasri@yahoo.com > (Mohammed Al-Basri) www.mohd.tk
##          MJ < mj@phpbbfm.net > www.phpbbfm.net
## MOD Description: Integration of pafiledb (Database download manager) with phpbb.
##                  pafiledb use header, footer, session, template, and database system
##          of phpbb.
## Installation Level: (easy)
## Installation Time: 10 Minutes
## Files To Edit (9) : admin/index.php,
##             admin/admin_db_utilities.php
##                     includes/constants.php
##             includes/page_header.php,
##             includes/page_tail.php,
##                     language/lang_english/lang_main.php,
##                     templates/subSilver/admin/page_header.tpl,
##                     templates/subSilver/overall_header.tpl,
##             templates/subSilver/overall_footer.tpl
## Included Files:     dload.php,
##             admin/admin_backupdb.php,
##             admin/admin_category.php,
##             admin/admin_custom.php,
##             admin/admin_file.php,
##             admin/admin_license.php,
##             admin/admin_restoredb.php,
##             admin/admin_settings.php,
##             images/pafiledb_icons/*.*
##             language/lang_english/lang_pafiledb.php
##             pafiledb/*.* ( which I included in mod/ directory ),
##             templates/subSilver/pa_*.tpl ( 12 )
##             templates/subSilver/admin/pa_*.tpl ( 16 )
##             templates/subSilver/images/icon_mini_download.gif
## For Security Purposes, Please Check: http://www.phpbb.com/mods/downloads/ for the
## in our MOD-Database, located at: http://www.phpbb.com/mods/downloads/
## Author Note:
## follow all the instruction below first then upload and run from your browser,
## paFileDB_installer.php and if you have the table already installed,
## you won't need to change anything in them except that you won't need the admin table
## since you are going to use ACP.
## Change History:
##   0.0.7 : Added/Fixed:
##      - Fixing bug with screen shot upload.
##      - Fixing bug with templates in ACP.
##      - Removing Variable $str found in search.php.
##      - Changing directory for images and icons.
##      - Changing all url and action to append_sid.
##   0.0.6 : Added/Fixed:
##      - Backupdb & restore to phpBB forum backup style
##      - Changing tables to phpbb style
##      - Show screenshots as image instead of link.
##        (you may choose now either links or image).
##      - Long Description - Multiple line text area.
##      - Replacing pafiledb language with phpbb.
##      - Unlimited subCategories.
##      - Added Upload Screenshot feature
##      - Added Disable "View All" link
##      - Added Disable Database feature
##      - comment feature (only registered users can post)
##      - Email is using phpBB class emailer.
##      - New File indicator you can now set the
##        number of day to show that the file is new
##      - Added toplist file
##        (you can now specify number of file that in toplist.
##      - removing the following bugs:
##         * Replaced pafiledb Time Zone with phpbb.
##         * Replaced pafiledb Language with phpbb.
##         * Email fields can be left blank, but confirmation of email sent is returned.
##         * Custom Field data not reading from db
##         * Time on posted comment
##         * Edit file (ACP), sub-cats & files not showing
##         * Backup Database screwed
##         * removing some un needed row from setting table like language and style.
##         * fixing the problem of jumpmenu fix in pafiledb.php file because file send the $str instead of $lang
##         * 'Comment Explain' text missing
##         * Title on posted comment
##         * max_comment_chars field in _settings table missing
##         * Javascript error when posting or previewing comment
##         * Email not actually sending to address ??? (Not for me anyway!)
##         * Time on file page
##   0.0.5 : - Re-packing of all working files
##            - Changes to paFileDB_installer.php
##    0.0.4 : Fixed:
##       - {dbname} showing in the email instead of the variable that should replace it.
##       - Uploaded file not returning full URL.
##       - Replacing pafiledb Time Zone with phpbb.
##       - Email fields can be left blank, but confirmation of email sent is returned
##       - sort for viewall is now fixed.. (sort according to rating not yet due to php version)
##       - Custom Field data not reading from db
##       - Add the support for view online when some one in download page.
##   0.0.3 : - fix the editing file bug in ACP
##      - fix the the file in sub category bug.
##      - fix the uploading file url bug when uploading
##      - changing message after rating or e-mail sending
##      - making copywrite with phpbb copywrite only if you are in download database
##   0.0.2 : All templates made to fit phpBB default, clean up of code.
##    0.0.1 : First release, I need just to modify the *.tpl file in admin
##       section.
http://mohd.vraag-en-antwoord.nl/main/d ... file_id=53
間中上來走走吧~
