只有每次點選控制台中的「Portal-基本組態」時都會出現「已完成,但網頁發生錯誤」的錯誤訊息視窗。
上面寫著:
請問該如何修改?
附上 admin_portal.php 的程式碼:
[php]<?php
* admin_portal.php
* begin : Wednesday, Dec 25, 2002
* copyright : (C) 2002 ThunderCat
* email : thundercat@die-pretorianer.de
* $Id: admin_portal.php,v 1.01.0.0 2002/12/25 00:00:00 psotfx Exp $
define('IN_PHPBB', 1);
if( !empty($setmodules) )
$file = basename(__FILE__);
$module['Portal']['Configuration'] = "$file?mode=config";
return;
// Let's set the root dir for phpBB
$phpbb_root_path = "./../";
require($phpbb_root_path . 'extension.inc');
require('./pagestart.' . $phpEx);
define('PORTAL_TABLE', $table_prefix.'portal');
// Pull all config data
$sql = "SELECT * FROM " . PORTAL_TABLE;
if(!$result = $db->sql_query($sql))
message_die(CRITICAL_ERROR, "Could not query config information in admin_portal", "", __LINE__, __FILE__, $sql);
$portal_name = $row['portal_name'];
$portal_value = $row['portal_value'];
$default_portal[$portal_name] = $portal_value;
$new[$portal_name] = ( isset($HTTP_POST_VARS[$portal_name]) ) ? $HTTP_POST_VARS[$portal_name] : $default_portal[$portal_name];
if( isset($HTTP_POST_VARS['submit']) )
$sql = "UPDATE " . PORTAL_TABLE . " SET
portal_value = '" . str_replace("\'", "''", $new[$portal_name]) . "'
WHERE portal_name = '$portal_name'";
if( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, "Failed to update general configuration for $portal_name", "", __LINE__, __FILE__, $sql);
$message = $lang['Config_updated'] . "<br /><br />" . sprintf($lang['Click_return_config'], "<a href=\"" . append_sid("admin_portal.$phpEx") . "\">", "</a>") . "<br /><br />" . sprintf($lang['Click_return_admin_index'], "<a href=\"" . append_sid("index.$phpEx?pane=right") . "\">", "</a>");
"body" => "admin/portal_config_body.tpl")
$template->assign_vars(array(
"S_CONFIG_ACTION" => append_sid("admin_portal.$phpEx"),
"L_CONFIGURATION_TITLE" => $lang['EZPortal_Config'],
"L_GENERAL_SETTINGS" => $lang['EZPortal_settings'],
"L_WELCOME_TEXT" => $lang['Welcome_Text'],
"L_HTML_AREA" => $lang['Html_areal'],
"L_NUMBER_OF_NEWS" => $lang['Number_of_News'],
"L_NEWS_LENGTH" => $lang['News_length'],
"L_NEWS_FORUM" => $lang['News_Forum'],
"L_POLL_FORUM" => $lang['Poll_Forum'],
"L_NUMBER_RECENT_TOPICS" => $lang['Number_Recent_Topics'],
"L_EXCEPTIONAL_FORUMS" => $lang['Exceptional_forums'],
"L_LAST_SEEN" => $lang['Last_Seen'],
"L_SUBMIT" => $lang['Submit'],
"L_RESET" => $lang['Reset'],
"L_SHOW" => $lang['Portal_Show'],
"L_HIDE" => $lang['Portal_Hide'],
"L_COMMA" => $lang['Comma'],
"WELCOME_TEXT" => $new['welcome_text'],
"HTML_AREA" => $new['html_area'],
"NUMBER_OF_NEWS" => $new['number_of_news'],
"NEWS_LENGTH" => $new['news_length'],
"NEWS_FORUM" => $new['news_forum'],
"POLL_FORUM" => $new['poll_forum'],
"NUMBER_RECENT_TOPICS" => $new['number_recent_topics'],
"EXCEPTIONAL_FORUMS" => $new['exceptional_forums'],
"LAST_SEEN" => $new['last_seen'])
$template->pparse("body");
include('./page_footer_admin.'.$phpEx);
?>[/php]
