參考連結:http://phpbb-tw.net/phpbb/viewtopic.php ... =MX-Portal
使用版本:phpBB 2.0.8a
網站位置:失敗中\r
實在看不懂英文...可否大概說一下如何安裝呢\r
我看好像要把它下載的mx資料夾放到www下面\r
執行install
可是我執行後照他表格寫的填寫
按確認後最下面一行出現紅色訊息\r
Language: English must be default language for phpBB during installation
如果略過錯誤訊息繼續的話又到另一個安裝面 好像是裝DB的吧\r
出現紅色錯誤訊息...
[Already added in previous update (or db error)] line: 1 , ALTER TABLE mx_page add( auth_view tinyint(2) NOT NULL default '0' )
[Already added in previous update (or db error)] line: 2 , ALTER TABLE mx_portal add( portal_version varchar(255) default '2.7.3' )
[Already added in previous update (or db error)] line: 3 , ALTER TABLE mx_portal add( top_phpbb_links smallint(5) unsigned default '1' NOT NULL )
[Already added in previous update (or db error)] line: 4 , ALTER TABLE mx_menu_categories add( cat_show TINYINT(1) UNSIGNED DEFAULT '1' NOT NULL )
[Already added in previous update (or db error)] line: 5 , ALTER TABLE mx_menu_nav add( page_id smallint(5) unsigned default '0' )
[Already added in previous update (or db error)] line: 6 , ALTER TABLE mx_menu_nav add( auth_view_group smallint(5) NOT NULL default '0' )
[Already added in previous update (or db error)] line: 7 , ALTER TABLE mx_block add( auth_view_group smallint(5) NOT NULL default '0', auth_edit_group smallint(5) NOT NULL default '0', auth_delete_group smallint(5) NOT NULL default '0' )
[Already added in previous update (or db error)] line: 8 , ALTER TABLE mx_page add( auth_view_group smallint(5) NOT NULL default '0' )
[Already added in previous update (or db error)] line: 10 , ALTER TABLE mx_menu_nav add( link_target tinyint(2) unsigned NOT NULL default '0' )
[Already added in previous update (or db error)] line: 11 , ALTER TABLE mx_page add( page_header varchar(255) default 'overall_header.tpl' NULL )
之後以下的教學幾乎看不懂他再說什麼了...
可不可以大概說明一下下我再去猜~@@
可否問一下現在的入口網頁的MOD好像有
MX-System Portal
php-Nuke
ezPortal
爬一些文之後 都不建議安裝!?
不然就是很難安裝...
可是都是快一年前的文章
不知道現在有沒比較好用版本!?
或是比較好用....
還是要自己改版面比較好? (可是好難...)
希望我沒選錯^^a
