又安裝了相片簿mod,有時會想想,二者都有上傳的功能
且又會增加了不少站的複雜度!
所以就想利用attachment的功能來達到類似相本的功能
但無法像 4images 那樣有
開放區、會員區、相本評分之類!
若不想裝那麼多的話…就試試吧!
demo 圖
make copy attachments.php and attachments.tpl
then rename viewattachpic.php and viewattchpic.tpl
viewattachpic.php
#-----[ AFTER, ADD ]---------------------------------------
$pic_per_page=12; // picture per_page default is 12. u can set n of 4 n= 4,8,12,16...
#-----[ FIND ALL ]---------------------------------------------
$board_config['topics_per_page']
#-----[ REPLACE WITH ]---------------------------------------
# note: all about
# $board_config['topics_per_page'] -> $pic_per_page
$pic_per_page
attachments.tpl
viewattachpic.tpl
if (!$forum_id && $display_all_forums)
$sql = "SELECT a.post_id, t.topic_title, d.*
FROM " . $attach_table . " a, " .
WHERE (a.post_id = p.post_id) AND (p.forum_id I
#-----[ IN-LINE FIND ]---------------------------------------------
(a.attach_id = d.attach_id)
#-----[ IN-LINE AFTER, ADD ]---------------------------------------
AND (d.mimetype LIKE 'image%')
else if (($is_auth_ary[$forum_id]['auth_read'])
FROM " . $attach_table . " a, " . $atta
WHERE (a.post_id = p.post_id) AND (p.forum_id = " .
for ($i = 0; $i < $num_attachments; $i++)
#-----[ BEFORE, ADD ]---------------------------------------
$k=0;
# note: all
$class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
$post_title = $attachments[$i]['topic_title'];
$post_title_2 = '';
if($k==0)
\n$template->assign_block_vars('picrow', array());
$k=4; // how many row u want? k=?
$k--;
$pic_name=$attachments[$i]['physical_filename'];
$pic_url=($attachments[$i]['thumbnail'])? $upload_dir . '/' . THUMB_DIR . '/t_'. $pic_name : $upload_dir . '/' . $pic_name;
$pic_url="<img src='".$pic_url."' border='0'>";
if (strlen($filename) > 32)
$filename_2 = substr($filename, 0, 30) . '...';
$view_attachment = append_sid($phpbb_root_path . 'download.' . $phpEx . '?id=' . intval($attachments[$i]['attach_id']));
if ($filename_2 != '')
$filename_link = '<a href="' . $view_attachment . '" class="gen" title="' . $filename . '" target="_blank">' . $filename_2 . '</a>';
$filename_link = '<a href="' . $view_attachment . '" class="gen" target="_blank">' . $filename . '</a>';
# note: all
if (strlen($filename) > 32) // limit len of filename
$filename = substr($filename, 0, 30) . '...';
$template->assign_block_vars('attachrow', array(
'ROW_NUMBER' => $i + ( $HTTP_GET_VARS['start'] + 1 ),
'ROW_CLASS' => $class,
'FILENAME' => $filename,
'COMMENT' => $comment_field,
'SIZE' => round(($attachments[$i]['filesize'] / 1024), 2),
'DOWNLOAD_COUNT' => $attachments[$i]['download_count'],
'POST_TIME' => create_date($board_config['default_dateformat'], $attachments[$i]['filetime'], $board_config['board_timezone']),
'POST_TITLE' => $post_title,
'VIEW_ATTACHMENT' => $filename_link)
# note: all
$template->assign_block_vars('picrow.pic', array(
'PIC' =>$pic_url,
'PIC_URL' => $view_attachment,
'ROW_CLASS' => $theme['td_class2'])
$template->assign_block_vars('picrow.detail', array(
'ROW_CLASS' => $theme['td_class1'],
'POST_URL' => $view_topic,
# note: around 420, second $sql = '';
$sql = '';
// this is make table beauty, if u don't care then make if.
while($k)
'ROW_CLASS' => $theme['td_class2']));
$k--;
attachments.$phpEx?mode
viewattachpic.$phpEx?mode
viewattachpic.tpl
<th height="25" class="thCornerL" nowrap="nowrap">#</th>
<th class="thTop" nowrap="nowrap">{L_FILENAME}</th>
<th class="thTop" nowrap="nowrap">{L_FILECOMMENT}</th>
<th class="thTop" nowrap="nowrap">{L_SIZE}</th>
<th class="thTop" nowrap="nowrap">{L_DOWNLOADS}</th>
<th class="thTop" nowrap="nowrap">{L_POST_TIME}</th>
<th class="thCornerR" nowrap="nowrap">{L_POSTED_IN_TOPIC}</th>
<!-- BEGIN attachrow -->
<td class="{attachrow.ROW_CLASS}" align="center"><span class="gen"> {attachrow.ROW_NUMBER} </span></td>
<td class="{attachrow.ROW_CLASS}" align="center"><span class="gen">{attachrow.VIEW_ATTACHMENT}</span></td>
<td class="{attachrow.ROW_CLASS}" align="center"><span class="gen"><b>{attachrow.COMMENT}</b></span></td>
<td class="{attachrow.ROW_CLASS}" align="center" valign="middle"><span class="gen"><b>{attachrow.SIZE}</b></span></td>
<td class="{attachrow.ROW_CLASS}" align="center" valign="middle"><span class="gen"><b>{attachrow.DOWNLOAD_COUNT}</b></span></td>
<td class="{attachrow.ROW_CLASS}" align="center" valign="middle"><span class="gensmall">{attachrow.POST_TIME}</span></td>
<td class="{attachrow.ROW_CLASS}" align="center" valign="middle"><span class="gen">{attachrow.POST_TITLE}</span></td>
<!-- END attachrow -->
<td class="catbottom" colspan="8" height="28"> </td>
# note: all
<td class="catbottom" colspan="4" height="28"> </td>
<!-- BEGIN picrow -->
<!-- BEGIN pic -->
<td class="{picrow.pic.ROW_CLASS}" align="center" width="25%">
<a href="{picrow.pic.PIC_URL}" target="_blank">{picrow.pic.PIC}</a>
</td>
<!-- END pic -->
<!-- BEGIN detail -->
<td class="{picrow.detail.ROW_CLASS}" valign="top">
<span class="gen">
{L_FILENAME}:{picrow.detail.FILENAME}<br>
{L_FILECOMMENT}:{picrow.detail.COMMENT}<br>
{L_SIZE}:{picrow.detail.SIZE}<br>
{L_DOWNLOADS}:{picrow.detail.DOWNLOAD_COUNT}<br>
{L_POST_TIME}:{picrow.detail.POST_TIME}<br>
{L_POSTED_IN_TOPIC}:<a href="{picrow.detail.POST_URL}" class="topictitle">{picrow.detail.POST_TITLE}</a></span>
</td>
<!-- END detail -->
<!-- END picrow -->
基本上本程式也是利用view_attachments_v102來修改成的。
