就是在股票上市囉!!' 後面,你的是一個逗點,但是我卻有兩個逗點出來,所以我在想是不是這個檔案"admin_vault_exchange.php"的問題,因為我不覺得是"stock_total"的問題耶QQ
<?php
* admin_vault_exchange.php
* begin : 10/01/2004
if( !empty($setmodules) )
$file = basename(__FILE__);
$module['Vault']['Vault_exchange'] = $file;
return;
define('IN_PHPBB', true);
$phpbb_root_path = '../';
require($phpbb_root_path . 'extension.inc');
require("pagestart.$phpEx");
\n$template->set_filenames(array(
'body' => 'admin/config_vault_exchange_body.tpl')
$submit = isset($HTTP_POST_VARS['submit']);
$sql = "SELECT *
FROM " . VAULT_GENERAL_TABLE ;
if(!$result = $db->sql_query($sql))
message_die(CRITICAL_ERROR, "Could not query config information in admin_board", "", __LINE__, __FILE__, $sql);
$vault[$row['config_name']] = $row['config_value'];
if ( $submit )
$use = intval ( $HTTP_POST_VARS['use']);
$min = intval ( $HTTP_POST_VARS['min']);
$max = intval ( $HTTP_POST_VARS['max']);
$time = intval ( $HTTP_POST_VARS['time']);
$lsql= "UPDATE ". CONFIG_TABLE . " SET config_value = '$use' WHERE config_name = 'stock_use' ";
if ( !($lresult = $db->sql_query($lsql)) )
message_die(GENERAL_ERROR, $lang['Vault_update_error'] , "", __LINE__, __FILE__, $lsql);
$lsql= "UPDATE ". VAULT_GENERAL_TABLE . " SET config_value = '$min' WHERE config_name = 'stock_min_change' ";
$lsql= "UPDATE ". VAULT_GENERAL_TABLE . " SET config_value = '$max' WHERE config_name = 'stock_max_change' ";
$lsql= "UPDATE ". CONFIG_TABLE . " SET config_value = '$time' WHERE config_name = 'stock_time' ";
vault_update_general_config();
message_die(GENERAL_MESSAGE, sprintf($lang['Vault_exchange_updated_return_settings'], '<a href="' . append_sid(basename(__FILE__)) . '">', '</a>'), $lang['Vault_settings']);
if( isset($HTTP_POST_VARS['mode']) || isset($HTTP_GET_VARS['mode']) )
$mode = ( isset($HTTP_POST_VARS['mode']) ) ? $HTTP_POST_VARS['mode'] : $HTTP_GET_VARS['mode'];
$mode = "";
if( isset($HTTP_POST_VARS['add']) || isset($HTTP_GET_VARS['add']) )
"body" => 'admin/config_vault_exchange_add_body.tpl')
$template->assign_block_vars('exchange_add',array());
$s_hidden_fields = '<input type="hidden" name="mode" value="savenew" />';
$template->assign_vars(array(
'L_VAULT_EXCHANGE_ADD_SETTINGS' => $lang['Vault_exchange_settings_add'],
'L_VAULT_EXCHANGE_ADD_SETTINGS_EXPLAIN' => $lang['Vault_exchange_settings_explain_add'],
'L_STOCK_EXCHANGE_ACTIONS_ADD' => $lang['Vault_exchange_actions_add'],
'L_STOCK_TOTAL' => $lang['Vault_exchange_stock_total'],
'L_STOCK_NAME' => $lang['Vault_exchange_actions_name'],
'L_STOCK_DESC' => $lang['Vault_exchange_actions_desc'],
'L_STOCK_AMOUNT' => $lang['Vault_exchange_actions_amount'],
"S_HIDDEN_FIELDS" => $s_hidden_fields)
else if ( $mode != "" )
switch( $mode )
case 'delete':
$stock_id = ( !empty($HTTP_POST_VARS['id']) ) ? $HTTP_POST_VARS['id'] : $HTTP_GET_VARS['id'];
$sql = "SELECT * FROM " . VAULT_EXCHANGE_USERS_TABLE . "
WHERE stock_id = " . $stock_id;
if( !$result )
message_die(GENERAL_ERROR, "Couldn't delete stock", "", __LINE__, __FILE__, $sql);
$users = $db->sql_fetchrowset($result);
for ( $i = 0 ; $i < count ( $users ) ; $i ++ )
$ssql = "SELECT stock_price FROM " . VAULT_EXCHANGE_TABLE . "
$sresult = $db->sql_query($ssql);
if( !$sresult )
message_die(GENERAL_ERROR, "Couldn't delete stock", "", __LINE__, __FILE__, $ssql);
$prize = $db->sql_fetchrow($sresult);
$price = $prize['stock_price'] * $users[$i]['stock_amount'];
$usql = "UPDATE " . USERS_TABLE . "
SET user_points = user_points + $price
WHERE user_id = ".$users[$i]['user_id'];
$uresult = $db->sql_query($usql);
if( !$uresult )
message_die(GENERAL_ERROR, "Couldn't delete stock", "", __LINE__, __FILE__, $usql);
$sql = "DELETE FROM " . VAULT_EXCHANGE_USERS_TABLE . "
if( !$result )
$sql = "DELETE FROM " . VAULT_EXCHANGE_TABLE . "
if( !$result )
message_die(GENERAL_MESSAGE, sprintf($lang['Vault_exchange_deleted_return_settings'], '<a href="' . append_sid(basename(__FILE__)) . '">', '</a>'), $lang['Vault_settings']);
break;
case 'edit':
$sql = "SELECT *
if( !$result )
message_die(GENERAL_ERROR, 'Could not obtain stock exchange information', "", __LINE__, __FILE__, $sql);
$stock_data = $db->sql_fetchrow($result);
$template->assign_block_vars('exchange_edit',array());
$s_hidden_fields = '<input type="hidden" name="mode" value="save" /><input type="hidden" name="stock_id" value="' . $stock_data['stock_id'] . '" />';
'STOCK_TOTAL' => $stock_data['stock_total'],
'STOCK_NAME' => $stock_data['stock_name'],
'STOCK_DESC' => $stock_data['stock_desc'],
'STOCK_AMOUNT' => $stock_data['stock_price'],
'L_STOCK_EXCHANGE_ACTIONS_EDIT' => $lang['Vault_exchange_actions_edit'],
'L_VAULT_EXCHANGE_EDIT_SETTINGS' => $lang['Vault_exchange_settings_edit'],
'L_VAULT_EXCHANGE_EDIT_SETTINGS_EXPLAIN' => $lang['Vault_exchange_settings_explain_edit'],
break;
case "save":
$stock_name = ( isset($HTTP_POST_VARS['stock_name']) ) ? trim($HTTP_POST_VARS['stock_name']) : trim($HTTP_GET_VARS['stock_name']);
$stock_desc = ( isset($HTTP_POST_VARS['stock_desc']) ) ? trim($HTTP_POST_VARS['stock_desc']) : trim($HTTP_GET_VARS['stock_desc']);
$stock_total = ( isset($HTTP_POST_VARS['stock_total']) ) ? intval($HTTP_POST_VARS['stock_total']) : intval($HTTP_GET_VARS['stock_total']);
$stock_price = ( isset($HTTP_POST_VARS['stock_price']) ) ? intval($HTTP_POST_VARS['stock_price']) : intval($HTTP_GET_VARS['stock_price']);
$stock_id = ( isset($HTTP_POST_VARS['stock_id']) ) ? intval($HTTP_POST_VARS['stock_id']) : intval($HTTP_GET_VARS['stock_id']);
if ($stock_name == '' || $stock_desc == '' || $stock_total == '' || $stock_price == '')
message_die(MESSAGE, $lang['Fields_empty']);
$sql = "UPDATE " . VAULT_EXCHANGE_TABLE . "
SET stock_name = '" . str_replace("\'", "''", $stock_name) . "',
stock_desc = '" . str_replace("\'", "''", $stock_desc) . "',
stock_total = $stock_total,
stock_price = $stock_price
if( !$result )
message_die(GENERAL_ERROR, "Couldn't update stock", "", __LINE__, __FILE__, $sql);
message_die(GENERAL_MESSAGE, sprintf($lang['Vault_exchange_edited_return_settings'], '<a href="' . append_sid(basename(__FILE__)) . '">', '</a>'), $lang['Vault_settings']);
break;
case "savenew":
$sql = "SELECT *
FROM " . VAULT_EXCHANGE_TABLE ."
ORDER BY stock_id
DESC LIMIT 1";
if( !$result )
$stock_id = $stock_data['stock_id'] +1;
if ($stock_name == '' || $stock_desc == '' || $stock_price == '' )
$sql = "INSERT INTO " . VAULT_EXCHANGE_TABLE . " (stock_id, stock_name, stock_desc,stock_total,stock_price,stock_previous_price,stock_worst_price,stock_best_price)
VALUES ( $stock_id, '" . str_replace("\'", "''", $stock_name) . "' , '" . str_replace("\'", "''", $stock_desc) . "' ,$stock_total, $stock_price, $stock_price, $stock_price, $stock_price)";
if( !$result )
message_die(GENERAL_ERROR, "Couldn't insert new stock", "", __LINE__, __FILE__, $sql);
message_die(GENERAL_MESSAGE, sprintf($lang['Vault_exchange_added_return_settings'], '<a href="' . append_sid(basename(__FILE__)) . '">', '</a>'), $lang['Vault_settings']);
break;
$sql = "SELECT *
ORDER BY stock_id ";
if( !$result )
message_die(GENERAL_ERROR, "Couldn't obtain stock exchange from database", "", __LINE__, __FILE__, $sql);
$exchange = $db->sql_fetchrowset($result);
for($i = 0; $i < count($exchange); $i++)
$stock_name = isset($lang[$exchange[$i]['stock_name']]) ? $lang[$exchange[$i]['stock_name']] : $exchange[$i]['stock_name'];
$stock_desc = isset($lang[$exchange[$i]['stock_desc']]) ? $lang[$exchange[$i]['stock_desc']] : $exchange[$i]['stock_desc'];
$template->assign_block_vars("exchange", array(
"ROW_COLOR" => "#" . $row_color,
"ROW_CLASS" => $row_class,
"STOCK_NAME" => $stock_name,
"STOCK_DESC" => $stock_desc,
"STOCK_AMOUNT" => $exchange[$i]['stock_price'],
"U_STOCK_EDIT" => append_sid("admin_vault_exchange.$phpEx?mode=edit&id=" . $exchange[$i]['stock_id']),
"U_STOCK_DELETE" => append_sid("admin_vault_exchange.$phpEx?mode=delete&id=" . $exchange[$i]['stock_id']))
'L_STOCK_EXCHANGE_ACTIONS' => $lang['Vault_exchange_actions'],
'L_ACTION' => $lang['Vault_exchange_action'],
'L_EDIT' => $lang['Vault_exchange_edit'],
'L_DELETE' => $lang['Vault_exchange_delete'],
'L_STOCK_ADD' => $lang['Vault_exchange_actions_add'],
'VAULT_EXCHANGE_USE_CHECKED' => ( $board_config['stock_use'] ? 'CHECKED' :'' ),
'VAULT_EXCHANGE_TIME' => $board_config['stock_time'],
'VAULT_EXCHANGE_TIME_EXPLAIN' => $lang['Vault_time_explain'].vault_make_time($board_config['stock_time']),
'VAULT_EXCHANGE_MAX' => $vault['stock_max_change'],
'VAULT_EXCHANGE_MIN' => $vault['stock_min_change'],
'L_VAULT_EXCHANGE_LANGUAGE_KEY' => $lang['Vault_language_key'],
'L_VAULT_EXCHANGE_SETTINGS' => $lang['Vault_exchange_settings'],
'L_VAULT_EXCHANGE_SETTINGS_EXPLAIN' => $lang['Vault_exchange_settings_explain'],
'L_VAULT_EXCHANGE_USE' => $lang['Vault_exchange_use'],
'L_VAULT_EXCHANGE_MIN' => $lang['Vault_exchange_min'],
'L_VAULT_EXCHANGE_MIN_EXPLAIN' => $lang['Vault_exchange_min_explain'],
'L_VAULT_EXCHANGE_MAX' => $lang['Vault_exchange_max'],
'L_VAULT_EXCHANGE_MAX_EXPLAIN' => $lang['Vault_exchange_max_explain'],
'L_VAULT_EXCHANGE_TIME' => $lang['Vault_exchange_time'],
'L_VAULT_EXCHANGE_TIME_EXPLAIN' => $lang['Vault_exchange_time_explain'],
'L_SUBMIT' => $lang['Submit'],
'S_VAULT_ACTION' => append_sid(basename(__FILE__)),
$template->pparse('body');
include('./page_footer_admin.'.$phpEx);
