[問題]vault問題
[問題]vault問題
請問大大~~
phpBB : Critical Error
Could not query config information in admin_board
SQL Error : 1146 Table 'phpbb.vault_general_table' doesn't exist
SELECT * FROM VAULT_GENERAL_TABLE
Line : 33
File : c:\appserv\www\phpbb\admin\\admin_vault_exchange.php
怎辦?
Line : 33
怎辦?
仔細看看安裝說明中關於 SQL 的部份
#--------------[ SQL ]-------------
內的都要執行 看錯誤訊息是 phpbb_vault_general table 並不存在\r
應該是 SQL 指令沒執行或是執行不完全\r
因為 SQL 指令內有以下這段\r
因為 SQL 指令內有以下這段\r
CREATE TABLE phpbb_vault_general (
config_name varchar(255) NOT NULL default '',
config_value int(15) NOT NULL default '0',
PRIMARY KEY (config_name)
) TYPE=MyISAM;我巳打了
INSERT INTO phpbb_config (config_name, config_value) VALUES ('vault_enable', '1');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('vault_name', 'Vault');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('stock_use', '1');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('stock_time', '86400');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('stock_last_change', '0');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('vault_display_profile', '1');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('vault_display_topics', '0');
CREATE TABLE phpbb_vault_blacklist (
user_id int(8) NOT NULL default '0',
user_due int(8) NOT NULL default '0',
PRIMARY KEY (user_id)
) TYPE=MyISAM;
CREATE TABLE phpbb_vault_exchange (
stock_id int(8) NOT NULL default '0',
stock_name varchar(40) NOT NULL default '',
stock_desc varchar(255) NOT NULL default '',
stock_price int(8) NOT NULL default '0',
stock_previous_price int(8) NOT NULL default '0',
stock_best_price int(8) NOT NULL default '0',
stock_worst_price int(8) NOT NULL default '0',
PRIMARY KEY (stock_id)
) TYPE=MyISAM;
INSERT INTO phpbb_vault_exchange (stock_id, stock_name, stock_desc, stock_price, stock_previous_price, stock_best_price, stock_worst_price) VALUES (1, 'Vault_action_name_1', 'Vault_action_desc_1', 100, 100, 100, 100);
INSERT INTO phpbb_vault_exchange (stock_id, stock_name, stock_desc, stock_price, stock_previous_price, stock_best_price, stock_worst_price) VALUES (2, 'Vault_action_name_2', 'Vault_action_desc_2', 200, 200, 200, 200);
INSERT INTO phpbb_vault_exchange (stock_id, stock_name, stock_desc, stock_price, stock_previous_price, stock_best_price, stock_worst_price) VALUES (3, 'Vault_action_name_3', 'Vault_action_desc_3', 300, 300, 300, 300);
CREATE TABLE phpbb_vault_exchange_users (
stock_id mediumint(8) NOT NULL default '0',
user_id mediumint(8) NOT NULL default '0',
stock_amount mediumint(8) NOT NULL default '0',
KEY stock_id (stock_id),
KEY user_id (user_id)
) TYPE=MyISAM;
) TYPE=MyISAM;
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('vault_loan_enable', 1);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('interests_rate', 4);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('interests_time', 86400);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('loan_interests', 15);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('loan_interests_time', 864000);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('loan_max_sum', 5000);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('loan_requirements', 0);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('stock_max_change', 10);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('stock_min_change', 0);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('base_amount', 10);
INSERT INTO phpbb_vault_general (config_name, config_value) VALUES ('num_items', 30);
CREATE TABLE phpbb_vault_users (
owner_id int(8) NOT NULL default '0',
account_id int(8) NOT NULL default '0',
account_sum int(8) NOT NULL default '0',
account_time int(11) NOT NULL default '0',
loan_sum int(8) NOT NULL default '0',
loan_time int(11) NOT NULL default '0',
account_protect tinyint(1) NOT NULL default '0',
loan_protect tinyint(1) NOT NULL default '0',
newsletter tinyint(1) NOT NULL default '0',
PRIMARY KEY (owner_id)
) TYPE=MyISAM;
但回應是\r
MySQL 傳回:
#1062 - Duplicate entry 'vault_enable' for key 1
) TYPE=MyISAM;
) TYPE=MyISAM;
) TYPE=MyISAM;
) TYPE=MyISAM;
) TYPE=MyISAM;
但回應是\r
MySQL 傳回:
