[問題]Cash Mod 2.2.2的問題
嵐弟
文章: 17
註冊時間: 2004-12-03 14:10
文章 嵐弟 »
我照著cm_install_222檔案照著加入sql
There is an automatic sql installer that works currently for mysql and mssql
It is neccessary to copy the file sql_install.php to your main phpbb directory and run it from there
After that, you want to delete the file immediately.
If you prefer to run the queries manually yourself, or to translate it to a different dbms
than mysql or mssql, the raw queries are located in sql_222.txt, but are only available for mysql.
I will try to include more dbms's for the installer for future releases, but nothing is guaranteed
at present
出現\r
錯誤
SQL 語法:
MySQL 傳回:
#1065 - Query was empty
該怎麼辦= =~~
不管架什麼mod加入sql都會錯誤~~
有時還會連不到網頁~
