使用版本:1.0.2 Beta
我安裝Advanced Hide Post, 之後出現錯誤訊息:
Parse error: parse error, expecting `')'' in c:\appserv\www\phpbb2\includes\auth.php on line 59
<?php
* auth.php
* email : support@phpbb.com
* $Id: auth.php,v 1.37.2.5 2004/03/01 16:49:03 psotfx Exp $
$type's accepted (pre-pend with AUTH_):
VIEW, READ, POST, REPLY, EDIT, DELETE, STICKY, ANNOUNCE, VOTE, POLLCREATE
Possible options ($type/forum_id combinations):
* If you include a type and forum_id then a specific lookup will be done and
the single result returned
* If you set type to AUTH_ALL and specify a forum_id an array of all auth types
will be returned
* If you provide a forum_id a specific lookup on that forum will be done
* If you set forum_id to AUTH_LIST_ALL and specify a type an array listing the
results for all forums will be returned
* If you set forum_id to AUTH_LIST_ALL and type to AUTH_ALL a multidimensional
array containing the auth permissions for all types and all forums for that
user is returned
All results are returned as associative arrays, even when a single auth type is
specified.
If available you can send an array (either one or two dimensional) containing the
forum auth levels, this will prevent the auth function having to do its own
lookup
function auth($type, $forum_id, $userdata, $f_access = '')
global $db, $lang;
switch( $type )
case AUTH_ALL:
$a_sql = 'a.auth_view, a.auth_read, a.auth_post, a.auth_reply, a.auth_edit, a.auth_delete, a.auth_sticky, a.auth_announce, a.auth_vote, a.auth_pollcreate, a.auth_sellpost, a.auth_hide4reply, a.auth_hide4posts, a.auth_hide4fortune';
$auth_fields = array('auth_view', 'auth_read', 'auth_post', 'auth_reply', 'auth_edit', 'auth_delete', 'auth_sticky', 'auth_announce', 'auth_vote', 'auth_pollcreate, 'auth_sellpost', 'auth_hide4reply', 'auth_hide4posts', 'auth_hide4fortune'');
break;
case AUTH_VIEW:
$a_sql = 'a.auth_view';
$auth_fields = array('auth_view');
break;
case AUTH_READ:
$a_sql = 'a.auth_read';
$auth_fields = array('auth_read');
break;
case AUTH_POST:
$a_sql = 'a.auth_post';
$auth_fields = array('auth_post');
break;
case AUTH_REPLY:
$a_sql = 'a.auth_reply';
$auth_fields = array('auth_reply');
break;
case AUTH_EDIT:
$a_sql = 'a.auth_edit';
$auth_fields = array('auth_edit');
break;
case AUTH_DELETE:
$a_sql = 'a.auth_delete';
$auth_fields = array('auth_delete');
break;
case AUTH_ANNOUNCE:
$a_sql = 'a.auth_announce';
$auth_fields = array('auth_announce');
break;
case AUTH_STICKY:
$a_sql = 'a.auth_sticky';
$auth_fields = array('auth_sticky');
break;
case AUTH_POLLCREATE:
$a_sql = 'a.auth_pollcreate';
$auth_fields = array('auth_pollcreate');
break;
case AUTH_VOTE:
$a_sql = 'a.auth_vote';
$auth_fields = array('auth_vote');
break;
case AUTH_ATTACH:
break;
case AUTH_SELLPOST:
$a_sql = 'a.auth_sellpost';
$auth_fields = array('auth_sellpost');
break;
case AUTH_HIDE4REPLY:
$a_sql = 'a.auth_hide4reply';
$auth_fields = array('auth_hide4reply');
break;
case AUTH_HIDE4POSTS:
$a_sql = 'a.auth_hide4posts';
$auth_fields = array('auth_hide4posts');
break;
case AUTH_HIDE4FORTUNE:
$a_sql = 'a.auth_hide4fortune';
$auth_fields = array('auth_hide4fortune');
break;
default:
break;
// If f_access has been passed, or auth is needed to return an array of forums
// then we need to pull the auth information on the given forum (or all forums)
if ( empty($f_access) )
$forum_match_sql = ( $forum_id != AUTH_LIST_ALL ) ? "WHERE a.forum_id = $forum_id" : '';
$sql = "SELECT a.forum_id, $a_sql
FROM " . FORUMS_TABLE . " a
$forum_match_sql";
message_die(GENERAL_ERROR, 'Failed obtaining forum access control lists', '', __LINE__, __FILE__, $sql);
$sql_fetchrow = ( $forum_id != AUTH_LIST_ALL ) ? 'sql_fetchrow' : 'sql_fetchrowset';
if ( !($f_access = $db->$sql_fetchrow($result)) )
$db->sql_freeresult($result);
return array();
// If the user isn't logged on then all we need do is check if the forum
// has the type set to ALL, if yes they are good to go, if not then they
// are denied access
$u_access = array();
$forum_match_sql = ( $forum_id != AUTH_LIST_ALL ) ? "AND a.forum_id = $forum_id" : '';
$sql = "SELECT a.forum_id, $a_sql, a.auth_mod
FROM " . AUTH_ACCESS_TABLE . " a, " . USER_GROUP_TABLE . " ug
WHERE ug.user_id = ".$userdata['user_id']. "
AND ug.user_pending = 0
AND a.group_id = ug.group_id
$forum_match_sql";
do
if ( $forum_id != AUTH_LIST_ALL)
$u_access[] = $row;
$u_access[$row['forum_id']][] = $row;
while( $row = $db->sql_fetchrow($result) );
$is_admin = ( $userdata['user_level'] == ADMIN && $userdata['session_logged_in'] ) ? TRUE : 0;
$auth_user = array();
for($i = 0; $i < count($auth_fields); $i++)
$key = $auth_fields[$i];
// If the user is logged on and the forum type is either ALL or REG then the user has access
// If the type if ACL, MOD or ADMIN then we need to see if the user has specific permissions
// to do whatever it is they want to do ... to do this we pull relevant information for the
// user (and any groups they belong to)
// Now we compare the users access level against the forums. We assume here that a moderator
// and admin automatically have access to an ACL forum, similarly we assume admins meet an
// auth requirement of MOD
if ( $forum_id != AUTH_LIST_ALL )
$value = $f_access[$key];
switch( $value )
case AUTH_ALL:
$auth_user[$key] = TRUE;
$auth_user[$key . '_type'] = $lang['Auth_Anonymous_Users'];
break;
case AUTH_REG:
$auth_user[$key] = ( $userdata['session_logged_in'] ) ? TRUE : 0;
$auth_user[$key . '_type'] = $lang['Auth_Registered_Users'];
break;
case AUTH_ACL:
$auth_user[$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_ACL, $key, $u_access, $is_admin) : 0;
$auth_user[$key . '_type'] = $lang['Auth_Users_granted_access'];
break;
case AUTH_MOD:
$auth_user[$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access, $is_admin) : 0;
$auth_user[$key . '_type'] = $lang['Auth_Moderators'];
break;
case AUTH_ADMIN:
$auth_user[$key] = $is_admin;
$auth_user[$key . '_type'] = $lang['Auth_Administrators'];
break;
default:
$auth_user[$key] = 0;
break;
for($k = 0; $k < count($f_access); $k++)
$value = $f_access[$k][$key];
$f_forum_id = $f_access[$k]['forum_id'];
switch( $value )
case AUTH_ALL:
$auth_user[$f_forum_id][$key] = TRUE;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Anonymous_Users'];
break;
case AUTH_REG:
$auth_user[$f_forum_id][$key] = ( $userdata['session_logged_in'] ) ? TRUE : 0;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Registered_Users'];
break;
case AUTH_ACL:
$auth_user[$f_forum_id][$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_ACL, $key, $u_access[$f_forum_id], $is_admin) : 0;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Users_granted_access'];
break;
case AUTH_MOD:
$auth_user[$f_forum_id][$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access[$f_forum_id], $is_admin) : 0;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Moderators'];
break;
case AUTH_ADMIN:
$auth_user[$f_forum_id][$key] = $is_admin;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Administrators'];
break;
default:
$auth_user[$f_forum_id][$key] = 0;
break;
// Is user a moderator?
$auth_user['auth_mod'] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access, $is_admin) : 0;
$auth_user[$f_forum_id]['auth_mod'] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access[$f_forum_id], $is_admin) : 0;
return $auth_user;
function auth_check_user($type, $key, $u_access, $is_admin)
$auth_user = 0;
if ( count($u_access) )
for($j = 0; $j < count($u_access); $j++)
$result = 0;
switch($type)
case AUTH_ACL:
$result = $u_access[$j][$key];
case AUTH_MOD:
$result = $result || $u_access[$j]['auth_mod'];
case AUTH_ADMIN:
$result = $result || $is_admin;
break;
$auth_user = $auth_user || $result;
$auth_user = $is_admin;
return $auth_user;
