<?php
* page_header.php
* email : support@phpbb.com
* $Id: page_header.php,v 1.106.2.23 2004/07/11 16:46:19 acydburn Exp $
if ( !defined('IN_PHPBB') )
die("Hacking attempt");
define('HEADER_INC', TRUE);
// gzip_compression
$do_gzip_compress = FALSE;
if ( $board_config['gzip_compress'] )
$phpver = phpversion();
$useragent = (isset($_SERVER["HTTP_USER_AGENT"]) ) ? $_SERVER["HTTP_USER_AGENT"] : $HTTP_USER_AGENT;
if ( $phpver >= '4.0.4pl1' && ( strstr($useragent,'compatible') || strstr($useragent,'Gecko') ) )
if ( extension_loaded('zlib') )
ob_start('ob_gzhandler');
else if ( $phpver > '4.0' )
if ( strstr($HTTP_SERVER_VARS['HTTP_ACCEPT_ENCODING'], 'gzip') )
$do_gzip_compress = TRUE;
ob_start();
ob_implicit_flush(0);
header('Content-Encoding: gzip');
// Parse and show the overall header.
'overall_header' => ( empty($gen_simple_header) ) ? 'overall_header.tpl' : 'simple_header.tpl')
// Generate logged in/logged out status
$u_login_logout = 'login.'.$phpEx.'?logout=true&sid=' . $userdata['session_id'];
$l_login_logout = $lang['Logout'] . ' [ ' . $userdata['username'] . ' ]';
$u_login_logout = 'login.'.$phpEx;
$l_login_logout = $lang['Login'];
$s_last_visit = ( $userdata['session_logged_in'] ) ? create_date($board_config['default_dateformat'], $userdata['user_lastvisit'], $board_config['board_timezone']) : '';
// Get basic (usernames + totals) online
// situation
$logged_visible_online = 0;
$logged_hidden_online = 0;
$guests_online = 0;
$online_userlist = '';
$l_online_users = '';
if (defined('SHOW_ONLINE'))
$user_forum_sql = ( !empty($forum_id) ) ? "AND s.session_page = " . intval($forum_id) : '';
$sql = "SELECT u.username, u.user_id, u.user_allow_viewonline, u.user_level, s.session_logged_in, s.session_ip
FROM ".USERS_TABLE." u, ".SESSIONS_TABLE." s
WHERE u.user_id = s.session_user_id
AND s.session_time >= ".( time() - 300 ) . "
$user_forum_sql
ORDER BY u.username ASC, s.session_ip ASC";
message_die(GENERAL_ERROR, 'Could not obtain user/online information', '', __LINE__, __FILE__, $sql);
$userlist_ary = array();
$userlist_visible = array();
$prev_user_id = 0;
$prev_user_ip = $prev_session_ip = '';
// User is logged in and therefor not a guest
if ( $row['session_logged_in'] )
// Skip multiple sessions for one user
if ( $row['user_id'] != $prev_user_id )
$style_color = '';
if ( $row['user_level'] == ADMIN )
$row['username'] = '<b>' . $row['username'] . '</b>';
$style_color = 'style="color:#' . $theme['fontcolor3'] . '"';
else if ( $row['user_level'] == MOD )
$style_color = 'style="color:#' . $theme['fontcolor2'] . '"';
if ( $row['user_allow_viewonline'] )
$user_online_link = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '"' . $style_color .'>' . $row['username'] . '</a>';
$logged_visible_online++;
$user_online_link = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '"' . $style_color .'><i>' . $row['username'] . '</i></a>';
$logged_hidden_online++;
if ( $row['user_allow_viewonline'] || $userdata['user_level'] == ADMIN )
$online_userlist .= ( $online_userlist != '' ) ? ', ' . $user_online_link : $user_online_link;
$prev_user_id = $row['user_id'];
if ( $row['session_ip'] != $prev_session_ip )
$guests_online++;
$prev_session_ip = $row['session_ip'];
$db->sql_freeresult($result);
if ( empty($online_userlist) )
$online_userlist = $lang['None'];
$online_userlist = ( ( isset($forum_id) ) ? $lang['Browsing_forum'] : $lang['Registered_users'] ) . ' ' . $online_userlist;
$total_online_users = $logged_visible_online + $logged_hidden_online + $guests_online;
if ( $total_online_users > $board_config['record_online_users'])
$board_config['record_online_users'] = $total_online_users;
$board_config['record_online_date'] = time();
$sql = "UPDATE " . CONFIG_TABLE . "
SET config_value = '$total_online_users'
WHERE config_name = 'record_online_users'";
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, 'Could not update online user record (nr of users)', '', __LINE__, __FILE__, $sql);
SET config_value = '" . $board_config['record_online_date'] . "'
WHERE config_name = 'record_online_date'";
message_die(GENERAL_ERROR, 'Could not update online user record (date)', '', __LINE__, __FILE__, $sql);\r
if ( $total_online_users == 0 )
$l_t_user_s = $lang['Online_users_zero_total'];
else if ( $total_online_users == 1 )
$l_t_user_s = $lang['Online_user_total'];
$l_t_user_s = $lang['Online_users_total'];
if ( $logged_visible_online == 0 )
$l_r_user_s = $lang['Reg_users_zero_total'];
else if ( $logged_visible_online == 1 )
$l_r_user_s = $lang['Reg_user_total'];
$l_r_user_s = $lang['Reg_users_total'];
if ( $logged_hidden_online == 0 )
$l_h_user_s = $lang['Hidden_users_zero_total'];
else if ( $logged_hidden_online == 1 )
$l_h_user_s = $lang['Hidden_user_total'];
$l_h_user_s = $lang['Hidden_users_total'];
if ( $guests_online == 0 )
$l_g_user_s = $lang['Guest_users_zero_total'];
else if ( $guests_online == 1 )
$l_g_user_s = $lang['Guest_user_total'];
$l_g_user_s = $lang['Guest_users_total'];
$l_online_users = sprintf($l_t_user_s, $total_online_users);
$l_online_users .= sprintf($l_r_user_s, $logged_visible_online);
$l_online_users .= sprintf($l_h_user_s, $logged_hidden_online);
$l_online_users .= sprintf($l_g_user_s, $guests_online);
// Obtain number of new private messages
// if user is logged in
if ( ($userdata['session_logged_in']) && (empty($gen_simple_header)) )
// Start add - Birthday MOD
// see if user has or have had birthday, also see if greeting are enabled
if ( $userdata['user_birthday']!=999999 && $board_config['birthday_greeting'] && create_date('Ymd', time(), $board_config['board_timezone']) >= $userdata['user_next_birthday_greeting'].realdate ('md',$userdata['user_birthday'] ) )
SET user_next_birthday_greeting = " . (create_date('Y', time(), $board_config['board_timezone'])+1) . "
WHERE user_id = " . $userdata['user_id'];
if( !$status = $db->sql_query($sql) )
message_die(GENERAL_ERROR, "Could not update next_birthday_greeting for user.", "", __LINE__, __FILE__, $sql);
$template->assign_var("GREETING_POPUP",
"<script language="Javascript" type="text/javascript"><!--
window.open('".append_sid('birthday_popup.'.$phpEx)."', '_phpbbprivmsg', 'HEIGHT=225,resizable=yes,WIDTH=400');
</script>");
} //Sorry user shall not have a greeting this year
// End add - Birthday MOD
if ( $userdata['user_new_privmsg'] )
$l_message_new = ( $userdata['user_new_privmsg'] == 1 ) ? $lang['New_pm'] : $lang['New_pms'];
$l_privmsgs_text = sprintf($l_message_new, $userdata['user_new_privmsg']);
if ( $userdata['user_last_privmsg'] > $userdata['user_lastvisit'] )
SET user_last_privmsg = " . $userdata['user_lastvisit'] . "
message_die(GENERAL_ERROR, 'Could not update private message new/read time for user', '', __LINE__, __FILE__, $sql);
$s_privmsg_new = 1;
$icon_pm = $images['pm_new_msg'];
$s_privmsg_new = 0;
$l_privmsgs_text = $lang['No_new_pm'];
$s_privmsg_new = 0;
$icon_pm = $images['pm_no_new_msg'];
if ( $userdata['user_unread_privmsg'] )
$l_message_unread = ( $userdata['user_unread_privmsg'] == 1 ) ? $lang['Unread_pm'] : $lang['Unread_pms'];
$l_privmsgs_text_unread = sprintf($l_message_unread, $userdata['user_unread_privmsg']);
$l_privmsgs_text_unread = $lang['No_unread_pm'];
// Force Read Announcement MOD
$sql = "SELECT `forum_id`,`topic_id`
FROM `" . $table_prefix . "topics`
WHERE `forum_id` = 1
ORDER BY `topic_id` DESC";
$result = mysql_query($sql);
$line = mysql_num_rows($result);
$row = mysql_fetch_array($result);
if( $userdata['user_read_announcement'] != $line)
$template->assign_block_vars("force_read_announcement", array());
$template->assign_vars(array("U_FORCE_READ_ANNOUNCEMENT" => append_sid("force_read_announcement.$phpEx?line=" . $line . "&topic=" . $row['topic_id'])));
$l_privmsgs_text = $lang['Login_check_pm'];
$l_privmsgs_text_unread = '';
$s_privmsg_new = 0;
// Generate HTML required for Mozilla Navigation bar
if (!isset($nav_links))
$nav_links = array();
$nav_links_html = '';
$nav_link_proto = '<link rel="%s" href="%s" title="%s" />' . "
while( list($nav_item, $nav_array) = @each($nav_links) )
if ( !empty($nav_array['url']) )
$nav_links_html .= sprintf($nav_link_proto, $nav_item, append_sid($nav_array['url']), $nav_array['title']);
// We have a nested array, used for items like <link rel='chapter'> that can occur more than once.
while( list(,$nested_array) = each($nav_array) )
$nav_links_html .= sprintf($nav_link_proto, $nav_item, $nested_array['url'], $nested_array['title']);
// Format Timezone. We are unable to use array_pop here, because of PHP3 compatibility
$l_timezone = explode('.', $board_config['board_timezone']);
$l_timezone = (count($l_timezone) > 1 && $l_timezone[count($l_timezone)-1] != 0) ? $lang[sprintf('%.1f', $board_config['board_timezone'])] : $lang[number_format($board_config['board_timezone'])];
// The following assigns all _common_ variables that may be used at any point
// in a template.
'SITENAME' => $board_config['sitename'],
'SITE_DESCRIPTION' => $board_config['site_desc'],
'PAGE_TITLE' => $page_title,
'LAST_VISIT_DATE' => sprintf($lang['You_last_visit'], $s_last_visit),
'CURRENT_TIME' => sprintf($lang['Current_time'], create_date($board_config['default_dateformat'], time(), $board_config['board_timezone'])),
'TOTAL_USERS_ONLINE' => $l_online_users,
'LOGGED_IN_USER_LIST' => $online_userlist,
'RECORD_USERS' => sprintf($lang['Record_online_users'], $board_config['record_online_users'], create_date($board_config['default_dateformat'], $board_config['record_online_date'], $board_config['board_timezone'])),
'PRIVATE_MESSAGE_INFO' => $l_privmsgs_text,
'PRIVATE_MESSAGE_INFO_UNREAD' => $l_privmsgs_text_unread,
'PRIVATE_MESSAGE_NEW_FLAG' => $s_privmsg_new,
'PRIVMSG_IMG' => $icon_pm,
'L_USERNAME' => $lang['Username'],
'L_PASSWORD' => $lang['Password'],
'L_LOGIN_LOGOUT' => $l_login_logout,
'L_LOGIN' => $lang['Login'],
'L_LOG_ME_IN' => $lang['Log_me_in'],
'L_AUTO_LOGIN' => $lang['Log_me_in'],
'L_INDEX' => sprintf($lang['Forum_Index'], $board_config['sitename']),
'L_REGISTER' => $lang['Register'],
'L_PROFILE' => $lang['Profile'],
'L_SEARCH' => $lang['Search'],
'L_PRIVATEMSGS' => $lang['Private_Messages'],
'L_WHO_IS_ONLINE' => $lang['Who_is_Online'],
'L_MEMBERLIST' => $lang['Memberlist'],
'L_FAQ' => $lang['FAQ'],
'L_USERGROUPS' => $lang['Usergroups'],
'L_SEARCH_NEW' => $lang['Search_new'],
'L_SEARCH_UNANSWERED' => $lang['Search_unanswered'],
'L_SEARCH_SELF' => $lang['Search_your_posts'],
'L_WHOSONLINE_ADMIN' => sprintf($lang['Admin_online_color'], '<span style="color:#' . $theme['fontcolor3'] . '">', '</span>'),
'L_WHOSONLINE_MOD' => sprintf($lang['Mod_online_color'], '<span style="color:#' . $theme['fontcolor2'] . '">', '</span>'),
//-- start mod : Resize Posted Images Based on Max Width ----------------------------------
'L_RMW_IMAGE_TITLE' => $lang['rmw_image_title'],
'U_RMW_JSLIB' => $phpbb_root_path . 'templates/rmw_jslib.js',
//-- fin mod : Resize Posted Images Based on Max Width ------------------------------------
'U_SEARCH_UNANSWERED' => append_sid('search.'.$phpEx.'?search_id=unanswered'),
'U_SEARCH_SELF' => append_sid('search.'.$phpEx.'?search_id=egosearch'),
'U_SEARCH_NEW' => append_sid('search.'.$phpEx.'?search_id=newposts'),
'U_INDEX' => append_sid('index.'.$phpEx),
'U_REGISTER' => append_sid('profile.'.$phpEx.'?mode=register'),
'U_PROFILE' => append_sid('profile.'.$phpEx.'?mode=editprofile'),
'U_PRIVATEMSGS' => append_sid('privmsg.'.$phpEx.'?folder=inbox'),
'U_PRIVATEMSGS_POPUP' => append_sid('privmsg.'.$phpEx.'?mode=newpm'),
'U_SEARCH' => append_sid('search.'.$phpEx),
'U_MEMBERLIST' => append_sid('memberlist.'.$phpEx),
'U_MODCP' => append_sid('modcp.'.$phpEx),
'U_FAQ' => append_sid('faq.'.$phpEx),
'U_VIEWONLINE' => append_sid('viewonline.'.$phpEx),
'U_LOGIN_LOGOUT' => append_sid($u_login_logout),
'U_GROUP_CP' => append_sid('groupcp.'.$phpEx),
'S_CONTENT_DIRECTION' => $lang['DIRECTION'],
'S_CONTENT_ENCODING' => $lang['ENCODING'],
'S_CONTENT_DIR_LEFT' => $lang['LEFT'],
'S_CONTENT_DIR_RIGHT' => $lang['RIGHT'],
'S_TIMEZONE' => sprintf($lang['All_times'], $l_timezone),
'S_LOGIN_ACTION' => append_sid('login.'.$phpEx),
'T_HEAD_STYLESHEET' => $theme['head_stylesheet'],
'T_BODY_BACKGROUND' => $theme['body_background'],
'T_BODY_BGCOLOR' => '#'.$theme['body_bgcolor'],
'T_BODY_TEXT' => '#'.$theme['body_text'],
'T_BODY_LINK' => '#'.$theme['body_link'],
'T_BODY_VLINK' => '#'.$theme['body_vlink'],
'T_BODY_ALINK' => '#'.$theme['body_alink'],
'T_BODY_HLINK' => '#'.$theme['body_hlink'],
'T_TR_COLOR1' => '#'.$theme['tr_color1'],
'T_TR_COLOR2' => '#'.$theme['tr_color2'],
'T_TR_COLOR3' => '#'.$theme['tr_color3'],
'T_TR_CLASS1' => $theme['tr_class1'],
'T_TR_CLASS2' => $theme['tr_class2'],
'T_TR_CLASS3' => $theme['tr_class3'],
'T_TH_COLOR1' => '#'.$theme['th_color1'],
'T_TH_COLOR2' => '#'.$theme['th_color2'],
'T_TH_COLOR3' => '#'.$theme['th_color3'],
'T_TH_CLASS1' => $theme['th_class1'],
'T_TH_CLASS2' => $theme['th_class2'],
'T_TH_CLASS3' => $theme['th_class3'],
'T_TD_COLOR1' => '#'.$theme['td_color1'],
'T_TD_COLOR2' => '#'.$theme['td_color2'],
'T_TD_COLOR3' => '#'.$theme['td_color3'],
'T_TD_CLASS1' => $theme['td_class1'],
'T_TD_CLASS2' => $theme['td_class2'],
'T_TD_CLASS3' => $theme['td_class3'],
'T_FONTFACE1' => $theme['fontface1'],
'T_FONTFACE2' => $theme['fontface2'],
'T_FONTFACE3' => $theme['fontface3'],
'T_FONTSIZE1' => $theme['fontsize1'],
'T_FONTSIZE2' => $theme['fontsize2'],
'T_FONTSIZE3' => $theme['fontsize3'],
'T_FONTCOLOR1' => '#'.$theme['fontcolor1'],
'T_FONTCOLOR2' => '#'.$theme['fontcolor2'],
'T_FONTCOLOR3' => '#'.$theme['fontcolor3'],
'T_SPAN_CLASS1' => $theme['span_class1'],
'T_SPAN_CLASS2' => $theme['span_class2'],
'T_SPAN_CLASS3' => $theme['span_class3'],
'NAV_LINKS' => $nav_links_html)
// Login box?
$template->assign_block_vars('switch_user_logged_out', array());
$template->assign_block_vars('switch_user_logged_in', array());
if ( !empty($userdata['user_popup_pm']) )
$template->assign_block_vars('switch_enable_pm_popup', array());
// Add no-cache control for cookies if they are set
//$c_no_cache = (isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid']) || isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_data'])) ? 'no-cache="set-cookie", ' : '';
// Work around for "current" Apache 2 + PHP module which seems to not
// cope with private cache control setting
if (!empty($_SERVER['SERVER_SOFTWARE']) && strstr($_SERVER['SERVER_SOFTWARE'], 'Apache/2'))
header ('Cache-Control: no-cache, pre-check=0, post-check=0');
else\r
header ('Cache-Control: private, pre-check=0, post-check=0, max-age=0');
header ('Expires: 0');
header ('Pragma: no-cache');
$template->pparse('overall_header');
