[解決] 沒辦法新增版面>"< (已解決)
babycity
文章: 153
註冊時間: 2004-04-28 11:46
文章 babycity »
新增新的版面時,就會跑出下面的訊息 :cry: 但我不知道是裝哪個mod出的問題,還有辦法救嗎>"<
一般錯誤
Couldn't insert row in forums table
SQL Error : 1136 Column count doesn't match value count at row 1
INSERT INTO phpbb_forums (forum_id, forum_name, cat_id, forum_desc, forum_order, forum_status, forum_rule, prune_enable, forum_topictypes, auth_view, auth_read, auth_post, auth_reply, auth_edit, auth_delete, auth_sticky, auth_announce, auth_vote, auth_pollcreate) VALUES ('23', '1111', 1, '111, ''', 50, 0, 0,'[等你改],[]', 0, 0, 0, 0, 1, 1, 3, 3, 1, 1)
Line : 399
File : /home/babycity/public_html/phpbb/admin/admin_forums.php
這是394~424行
// There is no problem having duplicate forum names so we won't check for it.
$sql = "INSERT INTO " . FORUMS_TABLE . " (forum_id, forum_name, cat_id, forum_desc, forum_order, forum_status, forum_rule, prune_enable, forum_topictypes" . $field_sql . ")
VALUES ('" . $next_id . "', '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', " . intval($HTTP_POST_VARS[POST_CAT_URL]) . ", '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . ", '" . str_replace("\'", "''", $HTTP_POST_VARS['forumrule']) . "'', $next_order, " . intval($HTTP_POST_VARS['forumstatus']) . ", " . intval($HTTP_POST_VARS['prune_enable']) . ",'".str_replace("\'", "''", $HTTP_POST_VARS['topictypes'])."'".$value_sql . ")";
message_die(GENERAL_ERROR, "Couldn't insert row in forums table", "", __LINE__, __FILE__, $sql);
if( $HTTP_POST_VARS['prune_enable'] )
if( $HTTP_POST_VARS['prune_days'] == "" || $HTTP_POST_VARS['prune_freq'] == "")
message_die(GENERAL_MESSAGE, $lang['Set_prune_data']);
$sql = "INSERT INTO " . PRUNE_TABLE . " (forum_id, prune_days, prune_freq)
VALUES('" . $next_id . "', " . intval($HTTP_POST_VARS['prune_days']) . ", " . intval($HTTP_POST_VARS['prune_freq']) . ")";
message_die(GENERAL_ERROR, "Couldn't insert row in prune table", "", __LINE__, __FILE__, $sql);
$message = $lang['Forums_updated'] . "<br /><br />" . sprintf($lang['Click_return_forumadmin'], "<a href=\"" . append_sid("admin_forums.$phpEx") . "\">", "</a>") . "<br /><br />" . sprintf($lang['Click_return_admin_index'], "<a href=\"" . append_sid("index.$phpEx?pane=right") . "\">", "</a>");
break;
case 'modforum':
最後由 babycity 於 2005-02-15 15:37 編輯,總共編輯了 1 次。
Re: [問題] 沒辦法新增版面>"<
babycity 寫:新增新的版面時,就會跑出下面的訊息 :cry: 但我不知道是裝哪個mod出的問題,還有辦法救嗎>"<
一般錯誤
Line : 399
這是394~424行
$message = $lang['Forums_updated'] . "<br /><br />" . sprintf($lang['Click_return_forumadmin'], "<a href="" . append_sid("admin_forums.$phpEx") . "">", "</a>") . "<br /><br />" . sprintf($lang['Click_return_admin_index'], "<a href="" . append_sid("index.$phpEx?pane=right") . "">", "</a>");
break;
case 'modforum':
我猜想是您安裝外掛( forum_rule) 時, 在插入 VALUE 的位置有誤!
以下的修改, 提供您參考:
-----[find]-----
-----[replace]-----
VALUES ('" . $next_id . "', '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', " . intval($HTTP_POST_VARS[POST_CAT_URL]) . ", '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', $next_order, " . intval($HTTP_POST_VARS['forumstatus']) . ", '" . str_replace("\'", "''", $HTTP_POST_VARS['forumrule']) . "', " . intval($HTTP_POST_VARS['prune_enable']) . ",'".str_replace("\'", "''", $HTTP_POST_VARS['topictypes'])."'".$value_sql . ")";
babycity
文章: 153
[問題] ...
文章 babycity »
我有試過了替換,還是不行捏>"<我在試看看,謝謝,我知道是哪個外掛了^^
最後由 babycity 於 2005-02-15 12:36 編輯,總共編輯了 1 次。
baboo
文章: 79
註冊時間: 2004-02-11 10:23
文章 baboo »
是不是這裡少了一個 ","?
, forum_topictypes, " . $field_sql . ")
好像不是.... :oops:
啊.. 應該是這裡:
多了一個 '
還有這裡:
少了一個 '
$HTTP_POST_VARS['forumdesc']) . "', '" . str_replace
babycity
文章: 153
[問題] 11
文章 babycity »
謝謝你們^^
已經修好了>"<
原來是這個外掛我之前有裝,forums.php剪剪貼貼有貼錯位子,後來沒理他,想說不裝了,才會這樣
